  • 6432阅读
  • 17回复
[鑫创]8g U盘 怎么刷?SSS6692刷坏了- 0 帮我分析 分析。。。 [复制链接]
离线a56516029
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2011-06-04
Device 1:0xB5
MP Version:2.162
INI_File_Name:
Random delay 0 msec
--- Download MP ISP ---
CE-0, Flash ID=2C-88-04-4B-A9-00-00-00
Searching SORTING BOARD table ...
--> Not Found
Found BACKUP Table (0000143A-0014)
Found BACKUP Table (00001E3A-001E)
Original Bad Block - 0:0x0002
Original Bad Block - 0:0x0003
Original Bad Block - 0:0x0006
Original Bad Block - 0:0x0007
Original Bad Block - 0:0x0055
Original Bad Block - 0:0x0057
Original Bad Block - 0:0x0059
Original Bad Block - 0:0x005B
Original Bad Block - 0:0x005C
Original Bad Block - 0:0x005D
Original Bad Block - 0:0x005F
Original Bad Block - 0:0x0062
Original Bad Block - 0:0x0063
Original Bad Block - 0:0x0064
Original Bad Block - 0:0x0065
Original Bad Block - 0:0x0067
Original Bad Block - 0:0x0068
Original Bad Block - 0:0x0069
Original Bad Block - 0:0x006B
Original Bad Block - 0:0x006D
Original Bad Block - 0:0x006F
Original Bad Block - 0:0x0071
Original Bad Block - 0:0x0072
Original Bad Block - 0:0x0073
Original Bad Block - 0:0x0074
Original Bad Block - 0:0x0076
Original Bad Block - 0:0x0077
Original Bad Block - 0:0x0079
Original Bad Block - 0:0x007A
Original Bad Block - 0:0x007B
Original Bad Block - 0:0x007C
Original Bad Block - 0:0x007E
Original Bad Block - 0:0x007F
Original Bad Block - 0:0x0080
Original Bad Block - 0:0x0081
Original Bad Block - 0:0x0082
Original Bad Block - 0:0x0083
Original Bad Block - 0:0x0084
Original Bad Block - 0:0x0085
Original Bad Block - 0:0x0086
Original Bad Block - 0:0x0087
Original Bad Block - 0:0x0088
Original Bad Block - 0:0x0089
Original Bad Block - 0:0x008A
Original Bad Block - 0:0x008B
Original Bad Block - 0:0x008C
Original Bad Block - 0:0x008D
Original Bad Block - 0:0x008E
Original Bad Block - 0:0x008F
Original Bad Block - 0:0x0090
Original Bad Block - 0:0x0091Original Bad Block - 0:0x047F
Original Bad Block - 0:0x0480
Original Bad Block - 0:0x0481
Original Bad Block - 0:0x0482
Original Bad Block - 0:0x0483
Original Bad Block - 0:0x0492
Original Bad Block - 0:0x0880
。。。。中间都差不多 省略。。。。
Original Bad Block - 0:0x0C54
Original Bad Block - 0:0x0C55
Original Bad Block - 0:0x0C57
Original Bad Block - 0:0x0C59
Original Bad Block - 0:0x0C5B
Original Bad Block - 0:0x0C5C
Original Bad Block - 0:0x0C5D
Original Bad Block - 0:0x0C5F
Original Bad Block - 0:0x0C62
Original Bad Block - 0:0x0C63
Original Bad Block - 0:0x0C64
Original Bad Block - 0:0x0C65
Original Bad Block - 0:0x0C67
Original Bad Block - 0:0x0C68
Original Bad Block - 0:0x0C69
Original Bad Block - 0:0x0C6B
Original Bad Block - 0:0x0C6D
Original Bad Block - 0:0x0C6F
Original Bad Block - 0:0x0C71
Original Bad Block - 0:0x0C72
Original Bad Block - 0:0x0C73
Original Bad Block - 0:0x0C74
Original Bad Block - 0:0x0C76
Original Bad Block - 0:0x0C77
Original Bad Block - 0:0x0C79
