  • 9903阅读
  • 12回复
[SandForce]SF2281 开卡失败!! 已经更新了错误码,谁帮忙看看懂错误码 [复制链接]
离线twkblybb1
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2015-07-12
金士顿SF2281 开卡失败!已经改了写保护,重新开卡 这回到79%卡的时间长了一点
但是依然 报错,错误码有点不一样了
大神们再帮忙看看错误代码是什么意思?
Starting command:[/root/soft/genesis/SF_Genesis-v1.7.0.01020130612-fc14-32bit/SF_Genesis -PROCESS_SSD 3:0:0:0 "/root/mpt/FW_PPRO_5_2_2_Release.672199.release.0.mfp" "/root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/27108.0.driveconfig" 12345 12345  LOG="/root/mpt/12345_localhost.localdomain_DATETIMESTAMP_3.0.0.0_PROCESS_SSD_RESULT.log"   ]...
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Mon 07/13/2015 06:03:45] - SF_Genesis has been invoked with the following parameters:
                      argv[1]: -PROCESS_SSD
                      argv[2]: 3:0:0:0
                      argv[3]: /root/mpt/FW_PPRO_5_2_2_Release.672199.release.0.mfp
                      argv[4]: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/27108.0.driveconfig
                      argv[5]: 12345
                      argv[6]: 12345
                      argv[7]: LOG=/root/mpt/12345_localhost.localdomain_DATETIMESTAMP_3.0.0.0_PROCESS_SSD_RESULT.log
[Mon 07/13/2015 06:03:45] - Instructing the operating system to purge any existing cached data for device: '3:0:0:0'
[Mon 07/13/2015 06:03:50] - Issuing a discovery command for device: '3:0:0:0'
[Mon 07/13/2015 06:03:56] - Discovery command completed...
[Mon 07/13/2015 06:03:56] - Waiting 5 seconds for the system to settle...
[Mon 07/13/2015 06:04:01] - Device designation string '3:0:0:0' is mapped to node '/dev/sg2'
[Mon 07/13/2015 06:04:01] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg2
    MFP Package Filename = /root/mpt/FW_PPRO_5_2_2_Release.672199.release.0.mfp
      Configuration File = /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/27108.0.driveconfig
              Serial No. = 12345
         World Wide Name = 12345
[Mon 07/13/2015 06:04:01] - Successfully received the IDENTIFY data from the drive...
[Mon 07/13/2015 06:04:01] - Validating Manufacturing Firmware Package: /root/mpt/FW_PPRO_5_2_2_Release.672199.release.0.mfp
[Mon 07/13/2015 06:04:10] - Successfully opened the package: /root/mpt/FW_PPRO_5_2_2_Release.672199.release.0.mfp
[Mon 07/13/2015 06:04:10] - file  /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/27108.0.driveconfig Loaded successfully
[Mon 07/13/2015 06:04:10] - Warning:  Unable to query diagnostics information to perform power management settings check
[Mon 07/13/2015 06:04:10] - B02 Power Management configuration request detected
[Mon 07/13/2015 06:04:10] - Successfully extracted *.DriveConfig file: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/27108.0.driveconfig
[Mon 07/13/2015 06:04:10] - Extracted Config_ID: 1 (27108) in DriveConfig file: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/27108.0.driveconfig
[Mon 07/13/2015 06:04:10] - Extracted SerialOutputControl: 0
[Mon 07/13/2015 06:04:10] - Searching for flashware image for configuration 27108
[Mon 07/13/2015 06:04:10] - Manifest found for configuration 27108
[Mon 07/13/2015 06:04:10] - Flashware image extracted: 27108_fw_cl_mlc_Toshiba_64Gb_TC58NVG6D2HTA00_2Q_2C_1D_S_PP_R01111_s512.vic
[Mon 07/13/2015 06:04:10] - Searching for manufacturing image for configuration 27108
[Mon 07/13/2015 06:04:10] - Manufacturing image extracted: 27108_mf_mlc_Toshiba_64Gb_TC58NVG6D2HTA00_2Q_2C_1D_S_PP_R01111_s512.vic
[Mon 07/13/2015 06:04:10] - Proceeding in ROM mode, download feature 3...
[Mon 07/13/2015 06:04:11] - Successfully downloaded MFB to the drive...
[Mon 07/13/2015 06:04:11] - Waiting (5 sec) for the drive to settle...
