  • 1382阅读
  • 7回复
TB6560驱动板 [复制链接]
离线xxj1975
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2017-03-20
哪位大神有TB6560驱动板的原理图和元件清单就是下图
离线fan19880826
只看该作者 1楼 发表于: 2017-05-03
  元件清单就帮不了你了。
离线syp0625
只看该作者 2楼 发表于: 2017-06-22
买几套也不贵啊
离线mmfinger
只看该作者 3楼 发表于: 2017-06-23
做这个就不如直接做LiniStepper了,网址:http://www.piclist.com/techref/io/stepper/linistep/index.htm
源程序也有,用三极管驱动,效果好,开源的。
离线mmfinger
只看该作者 4楼 发表于: 2017-06-23
源程序如下(直接复制过来的):
;  LiniStepper v2
;  PIC 16F84 / 16F628 / 16F628A code (updated 628A June 2007)
;  Copyright Aug 2002 - Nov 2009 - Roman Black   http://www.romanblack.com
;  PIC assembler code for the LiniStepper stepper motor driver board.
;  200/400/1200/3600 steps
;  v2.0    New version 2.0; 2nd Nov 2009.
;        * modified v1 source to work with new Lini v2 PCB.
;        * STEP and DIR are the same, but POWER is now "ENABLE" (active LOW)
;          (so the POWER pin function is inverted in Lini v2)
;  v2.1   Updated 16th Nov 2010.
;        Now incorporates update suggested by Brian D Freeman; improves
;         performance by skipping the current calculation on the hi-lo
;         transition of the step input.
;  (set mplab TABS to 5 for best viewing this .asm file)
; mplab settings
    ERRORLEVEL -224        ; suppress annoying message because of option/tris
    ERRORLEVEL -302        ; suppress message because of bank select in setup ports
    LIST b=5, n=97, t=ON, st=OFF        ;
    ; absolute listing tabs=5, lines=97, trim long lines=ON, symbol table=OFF
; processor defined
    ;include <p16f84A.inc>
    ;include <p16f628.inc>
    include <p16f628A.inc>
; processor config
    IFDEF __16F84A
        __CONFIG   _CP_OFF & _WDT_OFF & _PWRTE_ON & _HS_OSC
    ENDIF
    IFDEF __16F628
        __CONFIG   _CP_OFF & _WDT_OFF & _PWRTE_ON & _HS_OSC & _MCLRE_ON & _BODEN_OFF & _LVP_OFF
    ENDIF
    IFDEF __16F628A
    ENDIF
; Variables here
    IFDEF __16F84A
        #define RAM_START    0x0C
        #define RAM_END    RAM_START+d'68'         ; 16F84 has only 68 ram
    ENDIF
    IFDEF __16F628
        #define RAM_START    0x20
        #define RAM_END    RAM_START+d'96'         ; F628 has 96 ram
    ENDIF
    IFDEF __16F628A
        #define RAM_END    RAM_START+d'96'         ; F628A has 96 ram
    ENDIF
    CBLOCK     RAM_START
        status_temp        ; used for int servicing
        w_temp            ; used for int servicing
        step                ; (0-71) ustep position!
        steptemp            ; for calcs
        phase            ; stores the 4 motor phase pins 0000xxxx
        current1            ; for current tween pwm
        current2            ; for current tween pwm
        inputs            ; stores new input pins
        inputs_last        ; stores last states of input pins
    ENDC
    ; PIC input pins for porta
    #define     STEP            0        ; / = move 1 step, \=do nothing
    #define     DIR            1        ; lo= cw,  hi=ccw
    #define     POWER        2        ; lo=full power, hi=half power
            ; (Note! POWER pin was inverted for v2 !!!)
    ; Custom instructions!
    #define    skpwne        skpnz            ; after subxx, uses zero
    #define    skpweq        skpz                ; after subxx, uses zero
    #define    skpwle        skpc                ; after subxx, uses carry
    #define    skpwgt        skpnc            ; after subxx, uses carry
; CODE GOES HERE
    org 0x0000             ; Set program memory base at reset vector 0x00
reset
    goto main                ;
; INTERRUPT vector here
    org 0x0004             ; interrupt routine must start here
int_routine
                        ; first we preserve w and status register
    movwf w_temp              ; save off current W register contents
    movf    STATUS,w              ; move status register into W register
    movwf status_temp           ; save off contents of STATUS register
                        ; we get here every 256 timer0 ticks  3900Hz
                        ; int body code here if you want
                        ; finally we restore w and status registers and
                        ; clear TMRO int flag now we are finished.