Original Bad Block - 0:0x0C7A
Original Bad Block - 0:0x0C7B
Original Bad Block - 0:0x0C7C
Original Bad Block - 0:0x0C7E
Original Bad Block - 0:0x0C7F
Original Bad Block - 0:0x0C80
Original Bad Block - 0:0x0C81
Original Bad Block - 0:0x0C82
Original Bad Block - 0:0x0C83
Original Bad Block - 0:0x0C84
Original Bad Block - 0:0x0C85
Original Bad Block - 0:0x0C86
Original Bad Block - 0:0x0C87
Original Bad Block - 0:0x0C88
Original Bad Block - 0:0x0C89
Original Bad Block - 0:0x0C8A
Original Bad Block - 0:0x0C8B
Original Bad Block - 0:0x0C8C
Original Bad Block - 0:0x0C8D
Original Bad Block - 0:0x0C8E
Original Bad Block - 0:0x0C8F
Original Bad Block - 0:0x0C90
Original Bad Block - 0:0x0C91
Original Bad Block - 0:0x0C92
Original Bad Block - 0:0x0C95
Original Bad Block - 0:0x0C96
Original Bad Block - 0:0x0C97
Original Bad Block - 0:0x0C98
Original Bad Block - 0:0x0C99
Original Bad Block - 0:0x0C9A
Original Bad Block - 0:0x0C9B
Original Bad Block - 0:0x0C9C
Original Bad Block - 0:0x0C9D
Original Bad Block - 0:0x0C9E
Original Bad Block - 0:0x0C9F
Original Bad Block - 0:0x0E02
Original Bad Block - 0:0x0E03
Original Bad Block - 0:0x0E06
Original Bad Block - 0:0x0E07
Original Bad Block - 0:0x0E0A
Original Bad Block - 0:0x0E0B
Original Bad Block - 0:0x0E0D
Original Bad Block - 0:0x0E0F
Original Bad Block - 0:0x0E10
Original Bad Block - 0:0x0E11
Original Bad Block - 0:0x0E12
Original Bad Block - 0:0x0E13
Original Bad Block - 0:0x0E14
Original Bad Block - 0:0x0E16
Original Bad Block - 0:0x0E17
Original Bad Block - 0:0x0E18
Original Bad Block - 0:0x0E1A
Original Bad Block - 0:0x0E1B
Original Bad Block - 0:0x0E1E
Original Bad Block - 0:0x0E1F
Original Bad Block - 0:0x0E20
Original Bad Block - 0:0x0E21
Original Bad Block - 0:0x0E22
Original Bad Block - 0:0x0E23
Original Bad Block - 0:0x0E26
Original Bad Block - 0:0x0E27
Original Bad Block - 0:0x0E29
Original Bad Block - 0:0x0E2A
Original Bad Block - 0:0x0E2E
Original Bad Block - 0:0x0E2F
Original Bad Block - 0:0x0E31
Original Bad Block - 0:0x0E32
Original Bad Block - 0:0x0E33
Original Bad Block - 0:0x0E36
Original Bad Block - 0:0x0E37
Original Bad Block - 0:0x0E38
Original Bad Block - 0:0x0E39
Original Bad Block - 0:0x0E3A
Original Bad Block - 0:0x0E3B
Original Bad Block - 0:0x0E3C
Original Bad Block - 0:0x0E3E
Original Bad Block - 0:0x0E3F
Original Bad Block - 0:0x0E40
Original Bad Block - 0:0x0E41
Original Bad Block - 0:0x0E43
Original Bad Block - 0:0x0E44
Original Bad Block - 0:0x0E45
Original Bad Block - 0:0x0E47
Original Bad Block - 0:0x0E49
Original Bad Block - 0:0x0E4B
Original Bad Block - 0:0x0E4C
Original Bad Block - 0:0x0E4D
Original Bad Block - 0:0x0E4F
Original Bad Block - 0:0x0E50
Original Bad Block - 0:0x0E53
Original Bad Block - 0:0x0E54
Original Bad Block - 0:0x0E55
Original Bad Block - 0:0x0E57
Original Bad Block - 0:0x0E59
Original Bad Block - 0:0x0E5B
Original Bad Block - 0:0x0E5C