[Mon 07/13/2015 06:04:16] - Successfully received the IDENTIFY data from the drive...
[Mon 07/13/2015 06:04:16] - Firmware revision reported to be: '522ABBM0'.  This indicates MFB download was successful.
[Mon 07/13/2015 06:04:16] - Successfully enabled SMART capabilities...
[Mon 07/13/2015 06:04:18] - Successfully issued a diagnostic unlock...
[Mon 07/13/2015 06:04:19] - Performing the flash test of block 0 (0x0000)...
[Mon 07/13/2015 06:04:21] - Flash Test Results:
Flash Test Parameters:
               Block Count: 0
                Page Count: 1
                 Bus Count: 2
        Chip Enabled Count: 2
                 Die Count: 1
                Lane Count: 4
               Plane Count: 2
Results Notes:
   N1 - At least one page tested and passed with no bit errors.
   N2 - No test data available.  Test may have aborted, or failed during the testing.
   N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
   N4 - At least  one erased page tested had bit error rate greater than half the correction power.
   N5 - Walking zeros test failed.
   N6 - Walking ones test failed.
   N7 - Block contained factory bad block markings and testing was skipped.
   N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
   N9 - Block in plane 0 was marked as a factory bad block.
  N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
  N11 - Block in plane 1 was marked as a factory bad block.
| Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |
| 0    | 0    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 3    | 0x0380 | N7,N9,N11                                  | WARNING |
| 0    | 1    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 3    | 0x0380 | N7,N9,N11                                  | WARNING |
| 1    | 0    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 3    | 0x0001 | N1                                         |    PASS |
  Total Number of test results: 16
            Number of failures: 0
         Number of Passed with warnings: 2
      No. Passed without warnings: 14
[Mon 07/13/2015 06:04:21] - Performing the FORMAT Command with the following parameters:
         MemoryWearCycleCapability = 0
              CurrentPE_CycleCount = 0
                     LifeInSeconds = 0
                   LogicalCapacity = 234441648
                        SectorSize = 512
             SectorAlignmentOffset = 0
                  ExpectedMemoryID = 56984 (0xDE98)
                   ExpectedNumDies = 0
               SerialOutputControl = 0
                           Time[8] = 0x0000000000000000
            MiscFlag_Erase_R_Block = 0
     MiscFlag_PanicHandlingEnabled = 0
        MiscFlag_PanicOnSATA_Error = 0
  MiscFlag_WriteThrottlingTestMode = 0
      MiscFlag_DisableUserBandECCX = 0
                        L_PageSize = 0
                        E_PageSize = 0
              ErrorCorrectionPower = 0
      ConfigDeviceReadDisturbCount = 0
   ConfigDeviceReadDisturbCountLow = 0
                  ExtraOptions_0_1 = 0
[Mon 07/13/2015 06:05:26] - FATAL_ERROR: Could not perform the FORMAT() operation on the drive... (0x11000001:SF_SG_DEVICE_CHECK_CONDITION_ERROR)
Extended Error data:
          ATA COMMAND : 0x00B0  (176)
          ATA FEATURE : 0x00D6  (214)
         Device Status: 0x0001  (1)
         Driver Status: 0x0000  (0)
           Host Status: 0x0008  (8)
Sense Data:
  0 -         No Sense: 114 (0x72)    OK
  1 -  Recovered Error:  11 (0x0B)    FAIL
  2 -        Not Ready:   0 (0x00)    OK
  3 -     Medium Error:   0 (0x00)    OK
  4 -   Hardware Error:   0 (0x00)    OK
  5 -  Illegal Request:   0 (0x00)    OK
  6 -   Unit Attention:   0 (0x00)    OK
  7 -     Data Protect:  14 (0x0E)    OK
