前几天逛下交易区,看到有便宜的LJ货:
http://bbs.mydigit.cn/read.php?tid=1307205 忍不住入了两个
用电查询终端,但是STM32不会用,只会用点C51,发疯地在网上找个屏的驱动,花了点费用,下载了一个并口的,修修改改成串口的终于可以点亮了,但是只能点亮上半屏,下半屏可有是串并口用的驱动控制命令不一样,可以没有办法点下半屏,发出来期待坛子里的高手完善,或看到坛友辛苦份上,直接上一个能用的C51驱动,最好是能在
用电查询终端这直接折腾个万年历什么的,开放源代码或BIN文件给下载!让入了这个的坛友玩得开心,物有所用,不成垃圾!
期待高手出现。 #include <reg52.h>
#include <math.h>
#define uchar unsigned char
#define uint unsigned int
/* Define the register command code */
#define Disp_On 0xaf // Display Enable
#define Disp_Off 0xae // Display Disable
#define Page_Add 0xb0 // Page Address Start
#define Row_Add 0x40 // Scroll Line Start
sbit CS0 = P2^7;
sbit RST = P2^6;
sbit CD = P2^5;
sbit SCK = P2^4;
sbit SDA = P2^3;
sbit KEY = P3^5;
uchar row,col; // 全局变量
void Putstr(uchar *str,uchar i,uchar col,uchar row);
void Putedot(uchar Order);
void disp8(uchar pag,uchar col, uchar code *k);
void disp9(uchar pag,uchar col, uchar code *hzk);
void dispfull(uchar *p);
uchar code eight[];
uchar code nine[], nine1[];
uchar code Ezk[];
uchar code number[][16]={
0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00,//"0",0
0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,//"1",1
0x00,0x70,0x08,0x08,0x08,0x88,0x70,0x00,0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00,//"2",2
0x00,0x30,0x08,0x88,0x88,0x48,0x30,0x00,0x00,0x18,0x20,0x20,0x20,0x11,0x0E,0x00,//"3",3
0x00,0x00,0xC0,0x20,0x10,0xF8,0x00,0x00,0x00,0x07,0x04,0x24,0x24,0x3F,0x24,0x00,//"4",4
0x00,0xF8,0x08,0x88,0x88,0x08,0x08,0x00,0x00,0x19,0x21,0x20,0x20,0x11,0x0E,0x00,//"5",5
0x00,0xE0,0x10,0x88,0x88,0x18,0x00,0x00,0x00,0x0F,0x11,0x20,0x20,0x11,0x0E,0x00,//"6",6
0x00,0x38,0x08,0x08,0xC8,0x38,0x08,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00,//"7",7
0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00,//"8",8
0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x00,0x31,0x22,0x22,0x11,0x0F,0x00,//"9",9
0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00,//"0",10
uchar code nine1[]={
0x80,0x80,0x40,0x20,0x10,0x0C,0x03,0x00,0x03,0x0C,0x10,0x20,0x40,0x80,0x80,0x00,
};//"天",0
/*------------------延时子程序1----------------------------*/
void delay(uint i)
while (i--);
/*------------------延时子程序2----------------------------*/
void delay1s(uint t)
uint i,j;
for (i=0;i<t;i++)
for (j=0;j<10000;j++)
/*------------------写命令到LCD-----------------------------*/
void write_com(uchar cmdcode)
int i;
CS0=0;
CD=0;
for (i=0;i<8;i++)
SCK=0;
if (cmdcode&0x80)
SDA=1;
else
SDA=0;
cmdcode=cmdcode<<1;
