拆开了,是6911。以前用6691_Toshiba 43nm D2可以量产成功,但是会变成16G.....于是便用MyDiskTest修复用了一段时间。
但是现在无论我怎么搞,量产时候都会提示 Error 28了。请教各位高手,谢谢了。
Starting Time: 01:29:27
Device 1:0xB3
MP Version:2.162
INI_File_Name:
Random delay 0 msec
--- Download MP ISP ---
CE-0, Flash ID=98-D7-94-32-76-54-0D-00
CE-1, Flash ID=98-D7-94-32-76-54-0D-00
CE-2, Flash ID=98-D7-94-32-76-54-0D-00
CE-3, Flash ID=98-D7-94-32-76-54-0D-00
Found BACKUP Table (000000BB-0001)
Defect Table (00000200-0004)
Original Bad Block - 0:0x0000
Original Bad Block - 0:0x003E
Original Bad Block - 0:0x0051
Original Bad Block - 0:0x0250
Original Bad Block - 0:0x02E6
Original Bad Block - 0:0x0405
Original Bad Block - 0:0x0466
Original Bad Block - 0:0x0473
Original Bad Block - 0:0x04D7
Original Bad Block - 0:0x0525
Original Bad Block - 0:0x05DD
Original Bad Block - 0:0x0699
Original Bad Block - 0:0x06CF
Original Bad Block - 0:0x06F1
Original Bad Block - 0:0x0791
Original Bad Block - 0:0x07A1
Original Bad Block - 0:0x0824
Original Bad Block - 0:0x0855
Original Bad Block - 0:0x09F3
Original Bad Block - 0:0x0B63
Original Bad Block - 0:0x0B7D
Original Bad Block - 0:0x0C9E
Original Bad Block - 0:0x0D0B
Original Bad Block - 0:0x0D9D
Original Bad Block - 0:0x0DBD
Original Bad Block - 0:0x0DE1
Original Bad Block - 0:0x0E71
Original Bad Block - 0:0x0E7D
Original Bad Block - 0:0x0E9D
Original Bad Block - 0:0x0F01
Original Bad Block - 0:0x0FC0
Original Bad Block - 0:0x1031
Original Bad Block - 0:0x1033
Original Bad Block - 1:0x0000
Original Bad Block - 1:0x008F
Original Bad Block - 1:0x013C
Original Bad Block - 1:0x013D
Original Bad Block - 1:0x0346
Original Bad Block - 1:0x06AD
Original Bad Block - 1:0x081A
Original Bad Block - 1:0x081C
Original Bad Block - 1:0x081D
Original Bad Block - 1:0x081E
Original Bad Block - 1:0x081F
Original Bad Block - 1:0x0820
Original Bad Block - 1:0x0821
Original Bad Block - 1:0x0822
Original Bad Block - 1:0x0823
Original Bad Block - 1:0x0828
Original Bad Block - 1:0x0829
Original Bad Block - 1:0x082A
Original Bad Block - 1:0x082B
Original Bad Block - 1:0x082E
Original Bad Block - 1:0x0832
Original Bad Block - 1:0x0833
Original Bad Block - 1:0x0834
Original Bad Block - 1:0x0835
Original Bad Block - 1:0x0836
Original Bad Block - 1:0x0837
Original Bad Block - 1:0x0838
Original Bad Block - 1:0x0839
Original Bad Block - 1:0x083A
Original Bad Block - 1:0x083B
Original Bad Block - 1:0x083E
Original Bad Block - 1:0x083F
Original Bad Block - 1:0x0840
Original Bad Block - 1:0x0841
Original Bad Block - 1:0x0842
Original Bad Block - 1:0x0843
Original Bad Block - 1:0x0846
Original Bad Block - 1:0x0847
Original Bad Block - 1:0x084A
Original Bad Block - 1:0x084B
Original Bad Block - 1:0x084C
Original Bad Block - 1:0x084D
Original Bad Block - 1:0x084E
