  • 2286阅读
  • 3回复
[SandForce]求助,SF2281开卡卡在25%是什么回事 [复制链接]
离线moshuai2013
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2018-04-19
此悬赏帖已过期
最佳答案:10 M币,热心助人剩余点数: 5 M币。
Starting command:[/root/soft/SF_Genesis-v1.7.0.01020130612-fc14-32bit/SF_Genesis -PROCESS_SSD 2:0:0:0 "/root/mpt/FW_SF-2000_B01_MP1-refresh_3-1-9--0/FW_SF-2000_B01_MP1-refresh_3-1-9.0.mfp" "/root/mpt/FW_SF-2000_B01_MP1-refresh_3-1-9--0/21114.0.driveconfig" 0 0  LOG="/root/mpt/FW_SF-2000_B01_MP1-refresh_3-1-9--0/0_0_DATETIMESTAMP_2.0.0.0_PROCESS_SSD_RESULT.log"   ]...
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Fri 04/20/2018 04:10:38] - SF_Genesis has been invoked with the following parameters:
                      argv[1]: -PROCESS_SSD
                      argv[2]: 2:0:0:0
                      argv[3]: /root/mpt/FW_SF-2000_B01_MP1-refresh_3-1-9--0/FW_SF-2000_B01_MP1-refresh_3-1-9.0.mfp
                      argv[4]: /root/mpt/FW_SF-2000_B01_MP1-refresh_3-1-9--0/21114.0.driveconfig
                      argv[5]: 0
                      argv[6]: 0
                      argv[7]: LOG=/root/mpt/FW_SF-2000_B01_MP1-refresh_3-1-9--0/0_0_DATETIMESTAMP_2.0.0.0_PROCESS_SSD_RESULT.log
[Fri 04/20/2018 04:10:38] - Instructing the operating system to purge any existing cached data for device: '2:0:0:0'
[Fri 04/20/2018 04:10:43] - Issuing a discovery command for device: '2:0:0:0'
[Fri 04/20/2018 04:10:49] - Discovery command completed...
[Fri 04/20/2018 04:10:49] - Waiting 5 seconds for the system to settle...
[Fri 04/20/2018 04:10:54] - Device designation string '2:0:0:0' is mapped to node '/dev/sg1'
[Fri 04/20/2018 04:10:54] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg1
    MFP Package Filename = /root/mpt/FW_SF-2000_B01_MP1-refresh_3-1-9--0/FW_SF-2000_B01_MP1-refresh_3-1-9.0.mfp
      Configuration File = /root/mpt/FW_SF-2000_B01_MP1-refresh_3-1-9--0/21114.0.driveconfig
              Serial No. = 0
         World Wide Name = 0
[Fri 04/20/2018 04:10:54] - Successfully received the IDENTIFY data from the drive...
[Fri 04/20/2018 04:10:54] - Validating Manufacturing Firmware Package: /root/mpt/FW_SF-2000_B01_MP1-refresh_3-1-9--0/FW_SF-2000_B01_MP1-refresh_3-1-9.0.mfp
[Fri 04/20/2018 04:11:00] - Successfully opened the package: /root/mpt/FW_SF-2000_B01_MP1-refresh_3-1-9--0/FW_SF-2000_B01_MP1-refresh_3-1-9.0.mfp
[Fri 04/20/2018 04:11:01] - file  /root/mpt/FW_SF-2000_B01_MP1-refresh_3-1-9--0/21114.0.driveconfig Loaded successfully
[Fri 04/20/2018 04:11:01] - Warning:  Unable to query diagnostics information to perform power management settings check
[Fri 04/20/2018 04:11:01] - B01 Power Management configuration request detected
[Fri 04/20/2018 04:11:01] - Successfully extracted *.DriveConfig file: /root/mpt/FW_SF-2000_B01_MP1-refresh_3-1-9--0/21114.0.driveconfig
[Fri 04/20/2018 04:11:01] - Extracted Config_ID: 1 (21114) in DriveConfig file: /root/mpt/FW_SF-2000_B01_MP1-refresh_3-1-9--0/21114.0.driveconfig
[Fri 04/20/2018 04:11:01] - Extracted SerialOutputControl: 0
[Fri 04/20/2018 04:11:01] - Searching for flashware image for configuration 21114
[Fri 04/20/2018 04:11:01] - Manifest found for configuration 21114
[Fri 04/20/2018 04:11:01] - Flashware image extracted: 21114_fw_cl_mlc_Intel_64Gb_JS29F16B08CAME1_1Q_2C_1D_PP_R00691_s512.vic
[Fri 04/20/2018 04:11:01] - Searching for manufacturing image for configuration 21114
[Fri 04/20/2018 04:11:01] - Manufacturing image extracted: 21114_mf_mlc_Intel_64Gb_JS29F16B08CAME1_1Q_2C_1D_PP_R00691_s512.vic
[Fri 04/20/2018 04:11:01] - Proceeding in ROM mode, download feature 3...
