  • 4788阅读
  • 11回复
[Marvell]光威垃圾盘数据保存测试 [复制链接]
离线bcm47186
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2019-02-17
盘现在写了约193TB了,发一下完整的SMART和盘的信息:
=== START OF INFORMATION SECTION ===
Device Model:     GLOWAY FER120GS3-S7
Serial Number:    I32003C003256LU WWN Device Id: 5 02b2a2 01d1c1b1a
Add. Product Id:  mavlsataFirmware Version: R0724A
User Capacity:    120,034,123,776 bytes [120 GB]Sector Size:      512 bytes logical/physical
Rotation Rate:    Solid State DeviceDevice is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   ACS-3 T13/2161-D revision 4SATA Version is:  SATA 3.2, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Sun Feb 17 15:37:56 2019 CSTSMART support is: Available - device has SMART capability.
SMART support is: Enabled
SMART Attributes Data Structure revision number: 5
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
9 Power_On_Hours          0x0033   100   100   010    Pre-fail  Always       -       1392
12 Power_Cycle_Count       0x0033   100   100   010    Pre-fail  Always       -       34
161 Unknown_Attribute       0x0033   100   100   010    Pre-fail  Always       -       0
164 Unknown_Attribute       0x0033   100   100   010    Pre-fail  Always       -       1001697
165 Unknown_Attribute       0x0033   100   100   010    Pre-fail  Always       -       2142
166 Unknown_Attribute       0x0033   100   100   010    Pre-fail  Always       -       1907
167 Unknown_Attribute       0x0033   100   100   010    Pre-fail  Always       -       2122
169 Unknown_Attribute       0x0033   100   100   010    Pre-fail  Always       -       0
176 Erase_Fail_Count_Chip   0x0033   100   100   010    Pre-fail  Always       -       0
177 Wear_Leveling_Count     0x0033   100   100   010    Pre-fail  Always       -       0
178 Used_Rsvd_Blk_Cnt_Chip  0x0033   100   100   010    Pre-fail  Always       -       0
192 Power-Off_Retract_Count 0x0033   100   100   010    Pre-fail  Always       -       0
194 Temperature_Celsius     0x0033   100   100   010    Pre-fail  Always       -       46
195 Hardware_ECC_Recovered  0x0033   100   100   010    Pre-fail  Always       -       0
199 UDMA_CRC_Error_Count    0x0033   100   100   010    Pre-fail  Always       -       0
241 Total_LBAs_Written      0x0033   100   100   010    Pre-fail  Always       -       193987
242 Total_LBAs_Read         0x0033   100   100   010    Pre-fail  Always       -       73007
243 Unknown_Attribute       0x0033   100   100   010    Pre-fail  Always       -       0
244 Unknown_Attribute       0x0033   100   100   010    Pre-fail  Always       -       0
245 Unknown_Attribute       0x0033   100   100   010    Pre-fail  Always       -       0
246 Unknown_Attribute       0x0033   100   100   010    Pre-fail  Always       -       0
250 Read_Error_Retry_Rate   0x0033   100   100   010    Pre-fail  Always       -       0
251 Unknown_Attribute       0x0033   100   100   010    Pre-fail  Always       -       0
252 Unknown_Attribute       0x0033   100   100   010    Pre-fail  Always       -       0
253 Unknown_Attribute       0x0033   100   100   010    Pre-fail  Always       -       0
254 Unknown_SSD_Attribute   0x0033   100   100   010    Pre-fail  Always       -       0
SMART Error Log not supported
SMART Self-test Log not supported
Selective Self-tests/Logging not supported
可以看到是MARVELL的主控,
猜测165,166,167三项和P/E计数有关,可能是平均/最大/最小,可以看到PE已经到2k了
接下来写入100GB的数据,保存到四月再看数据是否有损坏
本帖最近打赏记录:共1条打赏M币+8
听雨亭 M币 +8 謝謝分享 2019-02-17
只看该作者 1楼 发表于: 2019-02-17
离线bcm47186
只看该作者 2楼 发表于: 2019-02-17
回 十一查身份证 的帖子
离线bcm47186
只看该作者 3楼 发表于: 2019-02-17
离线ww5223017240
只看该作者 4楼 发表于: 2019-02-17
离线bcm47186
只看该作者 5楼 发表于: 2019-02-17
回 ww5223017240 的帖子
离线bboroo
只看该作者 6楼 发表于: 2019-02-17
只看该作者 7楼 发表于: 2019-02-17
离线zhuyimin
只看该作者 8楼 发表于: 2019-02-17
回 bcm47186 的帖子
离线bcm47186
只看该作者 9楼 发表于: 2019-02-17
回 zhuyimin 的帖子
