  • 7220阅读
  • 13回复
[SandForce]jcne1  8贴2281,报错20,兄弟们能告诉下是哪出问题了吗? [复制链接]
离线chtianhu
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2015-01-01
tarting command:[/root/soft/SF_Genesis-v1.7.0.01020130612-RC-fc14-32bit.tar.zip_FILES/SF_Genesis-v1.7.0.01020130612-fc14-32bit/SF_Genesis -PROCESS_SSD 0:0:0:0 "/root/fw/FW_SF-2000_MP_5-0-7_Client--12345600/FW_SF-2000_MP_5-0-7_Client.12345600.mfp" "/root/fw/22249.12345600.driveconfig" 830102 Jie  LOG="/root/fw/830102_localhost.localdomain_DATETIMESTAMP_0.0.0.0_PROCESS_SSD_RESULT.log"   ]...
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Thu 01/01/2015 19:06:02] - SF_Genesis has been invoked with the following parameters:
                      argv[1]: -PROCESS_SSD
                      argv[2]: 0:0:0:0
                      argv[3]: /root/fw/FW_SF-2000_MP_5-0-7_Client--12345600/FW_SF-2000_MP_5-0-7_Client.12345600.mfp
                      argv[4]: /root/fw/22249.12345600.driveconfig
                      argv[5]: 830102
                      argv[6]: Jie
                      argv[7]: LOG=/root/fw/830102_localhost.localdomain_DATETIMESTAMP_0.0.0.0_PROCESS_SSD_RESULT.log
[Thu 01/01/2015 19:06:02] - Instructing the operating system to purge any existing cached data for device: '0:0:0:0'
[Thu 01/01/2015 19:06:07] - Issuing a discovery command for device: '0:0:0:0'
[Thu 01/01/2015 19:06:12] - Discovery command completed...
[Thu 01/01/2015 19:06:12] - Waiting 5 seconds for the system to settle...
[Thu 01/01/2015 19:06:17] - Device designation string '0:0:0:0' is mapped to node '/dev/sg0'
[Thu 01/01/2015 19:06:17] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg0
    MFP Package Filename = /root/fw/FW_SF-2000_MP_5-0-7_Client--12345600/FW_SF-2000_MP_5-0-7_Client.12345600.mfp
      Configuration File = /root/fw/22249.12345600.driveconfig
              Serial No. = 830102
         World Wide Name = Jie
[Thu 01/01/2015 19:06:17] - Successfully received the IDENTIFY data from the drive...
[Thu 01/01/2015 19:06:17] - Validating Manufacturing Firmware Package: /root/fw/FW_SF-2000_MP_5-0-7_Client--12345600/FW_SF-2000_MP_5-0-7_Client.12345600.mfp
[Thu 01/01/2015 19:06:32] - Successfully opened the package: /root/fw/FW_SF-2000_MP_5-0-7_Client--12345600/FW_SF-2000_MP_5-0-7_Client.12345600.mfp
[Thu 01/01/2015 19:06:32] - file  /root/fw/22249.12345600.driveconfig Loaded successfully
[Thu 01/01/2015 19:06:32] - Warning:  Unable to query diagnostics information to perform power management settings check
[Thu 01/01/2015 19:06:32] - B01 Power Management configuration request detected
[Thu 01/01/2015 19:06:32] - Successfully extracted *.DriveConfig file: /root/fw/22249.12345600.driveconfig
[Thu 01/01/2015 19:06:32] - Extracted Config_ID: 1 (22249) in DriveConfig file: /root/fw/22249.12345600.driveconfig
[Thu 01/01/2015 19:06:32] - Extracted SerialOutputControl: 0
[Thu 01/01/2015 19:06:32] - Searching for flashware image for configuration 22249
[Thu 01/01/2015 19:06:32] - Manifest found for configuration 22249
[Thu 01/01/2015 19:06:32] - Flashware image extracted: 22249_fw_cl_slc_Intel_64Gb_PF29F64G16MCNE_2Q_4C_1D_PP_R00804_s512.vic
[Thu 01/01/2015 19:06:32] - Searching for manufacturing image for configuration 22249
[Thu 01/01/2015 19:06:32] - Manufacturing image extracted: 22249_mf_slc_Intel_64Gb_PF29F64G16MCNE_2Q_4C_1D_PP_R00804_s512.vic
[Thu 01/01/2015 19:06:32] - Proceeding in ROM mode, download feature 3...