Original Bad Block - 0:0x0E5D
Original Bad Block - 0:0x0E5F
Original Bad Block - 0:0x0E62
Original Bad Block - 0:0x0E63
Original Bad Block - 0:0x0E64
Original Bad Block - 0:0x0E65
Original Bad Block - 0:0x0E67
Original Bad Block - 0:0x0E68
Original Bad Block - 0:0x0E69
Original Bad Block - 0:0x0E6B
Original Bad Block - 0:0x0E6D
Original Bad Block - 0:0x0E6F
Original Bad Block - 0:0x0E71
Original Bad Block - 0:0x0E72
Original Bad Block - 0:0x0E73
Original Bad Block - 0:0x0E74
Original Bad Block - 0:0x0E76
Original Bad Block - 0:0x0E77
Original Bad Block - 0:0x0E79
Original Bad Block - 0:0x0E7A
Original Bad Block - 0:0x0E7B
Original Bad Block - 0:0x0E7C
Original Bad Block - 0:0x0E7E
Original Bad Block - 0:0x0E7F
Original Bad Block - 0:0x0E80
Original Bad Block - 0:0x0E81
Original Bad Block - 0:0x0E82
Original Bad Block - 0:0x0E83
Original Bad Block - 0:0x0E84
Original Bad Block - 0:0x0E85
Original Bad Block - 0:0x0E86
Original Bad Block - 0:0x0E87
Original Bad Block - 0:0x0E88
Original Bad Block - 0:0x0E89
Original Bad Block - 0:0x0E8A
Original Bad Block - 0:0x0E8B
Original Bad Block - 0:0x0E8C
Original Bad Block - 0:0x0E8D
Original Bad Block - 0:0x0E8E
Original Bad Block - 0:0x0E8F
Original Bad Block - 0:0x0E90
Original Bad Block - 0:0x0E91
Original Bad Block - 0:0x0E92
Original Bad Block - 0:0x0E95
Original Bad Block - 0:0x0E96
Original Bad Block - 0:0x0E97
Original Bad Block - 0:0x0E98
Original Bad Block - 0:0x0E99
Original Bad Block - 0:0x0E9A
Original Bad Block - 0:0x0E9B
Original Bad Block - 0:0x0E9C
Original Bad Block - 0:0x0E9D
Original Bad Block - 0:0x0E9E
Original Bad Block - 0:0x0E9F
Defect Table shows 3175 Good blocks, 921 Bad blocks
SafeErase (0,4096)
Erase failed Block - 0:0:0x0002
Erase failed Block - 0:0:0x0003
Erase failed Block - 0:0:0x0006
Erase failed Block - 0:0:0x0007
Erase failed Block - 0:0:0x000A
Erase failed Block - 0:0:0x000B
Erase failed Block - 0:0:0x000D
Erase failed Block - 0:0:0x000F
Erase failed Block - 0:0:0x0010
Erase failed Block - 0:0:0x0011
Erase failed Block - 0:0:0x0012
Erase failed Block - 0:0:0x0013
Erase failed Block - 0:0:0x0014
Erase failed Block - 0:0:0x0016
Erase failed Block - 0:0:0x0017
Erase failed Block - 0:0:0x0018
Erase failed Block - 0:0:0x001A
Erase failed Block - 0:0:0x001B
Erase failed Block - 0:0:0x001E
Erase failed Block - 0:0:0x001F
Erase failed Block - 0:0:0x0020
Erase failed Block - 0:0:0x0021
Erase failed Block - 0:0:0x0022
Erase failed Block - 0:0:0x0023
Erase failed Block - 0:0:0x0026
Erase failed Block - 0:0:0x0027
Erase failed Block - 0:0:0x0029
Erase failed Block - 0:0:0x002A
Erase failed Block - 0:0:0x002E
Erase failed Block - 0:0:0x002F
Erase failed Block - 0:0:0x0031
Erase failed Block - 0:0:0x0032
Erase failed Block - 0:0:0x0033
Erase failed Block - 0:0:0x0036
Erase failed Block - 0:0:0x0037
Erase failed Block - 0:0:0x0038
Erase failed Block - 0:0:0x0039
Erase failed Block - 0:0:0x003A
