设备描述: [D:]USB Mass Storage Device(GENERIC USB Mass Storage)
设备类型: 大容量存储设备
协议版本: USB 2.00
当前速度: 高速(HighSpeed)
电力消耗: 100mA
USB设备ID: VID = 0C76 PID = 0005
设备供应商: GENERIC
设备名称: USB Mass Storage
设备修订版: 0100
产品制造商: GENERIC
产品型号: USB Mass Storage
产品修订版: 1.00
主控厂商: SSS(鑫创)
主控型号: TC58NC6621/SSS6692-B5
闪存识别码: 2C68044A - Micron(美光) MT29F32G08CBACA - 1CE/单通道 [MLC-4K] -> 总容量 = 4GB
在线资料:
http://dl.mydigit.net/special/up/sss.html可能的闪存型号
[1CE]MT29F32G08CBACA(25nm) x 1片/通道 x 1通道
闪存识别码映射表
[通道 0] [通道 1]
2C68044AA900 --------
Starting Time: 06:54:38
Device 1:0xB5
MP Version:2.182
INI_File_Name:6692_IM25_256P_4KB.INI
Random delay 0 msec
--- Download MP ISP ---
Auto CE: 0x00 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF
CE-0, Flash ID=2C-68-04-4A-A9-00-00-00
Page/Block=256
Searching SORTING BOARD table ...
--> Not Found
Scan (0,4096)
Original Defect Block - 0:0:0x0002
Original Defect Block - 0:0:0x0004
Original Defect Block - 0:0:0x0006
Original Defect Block - 0:0:0x0008
Original Defect Block - 0:0:0x000A
Original Defect Block - 0:0:0x000C
Original Defect Block - 0:0:0x000D
Original Defect Block - 0:0:0x000E
Original Defect Block - 0:0:0x000F
Original Defect Block - 0:0:0x0010
Original Defect Block - 0:0:0x0011
Original Defect Block - 0:0:0x0012
Original Defect Block - 0:0:0x0013
Original Defect Block - 0:0:0x0014
Original Defect Block - 0:0:0x0015
Original Defect Block - 0:0:0x0016
Original Defect Block - 0:0:0x0017
Original Defect Block - 0:0:0x0018
Original Defect Block - 0:0:0x0019
Original Defect Block - 0:0:0x001A
Original Defect Block - 0:0:0x001B
Original Defect Block - 0:0:0x001C
Original Defect Block - 0:0:0x001D
Original Defect Block - 0:0:0x001E
Original Defect Block - 0:0:0x001F
Original Defect Block - 0:0:0x0020
Original Defect Block - 0:0:0x0021
Original Defect Block - 0:0:0x0022
Original Defect Block - 0:0:0x0023
Original Defect Block - 0:0:0x0024
Original Defect Block - 0:0:0x0025
Original Defect Block - 0:0:0x0026
Original Defect Block - 0:0:0x0027
Original Defect Block - 0:0:0x0028
Original Defect Block - 0:0:0x0029
Original Defect Block - 0:0:0x002A
Original Defect Block - 0:0:0x002B
Original Defect Block - 0:0:0x002C
Original Defect Block - 0:0:0x002D
Original Defect Block - 0:0:0x002E
Original Defect Block - 0:0:0x002F
Original Defect Block - 0:0:0x0030
Original Defect Block - 0:0:0x0031
Original Defect Block - 0:0:0x0032
Original Defect Block - 0:0:0x0033
Original Defect Block - 0:0:0x0034
Original Defect Block - 0:0:0x0035
Original Defect Block - 0:0:0x0036
Original Defect Block - 0:0:0x0037
Original Defect Block - 0:0:0x0038
Original Defect Block - 0:0:0x0039
Original Defect Block - 0:0:0x003A
Original Defect Block - 0:0:0x003B
Original Defect Block - 0:0:0x003C
Original Defect Block - 0:0:0x003D
Original Defect Block - 0:0:0x003E