int_exit
    bcf INTCON,T0IF        ; reset the tmr0 interrupt flag
    movf status_temp,w         ; retrieve copy of STATUS register
    movwf STATUS                ; restore pre-isr STATUS register contents
    swapf w_temp,f
    swapf w_temp,w              ; restore pre-isr W register contents
    retfie                ; return from interrupt
; MOVE MOTOR            sets 8 portb output pins to control motor
; NOTE!! var step is used for sequencing the 0-71 steps
; uses tables! so keep it first in the code and set PCLATH to page 0
move_motor                ; goto label
    ; this code controls the phase sequencing and current
    ; settings for the motor.
    ; there are always 72 steps (0-71)
    ; we can split the main table into 2 halves, each have identical
    ; current sequencing. That is only 12 entries for hardware current.
    ; Then can x3 the table to get 36 table entries which cover all 72 steps.
    ; the 36 entries jump to 36 code pieces, which set the current values
    ; for the 2 possible tween steps... We need 2 current values, one
    ; for the x2 value and one for the x1 value.
    ; PHASE SEQUENCING (switch the 4 coils)
    ; there are 4 possible combinations for the phase switching:
    ; each have 18 steps, total 72 steps:
    ;    A+ B+    range 0        step 0-17
    ;    A- B+    range 1        18-35
    ;    A- B-    range 2        36-53
    ;    A+ B-    range 3        54-71
                        ; find which of the 4 ranges we are in
    movf step,w            ; get step
    movwf steptemp            ; store as working temp
    movf steptemp,w        ;
    sublw d'35'            ; sub to test
    skpwle                ;
    goto half_hi            ; wgt, steptemp is 36-71 (upper half)
half_low                    ; wle, steptemp is 0-35
    movf steptemp,w        ;
    sublw d'17'            ; sub to test
    skpwle                ;
    goto range1            ; wgt
range0                    ; wle
    movlw b'00000101'        ; 0101 = A+ B+
    goto phase_done        ;
range1
    movlw b'00001001'        ; 1001 = A- B+
    goto phase_done        ;
half_hi                    ; steptemp is 36-71
                        ; NOTE! must subtract 36 from steptemp, so it
                        ; will become 0-35 and ok with table later!
    movlw d'36'            ; subtract 36 from steptemp,
    subwf steptemp,f        ; (now steptemp is 0-35)
                        ; now find the range
    movf steptemp,w        ;
    skpwle                ;
    goto range3            ; wgt
range2                    ; wle
    movlw b'00001010'        ; 1010 = A- B-
    goto phase_done        ;
range3
    movlw b'00000110'        ; 0110 = A+ B-
phase_done                ; note! steptemp is always 0-35 by here
    movwf phase            ; store phase values
    ; at this point we have the phasing done and stored as the last
    ; 4 bits in var phase; 0000xxxx
    ; now we have 36 possible current combinations, which we can do
    ; by separate code fragments, from a jump table.
    ; as we have 2 power modes; full and low power, we
    ; need 2 tables.
    btfsc inputs,POWER        ; select table to use
    goto table_lowpower        ;
    ; HIGH POWER TABLE
table_highpower            ;
    movf steptemp,w        ; add steptemp to the PCL
    addwf PCL,f            ;
                        ; here are the 36 possible values;
    goto st00                ; * (hardware 6th steps)
    goto st01                ;   (pwm tween steps)
    goto st02                ;   (pwm tween steps)
    goto st03                ; *
    goto st04                ;
    goto st05                ;
    goto st06                ; *
    goto st07                ;
    goto st08                ;
    goto st09                ; *
    goto st10                ;
    goto st11                ;
    goto st12                ; *
    goto st13                ;
    goto st14                ;
    goto st15                ; *
    goto st16                ;
    goto st17                ;
    goto st18                ; *
    goto st19                ;
    goto st20                ;
    goto st21                ; *
    goto st22                ;
    goto st23                ;
    goto st24                ; *
    goto st25                ;
    goto st26                ;
    goto st27                ; *
    goto st28                ;
    goto st29                ;
    goto st30                ; *
    goto st31                ;
    goto st32                ;
    goto st33                ; *
    goto st34                ;
    goto st35                ;
    ; LOW POWER TABLE
    ; as low power mode is for wait periods we don't need to
    ; maintain the full step precision and can wait on the
    ; half-step (400 steps/rev). This means much easier code tables.
