  • 8215阅读
  • 6回复
[SandForce]2241开卡求助****** FAIL ******   Process exited with code 8 [复制链接]
离线天天同
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2017-03-19
Starting command:[/root/桌面/SF_Genesis-v1.5.21.20110919-fc14-32bit/SF_Genesis -PROCESS_SSD 2:0:0:0 "/mnt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp" "/mnt/FW_PPRO_5_2_2_Release.672199.release--0/Configuration_Files/28041.0.driveconfig" 12345 345  LOG="/mnt/12345_localhost.localdomain_DATETIMESTAMP_2.0.0.0_PROCESS_SSD_RESULT.log" ]...
SandForce Genesis Utility v1.5.21.20110919-fc14-32bit
SF_Core Library: v1.7.0.20110919-fc14-32bit
Copyright 2010-2011, SandForce Inc., All Rights Reserved Worldwide.
[Sun 03/19/2017 11:07:54] - SF_Genesis has been invoked with the following parameters:
                      argv[1]: -PROCESS_SSD
                      argv[2]: 2:0:0:0
                      argv[3]: /mnt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
                      argv[4]: /mnt/FW_PPRO_5_2_2_Release.672199.release--0/Configuration_Files/28041.0.driveconfig
                      argv[5]: 12345
                      argv[6]: 345
                      argv[7]: LOG=/mnt/12345_localhost.localdomain_DATETIMESTAMP_2.0.0.0_PROCESS_SSD_RESULT.log
[Sun 03/19/2017 11:07:54] - Instructing the operating system to purge any existing cached data for device: '2:0:0:0'
[Sun 03/19/2017 11:07:59] - Issuing a discovery command for device: '2:0:0:0'
[Sun 03/19/2017 11:08:04] - Discovery command completed...
[Sun 03/19/2017 11:08:04] - Waiting 5 seconds for the system to settle...
[Sun 03/19/2017 11:08:09] - Device designation string '2:0:0:0' is mapped to node '/dev/sg0'
[Sun 03/19/2017 11:08:09] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg0
    MFP Package Filename = /mnt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
      Configuration File = /mnt/FW_PPRO_5_2_2_Release.672199.release--0/Configuration_Files/28041.0.driveconfig
              Serial No. = 12345
         World Wide Name = 345
[Sun 03/19/2017 11:08:09] - Successfully received the IDENTIFY data from the drive...
SF_Internal_PackageManager::OpenExisting:
                     HeaderCRC32: -674898193,(D7C5DEEF)
     _Package.Header.HeaderCRC32: -674898193,(D7C5DEEF)
                    OverallCRC32: -517457266,(E1283A8E)
    _Package.Header.OverallCRC32: -517457266,(E1283A8E)
[Sun 03/19/2017 11:08:15] - Successfully opened the package: /mnt/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
[Sun 03/19/2017 11:08:15] - Successfully extracted *.DriveConfig file: /mnt/FW_PPRO_5_2_2_Release.672199.release--0/Configuration_Files/28041.0.driveconfig
[Sun 03/19/2017 11:08:15] - Extracted Config_ID: 1 (28041) in DriveConfig file: /mnt/FW_PPRO_5_2_2_Release.672199.release--0/Configuration_Files/28041.0.driveconfig
[Sun 03/19/2017 11:08:15] - Extracted SerialOutputControl: 0
[Sun 03/19/2017 11:08:15] - Successfully extracted Config record: 28041
[Sun 03/19/2017 11:08:15] - Successfully extracted flashware image: 28041_fw_cl_mlc_MIC_64Gb_MT29F64G08CBABBWP_1Q_2C_1D_S_PP_R01365_s512.vic
[Sun 03/19/2017 11:08:15] - Successfully extracted manufacturing image: 28041_mf_mlc_MIC_64Gb_MT29F64G08CBABBWP_1Q_2C_1D_S_PP_R01365_s512.vic
[Sun 03/19/2017 11:08:15] - Proceeding in ROM mode, download feature 1...
[Sun 03/19/2017 11:08:16] - Successfully downloaded MFB to the drive...
[Sun 03/19/2017 11:08:16] - Waiting (5 sec) for the drive to settle...
[Sun 03/19/2017 11:08:21] - Successfully received the IDENTIFY data from the drive...
[Sun 03/19/2017 11:08:21] - Firmware revision reported to be: '522ABBM0'.  This indicates MFB download was successful.
[Sun 03/19/2017 11:08:21] - Successfully enabled SMART capabilities...
[Sun 03/19/2017 11:08:22] - Successfully issued a diagnostic unlock...
[Sun 03/19/2017 11:08:22] - Performing the flash test of block 0 (0x0000)...
[Sun 03/19/2017 11:08:23] - Flash Test Results:
Flash Test Parameters:
               Block Count: 0
                Page Count: 1
                 Bus Count: 1
        Chip Enabled Count: 2
                 Die Count: 1
                Lane Count: 4
               Plane Count: 2
Results Notes:
   N1 - At least one page tested and passed with no bit errors.
   N2 - No test data available.  Test may have aborted, or failed during the testing.
   N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
   N4 - At least  one erased page tested had bit error rate greater than half the correction power.
   N5 - Walking zeros test failed.
   N6 - Walking ones test failed.
   N7 - Block contained factory bad block markings and testing was skipped.
   N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
   N9 - Block in plane 0 was marked as a factory bad block.
  N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
  N11 - Block in plane 1 was marked as a factory bad block.
| Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |
| 0    | 0    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 3    | 0x0001 | N1                                         |    PASS |
  Total Number of test results: 8
            Number of failures: 0
         Number of Passed with warnings: 0
      No. Passed without warnings: 8
[Sun 03/19/2017 11:08:24] - Performing the FORMAT Command with the following parameters:
         MemoryWearCycleCapability = 0
              CurrentPE_CycleCount = 0
                     LifeInSeconds = 0
                   LogicalCapacity = 125045424
                        SectorSize = 512
             SectorAlignmentOffset = 0
                  ExpectedMemoryID = 25644 (0x642C)
                   ExpectedNumDies = 0
               SerialOutputControl = 0
                           Time[8] = 0x0000000000000000
            MiscFlag_Erase_R_Block = 0
     MiscFlag_PanicHandlingEnabled = 0
        MiscFlag_PanicOnSATA_Error = 0
  MiscFlag_WriteThrottlingTestMode = 0
      MiscFlag_DisableUserBandECCX = 1
                        L_PageSize = 0
                        E_PageSize = 0
              ErrorCorrectionPower = 0
      ConfigDeviceReadDisturbCount = 0
   ConfigDeviceReadDisturbCountLow = 0
[Sun 03/19/2017 11:08:36] - FATAL_ERROR: Could not perform the FORMAT() operation on the drive... (0x0000C048:SF_SCT (C048h): Root Creation Failed (MFB format))
[Sun 03/19/2017 11:08:36] - End of Genesis manufacturing log.
[Sun 03/19/2017 11:08:36] - Exiting...
[Sun 03/19/2017 11:08:36] - Overall Result for Device: /dev/sg0 ****** FAIL ******
离线perter
只看该作者 1楼 发表于: 2017-03-20
Re
离线天天同
只看该作者 2楼 发表于: 2017-03-20
回 perter 的帖子
离线perter
只看该作者 3楼 发表于: 2017-03-20
回 天天同 的帖子
离线天天同
只看该作者 4楼 发表于: 2017-03-20
回 perter 的帖子
离线wangsky8888
只看该作者 5楼 发表于: 2017-06-04
离线taotaohua
只看该作者 6楼 发表于: 2019-11-03
回 天天同 的帖子
