本机能开机,一直在液晶屏界面滚动条滚动20%后重启,据一个大侠说是无线部分毛病了,拆机给大家看看这个上千元的路由器是个啥样。
背面
正面
螺丝就两个
电路板正面
液晶显示器
主板
主板背面
背面2
ttl信息,哪位高手能告诉我哪里出问题了。
Copyright (C) 2000, 2001, 2002, 2003, 2004 Red Hat, Inc.
Board: pb42
RAM: 0x80000000-0x81000000, [0x80032d60-0x80ff4000] available
FLASH: 0xbf000000 - 0xbf400000, 64 blocks of 0x00010000 bytes each.
in Init LCD now.
Chance for pushing button, 2 seconds time out!
== Executing boot script in 2.000 seconds - enter ^C to abort
RedBoot> boot;exe
Now booting linux kernel:
Base address 0x80050000 Entry 0x8024e00
Linux version 2.6.15--LSDK-6.1.1.65 (
asraul@localhost.localdomain) (gcc version 3.4.4) #1 Fri Apr 11 03:54:27 CST 2008
flash_size passed from bootloader = 4
arg 1: console=ttyS0,115200 root=31:03 rootfstype=squashfs init=/sbin/init mem=16M
CPU revision is: 00019374
Determined physical RAM map:
memory: 02000000 @ 00000000 (usable)
User-defined physical RAM map:
memory: 01000000 @ 00000000 (usable)
Built 1 zonelists
Kernel command line: console=ttyS0,115200 root=31:03 rootfstype=squashfs init=/sbin/init mem=16M
Primary instruction cache 64kB, physically tagged, 4-way, linesize 32 bytes.
Primary data cache 32kB, 4-way, linesize 32 bytes.
Synthesized TLB refill handler (20 instructions).
Synthesized TLB load handler fastpath (32 instructions).
Synthesized TLB store handler fastpath (32 instructions).
Synthesized TLB modify handler fastpath (31 instructions).
Cache parity protection disabled
PID hash table entries: 128 (order: 7, 2048 bytes)
Using 200.000 MHz high precision timer.
Console: colour dummy device 80x25
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Memory: 13508k/16384k available (1622k kernel code, 2876k reserved, 349k data, 108k init, 0k highmem)
Mount-cache hash table entries: 512
Checking for 'wait' instruction... available.
NET: Registered protocol family 16
AR7100 GPIOC major 0
squashfs: version 3.1 (2006/08/19) Phillip Lougher
Initializing Cryptographic API
io scheduler noop registered
io scheduler deadline registered
Serial: 8250/16550 driver $Revision: #1 $ 4 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0x0 (irq = 19) is a 16550A
PPP generic driver version 2.4.2
PPP Deflate Compression module registered
PPP BSD Compression module registered
NET: Registered protocol family 24
SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256).
CSLIP: code copyright 1989 Regents of the University of California.
Add static partition for flash bank 0
Creating 4 MTD partitions on "ar7100-nor0":
0x00000000-0x00020000 : "RedBoot"
0x00020000-0x00030000 : "Nvram"
0x00030000-0x00130000 : "Kernel"
0x00130000-0x00400000 : "FileSystem"
Netfilter messages via NETLINK v0.30.
IP route cache hash table entries: 256 (order: -2, 1024 bytes)
TCP established hash table entries: 1024 (order: 0, 4096 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP reno registered
GRE over IPv4 tunneling driver
ip_conntrack version 2.4 (128 buckets, 1024 max) - 236 bytes per conntrack
ip_conntrack_pptp version 3.1 loaded
ip_nat_pptp version 3.0 loaded
ip_tables: (C) 2000-2002 Netfilter core team
TCP bic registered
NET: Registered protocol family 17
802.1Q VLAN Support v1.8 Ben Greear <
greearb@candelatech.com>
All bugs added by David S. Miller <
davem@redhat.com>
VFS: Mounted root (squashfs filesystem) readonly.
Freeing unused kernel memory: 108k freed
init started: BusyBox v1.00 (2008.03.31-01:40+0000) multi-call binary
init started: BusyBox v1.00 (2008.03.31-01:40+0000) multi-call binaryAlgorithmics/MIPS FPU Emulator v1.5
Starting pid 657, console /dev/ttyS0: '/etc/rcS'
ag7100_mod: module license 'unspecified' taints kernel.
/proc/eth_status created
params: tx_len_per_ds 1536
fifo_3 0x7801ffnetfilter PSD loaded - (c) astaro AG
ipt_random match loaded
lcd_init_module: sucess to create a netlink socket
Fail to nvram_load with <4>, restore to default!
erase addr: 0x20000
write flash, addr: 0x20000, size 0x10000
nvram_factory_default, do reboot
Sending SIGKILL to all processes.
Please stand by while rebooting the system.
Restarting system.
