  • 5289阅读
  • 24回复
[SandForce]蛤蛤!我的2241vb4   sp900s7 有结果出来了 [复制链接]
离线ctnet
只看该作者 10楼 发表于: 2018-12-08
SandForce Genesis Utility v1.5.21.20110919-fc14-32bit
SF_Core Library: v1.7.0.20110919-fc14-32bit
Copyright 2010-2011, SandForce Inc., All Rights Reserved Worldwide.
[Sat 12/08/2018 08:20:33] - SF_Genesis has been invoked with the following parameters:
                      argv[1]: -PROCESS_SSD
                      argv[2]: 1:0:0:0
                      argv[3]: /home/ctnet/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
                      argv[4]: /home/ctnet/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/Configuration_Files/31060.123456.driveconfig
                      argv[5]: 12345
                      argv[6]: www_
                      argv[7]: 123
                      argv[8]: log=/home/ctnet/ssd/ssd.log
[Sat 12/08/2018 08:20:33] - Instructing the operating system to purge any existing cached data for device: '1:0:0:0'
[Sat 12/08/2018 08:20:38] - Issuing a discovery command for device: '1:0:0:0'
[Sat 12/08/2018 08:20:43] - Discovery command completed...
[Sat 12/08/2018 08:20:43] - Waiting 5 seconds for the system to settle...
[Sat 12/08/2018 08:20:48] - Device designation string '1:0:0:0' is mapped to node '/dev/sg1'
[Sat 12/08/2018 08:20:48] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg1
    MFP Package Filename = /home/ctnet/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
      Configuration File = /home/ctnet/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/Configuration_Files/31060.123456.driveconfig
              Serial No. = 12345
         World Wide Name = www_
[Sat 12/08/2018 08:20:48] - Successfully received the IDENTIFY data from the drive...
SF_Internal_PackageManager::OpenExisting:
                     HeaderCRC32: -1786050351,(958B08D1)
     _Package.Header.HeaderCRC32: -1786050351,(958B08D1)
                    OverallCRC32:  587984375,(230BEDF7)
    _Package.Header.OverallCRC32:  587984375,(230BEDF7)
[Sat 12/08/2018 08:20:48] - Successfully opened the package: /home/ctnet/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
[Sat 12/08/2018 08:20:48] - Successfully extracted *.DriveConfig file: /home/ctnet/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/Configuration_Files/31060.123456.driveconfig
[Sat 12/08/2018 08:20:48] - Extracted Config_ID: 1 (31060) in DriveConfig file: /home/ctnet/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/Configuration_Files/31060.123456.driveconfig
[Sat 12/08/2018 08:20:48] - Extracted SerialOutputControl: 0
[Sat 12/08/2018 08:20:48] - Successfully extracted Config record: 31060
[Sat 12/08/2018 08:20:48] - Successfully extracted flashware image: 31060_fw_cl_mlc_Micron_128Gb_33bit_MT29F128G08CBECB_1Q_2C_1D_S_PP_R03144_s512.vic
[Sat 12/08/2018 08:20:48] - Successfully extracted manufacturing image: 31060_mf_mlc_Micron_128Gb_33bit_MT29F128G08CBECB_1Q_2C_1D_S_PP_R03144_s512.vic
[Sat 12/08/2018 08:20:48] - Proceeding in ROM mode, download feature 1...
[Sat 12/08/2018 08:20:49] - Successfully downloaded MFB to the drive...
[Sat 12/08/2018 08:20:49] - Waiting (5 sec) for the drive to settle...
[Sat 12/08/2018 08:20:54] - Successfully received the IDENTIFY data from the drive...
[Sat 12/08/2018 08:20:54] - Firmware revision reported to be: '60AABBM0'.  This indicates MFB download was successful.
[Sat 12/08/2018 08:20:54] - Successfully enabled SMART capabilities...
[Sat 12/08/2018 08:20:55] - Successfully issued a diagnostic unlock...
[Sat 12/08/2018 08:20:55] - Performing the flash test of block 0 (0x0000)...
[Sat 12/08/2018 08:20:57] - Flash Test Results:
Flash Test Parameters:
               Block Count: 0
                Page Count: 1
                 Bus Count: 1
        Chip Enabled Count: 2
                 Die Count: 1
                Lane Count: 4
               Plane Count: 2
Results Notes:
   N1 - At least one page tested and passed with no bit errors.
   N2 - No test data available.  Test may have aborted, or failed during the testing.
   N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
   N4 - At least  one erased page tested had bit error rate greater than half the correction power.
   N5 - Walking zeros test failed.
