  • 9578阅读
  • 21回复
[SandForce]金士顿v300开卡报错2013.年板子,求助 [复制链接]
离线233277801
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2018-01-22
此悬赏帖已过期
最佳答案:50 M币,热心助人剩余点数: 4 M币。
关闭读写保护开到80%处报错,代码8。开启读写保护80%处同样报错,代码9
Starting command:[/root/soft/SF_Genesis-v1.7.0.01020130612-fc14-32bit/SF_Genesis -PROCESS_SSD 1:0:0:0 "/root/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp" "/root/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/27733.123456.driveconfig" 0 0  LOG="/root/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/0_localhost.localdomain_DATETIMESTAMP_1.0.0.0_PROCESS_SSD_RESULT.log"   ]...
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Tue 01/23/2018 00:49:31] - SF_Genesis has been invoked with the following parameters:
                      argv[1]: -PROCESS_SSD
                      argv[2]: 1:0:0:0
                      argv[3]: /root/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
                      argv[4]: /root/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/27733.123456.driveconfig
                      argv[5]: 0
                      argv[6]: 0
                      argv[7]: LOG=/root/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/0_localhost.localdomain_DATETIMESTAMP_1.0.0.0_PROCESS_SSD_RESULT.log
[Tue 01/23/2018 00:49:31] - Instructing the operating system to purge any existing cached data for device: '1:0:0:0'
[Tue 01/23/2018 00:49:36] - Issuing a discovery command for device: '1:0:0:0'
[Tue 01/23/2018 00:49:42] - Discovery command completed...
[Tue 01/23/2018 00:49:42] - Waiting 5 seconds for the system to settle...
[Tue 01/23/2018 00:49:47] - Device designation string '1:0:0:0' is mapped to node '/dev/sg1'
[Tue 01/23/2018 00:49:47] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg1
    MFP Package Filename = /root/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
      Configuration File = /root/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/27733.123456.driveconfig
              Serial No. = 0
         World Wide Name = 0
[Tue 01/23/2018 00:49:47] - Successfully received the IDENTIFY data from the drive...
[Tue 01/23/2018 00:49:47] - Validating Manufacturing Firmware Package: /root/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
[Tue 01/23/2018 00:50:37] - Successfully opened the package: /root/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
[Tue 01/23/2018 00:50:37] - file  /root/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/27733.123456.driveconfig Loaded successfully
[Tue 01/23/2018 00:50:37] - Warning:  Unable to query diagnostics information to perform power management settings check
[Tue 01/23/2018 00:50:37] - B01 Power Management configuration request detected
[Tue 01/23/2018 00:50:37] - Successfully extracted *.DriveConfig file: /root/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/27733.123456.driveconfig
[Tue 01/23/2018 00:50:37] - Extracted Config_ID: 1 (27733) in DriveConfig file: /root/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/27733.123456.driveconfig
[Tue 01/23/2018 00:50:37] - Extracted SerialOutputControl: 0
[Tue 01/23/2018 00:50:44] - Searching for flashware image for configuration 27733
[Tue 01/23/2018 00:50:44] - Manifest found for configuration 27733
[Tue 01/23/2018 00:50:44] - Flashware image extracted: 27733_fw_cl_mlc_Toshiba_BBR6_64Gb_FT64G08UCT18B_2Q_2C_1D_S_PP_R01928_s512.vic
[Tue 01/23/2018 00:50:44] - Searching for manufacturing image for configuration 27733
[Tue 01/23/2018 00:50:44] - Manufacturing image extracted: 27733_mf_mlc_Toshiba_BBR6_64Gb_FT64G08UCT18B_2Q_2C_1D_S_PP_R01928_s512.vic
[Tue 01/23/2018 00:50:44] - Proceeding in ROM mode, download feature 3...
[Tue 01/23/2018 00:50:45] - Successfully downloaded MFB to the drive...
[Tue 01/23/2018 00:50:45] - Waiting (5 sec) for the drive to settle...
[Tue 01/23/2018 00:50:50] - Successfully received the IDENTIFY data from the drive...
[Tue 01/23/2018 00:50:50] - Firmware revision reported to be: '60AABBM0'.  This indicates MFB download was successful.
[Tue 01/23/2018 00:50:50] - Successfully enabled SMART capabilities...
[Tue 01/23/2018 00:50:52] - Successfully issued a diagnostic unlock...
[Tue 01/23/2018 00:50:53] - Performing the flash test of block 0 (0x0000)...
[Tue 01/23/2018 00:50:56] - Flash Test Results:
Flash Test Parameters:
               Block Count: 0
                Page Count: 1
                 Bus Count: 2
        Chip Enabled Count: 2
                 Die Count: 1
                Lane Count: 4
               Plane Count: 2
Results Notes:
   N1 - At least one page tested and passed with no bit errors.
   N2 - No test data available.  Test may have aborted, or failed during the testing.
   N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
   N4 - At least  one erased page tested had bit error rate greater than half the correction power.
   N5 - Walking zeros test failed.
   N6 - Walking ones test failed.
   N7 - Block contained factory bad block markings and testing was skipped.
   N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
   N9 - Block in plane 0 was marked as a factory bad block.
  N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
  N11 - Block in plane 1 was marked as a factory bad block.
| Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |
| 0    | 0    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 3    | 0x0001 | N1                                         |    PASS |
只看该作者 1楼 发表于: 2018-01-23
热心助人奖励:+1 M币
离线2017shuma
只看该作者 2楼 发表于: 2018-01-24
离线perter
只看该作者 3楼 发表于: 2018-01-24
离线perter
只看该作者 4楼 发表于: 2018-01-24
离线2017shuma
只看该作者 5楼 发表于: 2018-01-26
回 perter 的帖子
离线longnan
只看该作者 6楼 发表于: 2018-01-29
回 2017shuma 的帖子
离线longnan
只看该作者 7楼 发表于: 2018-01-29
离线perter
只看该作者 8楼 发表于: 2018-01-29
离线qazwsxedczzz
只看该作者 9楼 发表于: 2018-01-29