Erase failed Block - 0:0:0x003B
Erase failed Block - 0:0:0x003C
Erase failed Block - 0:0:0x003E
Erase failed Block - 0:0:0x003F
Erase failed Block - 0:0:0x0040
Erase failed Block - 0:0:0x0041
Erase failed Block - 0:0:0x0043
Erase failed Block - 0:0:0x0044
Erase failed Block - 0:0:0x0045
Erase failed Block - 0:0:0x0047
Erase failed Block - 0:0:0x0049
Erase failed Block - 0:0:0x004B
Erase failed Block - 0:0:0x004C
Erase failed Block - 0:0:0x004D
Erase failed Block - 0:0:0x004F
Erase failed Block - 0:0:0x0050
Erase failed Block - 0:0:0x0053
Erase failed Block - 0:0:0x0054
Erase failed Block - 0:0:0x0055
Erase failed Block - 0:0:0x0057
Erase failed Block - 0:0:0x0059
Erase failed Block - 0:0:0x005B
Erase failed Block - 0:0:0x005C
Erase failed Block - 0:0:0x005D
Erase failed Block - 0:0:0x005F
Erase failed Block - 0:0:0x0062
Erase failed Block - 0:0:0x0063
Erase failed Block - 0:0:0x0064
Erase failed Block - 0:0:0x0065
Erase failed Block - 0:0:0x0067
Erase failed Block - 0:0:0x0068
Erase failed Block - 0:0:0x0069
Erase failed Block - 0:0:0x006B
Erase failed Block - 0:0:0x006D
Erase failed Block - 0:0:0x006F
Erase failed Block - 0:0:0x0071
Erase failed Block - 0:0:0x0072
Erase failed Block - 0:0:0x0073
Erase failed Block - 0:0:0x0074
Erase failed Block - 0:0:0x0076
Erase failed Block - 0:0:0x0077
Erase failed Block - 0:0:0x0079
Erase failed Block - 0:0:0x007A
Erase failed Block - 0:0:0x007B
Erase failed Block - 0:0:0x007C
Erase failed Block - 0:0:0x007E
Erase failed Block - 0:0:0x007F
Erase failed Block - 0:0:0x0080
Erase failed Block - 0:0:0x0081
Erase failed Block - 0:0:0x0082
Erase failed Block - 0:0:0x0083
Erase failed Block - 0:0:0x0084
Erase failed Block - 0:0:0x0085
Erase failed Block - 0:0:0x0086
Erase failed Block - 0:0:0x0087
Erase failed Block - 0:0:0x0088
Erase failed Block - 0:0:0x0089
Erase failed Block - 0:0:0x008A
Erase failed Block - 0:0:0x008B
Erase failed Block - 0:0:0x008C
Erase failed Block - 0:0:0x008D
Erase failed Block - 0:0:0x008E
Erase failed Block - 0:0:0x008F
Erase failed Block - 0:0:0x0090
Erase failed Block - 0:0:0x0091
Erase failed Block - 0:0:0x0092
Erase failed Block - 0:0:0x0095
Erase failed Block - 0:0:0x0096
Erase failed Block - 0:0:0x0097
Erase failed Block - 0:0:0x0098
Erase failed Block - 0:0:0x0099
Erase failed Block - 0:0:0x009A
Erase failed Block - 0:0:0x009B
Erase failed Block - 0:0:0x009C
Erase failed Block - 0:0:0x009D
Erase failed Block - 0:0:0x009E
Erase failed Block - 0:0:0x009F
Erase failed Block - 0:0:0x0151
Erase failed Block - 0:0:0x0202
Erase failed Block - 0:0:0x0203
Erase failed Block - 0:0:0x0206
Erase failed Block - 0:0:0x0207
Erase failed Block - 0:0:0x020A
Erase failed Block - 0:0:0x020B
Erase failed Block - 0:0:0x020D
Erase failed Block - 0:0:0x020F
Erase failed Block - 0:0:0x0210
Erase failed Block - 0:0:0x0211
Erase failed Block - 0:0:0x0212
Erase failed Block - 0:0:0x0213
