0x5002 "SCSI STARTSTOPUNIT COMMAND ERROR",
0x5003 "VENDOR GETCONFIG COMMAND ERROR",
0x5004 "NO FLASH OR UNSUPPORTED ERROR",
0x5005 "READ_FLASHID_ERROR",
0x5006 "CHIP SIZE LARGER THAN FIRST FLASH ERROR",
0x5007 "CAN NOT FIND MATCHED FLASH ERROR",
0x5008 "INVALID FLASH MIXED ERROR",
0x5009 "FIND FLASHINFO FUNCTION ERROR",
0x500A "SET PARAMETER ERROR",
0x500B "GET SIB ERROR",
0x500C "ADVANCED SEARCH DRIVE LETTER ERROR",
0x500D "QC TEST COPYFILE ERROR",
0x500E "QC TEST FILEOPEN ERROR",
0x500F "QC TEST COMPARE ERROR",
0x5010 "QC TEST DELETEFILE ERROR",
0x5011 "NO ENOUGH GOOD BLOCK",
0x5012 "BUILD XBBT ON FLASH ERROR",
0x5013 "GET XBBT ERROR",
0x5014 "BUFFER MEMORY ALLOC ERROR",
0x5015 "BLOCK0 IS BAD BLOCK ERROR",
0x5016 "VENDOR ERASE FLASH CONMMAND ERROR",
0x5017 "FILL SIB STRUCT ERROR",
0x5018 "BUILD SIB ERROR",
0x5019 "VENDOR READ/WRITE MEMORY COMMAND ERROR",
0x501A "VENDOR SOFT RESET COMMAND ERROR",
0x501B "NO SIB ERROR",
0x501C "CHS VALUE ERROR",
0x501D "FDISK ERROR",
0x501E "FORMAT ERROR",
0x501F "FDISK FORAMT ERROR",
0x5020 "ISO FILEOPEN ERROR",
0x5021 "ISO FILEREAD ERROR",
0x5022 "ISO FILEWRITE ERROR",
0x5023 "COPY ISO ERROR",
0x5024 "MODIFY ELEMENT ATTRIBUTE ERROR",
0x5025 "SET VOLUME LABEL ERROR",
0x5026 "WRITE PROTECT ERROR, PLEASE TURN-OFF WRITE PROTECT OF FLASH",
0x5027 "WRITE PROTECT SWITCH ERROR, PLEASE TURN-OFF WRITE PROTECT",
0x5028 "ACQUIRE DEVICE HANDLE ERROR",
0x5029 "USER ABORT",
0x502A "NO PRODUCTION ERROR",
0x502B "CONTROLLER NOT SUPPORT AGAND TYPE FLASH",
0x502C "CONTROLLER NOT SUPPORT AGAND DUAL CHANNEL MODE",
0x502D "LUN SIZE SETTING VALUE CAN'T GREATER THAN UDISK SIZE",
0x502E "BUILD ZT ERROR",
0x502F "SERIAL NUMBER ERROR",
0x5030 "LUN ONE SIZE VALUE ERROR",
0x5031 "THE ELEMENT ONE OF LUN ONE SIZE VALUE ERROR",
0x5032 "THE ELEMENT ONE OF LUN TWO SIZE VALUE ERROR",
0x5033 "THE SERIAL NUMBER LENGTH INVALID",
0x5034 "THE ELEMENT SIZE IS LARGER THAN THE LUN SIZE",
0x5035 "THERE ARE NOT ENOUGH SPACE ON THE DISK",
0x5036 "VNDR ENTER VMODE ERROR",
0x5037 "VNDR SET BUS WIDTH ERROR",
0x5038 "READ FW PKG FILE ERROR",
0x5039 "VNDR ROMTORAM ERROR",
0x503A "BUILD FW BLOCK ERROR",
0x503B "BUILD CIT1 ERROR",
0x503C "BUILD CIT2 ERROR",
0x503D "VNDR EXIT VMODE ERROR",
0x503E "VNDR COMMAND CD ERROR",
0x503F "UNKNOW CARD TYPE OR CARD TYPE SELECT ERROR",
0x5040 "SET PARA ERROR",
0x5041 "TEST UNIT READY ERROR",
0x5042 "THE CAPACITY OF BUILD ZT IS ZERO",
0x5043 "WRITE MKB ERROR",
0x5044 "NOT FIND MATCH PKG ERROR",
0x5045 "COPY FILE ERROR",
0x5046 "VENDOR WRITE SECTOR ERROR",
0x5047 "VENDOR READ SECTOR ERROR",
0x5048 "VENDOR COMMAND 13 ERROR",
0x5049 "CONTROLLER TEST ERROR",
0x504A "FLASH OPTIMIZATION SETTING ERROR",
0x504B "MAPTABLE_FILECONVERT_ERROR",
0x504C "VERCODE DECODE ERROR",
0x504D "FIXED CAPACITY VALUE ERROR",
0x504E "READ WRITE TEST ERROR",
0x504F "GET CONFIG ERROR",
0x5050 "QC TEST GET CAPACITY ERROR",
0x5051 "MARK-SCAN FAIL",
0x5052 "COPY FILES TO PRIVATE-AREA ERROR",
0x5053 "VENDOR FLASHGETSTATUS COMMAND ERROR",
0x5054 "COPY DIRECTORY DATA FAIL",
0x5055 "ISO FILENAME ERROR"
希望能帮助大家维修