Original Bad Block - 1:0x084F
Original Bad Block - 1:0x0867
Original Bad Block - 1:0x09A0
Original Bad Block - 1:0x09FF
Original Bad Block - 1:0x0AF4
Original Bad Block - 1:0x0D53
Original Bad Block - 1:0x0E0A
Original Bad Block - 1:0x0E35
Original Bad Block - 1:0x0EF0
Original Bad Block - 1:0x1031
Original Bad Block - 1:0x1032
Original Bad Block - 1:0x1033
Original Bad Block - 2:0x0000
Original Bad Block - 2:0x0002
Original Bad Block - 2:0x0003
Original Bad Block - 2:0x0004
Original Bad Block - 2:0x0005
Original Bad Block - 2:0x0006
Original Bad Block - 2:0x0007
Original Bad Block - 2:0x0008
Original Bad Block - 2:0x0009
Original Bad Block - 2:0x000A
Original Bad Block - 2:0x000B
Original Bad Block - 2:0x000C
Original Bad Block - 2:0x000D
Original Bad Block - 2:0x0010
Original Bad Block - 2:0x0011
Original Bad Block - 2:0x0014
Original Bad Block - 2:0x0016
Original Bad Block - 2:0x0017
Original Bad Block - 2:0x0018
Original Bad Block - 2:0x0019
Original Bad Block - 2:0x001C
Original Bad Block - 2:0x001D
Original Bad Block - 2:0x001E
Original Bad Block - 2:0x001F
Original Bad Block - 2:0x0020
Original Bad Block - 2:0x0021
Original Bad Block - 2:0x0022
Original Bad Block - 2:0x0023
Original Bad Block - 2:0x0024
Original Bad Block - 2:0x0025
Original Bad Block - 2:0x0026
Original Bad Block - 2:0x0027
Original Bad Block - 2:0x002A
Original Bad Block - 2:0x002B
Original Bad Block - 2:0x002C
Original Bad Block - 2:0x002D
Original Bad Block - 2:0x0032
Original Bad Block - 2:0x0033
Original Bad Block - 2:0x0036
Original Bad Block - 2:0x0037
Original Bad Block - 2:0x003A
Original Bad Block - 2:0x003B
Original Bad Block - 2:0x003C
Original Bad Block - 2:0x003D
Original Bad Block - 2:0x003E
Original Bad Block - 2:0x003F
Original Bad Block - 2:0x0040
Original Bad Block - 2:0x0041
Original Bad Block - 2:0x0044
Original Bad Block - 2:0x0045
Original Bad Block - 2:0x0051
Original Bad Block - 2:0x00D3
Original Bad Block - 2:0x0405
Original Bad Block - 2:0x0408
Original Bad Block - 2:0x040A
Original Bad Block - 2:0x040C
Original Bad Block - 2:0x040E
Original Bad Block - 2:0x0473
Original Bad Block - 2:0x04B4
Original Bad Block - 2:0x04B6
Original Bad Block - 2:0x04BF
Original Bad Block - 2:0x04D7
Original Bad Block - 2:0x04ED
Original Bad Block - 2:0x0525
Original Bad Block - 2:0x0580
Original Bad Block - 2:0x0582
Original Bad Block - 2:0x05BC
Original Bad Block - 2:0x05BE
Original Bad Block - 2:0x05DD
Original Bad Block - 2:0x05DE
Original Bad Block - 2:0x0659
Original Bad Block - 2:0x065B
Original Bad Block - 2:0x0699
Original Bad Block - 2:0x069D
Original Bad Block - 2:0x069F
Original Bad Block - 2:0x06CF
Original Bad Block - 2:0x06F1
Original Bad Block - 2:0x0721
Original Bad Block - 2:0x0723
