  • 3134阅读
  • 8回复
[Indilinx]开卡失败求助 [复制链接]
离线water0000000
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2018-05-17
威刚SP900固态 128g 在fedora下开卡,使用SF的开卡工具,FW-PPRO-5-2-2-Release.672199.release--0,里面两个文件FFP和MFP与其他的开卡工具内dfp文件感觉不一样,不会用,直接用的里面的Configuration-Files文件夹里的28044开卡,但是每一次都是格式化不了,固态硬盘一直短接的ROM,这个没问题,不在ROM模式下到不了这一步。请教原因,该如何卡开?代码如下所示:
[root@localhost   SF]# lsscsi
[0:0:0:0]    disk    ATA      SILICONMOTION SM O122  /dev/sda
[16:0:0:0]   disk    IT-CEO   Storage          0204  /dev/sdb
[root@localhost   SF]# sudo  ./SF_Genesis -PROCESS_SSD 16:0:0:0 /home/hzq/SF/mpt/FW_PPRO_5_2_2_Release.672199.release.0.mfp /home/hzq/SF/28044.0.driveconfig 12345 www_123 log=/home/hzq/SF/mpt/SF-2241 VB2-SPSEHR12A50 1412.log
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Fri 05/18/2018 01:18:29] - SF_Genesis has been invoked with the following parameters:
                      argv[1]: -PROCESS_SSD
                      argv[2]: 16:0:0:0
                      argv[3]: /home/hzq/SF/mpt/FW_PPRO_5_2_2_Release.672199.release.0.mfp
                      argv[4]: /home/hzq/SF/28044.0.driveconfig
                      argv[5]: 12345
                      argv[6]: www_123
                      argv[7]: log=/home/hzq/SF/mpt/SF-2241
                      argv[8]: VB2-SPSEHR12A50
                      argv[9]: 1412.log
[Fri 05/18/2018 01:18:29] - Instructing the operating system to purge any existing cached data for device: '16:0:0:0'
[Fri 05/18/2018 01:18:34] - Issuing a discovery command for device: '16:0:0:0'
[Fri 05/18/2018 01:18:39] - Discovery command completed...
[Fri 05/18/2018 01:18:39] - Waiting 5 seconds for the system to settle...
[Fri 05/18/2018 01:18:44] - Device designation string '16:0:0:0' is mapped to node '/dev/sg1'
[Fri 05/18/2018 01:18:44] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg1
    MFP Package Filename = /home/hzq/SF/mpt/FW_PPRO_5_2_2_Release.672199.release.0.mfp
      Configuration File = /home/hzq/SF/28044.0.driveconfig
              Serial No. = 12345
         World Wide Name = www_123
[Fri 05/18/2018 01:18:44] - Successfully received the IDENTIFY data from the drive...
[Fri 05/18/2018 01:18:44] - Validating Manufacturing Firmware Package: /home/hzq/SF/mpt/FW_PPRO_5_2_2_Release.672199.release.0.mfp
[Fri 05/18/2018 01:18:52] - Successfully opened the package: /home/hzq/SF/mpt/FW_PPRO_5_2_2_Release.672199.release.0.mfp
[Fri 05/18/2018 01:18:52] - file  /home/hzq/SF/28044.0.driveconfig Loaded successfully
[Fri 05/18/2018 01:19:00] - B01 Power Management configuration request detected
[Fri 05/18/2018 01:19:00] - B01 Power Management conforms to hardware version 0x0
[Fri 05/18/2018 01:19:00] - Successfully extracted *.DriveConfig file: /home/hzq/SF/28044.0.driveconfig
[Fri 05/18/2018 01:19:00] - Extracted Config_ID: 1 (28044) in DriveConfig file: /home/hzq/SF/28044.0.driveconfig
[Fri 05/18/2018 01:19:00] - Extracted SerialOutputControl: 0
[Fri 05/18/2018 01:19:00] - Searching for flashware image for configuration 28044
[Fri 05/18/2018 01:19:00] - Manifest found for configuration 28044
[Fri 05/18/2018 01:19:00] - Flashware image extracted: 28044_fw_cl_mlc_MIC_64Gb_MT29F128G08CFABBWP_1Q_4C_1D_S_PP_R01358_s512.vic
[Fri 05/18/2018 01:19:00] - Searching for manufacturing image for configuration 28044
[Fri 05/18/2018 01:19:00] - Manufacturing image extracted: 28044_mf_mlc_MIC_64Gb_MT29F128G08CFABBWP_1Q_4C_1D_S_PP_R01358_s512.vic
[Fri 05/18/2018 01:19:00] - Proceeding in ROM mode, download feature 3...