  8 -      Blank Check:   9 (0x09)    OK
  9 -  Vendor Specific:  12 (0x0C)    OK
10 -     Copy Aborted:   0 (0x00)    OK
11 -  Aborted Command:   0 (0x00)    OK
12 - Equal Comparison:   0 (0x00)    NA
13 -  Volume Overflow:   0 (0x00)    NA
14 -       Miscompare:   0 (0x00)    OK
15 -         Reserved:   1 (0x01)    NA
System Trace:
[  235.056788] ata4: exception Emask 0x10 SAct 0x0 SErr 0x40c0000 action 0xe frozen
[  235.056798] ata4: irq_stat 0x00000040, connection status changed
[  235.056807] ata4: SError: { CommWake 10B8B DevExch }
[  235.056823] ata4: hard resetting link
[  236.793107] ata4: SATA link down (SStatus 0 SControl 300)
[  236.793146] ata4: EH complete
[  236.798529] ata4: exception Emask 0x10 SAct 0x0 SErr 0x40c0000 action 0xe frozen
[  236.798539] ata4: irq_stat 0x00000040, connection status changed
[  236.798548] ata4: SError: { CommWake 10B8B DevExch }
[  236.798564] ata4: limiting SATA link speed to 1.5 Gbps
[  236.798572] ata4: hard resetting link
[  237.676110] ata4: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[  237.677147] ata4.00: ATA-8: SandForce{200026BB}, 306ABBR0, max UDMA/133
[  237.677158] ata4.00: 64 sectors, multi 0: LBA48 NCQ (depth 31/32), AA
[  237.682865] ata4.00: configured for UDMA/133
[  237.682883] ata4: EH complete
[  237.683209] scsi 3:0:0:0: Direct-Access     ATA      SandForce{200026 306A PQ: 0 ANSI: 5
[  237.685401] sd 3:0:0:0: [sdc] 64 512-byte logical blocks: (32.7 kB/32.0 KiB)
[  237.685410] sd 3:0:0:0: [sdc] 4096-byte physical blocks
[  237.685521] sd 3:0:0:0: [sdc] Write Protect is off
[  237.685528] sd 3:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[  237.685575] sd 3:0:0:0: [sdc] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[  237.687363] sd 3:0:0:0: Attached scsi generic sg2 type 0
[  237.688682]  sdc: unknown partition table
[  237.698836] sd 3:0:0:0: [sdc] Attached SCSI disk
[  264.990531] ata4.00: exception Emask 0x10 SAct 0x0 SErr 0x400000 action 0x6 frozen
[  264.990535] ata4.00: irq_stat 0x08000000, interface fatal error
[  264.990539] ata4: SError: { Handshk }
[  264.990542] ata4.00: failed command: SMART
[  264.990548] ata4.00: cmd b0/d6:01:e0:4f:c2/00:00:00:00:00/00 tag 0 pio 512 out
[  264.990550]          res 50/00:00:01:00:00/00:00:00:00:00/e0 Emask 0x10 (ATA bus error)
[  264.990553] ata4.00: status: { DRDY }
[  264.990558] ata4: hard resetting link
[  265.450148] ata4: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[  265.450498] ata4.00: model number mismatch 'SandForce{200026BB}' != 'SandForce'
[  265.450510] ata4.00: revalidation failed (errno=-19)
[  270.450119] ata4: hard resetting link
[  280.451099] ata4: softreset failed (1st FIS failed)
[  280.451111] ata4: hard resetting link
[  290.451096] ata4: softreset failed (1st FIS failed)
[  290.451108] ata4: hard resetting link
[  325.452095] ata4: softreset failed (1st FIS failed)
[  325.452108] ata4: hard resetting link
[  330.453092] ata4: softreset failed (1st FIS failed)
[  330.453103] ata4: reset failed, giving up
[  330.453110] ata4.00: disabled
[  330.453149] ata4: EH complete
[Mon 07/13/2015 06:05:26] - End of Genesis manufacturing log.
[Mon 07/13/2015 06:05:26] - Exiting...
[Mon 07/13/2015 06:05:26] - Overall Result for Device: /dev/sg2 ****** FAIL ******
Process exited with code 8
[ 此帖被twkblybb1在2015-07-18 19:36重新编辑 ]
离线perter
只看该作者 1楼 发表于: 2015-07-12
离线jpdd521
只看该作者 2楼 发表于: 2015-07-12
离线john_chuck
只看该作者 3楼 发表于: 2015-07-12
离线perter
只看该作者 4楼 发表于: 2015-07-12
离线guoke1930
只看该作者 5楼 发表于: 2015-07-12
离线ahuangxiang
只看该作者 6楼 发表于: 2015-07-13
离线羲和玄炎
只看该作者 7楼 发表于: 2015-07-13
离线音之韵
只看该作者 8楼 发表于: 2015-07-13
回 羲和玄炎 的帖子
离线羲和玄炎
只看该作者 9楼 发表于: 2015-07-15
回 音之韵 的帖子
[ 此帖被羲和玄炎在2015-07-16 13:34重新编辑 ]
