  • 9388阅读
  • 29回复
求助 金士顿TC58NC6686G1F 8G量产失败 Err: SECURE failed(32) [复制链接]
离线kayangelee
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2010-11-06
— 本帖被 jjsfm 执行合并操作(2010-11-06) —
6686 6690都不行用6691总算有反应了,但是点击量产的时候中途会失败!
点cardinfo 出现这个
---------------- Device 1------------------
FW version:0xB2
  CE-0, Flash ID=98-D7-98-B2-76-54-09
  CE-1, Flash ID=98-D7-98-B2-76-54-09
Found boot block at (0x00000100)
### Error: Read BPB
量产失败的代码
Device 1:0xB2
    MP Version:2.157
    INI_File_Name:6691.ini
    Random delay 0 msec
    --- Download MP ISP ---
    CE-0, Flash ID=98-D7-98-B2-76-54-09-14
    CE-1, Flash ID=98-D7-98-B2-76-54-09-14
    Found BACKUP Table (00000159-0001)
    Defect Table (00000400-0004)
        Original Bad Block - 0:0x0034
        Original Bad Block - 0:0x009A
        Original Bad Block - 0:0x01C4
        Original Bad Block - 0:0x0284
        Original Bad Block - 0:0x02D9
        Original Bad Block - 0:0x0608
        Original Bad Block - 0:0x0784
        Original Bad Block - 0:0x08B1
        Original Bad Block - 0:0x08ED
        Original Bad Block - 0:0x0A59
        Original Bad Block - 1:0x00B9
        Original Bad Block - 1:0x0138
        Original Bad Block - 1:0x017F
        Original Bad Block - 1:0x029B
        Original Bad Block - 1:0x0649
        Original Bad Block - 1:0x080B
    Defect Table shows 5544 Good blocks, 16 Bad blocks
    SafeErase (0,2780)
        Erase failed Block - 0:0:0x0034
        Erase failed Block - 0:0:0x009A
        Erase failed Block - 0:0:0x01C4
        Erase failed Block - 0:0:0x0284
        Erase failed Block - 0:0:0x02D9
        Erase failed Block - 0:0:0x0608
        Erase failed Block - 0:0:0x0784
        Erase failed Block - 0:0:0x08B1
        Erase failed Block - 0:0:0x08ED
        Erase failed Block - 0:0:0x0A59
        ---> Max Bad of Plane (3,2)
    SafeErase (1,2780)
        Erase failed Block - 1:0:0x00B9
        Erase failed Block - 1:0:0x0138
        Erase failed Block - 1:0:0x017F
        Erase failed Block - 1:0:0x029B
        Erase failed Block - 1:0:0x0649
        Erase failed Block - 1:0:0x080B
        ---> Max Bad of Plane (1,3)
        ---> Max BAD/DIE = 3
    Total good blocks after SCAN: 5544 / 5560, Bad block=16
    ==> 2-Plane mode
    Max. Bad Block Allowed = 275(16)
    Adjust Max LBA = 15654912, 15654848
    MaxWindows=4/1274, MaxLBA=15654848, Size=7643 MB
    Max BAD of one plane is 3 (34),5560,1,2
    RootSector=0x1E39,Sec/Cluster=32, SuperPage=32 ---> Alignment=7
    Boot Block=0x0001,0x0002
    Lun0(15654848), Lun1(0), Public=15654848, Secure=0, CDROM=0
    Special FE Config = 54-0B-00
    Defect Table Block=0x0004
    --- Download ISP Code:ISP_CODE\6691_B3-D3_20100210_VA20B00_F558.BIN---
    --- ISP Code installed.
    Public,Secure,CDROM = 15654848,0,0
    SN=00E065042850F0B059F9002B
    === Preformat Done ===
    Low Level Format DONE
    Store INI/ERROR MSG to Block-0x0001:119.
    Total=15654848,CDROM=0, PublicArea=15654720, SecureArea=0
    ### Err: SECURE failed(32).
怎么回事啊!!! 一直都量产失败但是突然又一次量产失败后还是有个cdrom 但是就是没有iso镜像~ 那个金士顿量产的帖子我也看了。。所以试试6691的可以识别 但是量产
配置文件如下
[OEM]
PN=05430-086
Note=ISP:6691_B3-D3_20100210_VA20B00_F558.BIN
VID=0
PID=0
VENDOR_NAME="Kingston"
PRODUCT_NAME="USB Flash Disk"
STRING_DESC_ENABLE=1
SN_CustomerCode=0x0F
[FEATURE_SETTING]
FLASH_OP="ALL123"
ID35=1
[CDROM]
CDROM_ISO=D:\abc.iso
[ISP]
Code=ISP_CODE\6691_B3-D3_20100210_VA20B00_F558.BIN
下面这个配置也试过问题same
[OEM]
PN=6691 + Toshiba 43nm D2 CDROM Flash
Note=ISP:6691_B3-A_20100331_VA10F00_9083.BIN
VID=0
PID=0
VENDOR_NAME="3SYSTEM"
[FEATURE_SETTING]
FLASH_OP="ALL123"
ID35=1
[CDROM]
CDROM_ISO=d:\abc.iso
[ISP]
Code=6691_B3-A_20100331_VA10F00_9083.BIN
离线kayangelee
只看该作者 1楼 发表于: 2010-11-06
离线bbdx214
只看该作者 2楼 发表于: 2010-11-06
本帖最近打赏记录:共1条打赏
离线li8025
只看该作者 3楼 发表于: 2010-11-06
离线kayangelee
只看该作者 4楼 发表于: 2010-11-06
离线kayangelee
只看该作者 5楼 发表于: 2010-11-06
离线kayangelee
只看该作者 6楼 发表于: 2010-11-06
回 2楼(bbdx214) 的帖子
离线kayangelee
只看该作者 7楼 发表于: 2010-11-06
离线kayangelee
只看该作者 8楼 发表于: 2010-11-06
离线kayangelee
只看该作者 9楼 发表于: 2010-11-06
