  • 606阅读
  • 7回复
紧急求助,谁有UC1698驱动的单色屏160160的画点程序 [复制链接]
离线hed
各位大哥大姐,帮帮忙,谢谢了
包括读屏RAM
包括读屏RAM
离线hed
只看该作者 1楼 发表于: 02-12
一个M币都没有了,,,只能用谢谢了
离线junyee
只看该作者 2楼 发表于: 02-12
是uc1698u吧,以前玩过,论坛也有人发过帖
离线bg4rff
只看该作者 3楼 发表于: 02-13
#include<18F452.h>
#include<stdio.h>
#include<stdlib.h>
#use delay(clock=20000000)
#define uchar char
#define uint  int
#DEFINE wr  PIN_B0
#DEFINE rd  PIN_B1
#DEFINE cs  PIN_B2
#DEFINE cd  PIN_B3
#DEFINE rst PIN_B4
uchar  zimu[8][93]=
         0,   0,   0,   0,   0,   0,   0,   0, //' '
         0,   6,  95,  95,   6,   0,   0,   0, //'!'
         0,   7,   7,   0,   7,   7,   0,   0, //'"'
         20, 127, 127,  20, 127, 127,  20,   0, //'#'
         36,  46, 107, 107,  58,  18,   0,   0, //'$'
         70, 102,  48,  24,  12, 102,  98,   0, //'%'
         48, 122,  79,  93,  55, 122,  72,   0, //'&'
          4,   7,   3,   0,   0,   0,   0,   0, //'''
          0,  28,  62,  99,  65,   0,   0,   0, //'('
          0,  65,  99,  62,  28,   0,   0,   0, //')'
          8,  42,  62,  28,  28,  62,  42,   8, //'*'
          8,   8,  62,  62,   8,   8,   0,   0, //'+'
          0, 128, 224,  96,   0,   0,   0,   0, //','
          8,   8,   8,   8,   8,   8,   0,   0, //'-'
          0,   0,  96,  96,   0,   0,   0,   0, //'.'
         96,  48,  24,  12,   6,   3,   1,   0, //'/'
         62, 127, 113,  89,  77, 127,  62,   0, //'0'
         64,  66, 127, 127,  64,  64,   0,   0, //'1'
         98, 115,  89,  73, 111, 102,   0,   0, //'2'
         34,  99,  73,  73, 127,  54,   0,   0, //'3'
         24,  28,  22,  83, 127, 127,  80,   0, //'4'
         39, 103,  69,  69, 125,  57,   0,   0, //'5'
         60, 126,  75,  73, 121,  48,   0,   0, //'6'
          3,   3, 113, 121,  15,   7,   0,   0, //'7'
         54, 127,  73,  73, 127,  54,   0,   0, //'8'
          6,  79,  73, 105,  63,  30,   0,   0, //'9'
          0,   0, 102, 102,   0,   0,   0,   0, //':'
          0, 128, 230, 102,   0,   0,   0,   0, //';'
          8,  28,  54,  99,  65,   0,   0,   0, //'<'
         36,  36,  36,  36,  36,  36,   0,   0, //'='
          0,  65,  99,  54,  28,   8,   0,   0, //'>'
          2,   3,  81,  89,  15,   6,   0,   0, //'?'
         62, 127,  65,  93,  93,  31,  30,   0, //'@  '
        124, 126,  19,  19, 126, 124,   0,   0, //'A'
         65, 127, 127,  73,  73, 127,  54,   0, //'B'
         28,  62,  99,  65,  65,  99,  34,   0, //'C'
         65, 127, 127,  65,  99,  62,  28,   0, //'D'
         65, 127, 127,  73,  93,  65,  99,   0, //'E'
         65, 127, 127,  73,  29,   1,   3,   0, //'F'
         28,  62,  99,  65,  81, 115, 114,   0, //'G'
        127, 127,   8,   8, 127, 127,   0,   0, //'H'
          0,  65, 127, 127,  65,   0,   0,   0, //'I'
         48, 112,  64,  65, 127,  63,   1,   0, //'J'
         65, 127, 127,   8,  28, 119,  99,   0, //'K'
         65, 127, 127,  65,  64,  96, 112,   0, //'L'
        127, 127,  14,  28,  14, 127, 127,   0, //'M'
        127, 127,   6,  12,  24, 127, 127,   0, //'N'
         28,  62,  99,  65,  99,  62,  28,   0, //'O'
         65, 127, 127,  73,   9,  15,   6,   0, //'P'
         30,  63,  33, 113, 127,  94,   0,   0, //'Q'
         65, 127, 127,   9,  25, 127, 102,   0, //'R'
         38, 111,  77,  89, 115,  50,   0,   0, //'S'
          3,  65, 127, 127,  65,   3,   0,   0, //'T'
        127, 127,  64,  64, 127, 127,   0,   0, //'U'
         31,  63,  96,  96,  63,  31,   0,   0, //'V'