   N6 - Walking ones test failed.
   N7 - Block contained factory bad block markings and testing was skipped.
   N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
   N9 - Block in plane 0 was marked as a factory bad block.
  N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
  N11 - Block in plane 1 was marked as a factory bad block.
| Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |
| 0    | 0    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 0    | 0    | 0    | 1    | 0x0022 | N3,N5                                      | WARNING |
| 0    | 0    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 0    | 0    | 0    | 3    | 0x0002 | N3                                         | WARNING |
| 0    | 1    | 0    | 0    | 0x0003 | N1,N3                                      | WARNING |
| 0    | 1    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 0    | 1    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 0    | 1    | 0    | 3    | 0x0002 | N3                                         | WARNING |
  Total Number of test results: 8
            Number of failures: 0
         Number of Passed with warnings: 8
      No. Passed without warnings: 0
[Sat 12/08/2018 08:20:59] - Performing the FORMAT Command with the following parameters:
         MemoryWearCycleCapability = 0
              CurrentPE_CycleCount = 0
                     LifeInSeconds = 0
                   LogicalCapacity = 250069680
                        SectorSize = 512
             SectorAlignmentOffset = 0
                  ExpectedMemoryID = 33836 (0x842C)
                   ExpectedNumDies = 0
               SerialOutputControl = 0
                           Time[8] = 0x0000000000000000
            MiscFlag_Erase_R_Block = 0
     MiscFlag_PanicHandlingEnabled = 0
        MiscFlag_PanicOnSATA_Error = 0
  MiscFlag_WriteThrottlingTestMode = 0
      MiscFlag_DisableUserBandECCX = 1
                        L_PageSize = 0
                        E_PageSize = 0
              ErrorCorrectionPower = 0
      ConfigDeviceReadDisturbCount = 0
   ConfigDeviceReadDisturbCountLow = 0
[Sat 12/08/2018 08:21:10] - FATAL_ERROR: Could not perform the FORMAT() operation on the drive... (0x0000C048:SF_SCT (C048h): Root Creation Failed (MFB format))
[Sat 12/08/2018 08:21:10] - End of Genesis manufacturing log.
[Sat 12/08/2018 08:21:10] - Exiting...
[Sat 12/08/2018 08:21:10] - Overall Result for Device: /dev/sg1 ****** FAIL ******
回复内容请大于5个汉字
离线perter
只看该作者 11楼 发表于: 2018-12-08
到这步失败是因为写保护问题,请选择第四行那个write protect相关
离线ctnet
只看该作者 12楼 发表于: 2018-12-08
回 perter 的帖子
perter:到这步失败是因为写保护问题,请选择第四行那个write protect相关 (2018-12-08 08:30) 回 perter 的帖子
write protec
里只有两项选择
都试了还哪样
我重新装一遍F14
是不是这几天改的乱套了~好像是linux缺插件
离线perter
只看该作者 13楼 发表于: 2018-12-08
回 ctnet 的帖子
ctnet:write protec
里只有两项选择
都试了还哪样
....... (2018-12-08 16:25) 回 ctnet 的帖子
vb4配60A你要用1.7.7开卡,我猜你是1.7.2开的。。。所以也容易出现在那一步
离线ctnet
只看该作者 14楼 发表于: 2018-12-08
回 perter 的帖子
perter:vb4配60A你要用1.7.7开卡,我猜你是1.7.2开的。。。所以也容易出现在那一步 (2018-12-08 17:08) 回 perter 的帖子
1.77?
哪里有下载俄?
离线ctnet
只看该作者 15楼 发表于: 2018-12-08
回 perter 的帖子
只见到有1.7.0
回复内容请大于5个汉字
离线perter
只看该作者 16楼 发表于: 2018-12-08
善用论坛搜索,我记得大神又放出来的,我自己都用1.7.2.。。。很好奇你哪来的1.7.0
离线ctnet
只看该作者 17楼 发表于: 2018-12-08
重装系统后lic不好用了
离线perter
只看该作者 18楼 发表于: 2018-12-08
回 ctnet 的帖子
ctnet:重装系统后lic不好用了 (2018-12-08 20:43) 回 ctnet 的帖子
因为你没安装插件
离线zhgao
只看该作者 19楼 发表于: 2018-12-09
回 perter 的帖子
perter:善用论坛搜索,我记得大神又放出来的,我自己都用1.7.2.。。。很好奇你哪来的1.7.0 (2018-12-08 17:17) 回 perter 的帖子
高于1.7.2的版本我是没见过,估计太久以前的帖子沉了,搜不出来
