  • 2704阅读
  • 27回复
[网络]12块的路由器到手即拆 [复制链接]
离线no89756
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2016-10-01
路由器12块加邮费10块
腾达F306  博通5358  带USB
64M RAM   16M ROM
求可以刷的固件  谁有独舞TT固件麻烦分享一下啊
附上部分TTL
Decompressing...done
CFE version 5.100.138.3 based on BBP 1.0.37 for BCM947XX (32bit,SP,LE)
Build Date: 2011-05-26 10:33:50 4 (richard@aeteam.com)
Copyright (C) 2000-2008 Broadcom Corporation.
Init Arena
Init Devs.
Boot partition size = 131072(0x20000)
Found an ST compatible serial flash with 256 64KB blocks; total size 16MB
et0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 5.100.138.3
CPU type 0x19749: 300MHz
Tot mem: 65536 KBytes
CFE mem:    0x80700000 - 0x80798550 (623952)
Data:       0x8072E3A0 - 0x807315C0 (12832)
BSS:        0x807315C0 - 0x80732550 (3984)
Heap:       0x80732550 - 0x80796550 (409600)
Stack:      0x80796550 - 0x80798550 (8192)
Text:       0x80700000 - 0x8072E39C (189340)
Device eth0:  hwaddr --手动马赛克--, ipaddr 192.168.1.1, mask 255.255.255.0
        gateway not set, nameserver not set
Loader:raw Filesys:raw Dev:flash0.os File: Options:(null)
Loading: ....... 3731968 bytes read
Entry at 0x80001000
Closing network.
Starting program at 0x80001000
[42949372.960000] Linux version 2.6.22 (root@linux-qxix) (gcc version 4.2.3) #8 PREEMPT Tue May 3 16:40:00 CST 2016
[42949372.960000] CPU revision is: 00019749
[42949372.960000] Found an ST compatible serial flash with 256 64KB blocks; total size 16MB
[42949372.960000] Determined physical RAM map:
[42949372.960000]  memory: 04000000 @ 00000000 (usable)
[42949372.960000] Initrd not found or empty - disabling initrd
[42949372.960000] Zone PFN ranges:
[42949372.960000]   Normal          0 ->    16384
[42949372.960000]   HighMem     16384 ->    16384
[42949372.960000] early_node_map[1] active PFN ranges
[42949372.960000]     0:        0 ->    16384
[42949372.960000] Built 1 zonelists.  Total pages: 16384
[42949372.960000] Kernel command line: root=/dev/mtdblock3 console=ttyS0,115200 init=/sbin/preinit
[42949372.960000] Primary instruction cache 32kB, physically tagged, 4-way, linesize 32 bytes.
[42949372.960000] Primary data cache 32kB, 4-way, linesize 32 bytes.
[42949372.960000] Synthesized TLB refill handler (20 instructions).
[42949372.960000] Synthesized TLB load handler fastpath (32 instructions).
[42949372.960000] Synthesized TLB store handler fastpath (32 instructions).
[42949372.960000] Synthesized TLB modify handler fastpath (31 instructions).
[42949372.960000] PID hash table entries: 512 (order: 9, 2048 bytes)
[42949372.960000] CPU: BCM5357 rev 2 at 300 MHz
[42949372.960000] Using 150.000 MHz high precision timer.
[42949372.970000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[42949372.970000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[42949372.990000] Memory: 60268k/65536k available (2854k kernel code, 5212k reserved, 578k data, 212k init, 0k highmem)
[42949373.210000] Mount-cache hash table entries: 512
[42949373.210000] NET: Registered protocol family 16
[42949373.230000] SCSI subsystem initialized
[42949373.230000] PCI: no core
[42949373.240000] PCI: Fixing up bus 0
[42949373.250000] NET: Registered protocol family 2
[42949373.260000] Time: MIPS clocksource has been installed.