SCK=1;
CS0=1;
/*-------------------写数据到LCD----------------------------*/
void write_data(uchar Dispdata)
int i;
CS0=0;
CD=1;
for (i=0;i<8;i++)
SCK=0;
if (Dispdata&0x80)
SDA=1;
else
SDA=0;
Dispdata=Dispdata<<1;
SCK=1;
CS0=1;
/*-------------------清屏-----------------------------------*/
void Clr_Scr()
uchar j,k;
for (k=0;k<4;k++)
write_com(Page_Add+k);
write_com(0x10);
write_com(0x00);
for (j=0;j<132;j++)
write_data(0x00);
/*------------------显示测试----------------------------------*/
void Disptest(uchar data1,data2)
uchar i,j;
for (j=0;j<4;j++)
write_com(Page_Add+j);
write_com(0x10);
write_com(0x00);
for (i=0;i<66;i++)
write_data(data1);
write_data(data2);
/*------------------初始化LCD屏-----------------------------*/
void Init_lcd()
delay(200);
RST=0;
delay(2000);
RST=1;
delay(2000);
write_com(0xE2);//system reset
delay(200);
write_com(0x23);//set duty 1/65
write_com(0x24);//set t.c
write_com(0x2f);//set pump 2f/internal vlcd 29/external vlcd
write_com(0x81);//set vop
write_com(130);
write_com(0x8d);//set ram address control
write_com(0xeb);//set bias=1/9
write_com(0xc0);
write_com(0xAF);//set display enable
delay(6000);
RST=0;
delay(6000);
RST=1;
delay(6000);
write_com(0xe2); // Set System Reset
delay(6000);
write_com(0x2f); // Set Power Control loading 15-24nF
write_com(0x24); // Set T.C
//write_com(0xa7); // Set Inverse Display 设置反显
write_com(0xc4); // Set Mapping Control
write_com(0xa0); // Set Frame Rate
write_com(0x89); // Set RAM Address Control
write_com(0xe8); // Set Bias Ratio : 1/6
write_com(0x81);
write_com(0xe8); // Set Vbias : 7.99V设置偏压
write_com(0xf1);
write_com(0x3f); // Set COM End (63)
write_com(0xf2);
write_com(0x20); // Set Partial Display Start (0)
write_com(0xf3);
write_com(0x3f); // Set Partial Display End (63)
write_com(0x85); // Set Partial Display Control
write_com(Disp_On); // Set Display Enable
void waitkey(void)
{delay(400);
while(KEY)
delay(3000);
void main()
uchar i,A=1;
uchar code str[ ]="12345678901234567890"; // 定义任意字符串数组
Clr_Scr();
Init_lcd();
while (1)
Init_lcd();
disp8(0,0,eight); // 指定位置显示8*8点阵字符
disp8(0,8,eight); // 指定位置显示8*8点阵字符
disp8(0,16,eight); // 指定位置显示8*8点阵字符
disp8(0,24,eight); // 指定位置显示8*8点阵字符
disp8(0,32,eight); // 指定位置显示8*8点阵字符
disp8(0,40,eight); // 指定位置显示8*8点阵字符
disp8(0,48,eight); // 指定位置显示8*8点阵字符
disp8(0,56,eight); // 指定位置显示8*8点阵字符
disp9(0,64,number[1]); // 指定位置显示8*16点阵字符
disp9(0,72,number[0]); // 指定位置显示8*16点阵字符
// disp9(0,72,nine+16); // 指定位置显示8*16点阵字符