    ; The nature of the board electronics is not really suited
    ; for LOW power microstepping, but it could be programmed here
    ; if needed.
    ; NOTE!! uses my hi-torque half stepping, not normal half step.
    ;  doing half stepping with the 55,25 current values gives;
    ; 55+25 = 80
    ; max current 100+100 = 200
    ; typical (high) current 100+50 = 150
    ; so low power is about 1/2 the current of high power mode,
    ; giving about 1/4 the motor heating and half the driver heating.
    ; for now it uses only half-steps or 8 separate current modes.
    ; we only have to use 4 actual current modes as
    ; the table is doubled like the table_highpower is.
    ; NOTE!! I have left the table full sized so it can be modified
    ; to 1200 or 3600 steps if needed.
table_lowpower                ;
    addwf PCL,f            ;
                        ; A+ B+ (A- B-)
    goto lp00                ;
    goto lp00                ;
    goto lp00                ;
    goto lp00                ;
    goto lp00                ;    55,25 (100,45) current low (high)
    goto lp00                ;
    goto lp00                ;
    goto lp00                ;
    goto lp00                ;
    goto lp09                ;
    goto lp09                ;
    goto lp09                ;
    goto lp09                ;
    goto lp09                ;    25,55 (45,100)
    goto lp09                ;
    goto lp09                ;
    goto lp09                ;
    goto lp09                ;
                        ; A- B+ (A+ B-)
    goto lp18                ;
    goto lp18                ;
    goto lp18                ;
    goto lp18                ;
    goto lp18                ;    25,55 (45,100)
    goto lp18                ;
    goto lp18                ;
    goto lp18                ;
    goto lp18                ;
    goto lp27                ;
    goto lp27                ;
    goto lp27                ;
    goto lp27                ;
    goto lp27                ;    55,25 (100,45)
    goto lp27                ;
    goto lp27                ;
    goto lp27                ;
    goto lp27                ;
    ; all tables done, no more tables after this point!
    ; next are the 36 code fragments for the high power table.
    ; CURRENT INFO.
    ; hardware requires that we send the entire 8 bits to the motor
    ; at one time, to keep pwm fast.
    ; ----xxxx,  where xxxx is the coils on/off phasing (done)
    ; xxxx----,  where xxxx is the current settings for the A and B phases;
    ; xx------,  where xx is current for A phase
    ; --xx----,  where xx is current for B phase
    ; hardware currents for 6th stepping have 4 possible values;
    ; 00  =  0% current
    ; 01  =  25% current
    ; 10  =  55% current
    ; 11  =  100% current
    ; PWM INFO.
    ; hardware gives us 6th steps, or 1200 steps/rev.
    ; to get 3600 steps/rev we need TWO more
    ; "tween" steps between every proper hardware 6th step.
    ; to do this we set 2 currents, current1 and current2.
    ; then we do FAST pwm, with 2 time units at current2,
    ; and 1 time unit at current1.
    ; this gives a current which is between the two currents,
    ; proportionally closer to current2. (2/3 obviously)
    ; this gives the ability to get 2 evenly spaced "tween" currents
    ; between our hardware 6th step currents, and go from 1200 to 3600.
    ; the next 36 code fragments set the 2 currents desired, then
    ; we goto a fast-pwm loop (same loop used for all currents)
    ; which modulates between the 2 currents and gives final
    ; output current.