Erase failed Block - 0:0:0x0214
Erase failed Block - 0:0:0x0216
Erase failed Block - 0:0:0x0217
Erase failed Block - 0:0:0x0218
Erase failed Block - 0:0:0x021A
Erase failed Block - 0:0:0x021B
Erase failed Block - 0:0:0x021E
Erase failed Block - 0:0:0x021F
Erase failed Block - 0:0:0x0220
Erase failed Block - 0:0:0x0221
Erase failed Block - 0:0:0x0222
Erase failed Block - 0:0:0x0223
Erase failed Block - 0:0:0x0226
Erase failed Block - 0:0:0x0227
Erase failed Block - 0:0:0x0229
Erase failed Block - 0:0:0x022A
Erase failed Block - 0:0:0x022E
Erase failed Block - 0:0:0x022F
Erase failed Block - 0:0:0x0231
Erase failed Block - 0:0:0x0232
Erase failed Block - 0:0:0x0233
Erase failed Block - 0:0:0x0236
Erase failed Block - 0:0:0x0237
Erase failed Block - 0:0:0x0238
Erase failed Block - 0:0:0x0239
Erase failed Block - 0:0:0x023A
Erase failed Block - 0:0:0x023B
Erase failed Block - 0:0:0x023C
Erase failed Block - 0:0:0x023E
Erase failed Block - 0:0:0x023F
Erase failed Block - 0:0:0x0240
Erase failed Block - 0:0:0x0241
Erase failed Block - 0:0:0x0243
Erase failed Block - 0:0:0x0244
Erase failed Block - 0:0:0x0245
Erase failed Block - 0:0:0x0247
Erase failed Block - 0:0:0x0249
Erase failed Block - 0:0:0x024B
Erase failed Block - 0:0:0x024C
Erase failed Block - 0:0:0x024D
Erase failed Block - 0:0:0x024F
Erase failed Block - 0:0:0x0250
Erase failed Block - 0:0:0x0253
Erase failed Block - 0:0:0x0254
Erase failed Block - 0:0:0x0255
Erase failed Block - 0:0:0x0257
Erase failed Block - 0:0:0x0259
Erase failed Block - 0:0:0x025B
Erase failed Block - 0:0:0x025C
Erase failed Block - 0:0:0x025D
Erase failed Block - 0:0:0x025F
Erase failed Block - 0:0:0x0262
Erase failed Block - 0:0:0x0263
Erase failed Block - 0:0:0x0264
Erase failed Block - 0:0:0x0265
Erase failed Block - 0:0:0x0267
Erase failed Block - 0:0:0x0268
Erase failed Block - 0:0:0x0269
Erase failed Block - 0:0:0x026B
Erase failed Block - 0:0:0x026D
Erase failed Block - 0:0:0x026F
Erase failed Block - 0:0:0x0271
Erase failed Block - 0:0:0x0272
Erase failed Block - 0:0:0x0273
Erase failed Block - 0:0:0x0274
Erase failed Block - 0:0:0x0276
Erase failed Block - 0:0:0x0277
Erase failed Block - 0:0:0x0279
Erase failed Block - 0:0:0x027A
Erase failed Block - 0:0:0x027B
Erase failed Block - 0:0:0x027C
Erase failed Block - 0:0:0x027E
Erase failed Block - 0:0:0x027F
Erase failed Block - 0:0:0x0280
Erase failed Block - 0:0:0x0281
Erase failed Block - 0:0:0x0282
Erase failed Block - 0:0:0x0283
Erase failed Block - 0:0:0x0284
Erase failed Block - 0:0:0x0285
Erase failed Block - 0:0:0x0286
Erase failed Block - 0:0:0x0287
Erase failed Block - 0:0:0x0288
Erase failed Block - 0:0:0x0289
Erase failed Block - 0:0:0x028A
Erase failed Block - 0:0:0x028B
Erase failed Block - 0:0:0x028C
Erase failed Block - 0:0:0x028D
Erase failed Block - 0:0:0x028E
Erase failed Block - 0:0:0x028F
Erase failed Block - 0:0:0x0290
