  • 1327阅读
  • 2回复
[SandForce]sf2281 开卡求助,这个颗粒是什么厂家的 ocz solid3 的 [复制链接]
离线ecdn
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2019-01-17
上面就一串数字
60073093
530006071B
开卡都失败,
<?xml version = "1.0"?>
<Genesis_Log>
    <Log_Body>
Overall Summary:
                Start Time: Thu, 01/17/2019 @ 14:36:21
                  End Time: Thu, 01/17/2019 @ 14:39:30
             OverallResult: FAIL
                  ExitCode: (0x10090012:SF_GENESIS_IDENTIFY_ERROR)
Environment Settings:
          Input Parameters:
                  argv[1]: -PROCESS_SSD
                  argv[2]: 5:0:1:0
                  argv[3]: /home/a/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
                  argv[4]: /home/a/FW_PPRO_5_2_2_Release.672199.release--0/27230.0.driveconfig
                  argv[5]: 123
                  argv[6]: 123
                  argv[7]: LOG=/home/a/FW_PPRO_5_2_2_Release.672199.release--0/123_lo_DATETIMESTAMP_5.0.1.0_PROCESS_SSD_RESULT.log
                  Log File: /home/a/FW_PPRO_5_2_2_Release.672199.release--0/123_lo_DATETIMESTAMP_5.0.1.0_PROCESS_SSD_RESULT.log
                  Hostname: lo
           Host IP Address: 127.0.0.1
               Port Number: 1
                DeviceName: /dev/sg1
        SF_Genesis Version: v1.5.21.20110919-fc14-32bit
   SF_Core Library Version: v1.7.0.20110919-fc14-32bit
         SF_OS_Information: Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686
Post Processing Device Information:
                   WWN OUI: UNKNOWN
              WWN UniqueID: UNKNOWN
                Serial No.: UNKNOWN
                 Model No.: UNKNOWN
         Firmware Revision: UNKNOWN
              ROM Revision: UNKNOWN
            NAND Page Size: UNKNOWN
     Number Of Chip Enable: UNKNOWN
           Logical Sectors: UNKNOWN
                   NAND ID: UNKNOWN
        Flash Manufacturer: UNKNOWN
              Flash Device: UNKNOWN
SandForce Genesis Utility v1.5.21.20110919-fc14-32bit
SF_Core Library: v1.7.0.20110919-fc14-32bit
Copyright 2010-2011, SandForce Inc., All Rights Reserved Worldwide.
[Thu 01/17/2019 14:36:21] - SF_Genesis has been invoked with the following parameters:
                      argv[2]: 5:0:1:0
                      argv[5]: 123
                      argv[6]: 123
[Thu 01/17/2019 14:36:21] - Instructing the operating system to purge any existing cached data for device: '5:0:1:0'
[Thu 01/17/2019 14:36:27] - Issuing a discovery command for device: '5:0:1:0'
[Thu 01/17/2019 14:36:32] - Discovery command completed...
[Thu 01/17/2019 14:36:32] - Waiting 5 seconds for the system to settle...
[Thu 01/17/2019 14:36:37] - Device designation string '5:0:1:0' is mapped to node '/dev/sg1'
[Thu 01/17/2019 14:36:37] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg1
    MFP Package Filename = /home/a/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
      Configuration File = /home/a/FW_PPRO_5_2_2_Release.672199.release--0/27230.0.driveconfig
              Serial No. = 123
         World Wide Name = 123
[Thu 01/17/2019 14:36:37] - Successfully received the IDENTIFY data from the drive...
