  • 16436阅读
  • 29回复
i5128/i5122的错误代码(有朋友已经发过了.我在后面加了个中文解说) [复制链接]
离线pengdongop
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2008-03-03
0x5002        "SCSI STARTSTOPUNIT COMMAND ERROR",
0x5003        "VENDOR GETCONFIG COMMAND ERROR",
0x5004        "NO FLASH OR UNSUPPORTED ERROR",
0x5005        "READ_FLASHID_ERROR",
0x5006        "CHIP SIZE LARGER THAN FIRST FLASH ERROR",
0x5007        "CAN NOT FIND MATCHED FLASH ERROR",
0x5008        "INVALID FLASH MIXED ERROR",
0x5009        "FIND FLASHINFO FUNCTION ERROR",
0x500A        "SET PARAMETER ERROR",
0x500B        "GET SIB ERROR",
0x500C        "ADVANCED SEARCH DRIVE LETTER ERROR",
0x500D        "QC TEST COPYFILE ERROR",
0x500E        "QC TEST FILEOPEN ERROR",
0x500F        "QC TEST COMPARE ERROR",
0x5010        "QC TEST DELETEFILE ERROR",
0x5011        "NO ENOUGH GOOD BLOCK",
0x5012        "BUILD XBBT ON FLASH ERROR",
0x5013        "GET XBBT ERROR",
0x5014        "BUFFER MEMORY ALLOC ERROR",
0x5015        "BLOCK0 IS BAD BLOCK ERROR",
0x5016        "VENDOR ERASE FLASH CONMMAND ERROR",
0x5017        "FILL SIB STRUCT ERROR",
0x5018        "BUILD SIB ERROR",
0x5019        "VENDOR READ/WRITE MEMORY COMMAND ERROR",
0x501A        "VENDOR SOFT RESET COMMAND ERROR",
0x501B        "NO SIB ERROR",
0x501C        "CHS VALUE ERROR",
0x501D        "FDISK ERROR",
0x501E        "FORMAT ERROR",
0x501F        "FDISK FORAMT ERROR",
0x5020        "ISO FILEOPEN ERROR",
0x5021        "ISO FILEREAD ERROR",
0x5022        "ISO FILEWRITE ERROR",
0x5023        "COPY ISO ERROR",
0x5024        "MODIFY ELEMENT ATTRIBUTE ERROR",
0x5025        "SET VOLUME LABEL ERROR",
0x5026        "WRITE PROTECT ERROR, PLEASE TURN-OFF WRITE PROTECT OF FLASH",
0x5027        "WRITE PROTECT SWITCH ERROR, PLEASE TURN-OFF WRITE PROTECT",
0x5028        "ACQUIRE DEVICE HANDLE ERROR",
0x5029        "USER ABORT",
0x502A        "NO PRODUCTION ERROR",
0x502B        "CONTROLLER NOT SUPPORT AGAND TYPE FLASH",
0x502C        "CONTROLLER NOT SUPPORT AGAND DUAL CHANNEL MODE",
0x502D        "LUN SIZE SETTING VALUE CAN'T GREATER THAN UDISK SIZE",
0x502E        "BUILD ZT ERROR",
0x502F        "SERIAL NUMBER ERROR",
0x5030        "LUN ONE SIZE VALUE ERROR",
0x5031        "THE ELEMENT ONE OF LUN ONE SIZE VALUE ERROR",
0x5032        "THE ELEMENT ONE OF LUN TWO SIZE VALUE ERROR",
0x5033        "THE SERIAL NUMBER LENGTH INVALID",
0x5034        "THE ELEMENT SIZE IS LARGER THAN THE LUN SIZE",
0x5035        "THERE ARE NOT ENOUGH SPACE ON THE DISK",
0x5036        "VNDR ENTER VMODE ERROR",
0x5037        "VNDR SET BUS WIDTH ERROR",
0x5038        "READ FW PKG FILE ERROR",
0x5039        "VNDR ROMTORAM ERROR",
0x503A        "BUILD FW BLOCK ERROR",
0x503B        "BUILD CIT1 ERROR",
0x503C        "BUILD CIT2 ERROR",
0x503D        "VNDR EXIT VMODE ERROR",
0x503E        "VNDR COMMAND CD ERROR",
0x503F        "UNKNOW CARD TYPE OR CARD TYPE SELECT ERROR",
0x5040        "SET PARA ERROR",
0x5041        "TEST UNIT READY ERROR",
0x5042        "THE CAPACITY OF BUILD ZT IS ZERO",
0x5043        "WRITE MKB ERROR",
0x5044        "NOT FIND MATCH PKG ERROR",
0x5045        "COPY FILE ERROR",
0x5046        "VENDOR WRITE SECTOR ERROR",
0x5047        "VENDOR READ SECTOR ERROR",
0x5048        "VENDOR COMMAND 13 ERROR",
