  • 3073阅读
  • 5回复
[SandForce]求助金士顿兰色SF2281板子开卡驱动器IDENTIFY错误 [复制链接]
离线stereo00
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2015-07-13
按照论坛里的说明将FLASH的28、45脚的电阻拆除掉,4片INTEL的JS29F16B08CCME2贴在主控的背面,位置及焊接都检查过了没有错误没有虚焊和短路,BIOS能正常识别主控,在FEDORA 14下开卡选择22069的配置文件,老是卡在Could not get the IDENTIFY data from the drive... (0x12000004:SF_SG_HOST_BAD_TARGET_ERROR)这条错误这儿,求坛里的高手指点下,先谢谢了。另外在自定义修改配置这里没看到有写保护(EX开头的外部写保护英文)这个选项。
LOG文件代码如下:
[Mon 07/13/2015 19:28:28] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sda
    MFP Package Filename = /home/SSD/Fw/FW_319--1/FW_319.1.mfp
      Configuration File = /home/SSD/22069.1.driveconfig
              Serial No. = 2015071201
         World Wide Name = WWN_001
[Mon 07/13/2015 19:28:28] - Successfully received the IDENTIFY data from the drive...
[Mon 07/13/2015 19:28:35] - Successfully opened the package: /home/SSD/Fw/FW_319--1/FW_319.1.mfp
[Mon 07/13/2015 19:28:35] - Successfully extracted *.DriveConfig file: /home/SSD/22069.1.driveconfig
[Mon 07/13/2015 19:28:35] - Extracted Config_ID: 1 (22069) in DriveConfig file: /home/SSD/22069.1.driveconfig
[Mon 07/13/2015 19:28:35] - Extracted SerialOutputControl: 0
[Mon 07/13/2015 19:28:35] - Successfully extracted Config record: 22069
[Mon 07/13/2015 19:28:35] - Successfully extracted flashware image: 22069_fw_cl_ccmlc_Intel_64Gb_JS29F16B08CCME2_1Q_2C_1D_PP_R00424_s512.vic
[Mon 07/13/2015 19:28:35] - Successfully extracted manufacturing image: 22069_mf_ccmlc_Intel_64Gb_JS29F16B08CCME2_1Q_2C_1D_PP_R00424_s512.vic
[Mon 07/13/2015 19:28:35] - Proceeding in ROM mode, download feature 1...
[Mon 07/13/2015 19:28:35] - Successfully downloaded MFB to the drive...
[Mon 07/13/2015 19:28:35] - Waiting (5 sec) for the drive to settle...
[Mon 07/13/2015 19:31:11] - FATAL_ERROR: Could not get the IDENTIFY data from the drive... (0x12000004:SF_SG_HOST_BAD_TARGET_ERROR)
[Mon 07/13/2015 19:31:11] - End of Genesis manufacturing log.
[Mon 07/13/2015 19:31:11] - Exiting...
    </Log_Body>
    <Overall_Summary>
        <Start_Time> Mon, 07/13/2015 @ 19:28:27 </Start_Time>
        <End_Time> Mon, 07/13/2015 @ 19:31:11 </End_Time>
        <Overall_Result> FAIL </Overall_Result>
        <Exit_Code> (0x10090012:SF_GENESIS_IDENTIFY_ERROR) </Exit_Code>
    </Overall_Summary>
    <Environment_Settings>
        <Input_Parameters>
                  argv[1]: -PROCESS_SSD
                  argv[2]: /dev/sda
                  argv[3]: /home/SSD/Fw/FW_319--1/FW_319.1.mfp
                  argv[4]: /home/SSD/22069.1.driveconfig
                  argv[5]: 2015071201
                  argv[6]: WWN_001
                  argv[7]: LOG=./SomeRun.log
        </Input_Parameters>
        <Log_File> ./SomeRun.log </Log_File>
        <Hostname> HP6531S </Hostname>
        <Host_IP_Address> 10.99.68.126 </Host_IP_Address>
        <Port_Number> a </Port_Number>
        <Device_Name> /dev/sda </Device_Name>
        <SF_Genesis_Version> v1.5.21.20110919-fc14-32bit </SF_Genesis_Version>
        <SF_Core_Library_Version> v1.7.0.20110919-fc14-32bit </SF_Core_Library_Version>
        <SF_OS_Information> Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686 </SF_OS_Information>
    </Environment_Settings>
    <Post_Processing_Device_Info>
        <WWN_OUI> UNKNOWN </WWN_OUI>
        <WWN_UniqueID> UNKNOWN </WWN_UniqueID>
        <Serial_Number> UNKNOWN </Serial_Number>
        <Model_Number> UNKNOWN </Model_Number>
        <Firmware_Revision> UNKNOWN </Firmware_Revision>
        <ROM_Revision> UNKNOWN </ROM_Revision>
        <NAND_Page_Size> UNKNOWN </NAND_Page_Size>
        <Number_Of_Chip_Enable> UNKNOWN </Number_Of_Chip_Enable>
        <Logical_Sectors> UNKNOWN </Logical_Sectors>
        <NAND_ID> UNKNOWN </NAND_ID>
        <Flash_Manufacturer> UNKNOWN </Flash_Manufacturer>
        <Flash_Device> UNKNOWN </Flash_Device>
    </Post_Processing_Device_Info>
</Genesis_Log>
[Mon 07/13/2015 19:31:12] - Overall Result for Device: /dev/sda ****** FAIL ******
离线stereo00
只看该作者 1楼 发表于: 2015-07-13
自定义配置文件图片
本帖最近打赏记录:共1条打赏M币+3
离线音之韵
只看该作者 2楼 发表于: 2015-07-13
离线perter
只看该作者 3楼 发表于: 2015-07-14
离线john_chuck
只看该作者 4楼 发表于: 2015-07-14
离线stereo00
只看该作者 5楼 发表于: 2015-07-14
多谢大家指点,回头再检查下焊接。