st00                        ; (6th step)
    movf phase,w            ; get coil phasing (is 0000xxxx)
    iorlw b'11000000'        ; set currents; 100,0
    movwf current2            ;
    movwf current1            ;
    goto pwm                ;
st01                        ; (tween step)
    iorlw b'11000000'        ; set 100,0
    movwf current2            ;
    movf phase,w            ;
    iorlw b'11010000'        ; set 100,25
    movwf current1            ;
    goto pwm                ;
st02                        ; (tween step)
    movwf current2            ;
    movf phase,w            ;
    movwf current1            ;
    goto pwm                ;
st03                        ; (6th step)
    movf phase,w            ;
    movwf current2            ;
    movwf current1            ;
    goto pwm                ;
st04                        ;
    movf phase,w            ;
    movwf current2            ;
    movf phase,w            ;
    iorlw b'11100000'        ; set 100,55
    movwf current1            ;
    goto pwm                ;
st05                        ;
    movf phase,w            ;
    movwf current2            ;
    movf phase,w            ;
    movwf current1            ;
    goto pwm                ;
st06                        ; (6th step)
    movf phase,w            ;
    movwf current2            ;
    movwf current1            ;
    goto pwm                ;
st07                        ;
    movf phase,w            ;
    movwf current2            ;
    movf phase,w            ;
    iorlw b'11110000'        ; set 100,100
    movwf current1            ;
    goto pwm                ;
st08                        ;
    movf phase,w            ;
    movwf current2            ;
    movf phase,w            ;
    movwf current1            ;
    goto pwm                ;
st09                        ; (6th step)
    movf phase,w            ;
    movwf current2            ;
    movwf current1            ;
    goto pwm                ;
st10                        ;
    movf phase,w            ;
    movwf current2            ;
    movf phase,w            ;
    iorlw b'10110000'        ; set 55,100
    movwf current1            ;
    goto pwm                ;
st11                        ;
    movf phase,w            ;
    movwf current2            ;
    movf phase,w            ;
    movwf current1            ;
    goto pwm                ;
st12                        ; (6th step)
    movf phase,w            ;
    movwf current2            ;
    movwf current1            ;
    goto pwm                ;
st13                        ;
    movf phase,w            ;
    movwf current2            ;
    movf phase,w            ;
    iorlw b'01110000'        ; set 25,100
    movwf current1            ;
    goto pwm                ;
st14                        ;
    movf phase,w            ;
    movwf current2            ;
    movf phase,w            ;
    movwf current1            ;
    goto pwm                ;
st15                        ; (6th step)
    movf phase,w            ;
    movwf current2            ;
    movwf current1            ;
    goto pwm                ;
st16                        ;
    movf phase,w            ;
    movwf current2            ;
    movf phase,w            ;
    iorlw b'00110000'        ; set 0,100
    movwf current1            ;
    goto pwm                ;
st17                        ;
    movf phase,w            ;
    movwf current2            ;
    movf phase,w            ;
    movwf current1            ;
    goto pwm                ;
st18                        ; (6th step)
    movf phase,w            ;
    movwf current2            ;
    movwf current1            ;
    goto pwm                ;
st19                        ;
    movf phase,w            ;
    movwf current2            ;
    movf phase,w            ;
    movwf current1            ;
    goto pwm                ;
st20                        ;
    movf phase,w            ;
    movwf current2            ;
    movf phase,w            ;
    movwf current1            ;
    goto pwm                ;
st21                        ; (6th step)
    movf phase,w            ;
    movwf current2            ;
    movwf current1            ;
    goto pwm                ;
st22                        ;
    movf phase,w            ;
    movwf current2            ;
    movf phase,w            ;
    movwf current1            ;
    goto pwm                ;
st23                        ;
    movf phase,w            ;
    movwf current2            ;
    movf phase,w            ;
    movwf current1            ;
    goto pwm                ;
st24                        ; (6th step)
    movf phase,w            ;
    movwf current2            ;
    movwf current1            ;
    goto pwm                ;
st25                        ;
    movf phase,w            ;
    movwf current2            ;
    movf phase,w            ;
    movwf current1            ;
    goto pwm                ;
st26                        ;
    movf phase,w            ;
    movwf current2            ;
    movf phase,w            ;
    movwf current1            ;
    goto pwm                ;
st27                        ; (6th step)
    movf phase,w            ;
    movwf current2            ;
    movwf current1            ;
    goto pwm                ;
st28                        ;
    movf phase,w            ;
    movwf current2            ;
    movf phase,w            ;
    movwf current1            ;
    goto pwm                ;
st29                        ;
    movf phase,w            ;
    movwf current2            ;
    movf phase,w            ;
    movwf current1            ;
    goto pwm                ;
st30                        ; (6th step)
    movf phase,w            ;
    movwf current2            ;
    movwf current1            ;
    goto pwm                ;
st31                        ;
    movf phase,w            ;
    movwf current2            ;
    movf phase,w            ;
    movwf current1            ;
    goto pwm                ;
st32                        ;
    movf phase,w            ;
    movwf current2            ;
    movf phase,w            ;
    movwf current1            ;
    goto pwm                ;
st33                        ; (6th step)
    movf phase,w            ;
    movwf current2            ;
    movwf current1            ;
    goto pwm                ;
st34                        ;
    movf phase,w            ;
    movwf current2            ;
    movf phase,w            ;
    movwf current1            ;
    goto pwm                ;
st35                        ;
    movf phase,w            ;
    movwf current2            ;
    movf phase,w            ;
    movwf current1            ;
    goto pwm                ;
                        ; high power table done!
    ; next are the 4 code fragments for the low power table.