Putstr(str,16,2,0); // 从ACSII表中读字符,指定位置显示8*16点阵字符串
waitkey() ;
Disptest(0x55,0x55);
waitkey() ;
Disptest(0xaa,0xaa);
waitkey() ;
Disptest(0x55,0xaa);
waitkey() ;
Disptest(0xaa,0x55);
waitkey() ;
Disptest(0xff,0x00);
waitkey() ;
Disptest(0x00,0xff);
waitkey() ;
Disptest(0xff,0xff);
waitkey() ;
Disptest(0x00,0x00);
waitkey() ;
dispfull(eight); // 全屏显示8*8点阵字符
waitkey() ;
for(i=32;i<=63;i++)
dispfull(eight);
write_com(0x40+i); // Set Scroll Line
for(i=63;i>=32;i--)
dispfull(eight);
waitkey() ;
/*-------------半角字符8×8点阵码----------------*/
uchar j=0,i=0;
uchar lie;
lie=col&0xf0;
lie>>=4;
write_com(Page_Add+pag);
write_com(0x10+lie);
write_com(0x00+col&0x0f);
for (i=0;i<8;i++)
write_data(k
/*-------------半角字符8×16点阵码(汉字)----------------*/
uchar j=0,i=0;
uchar lie;
for (j=0;j<2;j++) // 整个字符分上下半部分字符
lie=col&0xf0;
lie>>=4;
write_com(Page_Add+pag+j);
for (i=0;i<8;i++)
write_data(hzk[8*j+i]);
uint i,j,k;
uchar *q;
for (i=0;i<8;i++)
write_com(i+0xb0); //SET PAGE ADDRESS
write_com(0x10); //SET Column Address MSB
write_com(0x00); //SET Column Address LSB
for (j=0;j<16;j++)
q=p;
for (k=0;k<8;k++)
write_data(*q++);
/*----------------------一个字符串的输出------------------*/
void Putstr(uchar *str,uchar i,uchar page,uchar lie)
uchar j,X;
for (j=0;j<i;j++)
col = lie+8*j; // 换列
row = page;
X = str[j];
Putedot(X-0x20); // ascii码表从0x20开始
/*-------------半角字符8×16点阵码数据输出----------------*/
uchar j=0,i=0;
uchar lie,cbyte;
int x;
x = Order * 0x10; // 如字符!,在Ezk[]中的位置为1,对应Order=1,但其第1个点阵字节在Ezk[16]中,将Order乘以0x10的值x作为该字符在Ezk[]中的第一个点阵码的下标
lie=col&0xf0;
lie>>=4;
write_com(Page_Add+row+j);
for (i=0;i<8;i++)
cbyte = Ezk[x];
write_data(cbyte); // 输出一字节
x++;
uchar code eight[]={0x00,0x00,0x00,0x36,0x49,0x49,0x49,0x36};
//uchar code nine[]={0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x00,0x31,0x22,0x22,0x11,0x0F,0x00};
//汉字符取码方式:阴码,列行,逆向。
uchar code Ezk[]={
/*-文字:(space)--0x20*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
/*-文字:!--0x21*/
0x00,0x00,0x00,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x27,0x00,0x00,0x00,0x00,
/*-文字:"--0x22*/
0x00,0x08,0x04,0x02,0x08,0x04,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
/*-文字:#--0x23*/
0x40,0x40,0xF8,0x40,0x40,0xF8,0x40,0x00,0x04,0x3F,0x04,0x04,0x3F,0x04,0x04,0x00,
/*-文字:$--0x24*/
0x00,0x70,0x88,0xFC,0x08,0x08,0x30,0x00,0x00,0x1C,0x20,0xFF,0x21,0x22,0x1C,0x00,
/*-文字:%--0x25*/
0xF0,0x08,0xF0,0x80,0x70,0x08,0x00,0x00,0x00,0x31,0x0E,0x01,0x1E,0x21,0x1E,0x00,
/*-文字:&--0x26*/