Original Bad Block - 2:0x0791
Original Bad Block - 2:0x07A1
Original Bad Block - 2:0x0832
Original Bad Block - 2:0x0834
Original Bad Block - 2:0x0835
Original Bad Block - 2:0x0836
Original Bad Block - 2:0x0837
Original Bad Block - 2:0x083E
Original Bad Block - 2:0x083F
Original Bad Block - 2:0x0842
Original Bad Block - 2:0x0843
Original Bad Block - 2:0x0846
Original Bad Block - 2:0x084E
Original Bad Block - 2:0x084F
Original Bad Block - 2:0x0855
Original Bad Block - 2:0x0889
Original Bad Block - 2:0x088B
Original Bad Block - 2:0x09F3
Original Bad Block - 2:0x0B63
Original Bad Block - 2:0x0B7D
Original Bad Block - 2:0x0D0B
Original Bad Block - 2:0x0D1F
Original Bad Block - 2:0x0D9D
Original Bad Block - 2:0x0DBD
Original Bad Block - 2:0x0DDB
Original Bad Block - 2:0x0DE1
Original Bad Block - 2:0x0E71
Original Bad Block - 2:0x0E7D
Original Bad Block - 2:0x0E9D
Original Bad Block - 2:0x0F01
Original Bad Block - 2:0x0F83
Original Bad Block - 2:0x1031
Original Bad Block - 2:0x1033
Original Bad Block - 3:0x0000
Original Bad Block - 3:0x0099
Original Bad Block - 3:0x009D
Original Bad Block - 3:0x0263
Original Bad Block - 3:0x031A
Original Bad Block - 3:0x05BD
Original Bad Block - 3:0x06E2
Original Bad Block - 3:0x0774
Original Bad Block - 3:0x0776
Original Bad Block - 3:0x07A6
Original Bad Block - 3:0x07BD
Original Bad Block - 3:0x0808
Original Bad Block - 3:0x080A
Original Bad Block - 3:0x0810
Original Bad Block - 3:0x0820
Original Bad Block - 3:0x0828
Original Bad Block - 3:0x082A
Original Bad Block - 3:0x0834
Original Bad Block - 3:0x0836
Original Bad Block - 3:0x085C
Original Bad Block - 3:0x085E
Original Bad Block - 3:0x0911
Original Bad Block - 3:0x0913
Original Bad Block - 3:0x09E1
Original Bad Block - 3:0x09FD
Original Bad Block - 3:0x09FF
Original Bad Block - 3:0x0A29
Original Bad Block - 3:0x0A2B
Original Bad Block - 3:0x0A34
Original Bad Block - 3:0x0A36
Original Bad Block - 3:0x0ACC
Original Bad Block - 3:0x0AD1
Original Bad Block - 3:0x0C7F
Original Bad Block - 3:0x0DC8
Original Bad Block - 3:0x0DCA
Original Bad Block - 3:0x1031
Original Bad Block - 3:0x1032
Original Bad Block - 3:0x1033
Defect Table shows 16354 Good blocks, 238 Bad blocks
SafeErase (0,4148)
Erase failed Block - 0:0:0x0000
Erase failed Block - 0:0:0x003E
Erase failed Block - 0:0:0x0051
Erase failed Block - 0:0:0x0250
Erase failed Block - 0:0:0x02E6
Erase failed Block - 0:0:0x0405
Erase failed Block - 0:0:0x0466
Erase failed Block - 0:0:0x0473
Erase failed Block - 0:0:0x04D7
Erase failed Block - 0:0:0x0525
Erase failed Block - 0:0:0x05DD
Erase failed Block - 0:0:0x0699
Erase failed Block - 0:0:0x06CF
Erase failed Block - 0:0:0x06F1
Erase failed Block - 0:0:0x0791
Erase failed Block - 0:0:0x07A1
Erase failed Block - 0:0:0x0824
