Array
  • 2409阅读
  • 4回复
[SandForce][SandForce]求大神帮看这个金士顿120g开卡是什么问题 [复制链接] [复制链接]
离线cy2cool
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2018-01-29
此悬赏帖已过期
最佳答案:10 M币,热心助人剩余点数: 2 M币。
RT;一块金士顿SV300,主控2281,想重新开卡试试,但总是卡在27%的位置!提示的是没有接收到正确的固件!求大神支招
   <?xml version = "1.0"?>
<Genesis_Log>
    <Log_Body>
Overall Summary:
                Start Time: Mon, 01/29/2018 @ 20:41:00
                  End Time: Mon, 01/29/2018 @ 20:41:38
             OverallResult: FAIL
                  ExitCode: (0x10090012:SF_GENESIS_IDENTIFY_ERROR)
Environment Settings:
          Input Parameters:
                  argv[1]: -PROCESS_SSD
                  argv[2]: 6:0:0:0
                  argv[3]: /home/linux/Desktop/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
                  argv[4]: /home/linux/Desktop/33174.123456.driveconfig
                  argv[5]: 123
                  argv[6]: 123
                  argv[7]: LOG=/home/linux/Desktop/log/123_linux-pc_DATETIMESTAMP_6.0.0.0_PROCESS_SSD_RESULT.log
                  Log File: /home/linux/Desktop/log/123_linux-pc_DATETIMESTAMP_6.0.0.0_PROCESS_SSD_RESULT.log
                  Hostname: linux-pc
           Host IP Address: 127.0.1.1
               Port Number: 2
                DeviceName: /dev/sg2
        SF_Genesis Version: v1.7.0.01020130612-fc14-32bit
   SF_Core Library Version: v1.7.1.20130612-fc14-32bit
         SF_OS_Information: Linux 4.4.0-2-deepin-686-pae #1 SMP Deepin 4.4.6-4 (2016-07-01) i686
Post Processing Device Information:
                   WWN OUI: UNKNOWN
              WWN UniqueID: UNKNOWN
                Serial No.: UNKNOWN
                 Model No.: UNKNOWN
         Firmware Revision: UNKNOWN
              ROM Revision: UNKNOWN
            NAND Page Size: UNKNOWN
     Number Of Chip Enable: UNKNOWN
           Logical Sectors: UNKNOWN
                   NAND ID: UNKNOWN
        Flash Manufacturer: UNKNOWN
              Flash Device: UNKNOWN
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Mon 01/29/2018 20:41:00] - SF_Genesis has been invoked with the following parameters:
                      argv[2]: 6:0:0:0
                      argv[5]: 123
                      argv[6]: 123
[Mon 01/29/2018 20:41:00] - Instructing the operating system to purge any existing cached data for device: '6:0:0:0'
[Mon 01/29/2018 20:41:05] - Issuing a discovery command for device: '6:0:0:0'
[Mon 01/29/2018 20:41:10] - Discovery command completed...
[Mon 01/29/2018 20:41:10] - Waiting 5 seconds for the system to settle...
[Mon 01/29/2018 20:41:15] - Device designation string '6:0:0:0' is mapped to node '/dev/sg2'
[Mon 01/29/2018 20:41:15] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg2
    MFP Package Filename = /home/linux/Desktop/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
      Configuration File = /home/linux/Desktop/33174.123456.driveconfig
              Serial No. = 123
         World Wide Name = 123
[Mon 01/29/2018 20:41:15] - Successfully received the IDENTIFY data from the drive...
[Mon 01/29/2018 20:41:15] - Validating Manufacturing Firmware Package: /home/linux/Desktop/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
[Mon 01/29/2018 20:41:31] - Successfully opened the package: /home/linux/Desktop/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
[Mon 01/29/2018 20:41:31] - file  /home/linux/Desktop/33174.123456.driveconfig Loaded successfully
[Mon 01/29/2018 20:41:32] - B01 Power Management configuration request detected
[Mon 01/29/2018 20:41:32] - Warning: Applying B01 Power Management settings to a device with hardware version 0x500026BB
[Mon 01/29/2018 20:41:32] - Successfully extracted *.DriveConfig file: /home/linux/Desktop/33174.123456.driveconfig
[Mon 01/29/2018 20:41:32] - Extracted Config_ID: 1 (33174) in DriveConfig file: /home/linux/Desktop/33174.123456.driveconfig
[Mon 01/29/2018 20:41:32] - Extracted SerialOutputControl: 0
[Mon 01/29/2018 20:41:33] - Searching for flashware image for configuration 33174
[Mon 01/29/2018 20:41:33] - Manifest found for configuration 33174
[Mon 01/29/2018 20:41:33] - Flashware image extracted: 33174_fw_cl_mlc_MIC_128Gb_29bit_FT16B08UCM1-34_2Q_1C_1D_PP_R02726_s512.vic
[Mon 01/29/2018 20:41:33] - Searching for manufacturing image for configuration 33174
[Mon 01/29/2018 20:41:33] - Manufacturing image extracted: 33174_mf_mlc_MIC_128Gb_29bit_FT16B08UCM1-34_2Q_1C_1D_PP_R02726_s512.vic
[Mon 01/29/2018 20:41:33] - Proceeding in non-ROM mode, Download feature 3...
