  • 4218阅读
  • 11回复
[SandForce]开卡失败(已成功) [复制链接]
离线wan06
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2018-10-08
<?xml version = "1.0"?>
<Genesis_Log>
    <Log_Body>
Overall Summary:
                Start Time: Mon, 10/08/2018 @ 18:18:40
                  End Time: Mon, 10/08/2018 @ 18:19:07
             OverallResult: FAIL
                  ExitCode: (0x10090014:SF_GENESIS_FW_DOWNLOAD_ERROR)
Environment Settings:
          Input Parameters:
                  argv[1]: -PROCESS_SSD
                  argv[2]: 7:0:0:0
                  argv[3]: /root/下载/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
                  argv[4]: /root/下载/FW_PPRO_6_0_A_Release.1134440.release--123456/Configuration_Files/22435.123456.edriveconfig
                  argv[5]: 12345678
                  argv[6]: 87654321
                  argv[7]: LOG=/root/下载/FW_PPRO_6_0_A_Release.1134440.release--123456/Configuration_Files/12345678_localhost.localdomain_DATETIMESTAMP_7.0.0.0_PROCESS_SSD_RESULT.log
                  argv[8]: -EEPROM=/root/下载/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
                  Log File: /root/下载/FW_PPRO_6_0_A_Release.1134440.release--123456/Configuration_Files/12345678_localhost.localdomain_DATETIMESTAMP_7.0.0.0_PROCESS_SSD_RESULT.log
                  Hostname: localhost.localdomain
           Host IP Address: 127.0.0.1
               Port Number: 2
                DeviceName: /dev/sg2
        SF_Genesis Version: v1.7.0.01020130612-fc14-32bit
   SF_Core Library Version: v1.7.1.20130612-fc14-32bit
         SF_OS_Information: Linux 4.5.5-300.fc24.i686+PAE #1 SMP Thu May 19 13:24:07 UTC 2016 i686
Post Processing Device Information:
                   WWN OUI: UNKNOWN
              WWN UniqueID: UNKNOWN
                Serial No.: UNKNOWN
                 Model No.: UNKNOWN
         Firmware Revision: UNKNOWN
              ROM Revision: UNKNOWN
            NAND Page Size: UNKNOWN
     Number Of Chip Enable: UNKNOWN
           Logical Sectors: UNKNOWN
                   NAND ID: UNKNOWN
        Flash Manufacturer: UNKNOWN
              Flash Device: UNKNOWN
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Mon 10/08/2018 18:18:40] - SF_Genesis has been invoked with the following parameters:
                      argv[2]: 7:0:0:0
                      argv[5]: 12345678
                      argv[6]: 87654321
[Mon 10/08/2018 18:18:40] - Instructing the operating system to purge any existing cached data for device: '7:0:0:0'
[Mon 10/08/2018 18:18:45] - Issuing a discovery command for device: '7:0:0:0'
[Mon 10/08/2018 18:18:50] - Discovery command completed...
[Mon 10/08/2018 18:18:50] - Waiting 5 seconds for the system to settle...
[Mon 10/08/2018 18:18:55] - Device designation string '7:0:0:0' is mapped to node '/dev/sg2'
[Mon 10/08/2018 18:18:55] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg2
    MFP Package Filename = /root/下载/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
      Configuration File = /root/下载/FW_PPRO_6_0_A_Release.1134440.release--123456/Configuration_Files/22435.123456.edriveconfig
              Serial No. = 12345678
         World Wide Name = 87654321
[Mon 10/08/2018 18:18:55] - Successfully received the IDENTIFY data from the drive...
[Mon 10/08/2018 18:18:55] - Validating Manufacturing Firmware Package: /root/下载/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
[Mon 10/08/2018 18:18:55] - Successfully opened the package: /root/下载/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
[Mon 10/08/2018 18:18:55] - File : /root/下载/FW_PPRO_6_0_A_Release.1134440.release--123456/Configuration_Files/22435.123456.edriveconfig in processing ...
[Mon 10/08/2018 18:18:55] - file  /root/下载/FW_PPRO_6_0_A_Release.1134440.release--123456/Configuration_Files/22435.123456.edriveconfig Loaded successfully
[Mon 10/08/2018 18:19:01] - Warning:  Unable to query diagnostics information to perform power management settings check
[Mon 10/08/2018 18:19:01] - B01 Power Management configuration request detected
[Mon 10/08/2018 18:19:01] - Successfully extracted *.DriveConfig file: /root/下载/FW_PPRO_6_0_A_Release.1134440.release--123456/Configuration_Files/22435.123456.edriveconfig
[Mon 10/08/2018 18:19:01] - Extracted Config_ID: 1 (22435) in DriveConfig file: /root/下载/FW_PPRO_6_0_A_Release.1134440.release--123456/Configuration_Files/22435.123456.edriveconfig
[Mon 10/08/2018 18:19:01] - Extracted SerialOutputControl: 0
[Mon 10/08/2018 18:19:01] - Searching for flashware image for configuration 22435
[Mon 10/08/2018 18:19:01] - Manifest found for configuration 22435
[Mon 10/08/2018 18:19:01] - Flashware image extracted: 22435_fw_cl_mlc_Micron_32Gb_MT29F128G08CBACAWP_2Q_4C_1D_S_PP_R01088_s512.vic
[Mon 10/08/2018 18:19:01] - Searching for manufacturing image for configuration 22435
[Mon 10/08/2018 18:19:01] - Manufacturing image extracted: 22435_mf_mlc_Micron_32Gb_MT29F128G08CBACAWP_2Q_4C_1D_S_PP_R01088_s512.vic
[Mon 10/08/2018 18:19:01] - Proceeding in ROM mode, download feature 3...