Erase failed Block - 0:0:0x0855
Erase failed Block - 0:0:0x09F3
Erase failed Block - 0:0:0x0B63
Erase failed Block - 0:0:0x0B7D
Erase failed Block - 0:0:0x0C9E
Erase failed Block - 0:0:0x0D0B
Erase failed Block - 0:0:0x0D9D
Erase failed Block - 0:0:0x0DBD
Erase failed Block - 0:0:0x0DE1
Erase failed Block - 0:0:0x0E71
Erase failed Block - 0:0:0x0E7D
Erase failed Block - 0:0:0x0E9D
Erase failed Block - 0:0:0x0F01
Erase failed Block - 0:0:0x0FC0
Erase failed Block - 0:0:0x1031
Erase failed Block - 0:0:0x1033
---> Max Bad of Plane (4,13)
SafeErase (1,4148)
Erase failed Block - 1:0:0x0000
Erase failed Block - 1:0:0x008F
Erase failed Block - 1:0:0x013C
Erase failed Block - 1:0:0x013D
Erase failed Block - 1:0:0x0346
Erase failed Block - 1:0:0x06AD
Erase failed Block - 1:0:0x081A
Erase failed Block - 1:0:0x081C
Erase failed Block - 1:0:0x081D
Erase failed Block - 1:0:0x081E
Erase failed Block - 1:0:0x081F
Erase failed Block - 1:0:0x0820
Erase failed Block - 1:0:0x0821
Erase failed Block - 1:0:0x0822
Erase failed Block - 1:0:0x0823
Erase failed Block - 1:0:0x0828
Erase failed Block - 1:0:0x0829
Erase failed Block - 1:0:0x082A
Erase failed Block - 1:0:0x082B
Erase failed Block - 1:0:0x082E
Erase failed Block - 1:0:0x0832
Erase failed Block - 1:0:0x0833
Erase failed Block - 1:0:0x0834
Erase failed Block - 1:0:0x0835
Erase failed Block - 1:0:0x0836
Erase failed Block - 1:0:0x0837
Erase failed Block - 1:0:0x0838
Erase failed Block - 1:0:0x0839
Erase failed Block - 1:0:0x083A
Erase failed Block - 1:0:0x083B
Erase failed Block - 1:0:0x083E
Erase failed Block - 1:0:0x083F
Erase failed Block - 1:0:0x0840
Erase failed Block - 1:0:0x0841
Erase failed Block - 1:0:0x0842
Erase failed Block - 1:0:0x0843
Erase failed Block - 1:0:0x0846
Erase failed Block - 1:0:0x0847
Erase failed Block - 1:0:0x084A
Erase failed Block - 1:0:0x084B
Erase failed Block - 1:0:0x084C
Erase failed Block - 1:0:0x084D
Erase failed Block - 1:0:0x084E
Erase failed Block - 1:0:0x084F
Erase failed Block - 1:0:0x0867
Erase failed Block - 1:0:0x09A0
Erase failed Block - 1:0:0x09FF
Erase failed Block - 1:0:0x0AF4
Erase failed Block - 1:0:0x0D53
Erase failed Block - 1:0:0x0E0A
Erase failed Block - 1:0:0x0E35
Erase failed Block - 1:0:0x0EF0
Erase failed Block - 1:0:0x1031
Erase failed Block - 1:0:0x1032
Erase failed Block - 1:0:0x1033
---> Max Bad of Plane (14,14)
SafeErase (2,4148)
Erase failed Block - 2:0:0x0000
Erase failed Block - 2:0:0x0002
Erase failed Block - 2:0:0x0003
Erase failed Block - 2:0:0x0004
Erase failed Block - 2:0:0x0005
Erase failed Block - 2:0:0x0006
Erase failed Block - 2:0:0x0007
Erase failed Block - 2:0:0x0008
Erase failed Block - 2:0:0x0009
Erase failed Block - 2:0:0x000A
Erase failed Block - 2:0:0x000B
