  • 19907阅读
  • 22回复
[SandForce]求助2281开卡问题 [复制链接]
离线cbass120
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2015-12-22
电脑上面的东芝msata的盘( THNSNS256GMCP SSD) 由于某次睡眠后唤醒蓝屏强制关机后,无法使用了,在bios里面可以看到盘 sandforce 200026 306A 的字样,但是用别的盘引导进入系统后在磁盘管理里面看到这个盘大小变成了33k了。 想请问一下,我这个盘是不是固件掉了呢?重新开下盘可以吗?
查询flash 得到信息如下
TOSHIBA-24nm MLC TH58TEG9DBHBAS9 64GB 16 KByte/page 4CE 4CH_8WAY
据说主控是sf2281的 可是查询不到这个flash 对应的id号啊。没有配置文件刷不了。试着用FW-UPDATE升级固件选项升级522的固件,也是失败,上个log请大神帮忙分析一下。谢谢
Starting command:[/root/soft/SF_Genesis-v1.7.0.01020130612-fc14-32bit/SF_Genesis -FW_UPDATE 0:0:0:0 "/root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.ffp" LOG="/root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/1_localhost.localdomain_DATETIMESTAMP_0.0.0.0_FW_UPDATE_RESULT.log" ]...
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Wed 12/23/2015 01:45:32] - SF_Genesis has been invoked with the following parameters:
argv[1]: -FW_UPDATE
argv[2]: 0:0:0:0
argv[3]: /root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.ffp
argv[4]: LOG=/root/mpt/FW_PPRO_5_2_2_Release.672199.release--0/1_localhost.localdomain_DATETIMESTAMP_0.0.0.0_FW_UPDATE_RESULT.log
[Wed 12/23/2015 01:45:32] - Instructing the operating system to purge any existing cached data for device: '0:0:0:0'
[Wed 12/23/2015 01:45:37] - Issuing a discovery command for device: '0:0:0:0'
[Wed 12/23/2015 01:45:44] - Discovery command completed...
[Wed 12/23/2015 01:45:44] - Waiting 5 seconds for the system to settle...
[Wed 12/23/2015 01:45:49] - Device designation string '0:0:0:0' is mapped to node '/dev/sg0'
[Wed 12/23/2015 01:45:49] - Proceeding to update the flashware on device: /dev/sg0
[Wed 12/23/2015 01:45:51] - FATAL_ERROR: Download MicroCode failed with error: (0x11000001:SF_SG_DEVICE_CHECK_CONDITION_ERROR)
Extended Error data:
ATA COMMAND : 0x0092 (146)
ATA FEATURE : 0x0003 (3)
Device Status: 0x0001 (1)
Driver Status: 0x0000 (0)
Host Status: 0x0008 (8)
Sense Data:
0 - No Sense: 114 (0x72) OK
1 - Recovered Error: 11 (0x0B) FAIL
2 - Not Ready: 0 (0x00) OK
3 - Medium Error: 0 (0x00) OK
4 - Hardware Error: 0 (0x00) OK
5 - Illegal Request: 0 (0x00) OK
6 - Unit Attention: 0 (0x00) OK
7 - Data Protect: 14 (0x0E) OK
8 - Blank Check: 9 (0x09) OK
9 - Vendor Specific: 12 (0x0C) OK
10 - Copy Aborted: 0 (0x00) OK
11 - Aborted Command: 4 (0x04) FAIL
12 - Equal Comparison: 0 (0x00) NA
13 - Volume Overflow: 0 (0x00) NA
14 - Miscompare: 0 (0x00) OK
15 - Reserved: 128 (0x80) NA
System Trace:
[ 25.377210] SELinux: initialized (dev fusectl, type fusectl), uses genfs_contexts
[ 25.431163] readahead-collector: sorting
[ 25.581558] readahead-collector: finished
[ 28.849035] ath9k: Two wiphys trying to scan at the same time
[ 28.849076] wlan0: deauthenticating from 04:8d:38:67:9c:eb by local choice (reason=3)
[ 29.051476] wlan0: authenticate with 04:8d:38:67:9c:eb (try 1)
[ 29.054362] wlan0: authenticated
[ 29.054389] wlan0: associate with 04:8d:38:67:9c:eb (try 1)
[ 29.059022] wlan0: RX AssocResp from 04:8d:38:67:9c:eb (capab=0x411 status=0 aid=7)
[ 29.059027] wlan0: associated
[ 29.066119] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 29.262354] padlock: VIA PadLock not detected.