0x00,0xF0,0x08,0x88,0x70,0x00,0x00,0x00,0x1E,0x21,0x23,0x24,0x18,0x16,0x20,0x00,
/*-文字:'--0x27*/
0x20,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
/*-文字:(--0x28*/
0x00,0x00,0x00,0x00,0xC0,0x30,0x08,0x04,0x00,0x00,0x00,0x00,0x03,0x0C,0x10,0x20,
/*-文字:)--0x29*/
0x04,0x08,0x30,0xC0,0x00,0x00,0x00,0x00,0x20,0x10,0x0C,0x03,0x00,0x00,0x00,0x00,
/*-文字:*--0x2a*/
0x40,0x40,0x80,0xF0,0x80,0x40,0x40,0x00,0x02,0x02,0x01,0x0F,0x01,0x02,0x02,0x00,
/*-文字:+--0x2b*/
0x00,0x00,0x00,0xE0,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x0F,0x01,0x01,0x01,0x00,
/*-文字:,--0x2c*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x60,0x00,0x00,0x00,0x00,0x00,0x00,
/*-文字:---0x2d*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x00,
/*-文字:.--0x2e*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x00,0x00,0x00,0x00,0x00,0x00,
/*-文字:/--ox2f*/
0x00,0x00,0x00,0x00,0x00,0xE0,0x18,0x04,0x00,0x40,0x30,0x0C,0x03,0x00,0x00,0x00,
/*-文字:0--0x30*/
/*-文字:1--0x31*/
/*-文字:2--0x32*/
/*-文字:3--0x33*/
/*-文字:4--0x34*/
/*-文字:5--0x35*/
/*-文字:6--0x36*/
/*-文字:7--0x37*/
/*-文字:8--0x38*/
/*-文字:9--0x39*/
/*-文字::--*/
0x00,0x00,0x60,0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x18,0x00,0x00,0x00,0x00,
/*-文字:/--*/
0x00,0x00,0x00,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x60,0x00,0x00,0x00,0x00,
/*-文字:<--*/
0x00,0x00,0x80,0x40,0x20,0x10,0x08,0x00,0x00,0x01,0x02,0x04,0x08,0x10,0x20,0x00,
/*-文字:=--*/
0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x00,0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x00,
/*-文字:>--*/
0x00,0x08,0x10,0x20,0x40,0x80,0x00,0x00,0x00,0x20,0x10,0x08,0x04,0x02,0x01,0x00,
/*-文字:?--*/
0x00,0x30,0x08,0x08,0x08,0x88,0x70,0x00,0x00,0x00,0x00,0x26,0x01,0x00,0x00,0x00,
/*-文字:@--*/
0xC0,0x30,0xC8,0x28,0xE8,0x10,0xE0,0x00,0x07,0x18,0x27,0x28,0x27,0x28,0x07,0x00,
/*-文字:A--*/
0x00,0x00,0xE0,0x18,0x18,0xE0,0x00,0x00,0x30,0x0F,0x04,0x04,0x04,0x04,0x0F,0x30,
/*-文字:B--*/
0xF8,0x08,0x08,0x08,0x08,0x90,0x60,0x00,0x3F,0x21,0x21,0x21,0x21,0x12,0x0C,0x00,
/*-文字:C--*/
0xE0,0x10,0x08,0x08,0x08,0x10,0x60,0x00,0x0F,0x10,0x20,0x20,0x20,0x10,0x0C,0x00,
/*-文字:D--*/
0xF8,0x08,0x08,0x08,0x08,0x10,0xE0,0x00,0x3F,0x20,0x20,0x20,0x20,0x10,0x0F,0x00,
/*-文字:E--*/
0x00,0xF8,0x08,0x08,0x08,0x08,0x08,0x00,0x00,0x3F,0x21,0x21,0x21,0x21,0x20,0x00,
/*-文字:F-- */
0xF8,0x08,0x08,0x08,0x08,0x08,0x08,0x00,0x3F,0x01,0x01,0x01,0x01,0x01,0x00,0x00,
/*-文字:G--*/
0xE0,0x10,0x08,0x08,0x08,0x10,0x60,0x00,0x0F,0x10,0x20,0x20,0x21,0x11,0x3F,0x00,