[Mon 01/29/2018 20:41:33] - Successfully downloaded MFB to the drive...
[Mon 01/29/2018 20:41:33] - Waiting (5 sec) for the drive to settle...
[Mon 01/29/2018 20:41:38] - Successfully received the IDENTIFY data from the drive...
[Mon 01/29/2018 20:41:38] - FATAL_ERROR: Did not recieve the correct firmware revision. it is reported to be: '60AABBF0', indicating MFB download has failed.
[Mon 01/29/2018 20:41:38] - End of Genesis manufacturing log.
[Mon 01/29/2018 20:41:38] - Exiting...
    </Log_Body>
    <Overall_Summary>
        <Start_Time> Mon, 01/29/2018 @ 20:41:00 </Start_Time>
        <End_Time> Mon, 01/29/2018 @ 20:41:38 </End_Time>
        <Overall_Result> FAIL </Overall_Result>
        <Exit_Code> (0x10090012:SF_GENESIS_IDENTIFY_ERROR) </Exit_Code>
    </Overall_Summary>
    <Environment_Settings>
        <Input_Parameters>
                  argv[2]: 6:0:0:0
                  argv[5]: 123
                  argv[6]: 123
        </Input_Parameters>
        <Log_File> /home/linux/Desktop/log/123_linux-pc_DATETIMESTAMP_6.0.0.0_PROCESS_SSD_RESULT.log </Log_File>
        <Hostname> linux-pc </Hostname>
        <Host_IP_Address> 127.0.1.1 </Host_IP_Address>
        <Port_Number> 2 </Port_Number>
        <Device_Name> /dev/sg2 </Device_Name>
        <SF_Genesis_Version> v1.7.0.01020130612-fc14-32bit </SF_Genesis_Version>
        <SF_Core_Library_Version> v1.7.1.20130612-fc14-32bit </SF_Core_Library_Version>
        <SF_OS_Information> Linux 4.4.0-2-deepin-686-pae #1 SMP Deepin 4.4.6-4 (2016-07-01) i686 </SF_OS_Information>
    </Environment_Settings>
    <Post_Processing_Device_Info>
        <WWN_OUI> UNKNOWN </WWN_OUI>
        <WWN_UniqueID> UNKNOWN </WWN_UniqueID>
        <Serial_Number> UNKNOWN </Serial_Number>
        <Model_Number> UNKNOWN </Model_Number>
        <Firmware_Revision> UNKNOWN </Firmware_Revision>
        <ROM_Revision> UNKNOWN </ROM_Revision>
        <NAND_Page_Size> UNKNOWN </NAND_Page_Size>
        <Number_Of_Chip_Enable> UNKNOWN </Number_Of_Chip_Enable>
        <Logical_Sectors> UNKNOWN </Logical_Sectors>
        <NAND_ID> UNKNOWN </NAND_ID>
        <Flash_Manufacturer> UNKNOWN </Flash_Manufacturer>
        <Flash_Device> UNKNOWN </Flash_Device>
    </Post_Processing_Device_Info>
</Genesis_Log>
[Mon 01/29/2018 20:41:38] - Overall Result for Device: /dev/sg2 ****** FAIL ******
离线wxmuzi
只看该作者 1楼 发表于: 2018-01-29
热心助人奖励:+1 M币
离线perter
只看该作者 2楼 发表于: 2018-01-29
热心助人奖励:+1 M币
离线perter
只看该作者 3楼 发表于: 2018-01-29
热心助人奖励:+1 M币
离线cy2cool
只看该作者 4楼 发表于: 2018-01-30
Array