0x5049        "CONTROLLER TEST ERROR",
0x504A        "FLASH OPTIMIZATION SETTING ERROR",
0x504B        "MAPTABLE_FILECONVERT_ERROR",
0x504C        "VERCODE DECODE ERROR",
0x504D        "FIXED CAPACITY VALUE ERROR",
0x504E        "READ WRITE TEST ERROR",
0x504F        "GET CONFIG ERROR",
0x5050        "QC TEST GET CAPACITY ERROR",
0x5051        "MARK-SCAN FAIL",
0x5052        "COPY FILES TO PRIVATE-AREA ERROR",
0x5053        "VENDOR FLASHGETSTATUS COMMAND ERROR",
0x5054        "COPY DIRECTORY DATA FAIL",
0x5055        "ISO FILENAME ERROR"
0 x5002    "SCSI STARTSTOPUNIT 指令错误",
0 x5003    "厂商 GETCONFIG 指令错误",
0 x5004    " 没有闪光或不支持错误",
0 x5005    "READ_FLASHID_ERROR",
0 x5006    " 薄片按规定尺寸制作大的比较第一的闪光错误",
0 x5007    "不能找相配闪光错误",
0 x5008    " 有病的闪光使错误混合了",
0 x5009    " 发现 FLASHINFO 动作错误",
0 x500A    "设定叁数错误",
0 x500B    "拿亲属的错误",
0 x500C    "进阶检索推进力信错误",
0 x500D    "QC 测试 COPYFILE 错误",
0 x500E    "QC 测试 FILEOPEN 错误",
0 x500F    "QC 测试比较错误",
0 x5010    "QC 测试 DELETEFILE 错误",
0 x5011    "没有充足的好区段",
0 x5012    "建立在闪光错误上的 XBBT",
0 x5013    "拿 XBBT 错误",
0 x5014    "缓冲记忆 ALLOC 错误",
0 x5015    "BLOCK0 是坏的区段错误",
0 x5016    "厂商消除闪光 CONMMAND 错误",
0 x5017    "填充亲属的 STRUCT 错误",
0 x5018    "建立亲属的错误",
0 x5019    " 厂商读/ 写记忆指令错误",
0 x501A    "厂商软的重新设定指令错误",
0 x501B    "没有亲属的错误",
0 x501C    "CHS 价值错误",
0 x501D    "FDISK 错误",
0 x501E    "格式错误",
0 x501F    "FDISK FORAMT 错误",
0 x5020    "ISO FILEOPEN 错误",
0 x5021    "ISO FILEREAD 错误",
0 x5022    "ISO FILEWRITE 错误",
0 x5023    "复印 ISO 错误",
0 x5024    "修正元素属性错误",
0 x5025    "设定体积标签错误",
0 x5026    " 写保护错误,请岔路写闪光保护",
0 x5027    " 写保护开关错误,请岔路写保护",
0 x5028    "获得装置柄错误",
0 x5029    "使用者放弃",
0 x502A    没有制造错误,
0 x502B    "控制器不支援 AGAND 类型闪光",
0 x502C    "控制器不支援 AGAND 双重的频道模态",
0 x502D    " LUN 大小设定价值不能包括市区及郊区的比较 UDISK 大小",
0 x502E    "建立 ZT 错误",
0 x502F    "序号错误",
0 x5030    "LUN 大小价值错误",
0 x5031
0 x5032    "元素 LUN 之一二个大小价值错误",
0 x5033    "序号长度病人",
0 x5034    " 元素大小比 LUN 大小更大",
0 x5035    "没有在磁盘片上的充足空间",
0 x5036    " VNDR 进入 VMODE 错误",
0 x5037    "VNDR 组合公共汽车宽度错误",
0 x5038    "读了 FW PKG 文件错误",
0 x5039    "VNDR ROMTORAM 错误",
0 x503A    "建立 FW 区段错误",
0 x503B    "建立 CIT1 错误",
0 x503C    "建立 CIT2 错误",
0 x503D    "VNDR 出口 VMODE 错误",
0 x503E    "VNDR 指令激光唱碟错误",
0 x503F    "卡片类型或备置卡片类型挑选出来的错误",
0 x5040    "设定 PARA 错误",
0 x5041    "测试单位准备好的错误",
0 x5042    "建造 ZT 的能力是零",
0 x5043    "写 MKB 错误",
0 x5044    "不找比赛 PKG 错误",
0 x5045    "副本文件错误",
0 x5046    " 厂商写部门错误",
0 x5047    "被读部门错误的厂商",
0 x5048    "厂商指令 13个错误",
0 x5049    "控制器测试错误",
0 x504A    "闪光最佳化设定错误",
0 x504B    "MAPTABLE_FILECONVERT_ERROR",
0 x504C    "VERCODE 译码错误",
0 x504D    固定的能力价值错误,
0 x504E    " 阅读写测试错误",
0 x504F    "拿 CONFIG 错误",
0 x5050    "QC 测试得到能力错误",
0 x5051    "马克- 扫描不及格",
0 x5052    "对二等兵- 区域错误的副本文件",
0 x5053    "厂商 FLASHGETSTATUS 指令错误",
0 x5054    "副本目录数据不及格",
0 x5055    "ISO FILENAME 错误"
本帖最近打赏记录:共3条打赏
jf201006 M币 +13 謝謝分享 2018-04-04
潜隆 M币 +5 謝謝分享 2018-04-04
关键词: i5128i5122代码
离线qgjq
只看该作者 1楼 发表于: 2008-03-03
离线plan_ng
只看该作者 2楼 发表于: 2008-03-03
离线yajun722
只看该作者 3楼 发表于: 2008-03-03
离线slfan
只看该作者 4楼 发表于: 2008-03-03
离线追风少年
只看该作者 5楼 发表于: 2008-03-03
离线hltang
只看该作者 6楼 发表于: 2008-03-04
离线udbh1987
只看该作者 7楼 发表于: 2008-03-04
离线cqcbc
只看该作者 8楼 发表于: 2008-03-04
离线qjwsanzu
只看该作者 9楼 发表于: 2008-03-05