        127, 127,  48,  24,  48, 127, 127,   0, //'W'
         67, 103,  60,  24,  60, 103,  67,   0, //'X'
          7,  79, 120, 120,  79,   7,   0,   0, //'Y'
         71,  99, 113,  89,  77, 103, 115,   0, //'Z'
          0, 127, 127,  65,  65,   0,   0,   0, //'['
          1,   3,   6,  12,  24,  48,  96,   0, //'\'
          0,  65,  65, 127, 127,   0,   0,   0, //']'
          8,  12,   6,   3,   6,  12,   8,   0, //'^'
        128, 128, 128, 128, 128, 128, 128, 128, //'_'
          0,   0,   3,   7,   4,   0,   0,   0, //'`'
         32, 116,  84,  84,  60, 120,  64,   0, //'a'
         65, 127,  63,  72,  72, 120,  48,   0, //'b'
         56, 124,  68,  68, 108,  40,   0,   0, //'c'
         48, 120,  72,  73,  63, 127,  64,   0, //'d'
         56, 124,  84,  84,  92,  24,   0,   0, //'e'
         72, 126, 127,  73,   3,   2,   0,   0, //'f'
        152, 188, 164, 164, 248, 124,   4,   0, //'g'
         65, 127, 127,   8,   4, 124, 120,   0, //'h'
          0,  68, 125, 125,  64,   0,   0,   0, //'i'
         96, 224, 128, 128, 253, 125,   0,   0, //'j'
         65, 127, 127,  16,  56, 108,  68,   0, //'k'
          0,  65, 127, 127,  64,   0,   0,   0, //'l'
        124, 124,  24,  56,  28, 124, 120,   0, //'m'
        124, 124,   4,   4, 124, 120,   0,   0, //'n'
         56, 124,  68,  68, 124,  56,   0,   0, //'o'
        132, 252, 248, 164,  36,  60,  24,   0, //'p'
        24,  60,  36, 164, 248, 252, 132,   0, //'q'
        68, 124, 120,  76,   4,  28,  24,   0, //'r'
        72,  92,  84,  84, 116,  36,   0,   0, //'s'
        0,   4,  62, 127,  68,  36,   0,   0, //'t'
        60, 124,  64,  64,  60, 124,  64,   0, //'u'
        28,  60,  96,  96,  60,  28,   0,   0, //'v'
        60, 124, 112,  56, 112, 124,  60,   0, //'w'
        68, 108,  56,  16,  56, 108,  68,   0, //'x'
        156, 188, 160, 160, 252, 124,   0,   0, //'y'
        76, 100, 116,  92,  76, 100,   0,   0, //'z'
        8,   8,  62, 119,  65,  65,   0,   0, //'{'
        0,   0,   0, 119, 119,   0,   0,   0, //'|'
void write(int1 flag,int dat)
   output_low(cs);
   if (flag==0)
   output_low(cd);
   if (flag==1)
   output_high(cd);
   output_low(wr);
   output_high(rd);
   output_d(dat);
   output_high(wr);
void init(void)//*
   output_low(cs);
   /*reset*/
   output_low(rst);
   delay_ms(2);         //power on reset
   output_high(rst);
   delay_ms(200);
   write(0,0xe2);         //reset by command
   delay_ms(2);
   /*power control*/
   write(0,0xe9);         //(26)Bias Ratio:1/10 bias
   write(0,0x2b);         //(6)power control set as internal power
   write(0,0x25);         //(5)set temperate compensation as 0%
   write(0,0x81);         //(10)electronic potentionmeter
   write(0,0xbf);
   /*display control*/
   write(0,0xa4);         //(15)all pixel off
   write(0,0xa6);         //(16)inverse display off
   /*lcd control*/
   write(0,0xc0);         //(18)partial display and MX disable,MY enable
   write(0,0xa3);         //(14)line rate 15.2klps
   write(0,0xd1);         //(20)rgb-rgb
   write(0,0xd5);         //(21)4k color mode
   write(0,0x84);         //(11)partial display control disable
   /*(19)n-line inversion*/
   write(0,0xc8);
   write(0,0x10);         //enable NIV
   /*(22)com scan fuction*/
   write(0,0xda);         //enable FRC,PWM,LRM sequence
   /*window*/
   write(0,0xf4);         //(30)wpc0:column
   write(0,0x25);         //start from 130