Erase failed Block - 0:0:0x0291
Erase failed Block - 0:0:0x0292
Erase failed Block - 0:0:0x0295
Erase failed Block - 0:0:0x0296
Erase failed Block - 0:0:0x0297
Erase failed Block - 0:0:0x0298
Erase failed Block - 0:0:0x0299
Erase failed Block - 0:0:0x029A
Erase failed Block - 0:0:0x029B
Erase failed Block - 0:0:0x029C
Erase failed Block - 0:0:0x029D
Erase failed Block - 0:0:0x029E
Erase failed Block - 0:0:0x029F
Erase failed Block - 0:0:0x0402
Erase failed Block - 0:0:0x0403
Erase failed Block - 0:0:0x0406
Erase failed Block - 0:0:0x0407
Erase failed Block - 0:0:0x040A
Erase failed Block - 0:0:0x040B
Erase failed Block - 0:0:0x040D
Erase failed Block - 0:0:0x040F
Erase failed Block - 0:0:0x0410
Erase failed Block - 0:0:0x0411
Erase failed Block - 0:0:0x0412
Erase failed Block - 0:0:0x0413
Erase failed Block - 0:0:0x0414
Erase failed Block - 0:0:0x0416
Erase failed Block - 0:0:0x0417
Erase failed Block - 0:0:0x0418
Erase failed Block - 0:0:0x041A
Erase failed Block - 0:0:0x041B
Erase failed Block - 0:0:0x041E
Erase failed Block - 0:0:0x041F
Erase failed Block - 0:0:0x0420
Erase failed Block - 0:0:0x0421
Erase failed Block - 0:0:0x0422
Erase failed Block - 0:0:0x0423
Erase failed Block - 0:0:0x0426
Erase failed Block - 0:0:0x0427
Erase failed Block - 0:0:0x0429
Erase failed Block - 0:0:0x042A
Erase failed Block - 0:0:0x042E
Erase failed Block - 0:0:0x042F
Erase failed Block - 0:0:0x0431
Erase failed Block - 0:0:0x0432
Erase failed Block - 0:0:0x0433
Erase failed Block - 0:0:0x0436
Erase failed Block - 0:0:0x0437
Erase failed Block - 0:0:0x0438
Erase failed Block - 0:0:0x0439
Erase failed Block - 0:0:0x043A
Erase failed Block - 0:0:0x043B
Erase failed Block - 0:0:0x043C
Erase failed Block - 0:0:0x043E
Erase failed Block - 0:0:0x043F
Erase failed Block - 0:0:0x0440
Erase failed Block - 0:0:0x0441
Erase failed Block - 0:0:0x0443
Erase failed Block - 0:0:0x0444
Erase failed Block - 0:0:0x0445
Erase failed Block - 0:0:0x0447
Erase failed Block - 0:0:0x0449
Erase failed Block - 0:0:0x044B
Erase failed Block - 0:0:0x044C
Erase failed Block - 0:0:0x044D
Erase failed Block - 0:0:0x044F
Erase failed Block - 0:0:0x0450
Erase failed Block - 0:0:0x0453
Erase failed Block - 0:0:0x0454
Erase failed Block - 0:0:0x0455
Erase failed Block - 0:0:0x0457
Erase failed Block - 0:0:0x0459
Erase failed Block - 0:0:0x045B
Erase failed Block - 0:0:0x045C
Erase failed Block - 0:0:0x045D
Erase failed Block - 0:0:0x045F
Erase failed Block - 0:0:0x0462
Erase failed Block - 0:0:0x0463
Erase failed Block - 0:0:0x0464
Erase failed Block - 0:0:0x0465
Erase failed Block - 0:0:0x0467
Erase failed Block - 0:0:0x0468
Erase failed Block - 0:0:0x0469
Erase failed Block - 0:0:0x046B
Erase failed Block - 0:0:0x046D
Erase failed Block - 0:0:0x046F
Erase failed Block - 0:0:0x0471
Erase failed Block - 0:0:0x0472
Erase failed Block - 0:0:0x0473
Erase failed Block - 0:0:0x0474
