  • 5724阅读
  • 11回复
[SandForce]SF2281错误,29F64B08PCME1板子是INTEL 525 固件是修改Lic从6_0_A提取出来的29555 [复制链接]
离线ddd111222
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2018-09-06
此帖悬赏结束
最佳答案:50 M币,最佳答案获得者:perter
板子是INTEL 525 msata 修改Lic提取出来的29555
[root@a SF_Genesis-v1.7]#  ./SF_Genesis -PROCESS_SSD 10:0:0:0 /home/1/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456.mfp /home/1/mpt/29555.123456.driveconfig 0 0 LOG=/home/1/mpt/Results_Test_PackageManager.log
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Sat 09/08/2018 03:25:42] - SF_Genesis has been invoked with the following parameters:
                      argv[1]: -PROCESS_SSD
                      argv[2]: 10:0:0:0
                      argv[3]: /home/1/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456.mfp
                      argv[4]: /home/1/mpt/29555.123456.driveconfig
                      argv[5]: 0
                      argv[6]: 0
                      argv[7]: LOG=/home/1/mpt/Results_Test_PackageManager.log
[Sat 09/08/2018 03:25:42] - Instructing the operating system to purge any existing cached data for device: '10:0:0:0'
[Sat 09/08/2018 03:25:47] - Issuing a discovery command for device: '10:0:0:0'
[Sat 09/08/2018 03:25:52] - Discovery command completed...
[Sat 09/08/2018 03:25:52] - Waiting 5 seconds for the system to settle...
[Sat 09/08/2018 03:25:57] - Device designation string '10:0:0:0' is mapped to node '/dev/sg1'
[Sat 09/08/2018 03:25:57] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg1
    MFP Package Filename = /home/1/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456.mfp
      Configuration File = /home/1/mpt/29555.123456.driveconfig
              Serial No. = 0
         World Wide Name = 0
[Sat 09/08/2018 03:25:57] - Successfully received the IDENTIFY data from the drive...
[Sat 09/08/2018 03:25:57] - Validating Manufacturing Firmware Package: /home/1/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456.mfp
[Sat 09/08/2018 03:25:57] - FATAL_ERROR: The package supplied: /home/1/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456.mfp is not a valid Manufacturing Firmware Package (*.mfp) type. Unabled to open file: /home/1/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456.mfp for reading
[Sat 09/08/2018 03:25:57] - End of Genesis manufacturing log.
[Sat 09/08/2018 03:25:57] - Exiting...
[Sat 09/08/2018 03:25:57] - Overall Result for Device: /dev/sg1 ****** FAIL ******
[ 此帖被ddd111222在2018-09-07 22:06重新编辑 ]
离线perter
只看该作者 1楼 发表于: 2018-09-08
回 ddd111222 的帖子
最佳答案奖励:+50 M币
离线nfy123
只看该作者 2楼 发表于: 2018-09-07
热心助人奖励:+1 M币
离线perter
只看该作者 3楼 发表于: 2018-09-07
热心助人奖励:+1 M币
离线perter
只看该作者 4楼 发表于: 2018-09-07
回 ddd111222 的帖子
热心助人奖励:+1 M币
本帖最近打赏记录:共1条打赏M币+15
ddd111222 M币 +15 認真發帖 2018-09-08
离线ddd111222
只看该作者 5楼 发表于: 2018-09-07
离线ddd111222
只看该作者 6楼 发表于: 2018-09-07
回 nfy123 的帖子
离线ddd111222
只看该作者 7楼 发表于: 2018-09-07
回 perter 的帖子
离线ddd111222
只看该作者 8楼 发表于: 2018-09-07
回 perter 的帖子
离线perter
只看该作者 9楼 发表于: 2018-09-08
回 ddd111222 的帖子
