  • 3096阅读
  • 9回复
[SandForce]各位大神们。。。sandforce无法开卡。。。求救 [复制链接]
离线ff94315
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2017-08-03
金士顿的盘掉固件了,所以要重新开卡。
lsscsi出来是有设备的,但是用SF开卡没法过。求教
<?xml version = "1.0"?>
<Genesis_Log>
    <Log_Body>
Overall Summary:
                Start Time: Thu, 08/03/2017 @ 20:40:18
                  End Time: Thu, 08/03/2017 @ 20:40:33
             OverallResult: FAIL
                  ExitCode: (0x10090005:SF_GENESIS_INVALID_PARAMTER_SUPPLIED)
Environment Settings:
          Input Parameters:
                  argv[1]: -PROCESS_SSD
                  argv[2]: 2:0:1:0
                  Log File: SF_Genesis_Main_Log__Thu_08.03.2017_20.40.18.log
                  Hostname: localhost.localdomain
           Host IP Address: 127.0.0.1
               Port Number: 1
                DeviceName: /dev/sg1
        SF_Genesis Version: v1.7.0.01020130612-fc14-32bit
   SF_Core Library Version: v1.7.1.20130612-fc14-32bit
         SF_OS_Information: Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686
Post Processing Device Information:
                   WWN OUI: UNKNOWN
              WWN UniqueID: UNKNOWN
                Serial No.: UNKNOWN
                 Model No.: UNKNOWN
         Firmware Revision: UNKNOWN
              ROM Revision: UNKNOWN
            NAND Page Size: UNKNOWN
     Number Of Chip Enable: UNKNOWN
           Logical Sectors: UNKNOWN
                   NAND ID: UNKNOWN
        Flash Manufacturer: UNKNOWN
              Flash Device: UNKNOWN
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Thu 08/03/2017 20:40:18] - SF_Genesis has been invoked with the following parameters:
                      argv[2]: 2:0:1:0
[Thu 08/03/2017 20:40:18] - Instructing the operating system to purge any existing cached data for device: '2:0:1:0'
[Thu 08/03/2017 20:40:23] - Issuing a discovery command for device: '2:0:1:0'
[Thu 08/03/2017 20:40:28] - Discovery command completed...
[Thu 08/03/2017 20:40:28] - Waiting 5 seconds for the system to settle...
[Thu 08/03/2017 20:40:33] - Device designation string '2:0:1:0' is mapped to node '/dev/sg1'
[Thu 08/03/2017 20:40:33] - FATAL_ERROR: Invalid number of input paramters have been supplied. Expected: 8, Received: 3. SF_Genesis can not proceed with performing the -PROCESS_SSD request.  Exiting...
[Thu 08/03/2017 20:40:33] - End of Genesis manufacturing log.
[Thu 08/03/2017 20:40:33] - Exiting...
    </Log_Body>
    <Overall_Summary>
        <Start_Time> Thu, 08/03/2017 @ 20:40:18 </Start_Time>
        <End_Time> Thu, 08/03/2017 @ 20:40:33 </End_Time>
        <Overall_Result> FAIL </Overall_Result>
        <Exit_Code> (0x10090005:SF_GENESIS_INVALID_PARAMTER_SUPPLIED) </Exit_Code>
    </Overall_Summary>
    <Environment_Settings>
        <Input_Parameters>
                  argv[2]: 2:0:1:0
        </Input_Parameters>
        <Log_File> SF_Genesis_Main_Log__Thu_08.03.2017_20.40.18.log </Log_File>
        <Hostname> localhost.localdomain </Hostname>
        <Host_IP_Address> 127.0.0.1 </Host_IP_Address>
        <Port_Number> 1 </Port_Number>
        <Device_Name> /dev/sg1 </Device_Name>
        <SF_Genesis_Version> v1.7.0.01020130612-fc14-32bit </SF_Genesis_Version>
        <SF_Core_Library_Version> v1.7.1.20130612-fc14-32bit </SF_Core_Library_Version>
        <SF_OS_Information> Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686 </SF_OS_Information>
    </Environment_Settings>
    <Post_Processing_Device_Info>
        <WWN_OUI> UNKNOWN </WWN_OUI>
        <WWN_UniqueID> UNKNOWN </WWN_UniqueID>
        <Serial_Number> UNKNOWN </Serial_Number>
        <Model_Number> UNKNOWN </Model_Number>
        <Firmware_Revision> UNKNOWN </Firmware_Revision>
        <ROM_Revision> UNKNOWN </ROM_Revision>
        <NAND_Page_Size> UNKNOWN </NAND_Page_Size>
        <Number_Of_Chip_Enable> UNKNOWN </Number_Of_Chip_Enable>
        <Logical_Sectors> UNKNOWN </Logical_Sectors>
        <NAND_ID> UNKNOWN </NAND_ID>
        <Flash_Manufacturer> UNKNOWN </Flash_Manufacturer>
        <Flash_Device> UNKNOWN </Flash_Device>
    </Post_Processing_Device_Info>
</Genesis_Log>
[Thu 08/03/2017 20:40:33] - Overall Result for Device: /dev/sg1 ****** FAIL ******
离线2017shuma
只看该作者 1楼 发表于: 2017-08-03
离线ff94315
只看该作者 2楼 发表于: 2017-08-03
回 2017shuma 的帖子
离线2017shuma
只看该作者 3楼 发表于: 2017-08-04
回 ff94315 的帖子
离线stasiz
只看该作者 4楼 发表于: 2017-08-04
离线ff94315
只看该作者 5楼 发表于: 2017-08-04
回 stasiz 的帖子
离线2017shuma
只看该作者 6楼 发表于: 2017-08-04
回 stasiz 的帖子
离线testpoint
只看该作者 7楼 发表于: 2017-08-18
回 ff94315 的帖子
离线527945545
只看该作者 8楼 发表于: 2017-08-18
离线haaker
只看该作者 9楼 发表于: 2017-10-26
