  • 2870阅读
  • 22回复
[SandForce]【sf2281开卡】找不到29F16B08JCNE1的配置文件 [复制链接]
离线cw760
只看该作者 10楼 发表于: 02-11
回 perter 的帖子
perter:自己翻论坛,JCNE是很普遍的SLC,论坛有帖子 (2018-02-07 22:16) 回 perter 的帖子
着实找了两天,没找到。用js29F16b16ncne1开不了,报“Did not recieve the correct firmware revision”
离线perter
只看该作者 11楼 发表于: 02-11
回 cw760 的帖子
cw760:着实找了两天,没找到。用js29F16b16ncne1开不了,报“Did not recieve the correct firmware revision” (2018-02-11 10:51) 回 cw760 的帖子
把日志发上来,这个我认为你焊接问题比较大,另外2281不支持4贴JCNE1开卡(固件bug)四贴你要用2181或者2241开。。。
离线cw760
只看该作者 12楼 发表于: 02-11
回 perter 的帖子
perter:把日志发上来,这个我认为你焊接问题比较大,另外2281不支持4贴JCNE1开卡(固件bug)四贴你要用2181或者2241开。。。 (2018-02-11 10:57) 回 perter 的帖子
是8片16G的F,日志在下面。直接用的1.7版本的SF_Genius
<?xml version = "1.0"?>
<Genesis_Log>
    <Log_Body>
Overall Summary:
                Start Time: Thu, 02/08/2018 @ 07:57:07
                  End Time: Thu, 02/08/2018 @ 07:57:38
             OverallResult: FAIL
                  ExitCode: (0x10090012:SF_GENESIS_IDENTIFY_ERROR)
Environment Settings:
          Input Parameters:
                  argv[1]: -PROCESS_SSD
                  argv[2]: 11:0:0:0
                  argv[3]: ../mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
                  argv[4]: ../mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/Configuration_Files/22249.123456.driveconfig
                  argv[5]: 12345
                  argv[6]: www_123
                  argv[7]: log=../mpt/ssd.log
                  Log File: SF_Genesis_Main_Log__Thu_02.08.2018_07.57.07.log
                  Hostname: localhost.localdomain
           Host IP Address: 127.0.0.1
               Port Number: 2
                DeviceName: /dev/sg2
        SF_Genesis Version: v1.7.0.01020130612-fc14-32bit
   SF_Core Library Version: v1.7.1.20130612-fc14-32bit
         SF_OS_Information: Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686
Post Processing Device Information:
                   WWN OUI: UNKNOWN
              WWN UniqueID: UNKNOWN
                Serial No.: UNKNOWN
                 Model No.: UNKNOWN
         Firmware Revision: UNKNOWN
              ROM Revision: UNKNOWN
            NAND Page Size: UNKNOWN
     Number Of Chip Enable: UNKNOWN
           Logical Sectors: UNKNOWN
                   NAND ID: UNKNOWN
        Flash Manufacturer: UNKNOWN
              Flash Device: UNKNOWN
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Thu 02/08/2018 07:57:07] - SF_Genesis has been invoked with the following parameters:
                      argv[2]: 11:0:0:0
                      argv[5]: 12345
                      argv[6]: www_123
[Thu 02/08/2018 07:57:07] - Instructing the operating system to purge any existing cached data for device: '11:0:0:0'
[Thu 02/08/2018 07:57:12] - Issuing a discovery command for device: '11:0:0:0'
[Thu 02/08/2018 07:57:17] - Discovery command completed...
[Thu 02/08/2018 07:57:17] - Waiting 5 seconds for the system to settle...
[Thu 02/08/2018 07:57:22] - Device designation string '11:0:0:0' is mapped to node '/dev/sg2'
[Thu 02/08/2018 07:57:22] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg2
    MFP Package Filename = ../mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
      Configuration File = ../mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/Configuration_Files/22249.123456.driveconfig
              Serial No. = 12345
         World Wide Name = www_123
[Thu 02/08/2018 07:57:22] - Successfully received the IDENTIFY data from the drive...
[Thu 02/08/2018 07:57:22] - Validating Manufacturing Firmware Package: ../mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
[Thu 02/08/2018 07:57:25] - Successfully opened the package: ../mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
[Thu 02/08/2018 07:57:25] - file  ../mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/Configuration_Files/22249.123456.driveconfig Loaded successfully
[Thu 02/08/2018 07:57:33] - B01 Power Management configuration request detected
[Thu 02/08/2018 07:57:33] - B01 Power Management conforms to hardware version 0x0
[Thu 02/08/2018 07:57:33] - Successfully extracted *.DriveConfig file: ../mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/Configuration_Files/22249.123456.driveconfig
[Thu 02/08/2018 07:57:33] - Extracted Config_ID: 1 (22249) in DriveConfig file: ../mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/Configuration_Files/22249.123456.driveconfig
[Thu 02/08/2018 07:57:33] - Extracted SerialOutputControl: 0
[Thu 02/08/2018 07:57:33] - Searching for flashware image for configuration 22249
[Thu 02/08/2018 07:57:33] - Manifest found for configuration 22249
[Thu 02/08/2018 07:57:33] - Flashware image extracted: 22249_fw_cl_slc_Intel_64Gb_PF29F64G16MCNE_2Q_4C_1D_PP_R00804_s512.vic
[Thu 02/08/2018 07:57:33] - Searching for manufacturing image for configuration 22249
[Thu 02/08/2018 07:57:33] - Manufacturing image extracted: 22249_mf_slc_Intel_64Gb_PF29F64G16MCNE_2Q_4C_1D_PP_R00804_s512.vic
[Thu 02/08/2018 07:57:33] - Proceeding in non-ROM mode, Download feature 3...