[Fri 04/20/2018 04:15:52] - FATAL_ERROR: Could not download MFB to the drive...(0x11000001:SF_SG_DEVICE_CHECK_CONDITION_ERROR)
Extended Error data:
          ATA COMMAND : 0x0092  (146)
          ATA FEATURE : 0x0003  (3)
         Device Status: 0x0001  (1)
         Driver Status: 0x0000  (0)
           Host Status: 0x0008  (8)
Sense Data:
  0 -         No Sense: 114 (0x72)    OK
  1 -  Recovered Error:  11 (0x0B)    FAIL
  2 -        Not Ready:   0 (0x00)    OK
  3 -     Medium Error:   0 (0x00)    OK
  4 -   Hardware Error:   0 (0x00)    OK
  5 -  Illegal Request:   0 (0x00)    OK
  6 -   Unit Attention:   0 (0x00)    OK
  7 -     Data Protect:  14 (0x0E)    OK
  8 -      Blank Check:   9 (0x09)    OK
  9 -  Vendor Specific:  12 (0x0C)    OK
10 -     Copy Aborted:   0 (0x00)    OK
11 -  Aborted Command:   0 (0x00)    OK
12 - Equal Comparison:   0 (0x00)    NA
13 -  Volume Overflow:   0 (0x00)    NA
14 -       Miscompare:   0 (0x00)    OK
15 -         Reserved: 128 (0x80)    NA
System Trace:
[  330.016166] ata3.00: failed command: DOWNLOAD MICROCODE
[  330.016180] ata3.00: cmd 92/03:50:00:80:01/00:00:00:00:00/00 tag 0 pio 40960 out
[  330.016183]          res 40/00:00:80:00:00/00:00:00:00:00/e0 Emask 0x4 (timeout)
[  330.016189] ata3.00: status: { DRDY }
[  330.016201] ata3: hard resetting link
[  340.016165] ata3: softreset failed (1st FIS failed)
[  340.016174] ata3: hard resetting link
[  350.016160] ata3: softreset failed (1st FIS failed)
[  350.016168] ata3: hard resetting link
[  385.016164] ata3: softreset failed (1st FIS failed)
[  385.016175] ata3: limiting SATA link speed to 1.5 Gbps
[  385.016181] ata3: hard resetting link
[  390.217177] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[  390.217185] ata3.00: link online but device misclassifed
[  395.217170] ata3.00: qc timeout (cmd 0xec)
[  395.217182] ata3.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[  395.217188] ata3.00: revalidation failed (errno=-5)
[  395.217196] ata3: hard resetting link
[  405.217160] ata3: softreset failed (1st FIS failed)
[  405.217169] ata3: hard resetting link
[  415.217109] ata3: softreset failed (1st FIS failed)
[  415.217118] ata3: hard resetting link
[  450.218163] ata3: softreset failed (1st FIS failed)
[  450.218174] ata3: hard resetting link
[  455.419181] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[  455.419212] ata3.00: link online but device misclassifed
[  465.419228] ata3.00: qc timeout (cmd 0xec)
[  465.419240] ata3.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[  465.419245] ata3.00: revalidation failed (errno=-5)
[  465.419254] ata3: hard resetting link
[  475.419160] ata3: softreset failed (1st FIS failed)
[  475.419168] ata3: hard resetting link
[  485.419163] ata3: softreset failed (1st FIS failed)
[  485.419172] ata3: hard resetting link
[  520.419112] ata3: softreset failed (1st FIS failed)
[  520.419122] ata3: hard resetting link
[  525.620183] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[  525.620191] ata3.00: link online but device misclassifed
[  555.620175] ata3.00: qc timeout (cmd 0xec)
[  555.620187] ata3.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[  555.620192] ata3.00: revalidation failed (errno=-5)
[  555.620197] ata3.00: disabled
[  555.620218] ata3: hard resetting link
[  565.620173] ata3: softreset failed (1st FIS failed)
[  565.620181] ata3: hard resetting link
[  575.620173] ata3: softreset failed (1st FIS failed)
[  575.620181] ata3: hard resetting link
[  610.620173] ata3: softreset failed (1st FIS failed)
[  610.620183] ata3: hard resetting link
[  615.821137] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[  615.821145] ata3.00: link online but device misclassifed
[  615.821173] ata3: EH complete
[Fri 04/20/2018 04:15:52] - End of Genesis manufacturing log.
[Fri 04/20/2018 04:15:52] - Exiting...
[Fri 04/20/2018 04:15:52] - Overall Result for Device: /dev/sg1 ****** FAIL ******
Process exited with code 20
只看该作者 1楼 发表于: 2018-04-24
离线tcgg1983
只看该作者 2楼 发表于: 2018-04-25
离线2017shuma
只看该作者 3楼 发表于: 2018-04-25
