  • 2047阅读
  • 4回复
[相机]求 卡西欧EX-S10维修 固件恢复程序 [复制链接]
离线blackghr
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2014-12-15
此悬赏帖已过期
最佳答案:100 M币,热心助人剩余点数: 2 M币。
求 卡西欧EX-S10维修固件恢复程序
现在情况是开机,粉色全屏,更新固件没反应,系统初始化提示成功,刷固件还是没反应
TEST MODE
              Note: Never perform the menu items unlessotherwise instructed. Doing so may cause destruction of the data inside, whichwill make the camera unusable.
To boot the test mode
1.  While firmlypressing down both [BS] and [UPPER], turn the power on.
+ + K X 11 0 0 + +
Ve r 1 . 0 0
2.  After theversion appears, press buttons in the order of [DOWN], [DOWN], [BS] and [MENU]in 0.5 second. The diagnostic menu appears.
PROGRAM VERSION UPGRADING
1.  To update thefirmware version
1.    Prepare the memory card which contains thefirmware for EX-S10 in the root directory.
        EX-S10.bin
2.    Insert the above memory card into the camera,and set a fully charged battery in the camera.
3.    Press the [power] button while holding [MENU]depressed. Keep holding [MENU] depressed until “ROGRAM UPDATE” appears in thedisplay.
PROGRAM UPDATE
YES
NO
      NEWVERSION IS
      VER  1.00
The followingappears.
The version ofthe firmware in the memory card appears at the bottom of the display.
NOTE 1) When a wrong software is mistakenly used,
the message below appears.Update the firmware again with the correct software.
  FILE ERROR!
(As ofJanuary 2008)
NOTE 2)
When only the version appears in the display
even though you are tryingto operate the camera, charge the battery to the fullest and try again. Thelevel of the battery indicator should be highest in order to update thefirmware.
4.    Align the white cursor to [YES] by [UPPER] and[DOWN], and then press [SET ].
“NOW LOADING”appears in the display and the update starts.
5.    “COMPLETE” appears after the update finishes.
6.    Remove the memory card after turning the poweroff once. Turn the power back on again while holding [ MENU] depressed, andcheck the version.
“VER.1.00”appears.
  VER  1.00(As of January 2008)
7.    If the version is correct, turn the power off.
8.    Finally, check the operation by recording,playing back and deleting an image.
2.  How to restorethe firmware
1.    Prepare the firmware restoration program.
        uranus.bin
NOTE: Thissoftware and procedure automatically restores the firmware even if the firmwarebelongs to a wrong model code. Make sure to use the correct software for thecorrect model.
2.    Copy the above file to the root directory in thememory card.
3.    Insert the memory card into the camera.
4.    Set a fully charged battery in the camera.
NOTE: Thissoftware and procedure automatically restores the firmware even if the batterycapacity of the camera is low. Make sure to use a fully charged battery toprevent the danger of power down during firmware restoration.
5.    Turn the power on while pressing the [shutter]button.
               If the power does not turn on only by pressingthe power button, insert the battery while holding the [ shutter] buttondepressed.
The LED next tothe [DATA] button changes from “green”, “red” to “green”.
                            NOTE: This software and procedureautomatically restores the firmware even if the firmware belongs to a wrongmodel code. Make sure to use the correct software for the correct mode.
6.    When the LED becomes “green steady”, thefirmware restoration is finished.
        Remove the battery and the memory card, andthen turn the power off.
7.    Turn the power on again while holding [BS] and[UPPER] depressed.
        Check the model name and the program version(PR:) in the opening screen of the test menu.
        ++KX1100++
        Ver 1.00
8.    If the model name and the program version arecorrect, perform SYSTEM INITIAL to initialize the system area.
                “[BS] + [UPPER] + PW ON” g “[DOWN], [DOWN], [BS], [MENU]” g “3:ROM UPDATE”g “5:SYSTEM INITIAL”
NOTE:After SYSTEM INITIAL is performed, “SYSTEM ERROR” appears when the power isturned on again.
9.    Write the latest firmware. (Refer to page  6)
               After the firmware is written, check the modelname and the program version (PR:) in the opening screen of the test menu.
10.  Finally, startthe camera normally to check the operation by recording, playing back anddeleting an image. Check also that the colors in the images are not too brightor two dark.
3.  To install thefirmware
Initially, firmware is notinstalled in the PCB supplied by the parts center.
Install the firmware intothe PCB after replacing with a new one as shown in the procedures below.
Note:The camera does not operate (only LED becomes “green blinking”) if the firmwareis not installed in the PCB.
< Writingthe restoration program  1>
1.    Copy the following software to the root directlyof the SD card.
        Restoration software: uranus.bin
        Firmware:    EX-S10.bin
2.    Insert the SD card into the camera.
3.    Insert the battery while holding the [shutter]button depressed.
        The LED next to the DATA button changes from“green”, “red” to “green”.
4.    When the LED becomes “green steady”, remove thebattery and turn the power off.
< SystemInitialize >
1.  Boot the testmode.
2.  Press [DOWN]twice and then press [BS], [MENU ].
3.  Select “3: ROMUPDATE” and then press [SET ].
4.  Select “5:SYSTEM INITIALIZE” and then press [SET ].
5.  When thefollowing message appears, press [SET ].
        SYSTEM INITIALIZE          START....
        PUSH OK KEY?
6.  The systeminitialize is executed. Turn off the power when “SUCCESS” appears.
* “SYSTEM ERROR” appearswhen the camera is turned off without system initialize.
< Writingthe firmware >
1.  Turn the poweron while holding [MENU] depressed.
2.  When “PROGRAMUPDATE” appears, select  “YES” and thenpress [SET ].
3.  “NOW LOADING”appears while the firmware is updated.
4.  When “COMPLETE”appears, the firmware update is complete.
5.  Turn the poweron and off to check if the camera normally functions. If there is no problem,the firmware update is successful.
http://bbs.mydigit.cn/read.php?tid=179223
[ 此帖被blackghr在2014-12-18 06:48重新编辑 ]
离线q8155128
只看该作者 1楼 发表于: 2014-12-15
离线blackghr
只看该作者 2楼 发表于: 2014-12-26
回 q8155128 的帖子
离线q8155128
只看该作者 3楼 发表于: 2014-12-26
回 blackghr 的帖子
热心助人奖励:+1 M币
离线blackghr
只看该作者 4楼 发表于: 2014-12-26
回 q8155128 的帖子
