  • 1568阅读
  • 1回复
[鑫创]东芝8GU盘量产 SSS6692-B4 [复制链接]
离线awfymwvf
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2017-04-19
通过论坛的方法,量产提示OK了。但是不好使。看下图:
VID PID全改为0也是一样情况
Report内容如下:意思应该就是擦除失败,是不是U盘报废了啊
Starting Time: 15:38:46
Device 1:0xB4
    MP Version:2.182
    INI_File_Name:6692_HY26_256P_8KB.INI
    Random delay 0 msec
    --- Download MP ISP ---
    Auto CE: 0x00 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF
    CE-0, Flash ID=98-DE-94-82-76-56-04-20
    Page/Block=256
    Searching SORTING BOARD table ...
    --> Not Found
    Found BACKUP Table (0000023A-0002)
    Found BACKUP Table (0000033A-0003)
        Original Bad Block - 0:0x0002
        Original Bad Block - 0:0x0003
        Original Bad Block - 0:0x0006
        Original Bad Block - 0:0x101A
        Original Bad Block - 0:0x101B
    Defect Table shows 3178 Good blocks, 946 Bad blocks
    SafeErase (0,4124)
        Erase failed Block - 0:0:0x0002
        Erase failed Block - 0:0:0x0003
        Erase failed Block - 0:0:0x0006
        Erase failed Block - 0:0:0x0007
        Erase failed Block - 0:0:0x000A
        Erase failed Block - 0:0:0x101A
        Erase failed Block - 0:0:0x101B
        ---> Max Bad of Plane (215,300)
        ---> Max BAD/DIE = 300
    Elasped Time = 00:00:14
Ending Time: 15:39:00
离线awfymwvf
只看该作者 1楼 发表于: 2017-04-20