[Mon 10/08/2018 18:19:07] - FATAL_ERROR: Could not download MFB to the drive...(0x13000006:SF_SG_DRIVER_TIMEOUT_ERROR)
[Mon 10/08/2018 18:19:07] - End of Genesis manufacturing log.
[Mon 10/08/2018 18:19:07] - Exiting...
    </Log_Body>
    <Overall_Summary>
        <Start_Time> Mon, 10/08/2018 @ 18:18:40 </Start_Time>
        <End_Time> Mon, 10/08/2018 @ 18:19:07 </End_Time>
        <Overall_Result> FAIL </Overall_Result>
        <Exit_Code> (0x10090014:SF_GENESIS_FW_DOWNLOAD_ERROR) </Exit_Code>
    </Overall_Summary>
    <Environment_Settings>
        <Input_Parameters>
                  argv[2]: 7:0:0:0
                  argv[5]: 12345678
                  argv[6]: 87654321
        </Input_Parameters>
        <Log_File> /root/下载/FW_PPRO_6_0_A_Release.1134440.release--123456/Configuration_Files/12345678_localhost.localdomain_DATETIMESTAMP_7.0.0.0_PROCESS_SSD_RESULT.log </Log_File>
        <Hostname> localhost.localdomain </Hostname>
        <Host_IP_Address> 127.0.0.1 </Host_IP_Address>
        <Port_Number> 2 </Port_Number>
        <Device_Name> /dev/sg2 </Device_Name>
        <SF_Genesis_Version> v1.7.0.01020130612-fc14-32bit </SF_Genesis_Version>
        <SF_Core_Library_Version> v1.7.1.20130612-fc14-32bit </SF_Core_Library_Version>
        <SF_OS_Information> Linux 4.5.5-300.fc24.i686+PAE #1 SMP Thu May 19 13:24:07 UTC 2016 i686 </SF_OS_Information>
    </Environment_Settings>
    <Post_Processing_Device_Info>
        <WWN_OUI> UNKNOWN </WWN_OUI>
        <WWN_UniqueID> UNKNOWN </WWN_UniqueID>
        <Serial_Number> UNKNOWN </Serial_Number>
        <Model_Number> UNKNOWN </Model_Number>
        <Firmware_Revision> UNKNOWN </Firmware_Revision>
        <ROM_Revision> UNKNOWN </ROM_Revision>
        <NAND_Page_Size> UNKNOWN </NAND_Page_Size>
        <Number_Of_Chip_Enable> UNKNOWN </Number_Of_Chip_Enable>
        <Logical_Sectors> UNKNOWN </Logical_Sectors>
        <NAND_ID> UNKNOWN </NAND_ID>
        <Flash_Manufacturer> UNKNOWN </Flash_Manufacturer>
        <Flash_Device> UNKNOWN </Flash_Device>
    </Post_Processing_Device_Info>
</Genesis_Log>
[Mon 10/08/2018 18:19:07] - Overall Result for Device: /dev/sg2 ****** FAIL ******
[ 此帖被wan06在2018-10-10 12:52重新编辑 ]
本帖最近打赏记录:共4条打赏M币+44
超级女生 M币 +5 歡迎探討 2018-10-20
jf201006 M币 +13 謝謝分享  我居然看完了 2018-10-09
中心小学 M币 +13 这不影响的评M成功 2018-10-08
kyhwhb M币 +13 優秀文章 2018-10-08
离线中心小学
只看该作者 1楼 发表于: 2018-10-08
本帖最近打赏记录:共3条打赏M币+11
bhzjr M币 +2 歡迎探討 2018-10-09
wan06 M币 +8 歡迎探討 2018-10-09
jf201006 M币 +1 精彩回帖 2018-10-09
离线jf201006
只看该作者 2楼 发表于: 2018-10-09
本帖最近打赏记录:共1条打赏M币+8
离线wan06
只看该作者 3楼 发表于: 2018-10-09
回 中心小学 的帖子
离线wan06
只看该作者 4楼 发表于: 2018-10-09
回 jf201006 的帖子
本帖最近打赏记录:共1条打赏M币+1
jf201006 M币 +1 精彩回帖  以为是汉语拼音呢 哈哈哈 2018-10-09
离线perter
只看该作者 5楼 发表于: 2018-10-09
本帖最近打赏记录:共1条打赏M币+2
wan06 M币 +2 熱心助人 2018-10-09
离线jf201006
只看该作者 6楼 发表于: 2018-10-09
本帖最近打赏记录:共1条打赏M币+1
wan06 M币 +1 拼音和英语都是26个字母组合,谁能解释一下? 2018-10-09
离线wan06
只看该作者 7楼 发表于: 2018-10-09
离线wan06
只看该作者 8楼 发表于: 2018-10-09
离线466878778
只看该作者 9楼 发表于: 2018-10-09