Erase failed Block - 2:0:0x000C
Erase failed Block - 2:0:0x000D
Erase failed Block - 2:0:0x0010
Erase failed Block - 2:0:0x0011
Erase failed Block - 2:0:0x0014
Erase failed Block - 2:0:0x0016
Erase failed Block - 2:0:0x0017
Erase failed Block - 2:0:0x0018
Erase failed Block - 2:0:0x0019
Erase failed Block - 2:0:0x001C
Erase failed Block - 2:0:0x001D
Erase failed Block - 2:0:0x001E
Erase failed Block - 2:0:0x001F
Erase failed Block - 2:0:0x0020
Erase failed Block - 2:0:0x0021
Erase failed Block - 2:0:0x0022
Erase failed Block - 2:0:0x0023
Erase failed Block - 2:0:0x0024
Erase failed Block - 2:0:0x0025
Erase failed Block - 2:0:0x0026
Erase failed Block - 2:0:0x0027
Erase failed Block - 2:0:0x002A
Erase failed Block - 2:0:0x002B
Erase failed Block - 2:0:0x002C
Erase failed Block - 2:0:0x002D
Erase failed Block - 2:0:0x0032
Erase failed Block - 2:0:0x0033
Erase failed Block - 2:0:0x0036
Erase failed Block - 2:0:0x0037
Erase failed Block - 2:0:0x003A
Erase failed Block - 2:0:0x003B
Erase failed Block - 2:0:0x003C
Erase failed Block - 2:0:0x003D
Erase failed Block - 2:0:0x003E
Erase failed Block - 2:0:0x003F
Erase failed Block - 2:0:0x0040
Erase failed Block - 2:0:0x0041
Erase failed Block - 2:0:0x0044
Erase failed Block - 2:0:0x0045
Erase failed Block - 2:0:0x0051
Erase failed Block - 2:0:0x00D3
Erase failed Block - 2:0:0x0405
Erase failed Block - 2:0:0x0408
Erase failed Block - 2:0:0x040A
Erase failed Block - 2:0:0x040C
Erase failed Block - 2:0:0x040E
Erase failed Block - 2:0:0x0473
Erase failed Block - 2:0:0x04B4
Erase failed Block - 2:0:0x04B6
Erase failed Block - 2:0:0x04BF
Erase failed Block - 2:0:0x04D7
Erase failed Block - 2:0:0x04ED
Erase failed Block - 2:0:0x0525
Erase failed Block - 2:0:0x0580
Erase failed Block - 2:0:0x0582
Erase failed Block - 2:0:0x05BC
Erase failed Block - 2:0:0x05BE
Erase failed Block - 2:0:0x05DD
Erase failed Block - 2:0:0x05DE
Erase failed Block - 2:0:0x0659
Erase failed Block - 2:0:0x065B
Erase failed Block - 2:0:0x0699
Erase failed Block - 2:0:0x069D
Erase failed Block - 2:0:0x069F
Erase failed Block - 2:0:0x06CF
Erase failed Block - 2:0:0x06F1
Erase failed Block - 2:0:0x0721
Erase failed Block - 2:0:0x0723
Erase failed Block - 2:0:0x0791
Erase failed Block - 2:0:0x07A1
Erase failed Block - 2:0:0x0832
Erase failed Block - 2:0:0x0834
Erase failed Block - 2:0:0x0835
Erase failed Block - 2:0:0x0836
Erase failed Block - 2:0:0x0837
Erase failed Block - 2:0:0x083E
Erase failed Block - 2:0:0x083F
Erase failed Block - 2:0:0x0842
Erase failed Block - 2:0:0x0843
Erase failed Block - 2:0:0x0846
Erase failed Block - 2:0:0x084E
Erase failed Block - 2:0:0x084F
Erase failed Block - 2:0:0x0855
Erase failed Block - 2:0:0x0889
Erase failed Block - 2:0:0x088B
