  • 11649阅读
  • 14回复
[SandForce]OCZ Agility 3 重新开卡失败求助 [复制链接]
离线demiurge3141
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2015-05-02
120G OCZ掉盘了就想从新开卡,但是总是刷不了固件。。。。。
另外这盘的F是大S PF412 AL,我用老固件22214 SF-2281 120GB Micron25 MLC TSOP 16xMT29F64G08CBAAAWP,这个是对的么?
================================================[Sun 05/03/2015 10:23:30] - Instructing the operating system to purge any existing cached data for device: '1:0:0:0'
[Sun 05/03/2015 10:23:35] - Issuing a discovery command for device: '1:0:0:0'
[Sun 05/03/2015 10:23:42] - Discovery command completed...
[Sun 05/03/2015 10:23:42] - Waiting 5 seconds for the system to settle...
[Sun 05/03/2015 10:23:47] - Device designation string '1:0:0:0' is mapped to node '/dev/sg1'
[Sun 05/03/2015 10:23:47] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg1
    MFP Package Filename = /MPT/FW_SF-2000_MP_5-0-7_Client--1234/FW_SF-2000_MP_5-0-7_Client.1234.mfp
      Configuration File = /SOFT/22214.1234.V507.driveconfig
              Serial No. = 11114
         World Wide Name = 11114
[Sun 05/03/2015 10:23:47] - Successfully received the IDENTIFY data from the drive...
[Sun 05/03/2015 10:23:47] - Validating Manufacturing Firmware Package: /MPT/FW_SF-2000_MP_5-0-7_Client--1234/FW_SF-2000_MP_5-0-7_Client.1234.mfp
[Sun 05/03/2015 10:24:04] - Successfully opened the package: /MPT/FW_SF-2000_MP_5-0-7_Client--1234/FW_SF-2000_MP_5-0-7_Client.1234.mfp
[Sun 05/03/2015 10:24:04] - file  /SOFT/22214.1234.V507.driveconfig Loaded successfully
[Sun 05/03/2015 10:24:04] - Warning:  Unable to query diagnostics information to perform power management settings check
[Sun 05/03/2015 10:24:04] - B01 Power Management configuration request detected
[Sun 05/03/2015 10:24:04] - Successfully extracted *.DriveConfig file: /SOFT/22214.1234.V507.driveconfig
[Sun 05/03/2015 10:24:04] - Extracted Config_ID: 1 (22214) in DriveConfig file: /SOFT/22214.1234.V507.driveconfig
[Sun 05/03/2015 10:24:04] - Extracted SerialOutputControl: 0
[Sun 05/03/2015 10:24:04] - Searching for flashware image for configuration 22214
[Sun 05/03/2015 10:24:04] - Manifest found for configuration 22214
[Sun 05/03/2015 10:24:04] - Flashware image extracted: 22214_fw_cl_mlc_Micron_64Gb_MT29F64G08CBAAAWP_2Q_1C_1D_PP_R00751_s512.vic
[Sun 05/03/2015 10:24:04] - Searching for manufacturing image for configuration 22214
[Sun 05/03/2015 10:24:04] - Manufacturing image extracted: 22214_mf_mlc_Micron_64Gb_MT29F64G08CBAAAWP_2Q_1C_1D_PP_R00751_s512.vic
[Sun 05/03/2015 10:24:04] - Proceeding in ROM mode, download feature 3...
