  • 2094阅读
  • 0回复
[电脑]请大神看看这HG522C是什么情况? [复制链接]
离线hcl521hb
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2014-12-08
一个HG522C全部启动完就一个电源灯亮,用终端软件读出来是这样的,有大神知道是个什么情况?谢谢
v0.06 PLL w ln p08 zi
Solos 461x PP boot v1.5
SDRAM size = 0x2000000
Processor clock speed 264.0MHz
FLASH Chip ID: 207e
@@@@@@@@@@@@@Disable watchdog.
cd
Solos 461x Network boot v1.19 (00000000)  (FLASH)
MAC 00:22:33:44:55:66
SDRAM 0x02000000 bytes
Phy reset line on GPIO 4
192.168.1.1
(Hold '*' during reset for prompt)
Check multicast upgrade packets
Boot from Ethernet Port
v0.06 PLL w ln p08 zipacket, boot normally!
FLASH Chip ID: 207e
--- Check Tag CRC success,System Type: DUAL.
Start up info: .
ulFsOffset: e0000ulFsLen: 3444736  ulFsOffset: 917504
Finding flashfs partition...done.
PPB: image.a_magic = 0xea000006
PPB: image.a_text = 0x000012a0
PPB: image.a_data = 0x000b6950
PPB: image.a_bss = 0x0016e6dc
PPB: image.a_syms = 0x00000000
PPB: image.a_entry = 0x00030020
PPB: image.a_trsize = 0x00000000
PPB: image.a_drsize = 0x00000000
Image 'image' is a Linux kernel
Trying to load initrd...none found
Calling Configure_NVS_FromFile.
Flash size is 0x01000000. sdram size = 0x02000000.
LZMA 4.05
init started:  BusyBox v1.00 (2009.06.12-02:49+0000) multi-call binary
RCS DONE
Loading Conexant BSP...
BASE MAC ADDRESS 00:22:33:44:55:66
Starting Conexant drivers
. msc16 loaded
.starting task turbo_WhipTask
DSL MSC16 imem 4096, dmem 2048
DSL MSC16 version 1.3
.msc16_load_file returned 0
sram_buffer : 0xffa01d60 addr : 0x70001d60
Passing command buffer 70001d60 to MSC16
Conexant drivers started
Loading Wireless ...
Load CX50321 Reading True PDA ...
Creating Delt char device
Loading drivers and kernel modules...
insmod: cannot insert `/lib/kernel/fs/nls/nls_cp936.ko': Invalid module format (-1): Unknown error 8
insmod: cannot insert `/lib/kernel/fs/nls/nls_cp950.ko': Invalid module format (-1): Unknown error 8
131
mc: '/lib/libpthread.so.0' is not an ELF file
mc: can't load library 'libpthread.so.0'
console: '/lib/libpthread.so.0' is not an ELF file
console: can't load library 'libpthread.so.0'
Done