Erase failed Block - 2:0:0x09F3
Erase failed Block - 2:0:0x0B63
Erase failed Block - 2:0:0x0B7D
Erase failed Block - 2:0:0x0D0B
Erase failed Block - 2:0:0x0D1F
Erase failed Block - 2:0:0x0D9D
Erase failed Block - 2:0:0x0DBD
Erase failed Block - 2:0:0x0DDB
Erase failed Block - 2:0:0x0DE1
Erase failed Block - 2:0:0x0E71
Erase failed Block - 2:0:0x0E7D
Erase failed Block - 2:0:0x0E9D
Erase failed Block - 2:0:0x0F01
Erase failed Block - 2:0:0x0F83
Erase failed Block - 2:0:0x1031
Erase failed Block - 2:0:0x1033
---> Max Bad of Plane (22,34)
SafeErase (3,4148)
Erase failed Block - 3:0:0x0000
Erase failed Block - 3:0:0x0099
Erase failed Block - 3:0:0x009D
Erase failed Block - 3:0:0x0263
Erase failed Block - 3:0:0x031A
Erase failed Block - 3:0:0x05BD
Erase failed Block - 3:0:0x06E2
Erase failed Block - 3:0:0x0774
Erase failed Block - 3:0:0x0776
Erase failed Block - 3:0:0x07A6
Erase failed Block - 3:0:0x07BD
Erase failed Block - 3:0:0x0808
Erase failed Block - 3:0:0x080A
Erase failed Block - 3:0:0x0810
Erase failed Block - 3:0:0x0820
Erase failed Block - 3:0:0x0828
Erase failed Block - 3:0:0x082A
Erase failed Block - 3:0:0x0834
Erase failed Block - 3:0:0x0836
Erase failed Block - 3:0:0x085C
Erase failed Block - 3:0:0x085E
Erase failed Block - 3:0:0x0911
Erase failed Block - 3:0:0x0913
Erase failed Block - 3:0:0x09E1
Erase failed Block - 3:0:0x09FD
Erase failed Block - 3:0:0x09FF
Erase failed Block - 3:0:0x0A29
Erase failed Block - 3:0:0x0A2B
Erase failed Block - 3:0:0x0A34
Erase failed Block - 3:0:0x0A36
Erase failed Block - 3:0:0x0ACC
Erase failed Block - 3:0:0x0AD1
Erase failed Block - 3:0:0x0C7F
Erase failed Block - 3:0:0x0DC8
Erase failed Block - 3:0:0x0DCA
Erase failed Block - 3:0:0x1031
Erase failed Block - 3:0:0x1032
Erase failed Block - 3:0:0x1033
---> Max Bad of Plane (11,8)
---> Max BAD/DIE = 34
Total good blocks after SCAN: 16354 / 16592, Bad block=238
==> 2-Plane mode
Adjust Max LBA = 32729088, 31981504
MaxWindows=8/1952, MaxLBA=31981504, Size=15615 MB
Max BAD of one plane is 34 (37),16592,1,4
RootSector=0x3D5B,Sec/Cluster=32, SuperPage=32 ---> Alignment=5
Boot Block=0x0001,0x0002
Lun0(31981504), Lun1(0), Public=31981504, Secure=0, CDROM=0
Special FE Config = 54-0B-00
Defect Table Block=0x0004
--- Download ISP Code:C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\桌面\U\16G\ISP_CODE\6691_B3-A_20100331_VA10F00_9083.BIN---
--- ISP Code installed.
Public,Secure,CDROM = 31981504,0,0
SN=20CF30864FC2F24022CF1502
=== Preformat Done ===
Low Level Format DONE
Store INI/ERROR MSG to Block-0x0001:79.
LBATest 10M activate
Total=0,CDROM=0, PublicArea=-128, SecureArea=0
Create SECURE(CDROM=0,Public=2097151 MB,Secure=0 MB)
Write LBA(0x00000000,128) Fail !
### Err: SECURE failed(41).
Ending Time: 01:30:39
