  • 6272阅读
  • 7回复
[综合]SF2281开卡失败 [复制链接]
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2017-03-29
SF2281 贴TC58NVG6D2HTA00   128G开卡83%报错,请高手
Starting command:[/root/SOFT/SF_Genesis-v1.7.0.01020130612-fc14-32bit/SF_Genesis -PROCESS_SSD 1:0:0:0 "/root/2000-4000/FW_SF-2000_MP_5-2-0_Client--123456/FW_SF-2000_MP_5-2-0_Client.123456.mfp" "/root/2000-4000/FW_SF-2000_MP_5-2-0_Client--123456/27100.123456.driveconfig" 123456 123456  LOG="/root/2000-4000/FW_SF-2000_MP_5-2-0_Client--123456/123456_a_DATETIMESTAMP_1.0.0.0_PROCESS_SSD_RESULT.log" -EEPROM="/root/2000-4000/SF-2281_EEPROM-KingStone_V300.BIN"  ]...
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Thu 03/30/2017 06:43:48] - SF_Genesis has been invoked with the following parameters:
                      argv[1]: -PROCESS_SSD
                      argv[2]: 1:0:0:0
                      argv[3]: /root/2000-4000/FW_SF-2000_MP_5-2-0_Client--123456/FW_SF-2000_MP_5-2-0_Client.123456.mfp
                      argv[4]: /root/2000-4000/FW_SF-2000_MP_5-2-0_Client--123456/27100.123456.driveconfig
                      argv[5]: 123456
                      argv[6]: 123456
                      argv[7]: LOG=/root/2000-4000/FW_SF-2000_MP_5-2-0_Client--123456/123456_a_DATETIMESTAMP_1.0.0.0_PROCESS_SSD_RESULT.log
                      argv[8]: -EEPROM=/root/2000-4000/SF-2281_EEPROM-KingStone_V300.BIN
[Thu 03/30/2017 06:43:48] - Instructing the operating system to purge any existing cached data for device: '1:0:0:0'
[Thu 03/30/2017 06:43:53] - Issuing a discovery command for device: '1:0:0:0'
[Thu 03/30/2017 06:43:58] - Discovery command completed...
[Thu 03/30/2017 06:43:58] - Waiting 5 seconds for the system to settle...
[Thu 03/30/2017 06:44:03] - Device designation string '1:0:0:0' is mapped to node '/dev/sg1'
[Thu 03/30/2017 06:44:03] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg1
    MFP Package Filename = /root/2000-4000/FW_SF-2000_MP_5-2-0_Client--123456/FW_SF-2000_MP_5-2-0_Client.123456.mfp
      Configuration File = /root/2000-4000/FW_SF-2000_MP_5-2-0_Client--123456/27100.123456.driveconfig
              Serial No. = 123456
         World Wide Name = 123456
[Thu 03/30/2017 06:44:03] - Successfully received the IDENTIFY data from the drive...
[Thu 03/30/2017 06:44:03] - Validating Manufacturing Firmware Package: /root/2000-4000/FW_SF-2000_MP_5-2-0_Client--123456/FW_SF-2000_MP_5-2-0_Client.123456.mfp
[Thu 03/30/2017 06:44:34] - Successfully opened the package: /root/2000-4000/FW_SF-2000_MP_5-2-0_Client--123456/FW_SF-2000_MP_5-2-0_Client.123456.mfp
[Thu 03/30/2017 06:44:34] - file  /root/2000-4000/FW_SF-2000_MP_5-2-0_Client--123456/27100.123456.driveconfig Loaded successfully
[Thu 03/30/2017 06:44:34] - Warning:  Unable to query diagnostics information to perform power management settings check
[Thu 03/30/2017 06:44:34] - B01 Power Management configuration request detected
[Thu 03/30/2017 06:44:34] - Successfully extracted *.DriveConfig file: /root/2000-4000/FW_SF-2000_MP_5-2-0_Client--123456/27100.123456.driveconfig
[Thu 03/30/2017 06:44:34] - Extracted Config_ID: 1 (27100) in DriveConfig file: /root/2000-4000/FW_SF-2000_MP_5-2-0_Client--123456/27100.123456.driveconfig
[Thu 03/30/2017 06:44:34] - Extracted SerialOutputControl: 0
[Thu 03/30/2017 06:44:35] - Searching for flashware image for configuration 27100
[Thu 03/30/2017 06:44:35] - Manifest found for configuration 27100
[Thu 03/30/2017 06:44:35] - Flashware image extracted: 27100_fw_cl_mlc_Toshiba_64Gb_TC58NVG6D2HTA00_2Q_2C_1D_S_PP_R01111_s512.vic
[Thu 03/30/2017 06:44:35] - Searching for manufacturing image for configuration 27100
[Thu 03/30/2017 06:44:35] - Manufacturing image extracted: 27100_mf_mlc_Toshiba_64Gb_TC58NVG6D2HTA00_2Q_2C_1D_S_PP_R01111_s512.vic
[Thu 03/30/2017 06:44:35] - Proceeding in ROM mode, download feature 3...