[Thu 01/17/2019 14:36:44] - Successfully opened the package: /home/a/FW_PPRO_5_2_2_Release.672199.release--0/FW_PPRO_5_2_2_Release.672199.release.0.mfp
[Thu 01/17/2019 14:36:44] - Successfully extracted *.DriveConfig file: /home/a/FW_PPRO_5_2_2_Release.672199.release--0/27230.0.driveconfig
[Thu 01/17/2019 14:36:44] - Extracted Config_ID: 1 (27230) in DriveConfig file: /home/a/FW_PPRO_5_2_2_Release.672199.release--0/27230.0.driveconfig
[Thu 01/17/2019 14:36:44] - Extracted SerialOutputControl: 0
[Thu 01/17/2019 14:36:44] - Successfully extracted Config record: 27230
[Thu 01/17/2019 14:36:44] - Successfully extracted flashware image: 27230_fw_cl_mlc_Micron_32Gb_MT29F128G08CBACAWP_2Q_2C_1D_PP_R01087_s512.vic
[Thu 01/17/2019 14:36:44] - Successfully extracted manufacturing image: 27230_mf_mlc_Micron_32Gb_MT29F128G08CBACAWP_2Q_2C_1D_PP_R01087_s512.vic
[Thu 01/17/2019 14:36:44] - Proceeding in ROM mode, download feature 1...
[Thu 01/17/2019 14:39:25] - Successfully downloaded MFB to the drive...
[Thu 01/17/2019 14:39:25] - Waiting (5 sec) for the drive to settle...
[Thu 01/17/2019 14:39:30] - FATAL_ERROR: Could not get the IDENTIFY data from the drive... (0x12000004:SF_SG_HOST_BAD_TARGET_ERROR)
[Thu 01/17/2019 14:39:30] - End of Genesis manufacturing log.
[Thu 01/17/2019 14:39:30] - Exiting...
    </Log_Body>
    <Overall_Summary>
        <Start_Time> Thu, 01/17/2019 @ 14:36:21 </Start_Time>
        <End_Time> Thu, 01/17/2019 @ 14:39:30 </End_Time>
        <Overall_Result> FAIL </Overall_Result>
        <Exit_Code> (0x10090012:SF_GENESIS_IDENTIFY_ERROR) </Exit_Code>
    </Overall_Summary>
    <Environment_Settings>
        <Input_Parameters>
                  argv[2]: 5:0:1:0
                  argv[5]: 123
                  argv[6]: 123
        </Input_Parameters>
        <Log_File> /home/a/FW_PPRO_5_2_2_Release.672199.release--0/123_lo_DATETIMESTAMP_5.0.1.0_PROCESS_SSD_RESULT.log </Log_File>
        <Hostname> lo </Hostname>
        <Host_IP_Address> 127.0.0.1 </Host_IP_Address>
        <Port_Number> 1 </Port_Number>
        <Device_Name> /dev/sg1 </Device_Name>
        <SF_Genesis_Version> v1.5.21.20110919-fc14-32bit </SF_Genesis_Version>
        <SF_Core_Library_Version> v1.7.0.20110919-fc14-32bit </SF_Core_Library_Version>
        <SF_OS_Information> Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686 </SF_OS_Information>
    </Environment_Settings>
    <Post_Processing_Device_Info>
        <WWN_OUI> UNKNOWN </WWN_OUI>
        <WWN_UniqueID> UNKNOWN </WWN_UniqueID>
        <Serial_Number> UNKNOWN </Serial_Number>
        <Model_Number> UNKNOWN </Model_Number>
        <Firmware_Revision> UNKNOWN </Firmware_Revision>
        <ROM_Revision> UNKNOWN </ROM_Revision>
        <NAND_Page_Size> UNKNOWN </NAND_Page_Size>
        <Number_Of_Chip_Enable> UNKNOWN </Number_Of_Chip_Enable>
        <Logical_Sectors> UNKNOWN </Logical_Sectors>
        <NAND_ID> UNKNOWN </NAND_ID>
        <Flash_Manufacturer> UNKNOWN </Flash_Manufacturer>
        <Flash_Device> UNKNOWN </Flash_Device>
    </Post_Processing_Device_Info>
</Genesis_Log>
[Thu 01/17/2019 14:39:30] - Overall Result for Device: /dev/sg1 ****** FAIL ******
M币换购:工善必利器,您的拆机好伴侣~数码之家X22精密型螺丝刀套装(拆客必备系列)
离线ecdn
只看该作者 1楼 发表于: 2019-01-18
已经在论坛上找到了,是intel 的JS29F64G08AAME1
顺利开卡成功
离线戎城小石
只看该作者 2楼 发表于: 2019-04-18
请问楼主是怎样搞得,我也是OCZ60G的不认盘,不知道怎么弄
