我的是金士顿 8G 红色旋转
芯片 6692
H2-U6C
J5P01-840B
1126
FL64G08UCHI-05
S1121-2122742
产量时出现Error8
Device 1:0xB5
MP Version:2.182
INI_File_Name:6692_HY26_256P_8KB.INI
Random delay 0 msec
--- Download MP ISP ---
Auto CE: 0x00 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF
CE-0, Flash ID=AD-DE-94-D2-04-43-AD-DE
Page/Block=256
Searching SORTING BOARD table ...
--> Not Found
Found BACKUP Table (0000063A-0006)
Defect Table (00001000-0010)
Original Bad Block - 0:0x0002
Erase failed Block - 0:0:0x0820
Erase failed Block - 0:0:0x0821
---> Max Bad of Plane (15,16)
---> Max BAD/DIE = 16
Total good blocks after SCAN: 4035 / 4096, Bad block=61
==> 2-Plane mode
Max. Bad Block Allowed = 174(61)
Adjust Max LBA = 15646720, 15646656
MaxWindows=2/1910, MaxLBA=15646656, Size=7639 MB
Max BAD of one plane is 16 (43),4096,1,1
RootSector=0xF4B,Sec/Cluster=64, SuperPage=64 ---> Alignment=53
Boot Block=0x0006,0x000C
Lun0(15646656), Lun1(0), Public=15646656, Secure=0, CDROM=0
Special FE Config = 54-0B-00
Defect Table Block=0x0010
--- Download ISP Code:C:\DOCUMENTS AND SETTINGS\KIM\桌面\6692_HY26_MP_V2182\ISP_CODE\6692_B5-IM_20110422_VB88200_B3EF.BIN---
--- ISP Code installed.
Public,Secure,CDROM = 15646656,0,0
PHY: E2/E4/E6=72h/36h/04h, D0/C0/CFG10=DFh/0Bh/87h
SN=20041230339EFC218D1D2030
=== Preformat Done ===
Low Level Format DONE
Store INI/ERROR MSG to Block-0x0006:78.
### Error: Device capacity is 0 bytes
Ending Time: 10:53:24
请高手解决,最好能留下qq,远程帮助我。