[Thu 03/30/2017 06:44:35] - Successfully downloaded MFB to the drive...
[Thu 03/30/2017 06:44:35] - Waiting (5 sec) for the drive to settle...
[Thu 03/30/2017 06:44:40] - Successfully received the IDENTIFY data from the drive...
[Thu 03/30/2017 06:44:40] - Firmware revision reported to be: '520ABBM0'.  This indicates MFB download was successful.
[Thu 03/30/2017 06:44:40] - Successfully enabled SMART capabilities...
[Thu 03/30/2017 06:44:42] - Successfully issued a diagnostic unlock...
[Thu 03/30/2017 06:44:42] - Starting to update EEPROM from file /root/2000-4000/SF-2281_EEPROM-KingStone_V300.BIN
[Thu 03/30/2017 06:47:03] - VERIFICATION: What is written and what is read ** matched **
[Thu 03/30/2017 06:47:03] - EEPROM update successful
[Thu 03/30/2017 06:47:04] - Performing the flash test of block 0 (0x0000)...
[Thu 03/30/2017 06:47:06] - Flash Test Results:
Flash Test Parameters:
               Block Count: 0
                Page Count: 1
                 Bus Count: 2
        Chip Enabled Count: 2
                 Die Count: 1
                Lane Count: 4
               Plane Count: 2
Results Notes:
   N1 - At least one page tested and passed with no bit errors.
   N2 - No test data available.  Test may have aborted, or failed during the testing.
   N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
   N4 - At least  one erased page tested had bit error rate greater than half the correction power.
   N5 - Walking zeros test failed.
   N6 - Walking ones test failed.
   N7 - Block contained factory bad block markings and testing was skipped.
   N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
   N9 - Block in plane 0 was marked as a factory bad block.
  N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
  N11 - Block in plane 1 was marked as a factory bad block.
| Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |
| 0    | 0    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 3    | 0x0001 | N1                                         |    PASS |
  Total Number of test results: 16
            Number of failures: 0
         Number of Passed with warnings: 0
      No. Passed without warnings: 16
[Thu 03/30/2017 06:47:06] - Performing the FORMAT Command with the following parameters:
         MemoryWearCycleCapability = 0
              CurrentPE_CycleCount = 0
                     LifeInSeconds = 0
                   LogicalCapacity = 250069680
                        SectorSize = 512
             SectorAlignmentOffset = 0
                  ExpectedMemoryID = 56984 (0xDE98)
                   ExpectedNumDies = 0
               SerialOutputControl = 0
                           Time[8] = 0x0000000000000000
            MiscFlag_Erase_R_Block = 0
     MiscFlag_PanicHandlingEnabled = 0
        MiscFlag_PanicOnSATA_Error = 0
  MiscFlag_WriteThrottlingTestMode = 0
      MiscFlag_DisableUserBandECCX = 1
                        L_PageSize = 0
                        E_PageSize = 0
              ErrorCorrectionPower = 0
      ConfigDeviceReadDisturbCount = 0
   ConfigDeviceReadDisturbCountLow = 0
                  ExtraOptions_0_1 = 0
[Thu 03/30/2017 06:47:40] - FORMAT command completed...
[Thu 03/30/2017 06:47:40] - Waiting (2 sec) for the drive to settle...
[Thu 03/30/2017 06:47:42] - Setting up the stamp information through CDU command...
[Thu 03/30/2017 06:47:45] - Waiting (2 sec) for the drive to settle...
[Thu 03/30/2017 06:47:47] - Downloading the flashware to the drive... feature 3
[Thu 03/30/2017 06:47:48] - Successfully downloaded flashware to the drive...
[Thu 03/30/2017 06:47:48] - Waiting (15 sec) for the drive to settle...
[Thu 03/30/2017 06:48:03] - Successfully received the IDENTIFY data from the drive...
[Thu 03/30/2017 06:48:03] - FATAL_ERROR: Did not recieve the correct firmware revision. it is reported to be: '20DABBR0', indicating flashware download has failed.
[Thu 03/30/2017 06:48:03] - End of Genesis manufacturing log.
[Thu 03/30/2017 06:48:03] - Exiting...
[Thu 03/30/2017 06:48:03] - Overall Result for Device: /dev/sg1 ****** FAIL ******
Process exited with code 18指教
离线wt186
只看该作者 1楼 发表于: 2017-03-29
只看该作者 2楼 发表于: 2017-03-30
离线m820426883
只看该作者 3楼 发表于: 2017-03-30
只看该作者 4楼 发表于: 2017-03-30
离线perter
只看该作者 5楼 发表于: 2017-03-31
离线onlyu7302
只看该作者 6楼 发表于: 2017-03-31
离线c2oud
只看该作者 7楼 发表于: 2018-11-14