/*-文字:H--*/
0x00,0xF8,0x00,0x00,0x00,0x00,0xF8,0x00,0x00,0x3F,0x01,0x01,0x01,0x01,0x3F,0x00,
/*-文字:I--*/
0x00,0x00,0x00,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00,
/*-文字:J--*/
0x00,0x00,0x00,0x00,0x00,0x00,0xF8,0x00,0x00,0x1C,0x20,0x20,0x20,0x20,0x1F,0x00,
/*-文字:K--*/
0x00,0xF8,0x00,0x80,0x40,0x20,0x10,0x08,0x00,0x3F,0x01,0x00,0x03,0x04,0x18,0x20,
/*-文字:L--*/
0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0x20,0x20,0x20,0x20,0x20,0x20,0x00,
/*-文字:M--*/
0xF8,0xE0,0x00,0x00,0x00,0xE0,0xF8,0x00,0x3F,0x00,0x0F,0x30,0x0F,0x00,0x3F,0x00,
/*-文字:N--*/
0x00,0xF8,0x30,0xC0,0x00,0x00,0xF8,0x00,0x00,0x3F,0x00,0x01,0x06,0x18,0x3F,0x00,
/*-文字:O--*/
/*-文字:P-- */
0xF8,0x08,0x08,0x08,0x08,0x10,0xE0,0x00,0x3F,0x02,0x02,0x02,0x02,0x01,0x00,0x00,
/*-文字:Q--*/
0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x0F,0x10,0x20,0x2C,0x10,0x2F,0x00,
/*-文字:R--*/
0xF8,0x08,0x08,0x08,0x08,0x90,0x60,0x00,0x3F,0x01,0x01,0x01,0x07,0x18,0x20,0x00,
/*-文字:S--*/
0x60,0x90,0x88,0x08,0x08,0x10,0x20,0x00,0x0C,0x10,0x20,0x21,0x21,0x12,0x0C,0x00,
/*-文字:T--*/
0x08,0x08,0x08,0xF8,0x08,0x08,0x08,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00,
/*-文字:U--*/
0xF8,0x00,0x00,0x00,0x00,0x00,0xF8,0x00,0x0F,0x10,0x20,0x20,0x20,0x10,0x0F,0x00,
/*-文字:V--*/
0x18,0xE0,0x00,0x00,0x00,0xE0,0x18,0x00,0x00,0x01,0x0E,0x30,0x0E,0x01,0x00,0x00,
/*-文字:W--*/
0xF8,0x00,0xC0,0x38,0xC0,0x00,0xF8,0x00,0x03,0x3C,0x03,0x00,0x03,0x3C,0x03,0x00,
/*-文字:X--*/
0x08,0x30,0xC0,0x00,0xC0,0x30,0x08,0x00,0x20,0x18,0x06,0x01,0x06,0x18,0x20,0x00,
/*-文字:Y--*/
0x08,0x30,0xC0,0x00,0xC0,0x30,0x08,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00,
/*-文字:Z--*/
0x08,0x08,0x08,0x08,0xC8,0x28,0x18,0x00,0x30,0x2C,0x22,0x21,0x20,0x20,0x20,0x00,
/*-文字:{--*/
0x00,0x00,0x00,0x80,0x7E,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0x20,0x00,0x00,
/*-文字:\--*/
0x00,0x08,0x70,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x0E,0x30,0xC0,0x00,
/*-文字:}--*/
0x00,0x02,0x7E,0x80,0x00,0x00,0x00,0x00,0x00,0x20,0x3F,0x00,0x00,0x00,0x00,0x00,
/*-文字:^--*/
0x00,0x08,0x04,0x02,0x02,0x04,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
/*-文字:_--*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,
/*-文字:`--*/
0x00,0x00,0x02,0x06,0x04,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
/*-文字:a--*/
0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x19,0x24,0x24,0x24,0x14,0x3F,0x00,
/*-文字:b--*/
0x00,0xF8,0x00,0x80,0x80,0x80,0x00,0x00,0x00,0x3F,0x11,0x20,0x20,0x20,0x1F,0x00,