[ 39.544311] wlan0: no IPv6 routers present
[ 165.580684] sd 0:0:0:0: [sda] Stopping disk
[ 165.580847] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 165.580856] ata1.00: failed command: STANDBY IMMEDIATE
[ 165.580870] ata1.00: cmd e0/00:00:00:00:00/00:00:00:00:00/a0 tag 0
[ 165.580873] res 51/04:00:00:00:00/00:00:00:00:00/a0 Emask 0x1 (device error)
[ 165.580880] ata1.00: status: { DRDY ERR }
[ 165.580884] ata1.00: error: { ABRT }
[ 165.580900] ata1.00: device reported invalid CHS sector 0
[ 165.580938] sd 0:0:0:0: [sda] START_STOP FAILED
[ 165.580945] sd 0:0:0:0: [sda] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 165.580954] sd 0:0:0:0: [sda] Sense Key : Aborted Command [current] [descriptor]
[ 165.580968] sd 0:0:0:0: [sda] Add. Sense: No additional sense information
[ 165.581128] ata1.00: disabled
[ 170.574742] ata1.00: hard resetting link
[ 170.878225] ata1.01: hard resetting link
[ 171.883168] ata1.01: failed to resume link (SControl 0)
[ 172.033954] ata1.00: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 172.033976] ata1.01: SATA link down (SStatus 0 SControl 0)
[ 172.034310] ata1.00: ATA-8: SandForce{200026BB}, 306ABBR0, max UDMA/133
[ 172.034314] ata1.00: 64 sectors, multi 0: LBA48 NCQ (depth 0/32)
[ 172.037231] ata1.00: configured for UDMA/133
[ 172.037242] ata1: EH complete
[ 172.037502] scsi 0:0:0:0: Direct-Access ATA SandForce{200026 306A PQ: 0 ANSI: 5
[ 172.039682] sd 0:0:0:0: [sda] 64 512-byte logical blocks: (32.7 kB/32.0 KiB)
[ 172.039689] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 172.039825] sd 0:0:0:0: [sda] Write Protect is off
[ 172.039832] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 172.039886] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 172.042135] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 172.043379] sda: unknown partition table
[ 172.046788] sd 0:0:0:0: [sda] Attached SCSI disk
. SF_Genesis can not proceed with performing the -FW_UPDATE request. Exiting...
[Wed 12/23/2015 01:45:51] - End of Genesis manufacturing log.
[Wed 12/23/2015 01:45:51] - Exiting...
[Wed 12/23/2015 01:45:51] - Overall Result for Device: ****** FAIL ******
Process exited with code 20
如有朋友能指导我修好此盘,奉上1000M币非常感谢。
[ 此帖被cbass120在2015-12-22 15:08重新编辑 ]
离线cbass120
只看该作者 1楼 发表于: 2015-12-22
只看该作者 2楼 发表于: 2015-12-22
本帖最近打赏记录:共1条打赏M币+3
离线cbass120
只看该作者 3楼 发表于: 2015-12-22
离线k1503
只看该作者 4楼 发表于: 2015-12-22
离线科冠维修
只看该作者 5楼 发表于: 2015-12-22
离线cbass120
只看该作者 6楼 发表于: 2015-12-23
离线cbass120
只看该作者 7楼 发表于: 2015-12-23
离线cbass120
只看该作者 8楼 发表于: 2015-12-24
离线hepcboy
只看该作者 9楼 发表于: 2015-12-24