Erase failed Block - 0:0:0x0476
Erase failed Block - 0:0:0x0477
Erase failed Block - 0:0:0x0479
Erase failed Block - 0:0:0x047A
Erase failed Block - 0:0:0x047B
Erase failed Block - 0:0:0x047C
Erase failed Block - 0:0:0x047E
Erase failed Block - 0:0:0x047F
Erase failed Block - 0:0:0x0480
Erase failed Block - 0:0:0x0481
Erase failed Block - 0:0:0x0482
Erase failed Block - 0:0:0x0483
Erase failed Block - 0:0:0x0484
Erase failed Block - 0:0:0x0485
Erase failed Block - 0:0:0x0486
Erase failed Block - 0:0:0x0487
Erase failed Block - 0:0:0x0488
Erase failed Block - 0:0:0x0489
Erase failed Block - 0:0:0x048A
Erase failed Block - 0:0:0x048B
Erase failed Block - 0:0:0x048C
Erase failed Block - 0:0:0x048D
Erase failed Block - 0:0:0x048E
Erase failed Block - 0:0:0x048F
Erase failed Block - 0:0:0x0490
Erase failed Block - 0:0:0x0491
Erase failed Block - 0:0:0x0492
Erase failed Block - 0:0:0x0495
Erase failed Block - 0:0:0x0496
Erase failed Block - 0:0:0x0497
Erase failed Block - 0:0:0x0498
Erase failed Block - 0:0:0x0499
Erase failed Block - 0:0:0x049A
Erase failed Block - 0:0:0x049B
Erase failed Block - 0:0:0x049C
Erase failed Block - 0:0:0x049D
Erase failed Block - 0:0:0x049E
Erase failed Block - 0:0:0x049F
Erase failed Block - 0:0:0x0602
Erase failed Block - 0:0:0x0603
Erase failed Block - 0:0:0x0606
Erase failed Block - 0:0:0x0607
Erase failed Block - 0:0:0x060A
Erase failed Block - 0:0:0x060B
Erase failed Block - 0:0:0x060D
Erase failed Block - 0:0:0x060F
Erase failed Block - 0:0:0x0610
Erase failed Block - 0:0:0x0611
Erase failed Block - 0:0:0x0612
Erase failed Block - 0:0:0x0613
Erase failed Block - 0:0:0x0614
Erase failed Block - 0:0:0x0616
Erase failed Block - 0:0:0x0617
Erase failed Block - 0:0:0x0618
Erase failed Block - 0:0:0x061A
Erase failed Block - 0:0:0x061B
Erase failed Block - 0:0:0x061E
Erase failed Block - 0:0:0x061F
Erase failed Block - 0:0:0x0620
Erase failed Block - 0:0:0x0621
Erase failed Block - 0:0:0x0622
Erase failed Block - 0:0:0x0623
Erase failed Block - 0:0:0x0626
Erase failed Block - 0:0:0x0627
Erase failed Block - 0:0:0x0629
Erase failed Block - 0:0:0x062A
Erase failed Block - 0:0:0x062E
Erase failed Block - 0:0:0x062F
Erase failed Block - 0:0:0x0631
Erase failed Block - 0:0:0x0632
Erase failed Block - 0:0:0x0633
Erase failed Block - 0:0:0x0636
Erase failed Block - 0:0:0x0637
Erase failed Block - 0:0:0x0638
Erase failed Block - 0:0:0x0639
Erase failed Block - 0:0:0x063A
Erase failed Block - 0:0:0x063B
Erase failed Block - 0:0:0x063C
Erase failed Block - 0:0:0x063E
Erase failed Block - 0:0:0x063F
Erase failed Block - 0:0:0x0640
Erase failed Block - 0:0:0x0641
Erase failed Block - 0:0:0x0643
Erase failed Block - 0:0:0x0644
Erase failed Block - 0:0:0x0645
Erase failed Block - 0:0:0x0647
Erase failed Block - 0:0:0x0649
Erase failed Block - 0:0:0x064B
Erase failed Block - 0:0:0x064C
Erase failed Block - 0:0:0x064D
Erase failed Block - 0:0:0x064F