[42949373.350000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[42949373.350000] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[42949373.360000] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[42949373.370000] TCP: Hash tables configured (established 2048 bind 2048)
[42949373.370000] TCP reno registered
[42949373.410000] VFS: Disk quotas dquot_6.5.1
[42949373.410000] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[42949373.420000] squashfs: version 3.2-r2 (2007/01/15) Phillip Lougher
[42949373.430000] fuse init (API version 7.8)
[42949373.430000] io scheduler noop registered (default)
[42949373.450000] Serial: 8250/16550 driver $Revision: 1.1.1.1 $ 4 ports, IRQ sharing disabled
[42949373.460000] serial8250: ttyS0 at MMIO 0x0 (irq = 8) is a 16550A
[42949373.480000] RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
[42949373.490000] PPP generic driver version 2.4.2
[42949373.490000] PPP Deflate Compression module registered
[42949373.500000] PPP BSD Compression module registered
[42949373.510000] PPP MPPE Compression module registered
[42949373.510000] NET: Registered protocol family 24
[42949373.520000] PPPoL2TP kernel driver, V0.18.3
[42949373.520000] pflash: found no supported devices
[42949373.530000] Boot partition size = 131072(0x20000)
[42949373.530000] sflash: squash filesystem with lzma found at block 22
[42949373.540000] Creating 11 MTD partitions on "sflash":
[42949373.550000] 0x00000000-0x01000000 : "All"
[42949373.550000] 0x00000000-0x00020000 : "Bootloader"
[42949373.560000] 0x00020000-0x00ed0000 : "KernelFS"
[42949373.560000] 0x001608b0-0x00ed0000 : "rootfs"
[42949373.570000] 0x00ed0000-0x00ee0000 : "CFM_BACKUP"
[42949373.580000] 0x00ee0000-0x00f30000 : "picture"
[42949373.580000] 0x00f30000-0x00f40000 : "Policy"
[42949373.590000] 0x00f40000-0x00fc0000 : "WebFS"
[42949373.600000] 0x00fc0000-0x00fd0000 : "CFM"
[42949373.600000] 0x00fd0000-0x00ff0000 : "CFM_URL"
[42949373.610000] 0x00ff0000-0x01000000 : "nvram"
[42949373.610000] nflash: found no supported devices
[42949373.650000] nf_conntrack version 0.5.0 (512 buckets, 4096 max)
[42949373.660000] [BM CORE     ]  INFO: online ip data hash table created, size = 199
[42949373.670000] [BM CORE     ]  INFO: online_ip proc file created
[42949373.680000] Kernel:Init flow dev success.
[42949373.680000] IPv4 over IPv4 tunneling driver
[42949373.690000] ip_tables: (C) 2000-2006 Netfilter Core Team
[42949373.690000] ClusterIP Version 0.8 loaded successfully
[42949373.700000] TCP cubic registered
[42949373.700000] NET: Registered protocol family 1
[42949373.710000] NET: Registered protocol family 17
[42949373.710000] Bridge firewalling registered
[42949373.720000] 802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
[42949373.720000] All bugs added by David S. Miller <davem@redhat.com>
[42949373.740000] VFS: Mounted root (squashfs filesystem) readonly.
[42949373.750000] Freeing unused kernel memory: 212k freed
init started: BusyBox v1.13.0 (2015-09-29 21:04:26 CST
starting pid 148, tty '': '/etc_ro/init.d/rcS
[42949374.520000] Algorithmics/MIPS FPU Emulator v1.5
[ 此帖被no89756在2016-10-02 14:50重新编辑 ]
内容来自Android手机客户端
本帖最近打赏记录:共15条打赏M币+48
12
离线cketk
只看该作者 1楼 发表于: 2016-10-01
本帖最近打赏记录:共1条打赏M币+3
离线wgm468
只看该作者 2楼 发表于: 2016-10-01
离线星星点点
只看该作者 3楼 发表于: 2016-10-01
本帖最近打赏记录:共3条打赏M币+13
离线青色风机
只看该作者 4楼 发表于: 2016-10-01
离线benli
只看该作者 5楼 发表于: 2016-10-01
离线在路上795
只看该作者 6楼 发表于: 2016-10-01
离线no89756
只看该作者 7楼 发表于: 2016-10-01
回 在路上795 的帖子
离线duxingkei
只看该作者 8楼 发表于: 2016-10-01
离线xteamdxf
只看该作者 9楼 发表于: 2016-10-01
本帖最近打赏记录:共1条打赏M币+3