   write(0,0xf6);         //(32)wpc1
   write(0,0x5a);         //end:272
   write(0,0xf5);         //(31)wpp0:row
   write(0,0x00);         //start from 0
   write(0,0xf7);         //(32)wpP0
   write(0,0x9F);         //end 160
   write(0,0xf8);         //(34)inside mode AC3
   write(0,0x89);         //(12)RAM control,ÏÔê¾·½Ïò
   write(0,0xad);         //(17)display on,select on/off mode.Green Enhance mode disable
   /*scroll line óë RAM μÄó3éä1ØÏμ*/
   write(0,0x40);         //(8)low bit of scroll line
   write(0,0x50);         //high bit of scroll line
   write(0,0xc4);         //(18)partial display and MX disable,MY enable
    write(0,0x90);         //(13):FLT,FLB set
   write(0,0x00);
   /*partial display*/
   write(0,0x84);         //(11),set partial display control:off
   write(0,0xf1);         //(27)com end
   write(0,0x9f);         //160
   write(0,0xf2);         //(28)display start
   write(0,0);            //0
   write(0,0xf3);         //(29)display end
   write(0,159);         //160
void words(uchar x,uchar y,uchar *p)         //type=1,ascii;type=2,Chinese character
   uchar i,k,j,m,n,l,x0,dat0,dat1,dat2,dat3,dat4,dat5,dat6;
   x=37+x;
   x0=0x00|(x&0x0f);
   x=0x10|((x&0xf0)>>4);
      for(j=0;j<8;j++)
         m=i*8+j;
         write(0,0x89);//SET RAM ADDRESS CONTROL
         write(0,x0);//Set Column Address LSB CA[3:0]
         write(0,x);//Set Column Address MSB CA[7:4]
         write(0,0x60|((y+m)&0x0f));//Set Row Address LSB RA [3:0]
         write(0,0x70|(((y+m)&0xf0)>>4));//Set Row Address MSB RA [7:4]
         for(k=0;k<2;k++)
            l=k*6+n;
            dat6=0x01<<j;
            dat0=(*(p+l))&dat6;
            dat0=dat0>>j;
            dat0<<=7;
            dat1=(*(p+l+1))&dat6;
            dat1=dat1>>j;
            dat1<<=3;
            dat2=*(p+2+l)&dat6;
            dat2=dat2>>j;
            dat2<<=7;
            dat3=(*(p+3+l))&dat6;
            dat3=dat3>>j;
            dat3<<=3;
            dat4=(*(p+4+l))&dat6;
            dat4=dat4>>j;
            dat4<<=7;
            dat5=(*(p+5+l))&dat6;
            dat5=dat5>>j;
            dat5<<=3;
            write(1,dat0|dat1);
            write(1,dat2|dat3);
            write(1,dat4|dat5);
      write(0,0x88);//SET RAM ADDRESS CONTROL
void lcdscan(uchar dat1,uchar dat2)
   uchar i,j;
   write(0,0x60);         //row address LSB
   write(0,0x70);         //row address MSB
   write(0,0x05);         //culomn address LSB
   write(0,0x12);         //culomn address MSB
   for(j=0;j<160;j++)
      for(i=0;i<27;i++)
         if(j%2==0)
            write(1,dat1);
            write(1,dat1);
            write(1,dat1);
         else
            write(1,dat2);
            write(1,dat2);
            write(1,dat2);
void character(void)
   uchar *q;
   uchar i,j;
   lcdscan(0x00,0x00);
   for(i=0;i<8;i++)//controller:
      q=zimu;
      j=4*i+4;
      words(j,0,q);
   for(i=11;i<18;i++)//uc1698u
      q=zimu+i*36;
      j=4*(i-11)+4;
      words(j,70,q);
void main(void)
init();
character();
delay_ms(1000);
紫薯布丁紫薯布丁
本帖提到的人: @
回江苏南通如东了,闲暇时间较多,欢迎交流
离线bg4rff
只看该作者 4楼 发表于: 02-13
离线hed
只看该作者 5楼 发表于: 02-13
bg4rff:https://www.sogou.com/link?url=suO31YCsYcYqqWxCdmPx9SfwS52Q49Awu4aAKP2i8oVc9-YpolH7QLB94ZN21M6VOWe74hdk6e0C3w2pQlkMl0xFhOMO0I6B
紫薯布丁紫薯布丁 (2019-02-13 11:07)
这些我知道,,,没有画点的
要读屏RAM,写点的,,,
用内存的,我有
[ 此帖被hed在2019-02-15 19:09重新编辑 ]
离线茶壹杯
只看该作者 6楼 发表于: 02-13
LZ屏什么接口的?
专业翻新航母、核弹抛光、卫星擦洗~
离线hed
只看该作者 7楼 发表于: 02-14
茶壹杯LZ屏什么接口的?
并口的