    ; (no PWM is used)
lp00                        ;
    movf phase,w            ;
    iorlw b'10010000'        ; set 55,25
    movwf current2            ;
    movwf current1            ;
    goto pwm                ;
lp09                        ;
    movf phase,w            ;
    iorlw b'01100000'        ; set 25,55
    movwf current2            ;
    movwf current1            ;
    goto pwm                ;
lp18                        ;
    movf phase,w            ;
    movwf current2            ;
    movwf current1            ;
    goto pwm                ;
lp27                        ;
    movf phase,w            ;
    movwf current2            ;
    movwf current1            ;
    goto pwm                ;
;  Main
main                        ; goto label
                        ; do initial setup for ports and ints and stuff
    call setup            ; this is our only proper call...
                        ; it is called only once, and does not really need
                        ; to be a function.
    ; main operating loop is here.
    goto move_motor        ; will set the motor to step 0,
                        ; and loop permanently from there
    goto main                ; safe loop, should never get here anyway.
; NEW INPUTS   input change was detected
new_inputs                ; goto tag
    ; when we enter here:
    ; * one or more PORTA inputs have just changed
    ; * inputs_last    contains last PORTA inputs values
    ; * inputs        contains new PORTA inputs values
    ; must first detect which input pins changed.
    ; ---x----    RA4    * mode bit1       ( 00=200 step    01=400 step
    ; ----x---    RA3    * mode bit0        10=1200 step    11=3600 step )
    ; -----x--    RA2    * power  (Lini v2; now 0 = full power!)
    ; ------x-    RA1    * direction
    ; -------x    RA0    * step
    ; if step went hi, we move the step (step++ or step--)
    ; if step went low, ignore
    ; ignore change in direction pin
    ; ignore change in power pin
    ; ignore change in mode pins
    ; (all pins besides step are handled automatically in move_motor)
    movf inputs,w            ; xor to compare new inputs with last values
    xorwf inputs_last,f        ; now inputs_last has the diff.
    btfss inputs_last,STEP    ; test if step input changed
    goto ni_end            ;
                        ; step input changed!
    btfsc inputs,STEP        ; test if change was lo-hi or hi-lo
    goto trans_hi            ; lo-hi, so process a step!
                        ; hi-lo, so ignore this transition
    bcf inputs_last,STEP    ; record new state of step pin
    goto pwm                ; fast exit back to pwm()
    ; step input changed lo-hi!
    ; now must make a step forward or back, based
    ; on the state of the dir pin.
    ; here it gets complex as we have 4 operating modes,
    ; determined by the state of the 2 input pins RA4 and RA3;
    ; ---00---    200 steps
    ; ---01---    400 steps
    ; ---10---    1200 steps
    ; ---11---    3600 steps
    ; there are 4 separate code systems to handle stepping
    ; in the 4 modes;
trans_hi
                        ; find which of the 4 modes we are in
    btfss inputs,4            ; test hi bit
    goto mode_lo            ;
mode_hi                    ; must be 1200 or 3600
    btfss inputs,3            ; test lo bit
    goto mode_1200            ;
mode_3600                    ; 3600 mode (72/1)
                        ; each step is 1
    btfss inputs,DIR        ; test direction input
    goto m36_up            ;
m36_down
    decf step,f            ; step--
    btfss step,7            ; test for roll under <0
    goto ni_end            ; ok
                        ; rolled under!
    movlw d'71'            ; force to top step (72-1)
    movwf step            ;
    goto ni_end            ;
m36_up
    incf step,f            ; step++
    movf step,w            ; test for roll over >71
    sublw d'71'            ; sub to test
    skpwle                ;
    clrf step                ; wgt, rolled over so force to step 0
    goto ni_end            ;
mode_1200                    ; 1200 mode (72/3)
                        ; each step is mod 3 (0,3,6,9,12 - 66, 69 etc)
    goto m12_up            ;
m12_down
    movlw d'3'            ; amount to subtract
    subwf step,f            ; step-=3
    goto ni_end            ; ok
                        ; rolled under!
    movlw d'69'            ; force to top step (72-3)
    movwf step            ;
    goto ni_end            ;
m12_up
    movlw d'3'            ; amount to add
    addwf step,f            ; step+=3
    movf step,w            ; test for roll over >69
    sublw d'69'            ; sub to test
    skpwle                ;
    goto ni_end            ;
mode_lo                    ; must be 200 or 400
    goto mode_200            ;
mode_400                    ; 400 mode (72/9)
                        ; note! we do special half stepping here.
