(0x7A): Vendor command flow fail after download ISP Code
<< Super Block count detail information >>
1 Super block = 4 * physical block
Total block Count = 548
Pretest calculated minimum required block Count = 494
Initial bad block Count = 6
Available good block Count = 542
Remaining spare block Count = 48
<< Total Bad Block numbers for each Channel and CE >>
CH0 CH1 CH2 CH3 (All-Plane)
CE0 015 015 015 005
CE1 --- --- --- ---
CE2 --- --- --- ---
CE3 --- --- --- ---
CE4 --- --- --- ---
CE5 --- --- --- ---
CE6 --- --- --- ---
CE7 --- --- --- ---
CH0 CH1 CH2 CH3 (Plane-0)
CE0 006 006 006 001
CE1 --- --- --- ---
CE2 --- --- --- ---
CE3 --- --- --- ---
CE4 --- --- --- ---
CE5 --- --- --- ---
CE6 --- --- --- ---
CE7 --- --- --- ---
CH0 CH1 CH2 CH3 (Plane-1)
CE0 004 004 004 001
CE1 --- --- --- ---
CE2 --- --- --- ---
CE3 --- --- --- ---
CE4 --- --- --- ---
CE5 --- --- --- ---
CE6 --- --- --- ---
CE7 --- --- --- ---
CH0 CH1 CH2 CH3 (Plane-2)
CE0 002 002 002 001
CE1 --- --- --- ---
CE2 --- --- --- ---
CE3 --- --- --- ---
CE4 --- --- --- ---
CE5 --- --- --- ---
CE6 --- --- --- ---
CE7 --- --- --- ---
CH0 CH1 CH2 CH3 (Plane-3)
CE0 003 003 003 002
CE1 --- --- --- ---
CE2 --- --- --- ---
CE3 --- --- --- ---
CE4 --- --- --- ---
CE5 --- --- --- ---
CE6 --- --- --- ---
CE7 --- --- --- ---
--- System block index ---
1st-Info [00] : CH0, CE0, Die0, P0, Blk0
2nd-Info [01] : CH1, CE0, Die0, P0, Blk0
3rd-Info [02] : CH2, CE0, Die0, P0, Blk0
4th-Info [03] : CH3, CE0, Die0, P0, Blk0
1st-ISP [04] : CH0, CE0, Die0, P1, Blk0
2nd-ISP [05] : CH1, CE0, Die0, P1, Blk0
3rd-ISP [06] : CH2, CE0, Die0, P1, Blk0
4th-ISP [07] : CH3, CE0, Die0, P1, Blk0
Index [08] : CH0, CE0, Die0, P2, Blk0
BadInfo [09] : CH1, CE0, Die0, P2, Blk0
MPInfo [0A] : CH2, CE0, Die0, P2, Blk0
Log [0B] : CH3, CE0, Die0, P2, Blk0