/*-文字:c--*/
0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x0E,0x11,0x20,0x20,0x20,0x20,0x11,0x00,
/*-文字:d--*/
0x00,0x00,0x80,0x80,0x80,0x00,0xF8,0x00,0x00,0x1F,0x20,0x20,0x20,0x11,0x3F,0x00,
/*-文字:e--*/
0x00,0x00,0x80,0x80,0x80,0x00,0x00,0x00,0x0E,0x15,0x24,0x24,0x24,0x25,0x16,0x00,
/*-文字:f--*/
0x00,0x80,0x80,0xF0,0x88,0x88,0x88,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00,
/*-文字:g--*/
0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x00,0x40,0xB7,0xA8,0xA8,0xA8,0xA7,0x40,0x00,
/*-文字:h--*/
0x00,0xF8,0x00,0x80,0x80,0x80,0x00,0x00,0x00,0x3F,0x01,0x00,0x00,0x00,0x3F,0x00,
/*-文字:i--*/
0x00,0x00,0x00,0x98,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00,
/*-文字:j--*/
0x00,0x00,0x00,0x00,0x98,0x00,0x00,0x00,0x00,0x80,0x80,0x80,0x7F,0x00,0x00,0x00,
/*-文字:k--*/
0x00,0xF8,0x00,0x00,0x00,0x80,0x00,0x00,0x00,0x3F,0x04,0x02,0x0D,0x10,0x20,0x00,
/*-文字:l--*/
/*-文字:m--*/
0x80,0x80,0x80,0x80,0x80,0x80,0x00,0x00,0x3F,0x00,0x00,0x3F,0x00,0x00,0x3F,0x00,
/*-文字:n--*/
0x00,0x80,0x00,0x80,0x80,0x80,0x00,0x00,0x00,0x3F,0x01,0x00,0x00,0x00,0x3F,0x00,
/*-文字:o--*/
0x00,0x00,0x80,0x80,0x80,0x00,0x00,0x00,0x0E,0x11,0x20,0x20,0x20,0x11,0x0E,0x00,
/*-文字:p--*/
0x00,0x80,0x00,0x80,0x80,0x80,0x00,0x00,0x00,0xFF,0x11,0x20,0x20,0x20,0x1F,0x00,
/*-文字:q--*/
0x00,0x00,0x80,0x80,0x80,0x00,0x80,0x00,0x00,0x1F,0x20,0x20,0x20,0x11,0xFF,0x00,
/*-文字:r--*/
0x00,0x00,0x80,0x00,0x00,0x80,0x80,0x00,0x00,0x00,0x3F,0x01,0x01,0x00,0x00,0x00,
/*-文字:s--*/
0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x13,0x24,0x24,0x24,0x24,0x19,0x00,
/*-文字:t--*/
0x00,0x80,0x80,0xE0,0x80,0x80,0x80,0x00,0x00,0x00,0x00,0x1F,0x20,0x20,0x20,0x00,
/*-文字:u--*/
0x00,0x80,0x00,0x00,0x00,0x00,0x80,0x00,0x00,0x1F,0x20,0x20,0x20,0x10,0x3F,0x00,
/*-文字:v--*/
0x80,0x00,0x00,0x00,0x00,0x00,0x80,0x00,0x00,0x07,0x18,0x20,0x18,0x07,0x00,0x00,
/*-文字:w--*/
0x80,0x00,0x00,0x80,0x00,0x00,0x80,0x00,0x0F,0x30,0x0E,0x01,0x0E,0x30,0x0F,0x00,
/*-文字:x--*/
0x80,0x00,0x00,0x00,0x00,0x00,0x80,0x00,0x20,0x11,0x0A,0x04,0x0A,0x11,0x20,0x00,
/*-文字:y--*/
0x80,0x00,0x00,0x00,0x00,0x00,0x80,0x00,0x00,0x87,0x98,0x60,0x18,0x07,0x00,0x00,
/*-文字:z--*/
0x00,0x80,0x80,0x80,0x80,0x80,0x80,0x00,0x00,0x30,0x28,0x24,0x22,0x21,0x20,0x00,
/*-文字:{--*/
/*-文字:|--*/
0x00,0x00,0x00,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,0x00,
/*-文字:}--*/
/*-文字:~--*/
0x00,0x06,0x01,0x01,0x06,0x04,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