                        ; there are ONLY 8 valid steps:
                        ; 4, 13, 22, 31, 40, 49, 58, 67
                        ; these steps give 100,45 and 35,100 combos, good
                        ; enough for now. (should average 100,41)
    goto m4_up            ;
m4_down
    movlw d'9'            ; amount to subtract
    subwf step,f            ; step-=9
    goto ni_end            ; ok
                        ; rolled under!
    movlw d'67'            ; force to top (full) step
    movwf step            ;
    goto ni_end            ;
m4_up
    movlw d'9'            ; amount to add
    addwf step,f            ; step+=9
    sublw d'67'            ; sub to test
    skpwgt                ;
    goto ni_end            ; wle, is ok
    movlw d'4'            ; wgt, rolled over so force to bottom step 5
    movwf step            ;
    goto ni_end            ;
mode_200                    ; 200 mode (72/18)
                        ; NOTE!! this has special needs as we can't use
                        ; step 0, we need to stay on the "2 steps on" steps.
                        ; there are ONLY 4 valid steps;  9, 27, 45, 63
    goto m2_up            ;
m2_down
    movlw d'18'            ; amount to subtract
    subwf step,f            ; step-=18
    goto ni_end            ; ok
                        ; rolled under!
    movlw d'63'            ; force to top (full) step (72-(18/2))
    movwf step            ;
    goto ni_end            ;
m2_up
    movlw d'18'            ; amount to add
    addwf step,f            ; step+=18
    sublw d'63'            ; sub to test
    skpwgt                ;
    movlw d'9'            ; wgt, rolled over so force to bottom step 9
    movwf step            ;
    goto ni_end            ;
ni_end
    movf inputs,w            ; save a copy of the inputs
    movwf inputs_last        ;
    goto move_motor        ; go and make it all happen
; PWM        is the fast pwm loop
; NOTE!! we enter the code in the middle of the loop!
    ; the 2 target currents were set in the move_motor code.
    ; what this function does is spend 2 time units at current2,
    ; actual is 8 clocks at current2
    ; and 4 clocks at current 1
    ; total 12 cycles, so 333 kHz with 16MHz resonator.
    ; this gives an average pwm current of 2/3 the way between
    ; current2 and current1.
    ; the routine is kept short to keep pwm frequency high, so it
    ; is easy to smooth in hardware by the ramping caps.
    ; IMPORTANT! is timed by clock cycles, don't change this code!
    ; it also checks for any change in input pins here
    ; the 8/4 code seen here was supplied by Eric Bohlman (thanks!)
pwm_loop
                        ; first output current1 to motor
    movf current1,w        ; get currents and phase switching
    movwf PORTB            ; send to motor!
    nop                    ; timing delay
    nop                    ;
                        ; (4 cycles)
pwm                        ; main entry!
                        ; better to enter at current2 for motor power.
                        ; now output current2
    movf current2,w        ;
    nop                    ; safe wait 250nS
                        ; now test input pins
    movf PORTA,w            ; get pin values from port
    xorwf inputs_last,w        ; xor to compare new inputs with last values
    skpnz
    goto pwm_loop            ; z, inputs not changed, so keep looping
                        ; (8 cycles)
                        ; nz, one or more input pins have changed!
    xorwf inputs_last,w        ; restore xored value back to the orig inputs value
    movwf inputs            ;
    goto new_inputs        ;
;  SETUP   sets port directions and interrupt stuff etc,
; NOTE!! is the only proper funtion, is done before other activity
setup                    ; routine tag
    ; Note! there are added bits for the 16F628!
    ; here we set up peripherals and port directions.
    ; this will need to be changed for different PICs.
                        ; OPTION setup
    movlw b'10000010'        ;
        ;  x-------        ; 7, 0=enable, 1=disable, portb pullups
        ;  -x------        ; 6, 1=/, int edge select bit
        ;  --x-----        ; 5, timer0 source, 0=internal clock, 1=ext pin.
        ;  ---x----        ; 4, timer0 ext edge, 1=\
        ;  ----x---        ; 3, prescaler assign, 1=wdt, 0=timer0
        ;  -----x--        ; 2,1,0, timer0 prescaler rate select
        ;  ------x-        ;   000=2, 001=4, 010=8, 011=16, etc.
        ;  -------x        ;
    banksel OPTION_REG        ; go proper reg bank
    movwf OPTION_REG        ; load data into OPTION_REG
    banksel 0                ;
    ; note! check for 16F628 (and A) and do extra setup for it.