Original Defect Block - 0:0:0x003F
Original Defect Block - 0:0:0x0040
Original Defect Block - 0:0:0x0041
Original Defect Block - 0:0:0x0042
Original Defect Block - 0:0:0x0043
Original Defect Block - 0:0:0x0044
Original Defect Block - 0:0:0x0045
Original Defect Block - 0:0:0x0046
Original Defect Block - 0:0:0x0047
Original Defect Block - 0:0:0x0048
Original Defect Block - 0:0:0x0049
Original Defect Block - 0:0:0x004A
Original Defect Block - 0:0:0x004B
Original Defect Block - 0:0:0x004C
Original Defect Block - 0:0:0x004D
Original Defect Block - 0:0:0x004E
Original Defect Block - 0:0:0x004F
Original Defect Block - 0:0:0x0050
Original Defect Block - 0:0:0x0051
Original Defect Block - 0:0:0x0052
Original Defect Block - 0:0:0x0053
Original Defect Block - 0:0:0x0054
Original Defect Block - 0:0:0x0055
Original Defect Block - 0:0:0x0056
Original Defect Block - 0:0:0x0057
Original Defect Block - 0:0:0x0058
Original Defect Block - 0:0:0x0059
Original Defect Block - 0:0:0x005A
Original Defect Block - 0:0:0x005B
Original Defect Block - 0:0:0x005C
Original Defect Block - 0:0:0x005D
Original Defect Block - 0:0:0x00F7
Original Defect Block - 0:0:0x0808
Original Defect Block - 0:0:0x080C
Original Defect Block - 0:0:0x080D
Original Defect Block - 0:0:0x0812
Original Defect Block - 0:0:0x0813
Original Defect Block - 0:0:0x0818
Original Defect Block - 0:0:0x0819
Original Defect Block - 0:0:0x081E
Original Defect Block - 0:0:0x081F
Original Defect Block - 0:0:0x0824
Original Defect Block - 0:0:0x0825
Original Defect Block - 0:0:0x082A
Original Defect Block - 0:0:0x082B
Original Defect Block - 0:0:0x0830
Original Defect Block - 0:0:0x0831
Original Defect Block - 0:0:0x0836
Original Defect Block - 0:0:0x0837
Original Defect Block - 0:0:0x0E29
Original Defect Block - 0:0:0x0E64
Original Defect Block - 0:0:0x0E65
Original Defect Block - 0:0:0x0F9F
---> Max Bad of Plane (28,27)
---> Max BAD/DIE = 28
Total good blocks after SCAN: 3987 / 4096, Bad block=109
==> 2-Plane mode
Max. Bad Block Allowed = 174(109)
Adjust Max LBA = 7823360, 7823296
MaxWindows=2/1910, MaxLBA=7823296, Size=3819 MB
Max BAD of one plane is 28 (43),4096,1,1
RootSector=0xEEB,Sec/Cluster=32, SuperPage=32 ---> Alignment=21
Boot Block=0x005E,0x0060
Lun0(7627204), Lun1(196092), Public=7627204, Secure=0, CDROM=196092
Special FE Config = 56-0B-00
Defect Table Block=0x0064
--- Download ISP Code:C:\DOCUMENTS AND SETTINGS\OWNER\桌面\20140530_062422864\3S6692_MP_VER2182\ISP_CODE\6692_B5-IM_20110217_VBB0300_5DA8.BIN---
--- ISP Code installed.
Public,Secure,CDROM = 7627204,0,196092
PHY: E2/E4/E6=72h/36h/04h, D0/C0/CFG10=DFh/0Bh/87h
SN=BC96802D63E2FE51E4332031
=== Preformat Done ===
Low Level Format DONE
Store INI/ERROR MSG to Block-0x005E:78.
### Error: Device capacity is 0 bytes
Ending Time: 06:54:44