[Thu 01/01/2015 19:11:24] - FATAL_ERROR: Could not download MFB to the drive...(0x11000001:SF_SG_DEVICE_CHECK_CONDITION_ERROR)
Extended Error data:
          ATA COMMAND : 0x0092  (146)
          ATA FEATURE : 0x0003  (3)
         Device Status: 0x0001  (1)
         Driver Status: 0x0000  (0)
           Host Status: 0x0008  (8)
Sense Data:
  0 -         No Sense: 114 (0x72)    OK
  1 -  Recovered Error:  11 (0x0B)    FAIL
  2 -        Not Ready:   0 (0x00)    OK
  3 -     Medium Error:   0 (0x00)    OK
  4 -   Hardware Error:   0 (0x00)    OK
  5 -  Illegal Request:   0 (0x00)    OK
  6 -   Unit Attention:   0 (0x00)    OK
  7 -     Data Protect:  14 (0x0E)    OK
  8 -      Blank Check:   9 (0x09)    OK
  9 -  Vendor Specific:  12 (0x0C)    OK
10 -     Copy Aborted:   0 (0x00)    OK
11 -  Aborted Command:   0 (0x00)    OK
12 - Equal Comparison:   0 (0x00)    NA
13 -  Volume Overflow:   1 (0x01)    NA
14 -       Miscompare:   0 (0x00)    OK
15 -         Reserved: 224 (0xE0)    NA
System Trace:
[  286.721049] ata1: hard resetting link
[  296.721042] ata1: softreset failed (1st FIS failed)
[  296.721054] ata1: hard resetting link
[  331.722031] ata1: softreset failed (1st FIS failed)
[  331.722045] ata1: limiting SATA link speed to 1.5 Gbps
[  331.722051] ata1: hard resetting link
[  336.923060] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[  336.923070] ata1.00: link online but device misclassifed
[  341.923048] ata1.00: qc timeout (cmd 0xec)
[  341.923063] ata1.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[  341.923069] ata1.00: revalidation failed (errno=-5)
[  341.923079] ata1: hard resetting link
[  351.924030] ata1: softreset failed (1st FIS failed)
[  351.924040] ata1: hard resetting link
[  361.925036] ata1: softreset failed (1st FIS failed)
[  361.925047] ata1: hard resetting link
[  396.926033] ata1: softreset failed (1st FIS failed)
[  396.926046] ata1: hard resetting link
[  402.127071] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[  402.127081] ata1.00: link online but device misclassifed
[  412.127058] ata1.00: qc timeout (cmd 0xec)
[  412.127073] ata1.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[  412.127080] ata1.00: revalidation failed (errno=-5)
[  412.127092] ata1: hard resetting link
[  422.127037] ata1: softreset failed (1st FIS failed)
[  422.127049] ata1: hard resetting link
[  432.127034] ata1: softreset failed (1st FIS failed)
[  432.127045] ata1: hard resetting link
[  467.127032] ata1: softreset failed (1st FIS failed)
[  467.127045] ata1: hard resetting link
[  472.328084] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[  472.328092] ata1.00: link online but device misclassifed
[  502.328055] ata1.00: qc timeout (cmd 0xec)
[  502.328071] ata1.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[  502.328078] ata1.00: revalidation failed (errno=-5)
[  502.328085] ata1.00: disabled
[  502.328110] ata1: exception Emask 0x40 SAct 0x0 SErr 0x800 action 0x6 frozen t4
[  502.328117] ata1: SError: { HostInt }
[  502.328126] ata1: hard resetting link
[  512.329032] ata1: softreset failed (1st FIS failed)
[  512.329044] ata1: hard resetting link
[  522.329032] ata1: softreset failed (1st FIS failed)
[  522.329044] ata1: hard resetting link
[  557.330031] ata1: softreset failed (1st FIS failed)
[  557.330044] ata1: hard resetting link
[  562.531083] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[  562.531091] ata1.00: link online but device misclassifed
[  562.531121] ata1: EH complete
[  562.531136] ata1: exception Emask 0x50 SAct 0x0 SErr 0x800 action 0x6 frozen
[  562.531141] ata1: irq_stat 0x08000000, interface fatal error
[  562.531147] ata1: SError: { HostInt }
[  562.531156] ata1: hard resetting link
[Thu 01/01/2015 19:11:24] - End of Genesis manufacturing log.
[Thu 01/01/2015 19:11:24] - Exiting...
[Thu 01/01/2015 19:11:24] - Overall Result for Device: /dev/sg0 ****** FAIL ******
Process exited with code 20
离线cylnpy
只看该作者 1楼 发表于: 2015-01-01
离线guoke1930
只看该作者 2楼 发表于: 2015-01-01
本帖最近打赏记录:共2条打赏M币+6
离线perter
只看该作者 3楼 发表于: 2015-01-02
本帖最近打赏记录:共1条打赏M币+3
离线y781638432
只看该作者 4楼 发表于: 2015-01-02
本帖最近打赏记录:共1条打赏M币+3
离线chtianhu
只看该作者 5楼 发表于: 2015-01-02
本帖最近打赏记录:共1条打赏M币+3
离线gyfhome
只看该作者 6楼 发表于: 2015-01-03
本帖最近打赏记录:共1条打赏M币+3
只看该作者 7楼 发表于: 2015-01-03
本帖最近打赏记录:共1条打赏M币+3
离线y781638432
只看该作者 8楼 发表于: 2015-01-03
本帖最近打赏记录:共1条打赏M币+3
离线y781638432
只看该作者 9楼 发表于: 2015-01-03