    IFDEF  __16F628
        banksel VRCON        ; do bank 1 stuff
        clrf VRCON        ; disable Vref
        clrf PIE1            ; disable pi etc
        banksel 0            ;
        clrf T1CON        ; disable timer1
        clrf T2CON        ; disable timer2
        clrf CCP1CON        ; disable CCP module
        movlw b'00000111'    ; disable comparators
        movwf CMCON        ;
    ENDIF
    IFDEF  __16F628A
        banksel 0            ;
        movwf CMCON        ;
    ENDIF
                        ; PORTB pins direction setup
                        ; 1=input, 0=output
    clrf PORTB            ;
    movlw b'00000000'        ; all 8 portb are outputs
    banksel TRISB            ; go proper reg bank
    movwf TRISB            ; send mask to portb
    banksel 0                ;
                        ; PORTA pins direction setup
                        ; 1=input, 0=output
    clrf PORTA            ;
                        ; NOTE!! all 5 PORTA pins are inputs
    movlw b'00011111'        ;
        ;  ---x----        ; RA4
        ;  ----x---        ; RA3
        ;  -----x--        ; RA2
        ;  ------x-        ; RA1
        ;  -------x        ; RA0
    banksel TRISA            ; go proper reg bank
    movwf TRISA            ; send mask to porta
    banksel 0                ;
    movlw 0x00            ; set up PCLATH for all jump tables on page 0
    movwf PCLATH            ; (all tables are in move_motor)
                        ; CLEAR RAM! for lower bank
    movlw RAM_START        ; first byte of ram
    movwf FSR                ; load pointer
ram_clear_loop
    clrf INDF                ; clear the ram we pointed to
    incf FSR,f            ; inc pointer to next ram byte
    movf FSR,w            ; get copy of pointer to w
    sublw RAM_END            ; test if PAST the last byte now
    skpweq                ;
    goto ram_clear_loop        ;
                        ; here we can set the user variables and output pins
    movlw 0x00            ; for step 0 of 0-71
    movwf step            ; loaded ready for jump table
    movf PORTA,w            ; get initial value for inputs
    movwf inputs            ;
    movwf inputs_last        ;
                        ; set up INTCON register last
    movlw b'00000000'        ; set the bit value
        ;  x-------        ; bit7     GIE global int enable, 1=enabled
        ;  -x------        ; bit6    EE write complete enable, 1=en
        ;  --x-----        ; bit5     TMR0 overflow int enable, 1=en
        ;  ---x----        ; bit4     RB0/INT enable, 1=en
        ;  ----x---        ; bit3    RB port change int enable, 1=en
        ;  -----x--        ; bit2    TMR0 int flag bit, 1=did overflow and get int
        ;  ------x-        ; bit1    RB0/INT flag bit, 1=did get int
        ;  -------x        ; bit0    RB port int flag bit, 1=did get int
    movwf INTCON            ; put in INTCON register
    return                ;
    ; this code is only to display 1k of the memory usage chart
    ; in the absolute listing!
    ; page 0 256 byte block--------------------
    ;org 0x40-2
    ;nop
    ;org 0x80-1
    ;nop
    ;org 0xC0-1
    ;nop
    ;org 0x100-1
    ;nop
    ; page 1 256 byte block--------------------
    ;org 0x140-2
    ;nop
    ;org 0x180-1
    ;nop
    ;org 0x1C0-1
    ;nop
    ;org 0x200-1
    ;nop
    ; page 2 256 byte block--------------------
    org 0x240-2
    nop
    org 0x280-1
    nop
    org 0x2C0-1
    nop
    org 0x300-1
    nop
    ; page 3 256 byte block--------------------
    org 0x340-2
    nop
    org 0x380-1
    nop
    org 0x3C0-1
    nop
    org 0x400-1
    nop
    IFDEF __16F628A
        ; page 4 256 byte block--------------------
        org 0x440-2
        nop
        org 0x480-1
        nop
        org 0x4C0-1
        nop
        org 0x500-1
        nop
        ; page 5 256 byte block--------------------
        org 0x540-2
        nop
        org 0x580-1
        nop
        org 0x5C0-1
        nop
        org 0x600-1
        nop
        ; page 6 256 byte block--------------------
        org 0x640-2
        nop
        org 0x680-1
        nop
        org 0x6C0-1
        nop
        org 0x700-1
        nop
        ; page 7 256 byte block--------------------
        org 0x740-2
        nop
        org 0x780-1
        nop
        org 0x7C0-1
        nop
        org 0x800-1
        nop
    ENDIF
    end
    ; NOTE!! example! below is the original (non-pwm) table for the
    ; 24x hardware 6th steps.
