  • 2786阅读
  • 12回复
[播放]inphic-i9双核网络播放器 拆解 [复制链接]
离线184562832
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2018-04-10
机顶盒拆解(二)inphic-i9双核网络播放器
2014年的机顶盒。现在开机卡logo。
正脸一览图。泛黄的外壳。沧桑的脸庞。
通透的背部。很多细长的长条散热孔。
赫然标着8G大闪存标贴!深怕别人不知道。
局部图
坑人的胶垫。防不胜防!只有靠近菊部才有俩螺丝!
拆开一看,好节约啊!这么大盒子配这么迷你的板子!
无线天线和红外接收、指示灯外接
红外接收、指示灯排线链接
处理器Main components of the A20
CPU:DualCore ARM CortexA7 1GHz Processor (r0p4, revidr=0x0) which have both VFP4and NEON SIMD coprocessors that share 32 floating point double-precisionregisters together[1]:FPU: standard ARM VFPv4-D32 FPU Floating Point Unit
SIMD: NEON (ARM's extended general-purposeSIMD vector processing extension engine)
GPU: Mali400 MP2VPU: Cedar Engine (VideoProcessor Unit for audio and video hardware decoding or encoding)HDMI-transmitter:HDMI CEC (Consumer Electronics Control)
A20 SoC Features
A20 SoC on a Cubieboard2
CPUARM Cortex-A7 Dual-Core (revision r0p4)
256KiB L2-Cache (shared between two cores)
32KiB (Instruction) / 32KiB (Data) L1-Cacheper core
SIMD NEON, VFP4
Virtualization
Large Physical Address Extensions (LPAE)1TB
GPU
ARM Mali400 MP2
Featuring 1 vertex shader (GP) and 2fragment shaders (PP).
Complies with OpenGL ES 2.0
Memory
LPDDR2/DDR3/DDR3L controller
NAND Flash controller and 64-bit ECC
Video
HD H.264 2160P video decoding
Full HD video decoding
BD Directory, BD ISO and BD m2ts videodecoding
H.264 High Profile 1080P@30fps encoding
3840×1080@30fps 3D decoding
Complies with RTSP, HTTP,HLS,RTMP,MMSstreaming media protocol
Display
Support multi-channel HD display
Integrated HDMI 1.4
CPU/RGB/LVDS LCD interface 1920×1080resolution
CVBS/YPbPr/VGA support
Integrated TV decoder
Camera
Integrated parallel 8-bit I/F YUV sensor
Integrated 24-bit parallel YUV 444 I/F
5M/8M CMOS sensor support
Dual-sensor support
Audio
Integrated HI-FI 100dB Audio Codec
Dual MIC noise cancellation
package:BGA441 19 mm × 19 mm (0.80 mm Pitch
全志A20双核
pmfs11816cbr-kadn运存,也没查到资料,估计是256M一片的
支持802.11b/g/n的无线网卡
The Realtek RTL8188ETV is a highlyintergrated singlechip 802.11n Wireless LAN(WLAN)network USB interface(USB1.0/1.1/2.0 comliant)controller.It combines a WLAN MAC,a 1T1R capable WLANbaseband,and WLAN RF in a single chip.The RTL8188ETV provides a completesolution for a high throughput performance integrated wireless LAN device.
Features
46-pin QFN
CMOS MAC,Baseband PHY and RF in a single chip for IEEE802.11b/g/ncompatible WLAN
Complete 802.11n solution for 2.4GHz band
72.1Mbps reveive PHY rate and 72.2Mbps transmit
150Mbps receive PHY rate and 150Mbps transmit PHY rate using 40MHzbandwidth
Compatible with 802.11n specification
Backward compatible with 802.11b/g devices while operating in802.11n mode
闪存是镁光 PFB48大S降级颗粒,外壳上标的是8G,没找到资料
背部光秃秃
无线的内置天线
拆解全家福!
拆解完毕,谢谢大家支持!
[ 此帖被184562832在2018-04-12 11:22重新编辑 ]
本帖最近打赏记录:共11条打赏M币+104专家+2
温力口 M币 +9 谢谢分享。。。认真发贴。。。 2018-04-10
yzs8414 专家 +1 謝謝分享 2018-04-10
snowrose2000 M币 +13 这外壳好像贝尔的一款猫。。。 2018-04-10
williamgarci M币 +13 謝謝分享 2018-04-10
zhkrid M币 +9 A20现在是不是有点过时了,应该有性能更好的方案出来了吧 2018-04-10
闲来瞎逛 M币 +1 謝謝分享 2018-04-10
200birds M币 +13 - 2018-04-10
taoshptao 专家 +1 謝謝分享 2018-04-10
taoshptao M币 +20 謝謝分享 2018-04-10
hfsp M币 +13 謝謝分享 2018-04-10
12
离线kygggg
只看该作者 1楼 发表于: 2018-04-10
本帖最近打赏记录:共1条打赏M币+1
184562832 M币 +1 歡迎探討 2018-04-10
离线360安仔
只看该作者 2楼 发表于: 2018-04-10
本帖最近打赏记录:共1条打赏M币+1
184562832 M币 +1 精彩回帖 2018-04-10
离线linglong364
只看该作者 3楼 发表于: 2018-04-10
本帖最近打赏记录:共1条打赏M币+1
184562832 M币 +1 謝謝分享 2018-04-10
离线200birds
只看该作者 4楼 发表于: 2018-04-10
本帖最近打赏记录:共1条打赏M币+5
184562832 M币 +5 精彩回帖 2018-04-10
离线zhkrid
只看该作者 5楼 发表于: 2018-04-10
离线mhtlov
只看该作者 6楼 发表于: 2018-04-10
离线bigmilk
只看该作者 7楼 发表于: 2018-04-10
离线wx886688
只看该作者 8楼 发表于: 2018-04-10
离线snowrose2000
只看该作者 9楼 发表于: 2018-04-10