[Thu 02/08/2018 07:57:33] - Successfully downloaded MFB to the drive...
[Thu 02/08/2018 07:57:33] - Waiting (5 sec) for the drive to settle...
[Thu 02/08/2018 07:57:38] - Successfully received the IDENTIFY data from the drive...
[Thu 02/08/2018 07:57:38] - FATAL_ERROR: Did not recieve the correct firmware revision. it is reported to be: '  |     ', indicating MFB download has failed.
[Thu 02/08/2018 07:57:38] - End of Genesis manufacturing log.
[Thu 02/08/2018 07:57:38] - Exiting...
    </Log_Body>
    <Overall_Summary>
        <Start_Time> Thu, 02/08/2018 @ 07:57:07 </Start_Time>
        <End_Time> Thu, 02/08/2018 @ 07:57:38 </End_Time>
        <Overall_Result> FAIL </Overall_Result>
        <Exit_Code> (0x10090012:SF_GENESIS_IDENTIFY_ERROR) </Exit_Code>
    </Overall_Summary>
    <Environment_Settings>
        <Input_Parameters>
                  argv[2]: 11:0:0:0
                  argv[5]: 12345
                  argv[6]: www_123
        </Input_Parameters>
        <Log_File> SF_Genesis_Main_Log__Thu_02.08.2018_07.57.07.log </Log_File>
        <Hostname> localhost.localdomain </Hostname>
        <Host_IP_Address> 127.0.0.1 </Host_IP_Address>
        <Port_Number> 2 </Port_Number>
        <Device_Name> /dev/sg2 </Device_Name>
        <SF_Genesis_Version> v1.7.0.01020130612-fc14-32bit </SF_Genesis_Version>
        <SF_Core_Library_Version> v1.7.1.20130612-fc14-32bit </SF_Core_Library_Version>
        <SF_OS_Information> Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686 </SF_OS_Information>
    </Environment_Settings>
    <Post_Processing_Device_Info>
        <WWN_OUI> UNKNOWN </WWN_OUI>
        <WWN_UniqueID> UNKNOWN </WWN_UniqueID>
        <Serial_Number> UNKNOWN </Serial_Number>
        <Model_Number> UNKNOWN </Model_Number>
        <Firmware_Revision> UNKNOWN </Firmware_Revision>
        <ROM_Revision> UNKNOWN </ROM_Revision>
        <NAND_Page_Size> UNKNOWN </NAND_Page_Size>
        <Number_Of_Chip_Enable> UNKNOWN </Number_Of_Chip_Enable>
        <Logical_Sectors> UNKNOWN </Logical_Sectors>
        <NAND_ID> UNKNOWN </NAND_ID>
        <Flash_Manufacturer> UNKNOWN </Flash_Manufacturer>
        <Flash_Device> UNKNOWN </Flash_Device>
    </Post_Processing_Device_Info>
</Genesis_Log>
[Thu 02/08/2018 07:57:38] - Overall Result for Device: /dev/sg2 ****** FAIL ******
离线perter
只看该作者 13楼 发表于: 02-11
回 cw760 的帖子
cw760:是8片16G的F,日志在下面。直接用的1.7版本的SF_Genius
<Genesis_Log>
....... (2018-02-11 11:07) 回 cw760 的帖子
把你贴图给我发上来,估计你焊接就有问题
离线cw760
只看该作者 14楼 发表于: 02-11
回 perter 的帖子
perter:把你贴图给我发上来,估计你焊接就有问题 (2018-02-11 11:09) 回 perter 的帖子
手机拍的,没有相机……
http://bbs.mydigit.cn/read.php?tid=2344040
ps:我觉得应该不是焊接问题 毕竟用了5年多了,都没出过问题,如果焊接有问题,应该早暴露出来了
离线perter
只看该作者 15楼 发表于: 02-11
回 cw760 的帖子
cw760:手机拍的,没有相机……
ps:我觉得应该不是焊接问题 毕竟用了5年多了,都没出过问题,如果焊接有问题,应该早暴露出来了 (2018-02-11 11:11) 回 cw760 的帖子
你短接了吗? 过LSSCSI了吗?具体的port号是多少?你填对了嘛
离线cw760
只看该作者 16楼 发表于: 02-11
回 perter 的帖子
perter:你短接了吗? 过LSSCSI了吗?具体的port号是多少?你填对了嘛 (2018-02-11 11:27) 回 perter 的帖子
未短接。
每次开卡都用lsscsi查看了port,并正确填写
离线perter
只看该作者 17楼 发表于: 02-11
回 cw760 的帖子
cw760:未短接。
每次开卡都用lsscsi查看了port,并正确填写 (2018-02-11 11:34) 回 cw760 的帖子
首先,你要短接ROM, LSSCSI看见的必须是sandforce{2000XXXXXX}才能开卡,XXXX是随机数不用管
离线cw760
只看该作者 18楼 发表于: 02-11
回 perter 的帖子
perter:
首先,你要短接ROM, LSSCSI看见的必须是sandforce{2000XXXXXX}才能开卡,XXXX是随机数不用管 回 perter 的帖子
看样子我得先短接,然后换个硬盘盒试试
离线perter
只看该作者 19楼 发表于: 02-11
回 cw760 的帖子
cw760:看样子我得先短接,然后换个硬盘盒试试
 (2018-02-11 13:19) 回 cw760 的帖子
说了多少遍了,新手不要VM开卡,VM开卡奇怪问题很多的,另外VM开卡好像挑转接卡。。。
