  • 36827阅读
  • 80回复
[电源]充电王者!PowerEx MH-C9000介绍及拆解[转] [复制链接]
离线char123
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2010-01-02
The Maha MH-C9000 Advanced Battery Charger can Charge, condition and analyze one to four AA or AAA rechargeable batteries with Independent operation of each battery slot.
4路独立5号,7号可充电电池充电,复新和分析
The Maha MH-C9000 Charger has a Large backlit LCD. Bright white LED light for easy to read the MH-C9000 display.
大屏幕背光lcd显示
Digitally displays capacity, voltage, time elapsed and current.
数字显示容量,电压,时间和电流
Adjustable charging rate from 0.2 to 2.0A and discharging rate from 0.1A to 1.0A.
可调整充电电流200ma到2000ma,200ma增量。放电电流100ma到1000ma,100ma增量。
Five modes of operation:
-- Charge: Charge the battery at the selected rate
-- Discharge: Discharge the battery at the selected rate.
-- Analyze & Refresh: First charge the battery at the selected rate, then discharge it at the selected rate followed by recharging. The discharge capacity is saved for display at the end of the cycle.
-- Break-In: Allows user to enter the battery capacity and performs a forming charge at 0.1C for 16 hours (using only temperature and timer cutoff) followed by discharge and medium rate recharge.
-- Cycle: Allows user to set charge and discharge rate and number of cycles to perform. The MH-C9000 will save the capacity for up to 12 cycles which user can access throughout the cycling.
5种操作模式
--充电
--放电
--分析和复新:先充电,再放点,得到电池容量,再充电。
--训练:允许用户输入电池容量,然后以0.1C的电流冲16小时(只有温度和时间控制),然后放电,再以中等电流充电。
--循环:允许用户指定冲放电流和循环次数,对电池进行循环充放电,最后12个循环的放电容量可以查询。
Negative delta V, peak voltage, dT/dt (temperature rise) and max
负电压,峰值(最高)电压,温度变化率以及最大温度保护,终止判断
The MH-C9000 Battery Charger has excellent Temperature protection
Four independent thermocouples to manage rechargeable battery temperatures.
4路独立温度检测(硬件方面)
Quartz-oscillator time base for 1% accuracy in capacity calculations. The capacity is determined by continously integrating the measured current (actual current not set point) over time. High accuracy is achieved by using a precision shunt-resistor coupled with a 12-bit Analog-to-Digital converter as well as a quartz oscillator timebase.
石英晶振以及12位ADC保证高精度容量和电压监测。
The MH-C9000 will charge and analyze all current NiMH Rechargeable Batteries as well as Future NiMH Rechargeable Batteries regardless of capacity.
可以分析高容量电池。除了训练模式外,没有最大时间限制(但也存在安全隐患--在下观点)
Built -In Trickle Charge -- 10mA trickle charge rate -- using modulated pulse trickle charge.
涓流充电--10ma
The MH-C9000 will charge and analyze the New Sanyo Eneloop Low Discharge NiMH Rechargeable Batteries as well as all other Low Discharge NiMH Rechargeable Batteries.
可用于冲新的低自放电电池(其他的充电器也可以--在下注)
12V input and can be powered by an optional car adapter
12V直流输入。
100~240V AC Lightweight ( 170gr (6oz) )Worldwide switching power supply.
100~240V外接电源,170克
Rugged construction with extensive ventilation for the batteries.
结实的结构和宽裕的电池散热空间
Built-in “lift rod” to raise the charger to improve air flow below the unit.
附有可拔起支架,以利于散热
The MH-C9000 Charger can be operated in a “Basic” or in “Advanced” mode. In the Basic mode, you merely need to insert the batteries into the MHC9000 with no further key presses. The Maha PowerEx MH-C9000 charger will select the appropriate settings automatically, making it suitable for the casual users.
In 'Advanced ' mode you can actually Program the MHC9000 Battery Charger to your Charging and discharging Specifications. See the Programming Diagram below.
充电器可以工作在“基本”模式和“高级模式”。基本模式下,用户只要插入电池,充电器就自动设定相关参数对电池充电。这对一般用户特别有效。
在高级模式,用户可以设定各个充放电参数对电池进行充放电。
主要特點如下:
1. 充電電流:可在100mA至2000mA間以100mA間距個別設定,共19級距(也就是說每個槽都能分開設定)
2. 放電電流:可在100mA至1000mA間以100mA間距個別設定,共10級距(也就是說每個槽都能分開設定)
3. 支援電池容量(自動偵測/手動輸入也行,同樣也是每個槽都能分開設定): 100mA - 20,000 mA
4. 共有五種模式: 一般充電 / 更新及分析 / 活化(Break-In) / 放電 / 循環
根據網友們的評價,此款可以把那種要死不活的電池救回來..但約需要35-48小時處理.小弟剛入手,正在努力測試中...
缺点:目前唯一发现,液晶显示不能关闭,晚上真亮!可以当夜灯了。
本帖最近打赏记录:共6条打赏M币+27
风间尘 M币 +9 謝謝分享 2018-10-14
离线char123
只看该作者 1楼 发表于: 2010-01-02
本帖最近打赏记录:共7条打赏M币+36
离线gearedbyby
只看该作者 2楼 发表于: 2010-01-02
离线dongyishaonv
只看该作者 3楼 发表于: 2010-01-02
Re:8欧 0.5W喇叭能做啥?
只看该作者 4楼 发表于: 2010-01-02
离线行云流水
只看该作者 5楼 发表于: 2010-01-02
只看该作者 6楼 发表于: 2010-01-02
[ 此帖被三月里的小雨在2010-01-02 15:27重新编辑 ]
离线jmcam
只看该作者 7楼 发表于: 2010-01-02
离线被就业
只看该作者 8楼 发表于: 2010-01-02
离线stephon1988
只看该作者 9楼 发表于: 2010-01-02