[Sun 05/03/2015 10:25:10] - FATAL_ERROR: Could not download MFB to the drive...(0x11000001:SF_SG_DEVICE_CHECK_CONDITION_ERROR)
Extended Error data:
          ATA COMMAND : 0x0092  (146)
          ATA FEATURE : 0x0003  (3)
         Device Status: 0x0001  (1)
         Driver Status: 0x0000  (0)
           Host Status: 0x0008  (8)
Sense Data:
  0 -         No Sense: 114 (0x72)    OK
  1 -  Recovered Error:  11 (0x0B)    FAIL
  2 -        Not Ready:   0 (0x00)    OK
  3 -     Medium Error:   0 (0x00)    OK
  4 -   Hardware Error:   0 (0x00)    OK
  5 -  Illegal Request:   0 (0x00)    OK
  6 -   Unit Attention:   0 (0x00)    OK
  7 -     Data Protect:  14 (0x0E)    OK
  8 -      Blank Check:   9 (0x09)    OK
  9 -  Vendor Specific:  12 (0x0C)    OK
10 -     Copy Aborted:   0 (0x00)    OK
11 -  Aborted Command:   0 (0x00)    OK
12 - Equal Comparison:   0 (0x00)    NA
13 -  Volume Overflow:   1 (0x01)    NA
14 -       Miscompare:   0 (0x00)    OK
15 -         Reserved: 224 (0xE0)    NA
System Trace:
[  545.671762] sd 1:0:0:0: [sdb] Add. Sense: No additional sense information
[  545.671803] ata2.00: disabled
[  550.668381] ata2.00: hard resetting link
[  550.972155] ata2.01: hard resetting link
[  551.977882] ata2.01: failed to resume link (SControl 0)
[  552.128764] ata2.00: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[  552.128779] ata2.01: SATA link down (SStatus 0 SControl 0)
[  552.129051] ata2.00: ATA-8: SandForce{200026BB}, 20DABBR0, max UDMA/133
[  552.129055] ata2.00: 64 sectors, multi 0: LBA48 NCQ (depth 0/32)
[  552.132007] ata2.00: configured for UDMA/133
[  552.132018] ata2: EH complete
[  552.132169] scsi 1:0:0:0: Direct-Access     ATA      SandForce{200026 20DA PQ: 0 ANSI: 5
[  552.136601] sd 1:0:0:0: [sdb] 64 512-byte logical blocks: (32.7 kB/32.0 KiB)
[  552.136605] sd 1:0:0:0: [sdb] 4096-byte physical blocks
[  552.136662] sd 1:0:0:0: [sdb] Write Protect is off
[  552.136666] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[  552.136689] sd 1:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[  552.137519]  sdb:
[  552.137866] sd 1:0:0:0: Attached scsi generic sg1 type 0
[  552.146856]  unknown partition table
[  552.147785] sd 1:0:0:0: [sdb] Attached SCSI disk
[  585.655010] ata2: lost interrupt (Status 0x58)
[  585.655030] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen
[  585.655046] ata2.00: failed command: DOWNLOAD MICROCODE
[  585.655051] ata2.00: cmd 92/03:80:00:00:00/00:00:00:00:00/00 tag 0 pio 65536 out
[  585.655053]          res 40/00:01:e0:4f:c2/00:00:00:00:00/00 Emask 0x4 (timeout)
[  585.655055] ata2.00: status: { DRDY }
[  585.655064] ata2.00: hard resetting link
[  585.959440] ata2.01: hard resetting link
[  586.965128] ata2.01: failed to resume link (SControl 0)
[  592.158485] ata2.00: link is slow to respond, please be patient (ready=0)
[  595.672987] ata2.00: SRST failed (errno=-16)
[  595.672997] ata2.00: hard resetting link
[  595.977600] ata2.01: hard resetting link
[  596.983327] ata2.01: failed to resume link (SControl 0)
[  602.176682] ata2.00: link is slow to respond, please be patient (ready=0)
[  605.691182] ata2.00: SRST failed (errno=-16)
[  605.691193] ata2.00: hard resetting link
[  605.995789] ata2.01: hard resetting link
[  607.001495] ata2.01: failed to resume link (SControl 0)
[  612.194862] ata2.00: link is slow to respond, please be patient (ready=0)
[  640.667450] ata2.00: SRST failed (errno=-16)
[  640.667464] ata2.00: hard resetting link
[  640.972054] ata2.01: hard resetting link
[  641.977759] ata2.01: failed to resume link (SControl 0)
[  645.694015] ata2.00: SRST failed (errno=-16)
[  645.694021] ata2.00: reset failed, giving up
[  645.694024] ata2.00: disabled
[  645.694049] ata2: EH complete
[Sun 05/03/2015 10:25:10] - End of Genesis manufacturing log.
[Sun 05/03/2015 10:25:10] - Exiting...
[ 此帖被demiurge3141在2015-05-03 12:45重新编辑 ]
离线demiurge3141
只看该作者 1楼 发表于: 2015-05-03
离线如影如梦
只看该作者 2楼 发表于: 2015-05-03
离线demiurge3141
只看该作者 3楼 发表于: 2015-05-03
离线afu7310
只看该作者 4楼 发表于: 2015-05-03
离线demiurge3141
只看该作者 5楼 发表于: 2015-05-03
回 afu7310 的帖子
离线demiurge3141
只看该作者 6楼 发表于: 2015-05-04
离线ph3203485
只看该作者 7楼 发表于: 2015-05-04
离线fdn86
只看该作者 8楼 发表于: 2015-05-04
离线demiurge3141
只看该作者 9楼 发表于: 2015-05-04