    ; this will be useful to code a minimum-rom microstepper
    ; if you don't need 3600 and can make do with 1200 steps.
    ; same system as the main code;
    ; ----xxxx    are the phase sequencing
    ; xxxx----    are the current values
    ; (this code table has been used and tested!)
    ; COMMENTED OUT!
        ;movlw b'11000101'        ; 0,        100,0     A+ B+    00=0        01=25
        ;movlw b'11010101'        ; 1,        100,25    A+ B+    10=55    11=100
        ;movlw b'11100101'        ; 2,     100,55     A+ B+
        ;movlw b'11110101'        ; 3,     100,100    A+ B+
        ;movlw b'10110101'        ; 4,     55,100    A+ B+
        ;movlw b'01110101'        ; 5,     25,100    A+ B+
        ;movlw b'00111001'        ; 6,     0,100    A- B+
        ;movlw b'01111001'        ; 7,     25,100    A- B+
        ;movlw b'10111001'        ; 8,     55,100    A- B+
        ;movlw b'11111001'        ; 9,     100,100    A- B+
        ;movlw b'11101001'        ; 10,     100,55    A- B+
        ;movlw b'11011001'        ; 11,     100,25    A- B+
        ;movlw b'11001010'        ; 12,     100,0    A- B-
        ;movlw b'11011010'        ; 13,     100,25    A- B-
        ;movlw b'11101010'        ; 14,     100,55    A- B-
        ;movlw b'11111010'        ; 15,     100,100    A- B-
        ;movlw b'10111010'        ; 16,     55,100    A- B-
        ;movlw b'01111010'        ; 17,     25,100    A- B-
        ;movlw b'00110110'        ; 18,     0,100    A+ B-
        ;movlw b'01110110'        ; 19,     25,100    A+ B-
        ;movlw b'10110110'        ; 20,     55,100    A+ B-
        ;movlw b'11110110'        ; 21,     100,100    A+ B-
        ;movlw b'11100110'        ; 22,     100,55    A+ B-
        ;movlw b'11010110'        ; 23,     100,25    A+ B-
    EXAMPLE! full table example here, 0-71 steps showing every step...
    0    100,0     A+ B+
    1     100,8   (pwm tween)
    2     100,17  (pwm tween)
    3    100,25    A+ B+
    4     100,35  (pwm tween)
    5     100,45  (pwm tween)
    6    100,55     A+ B+
    7     100,70  (pwm tween)
    8     100,85  (pwm tween)
    9    100,100    A+ B+    (rest of table is same, tweens not shown)
    10
    11
    12    55,100    A+ B+
    13
    14
    15    25,100    A+ B+
    16
    17
    18    0,100    A- B+
    19
    20
    21    25,100    A- B+
    22
    23
    24    55,100    A- B+
    25
    26
    27    100,100    A- B+
    28
    29
    30    100,55    A- B+
    31
    32
    33    100,25    A- B+
    34
    35
    36    100,0    A- B-
    37
    38
    39    100,25    A- B-
    40
    41
    42    100,55    A- B-
    43
    44
    45    100,100    A- B-
    46
    47
    48    55,100    A- B-
    49
    50
    51    25,100    A- B-
    52
    53
    54    0,100    A+ B-
    55
    56
    57    25,100    A+ B-
    58
    59
    60    55,100    A+ B-
    61
    62
    63    100,100    A+ B-
    64
    65
    66    100,55    A+ B-
    67
    68
    69    100,25    A+ B-
    70
    71
离线cl39048025
只看该作者 5楼 发表于: 2017-06-26
这个玩意干嘛用的?
离线iofree
只看该作者 6楼 发表于: 2017-06-28
回 mmfinger 的帖子
mmfinger:做这个就不如直接做LiniStepper了,网址:http://www.piclist.com/techref/io/stepper/linistep/index.htm
[图片]
[图片]
源程序也有,用三极管驱动,效果好,开源的。 (2017-06-23 22:49) 回 mmfinger 的帖子
这个好像只能单极步进才能用吧?
离线mmfinger
只看该作者 7楼 发表于: 2017-06-28
回 iofree 的帖子
iofree:这个好像只能单极步进才能用吧? (2017-06-28 13:37) 回 iofree 的帖子
单极?孤陋寡闻了,看PCB板上的接线端子,应该是两极步进电机用的,CNCZONE上也有讨论,应该很好用的。没做过。