[Fri 05/18/2018 01:19:01] - Successfully downloaded MFB to the drive...
[Fri 05/18/2018 01:19:01] - Waiting (5 sec) for the drive to settle...
[Fri 05/18/2018 01:19:06] - Successfully received the IDENTIFY data from the drive...
[Fri 05/18/2018 01:19:06] - Firmware revision reported to be: '522ABBM0'.  This indicates MFB download was successful.
[Fri 05/18/2018 01:19:06] - Successfully enabled SMART capabilities...
[Fri 05/18/2018 01:19:08] - Successfully issued a diagnostic unlock...
[Fri 05/18/2018 01:19:09] - Performing the flash test of block 0 (0x0000)...
[Fri 05/18/2018 01:19:11] - Flash Test Results:
Flash Test Parameters:
               Block Count: 0
                Page Count: 1
                 Bus Count: 1
        Chip Enabled Count: 4
                 Die Count: 1
                Lane Count: 4
               Plane Count: 2
Results Notes:
   N1 - At least one page tested and passed with no bit errors.
   N2 - No test data available.  Test may have aborted, or failed during the testing.
   N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
   N4 - At least  one erased page tested had bit error rate greater than half the correction power.
   N5 - Walking zeros test failed.
   N6 - Walking ones test failed.
   N7 - Block contained factory bad block markings and testing was skipped.
   N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
   N9 - Block in plane 0 was marked as a factory bad block.
  N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
  N11 - Block in plane 1 was marked as a factory bad block.
| Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |
| 0    | 0    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 2    | 0x0003 | N1,N3                                      | WARNING |
| 0    | 0    | 0    | 3    | 0x0003 | N1,N3                                      | WARNING |
| 0    | 1    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 0    | 2    | 0    | 0    | 0x0003 | N1,N3                                      | WARNING |
| 0    | 2    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 2    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 2    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 0    | 3    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 3    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 3    | 0    | 2    | 0x0003 | N1,N3                                      | WARNING |
| 0    | 3    | 0    | 3    | 0x0001 | N1                                         |    PASS |
  Total Number of test results: 16
            Number of failures: 0
         Number of Passed with warnings: 4
      No. Passed without warnings: 12
[Fri 05/18/2018 01:19:11] - Performing the FORMAT Command with the following parameters:
         MemoryWearCycleCapability = 0
              CurrentPE_CycleCount = 0
                     LifeInSeconds = 0
                   LogicalCapacity = 250069680
                        SectorSize = 512
             SectorAlignmentOffset = 0
                  ExpectedMemoryID = 25644 (0x642C)
                   ExpectedNumDies = 0
               SerialOutputControl = 0
                           Time[8] = 0x0000000000000000
            MiscFlag_Erase_R_Block = 0
     MiscFlag_PanicHandlingEnabled = 0
        MiscFlag_PanicOnSATA_Error = 0
  MiscFlag_WriteThrottlingTestMode = 0
      MiscFlag_DisableUserBandECCX = 1
                        L_PageSize = 0
                        E_PageSize = 0
              ErrorCorrectionPower = 0
      ConfigDeviceReadDisturbCount = 0
   ConfigDeviceReadDisturbCountLow = 0
                  ExtraOptions_0_1 = 0
[Fri 05/18/2018 01:19:34] - FATAL_ERROR: Could not perform the FORMAT() operation on the drive... (0x0000C048:SF_SCT (C048h): Root Creation Failed (MFB format))
[Fri 05/18/2018 01:19:34] - End of Genesis manufacturing log.
[Fri 05/18/2018 01:19:34] - Exiting...
[Fri 05/18/2018 01:19:34] - Overall Result for Device: /dev/sg1 ****** FAIL ******
本帖提到的人: @localhost
离线water0000000
只看该作者 1楼 发表于: 2018-05-17
离线zhao6866933
只看该作者 2楼 发表于: 2018-05-17
离线water0000000
只看该作者 3楼 发表于: 2018-05-17
回 zhao6866933 的帖子
离线zhao6866933
只看该作者 4楼 发表于: 2018-05-17
离线zhao6866933
只看该作者 5楼 发表于: 2018-05-17
离线water0000000
只看该作者 6楼 发表于: 2018-05-18
回 zhao6866933 的帖子
离线water0000000
只看该作者 7楼 发表于: 2018-05-18
回 water0000000 的帖子
离线water0000000
只看该作者 8楼 发表于: 2018-05-18
本帖提到的人: @localhost