Erase failed Block - 0:0:0x0650
Erase failed Block - 0:0:0x0653
Erase failed Block - 0:0:0x0654
Erase failed Block - 0:0:0x0655
Erase failed Block - 0:0:0x0657
Erase failed Block - 0:0:0x0659
Erase failed Block - 0:0:0x065B
Erase failed Block - 0:0:0x065C
Erase failed Block - 0:0:0x065D
Erase failed Block - 0:0:0x065F
Erase failed Block - 0:0:0x0662
Erase failed Block - 0:0:0x0663
Erase failed Block - 0:0:0x0664
Erase failed Block - 0:0:0x0665
Erase failed Block - 0:0:0x0667
Erase failed Block - 0:0:0x0668
Erase failed Block - 0:0:0x0669
Erase failed Block - 0:0:0x066B
Erase failed Block - 0:0:0x066D
Erase failed Block - 0:0:0x066F
Erase failed Block - 0:0:0x0671
Erase failed Block - 0:0:0x0672
Erase failed Block - 0:0:0x0673
Erase failed Block - 0:0:0x0674
Erase failed Block - 0:0:0x0676
Erase failed Block - 0:0:0x0677
Erase failed Block - 0:0:0x0679
Erase failed Block - 0:0:0x067A
Erase failed Block - 0:0:0x067B
Erase failed Block - 0:0:0x067C
Erase failed Block - 0:0:0x067E
Erase failed Block - 0:0:0x067F
Erase failed Block - 0:0:0x0680
Erase failed Block - 0:0:0x0681
Erase failed Block - 0:0:0x0682
Erase failed Block - 0:0:0x0683
Erase failed Block - 0:0:0x0684
Erase failed Block - 0:0:0x0685
Erase failed Block - 0:0:0x0686
Erase failed Block - 0:0:0x0687
Erase failed Block - 0:0:0x0688
Erase failed Block - 0:0:0x0689
Erase failed Block - 0:0:0x068A
Erase failed Block - 0:0:0x068B
Erase failed Block - 0:0:0x068C
Erase failed Block - 0:0:0x068D
Erase failed Block - 0:0:0x068E
Erase failed Block - 0:0:0x068F
Erase failed Block - 0:0:0x0690
Erase failed Block - 0:0:0x0691
Erase failed Block - 0:0:0x0692
Erase failed Block - 0:0:0x0695
Erase failed Block - 0:0:0x0696
Erase failed Block - 0:0:0x0697
Erase failed Block - 0:0:0x0698
Erase failed Block - 0:0:0x0699
Erase failed Block - 0:0:0x069A
Erase failed Block - 0:0:0x069B
Erase failed Block - 0:0:0x069C
Erase failed Block - 0:0:0x069D
Erase failed Block - 0:0:0x069E
Erase failed Block - 0:0:0x069F
Erase failed Block - 0:0:0x0802
Erase failed Block - 0:0:0x0803
Erase failed Block - 0:0:0x0806
Erase failed Block - 0:0:0x0807
Erase failed Block - 0:0:0x080A
Erase failed Block - 0:0:0x080B
Erase failed Block - 0:0:0x080D
Erase failed Block - 0:0:0x080F
Erase failed Block - 0:0:0x0810
Erase failed Block - 0:0:0x0811
Erase failed Block - 0:0:0x0812
Erase failed Block - 0:0:0x0813
Erase failed Block - 0:0:0x0814
Erase failed Block - 0:0:0x0816
Erase failed Block - 0:0:0x0817
Erase failed Block - 0:0:0x0818
Erase failed Block - 0:0:0x081A
Erase failed Block - 0:0:0x081B
Erase failed Block - 0:0:0x081E
Erase failed Block - 0:0:0x081F
Erase failed Block - 0:0:0x0820
Erase failed Block - 0:0:0x0821
Erase failed Block - 0:0:0x0822
Erase failed Block - 0:0:0x0823
Erase failed Block - 0:0:0x0826
Erase failed Block - 0:0:0x0827
Erase failed Block - 0:0:0x0829
Erase failed Block - 0:0:0x082A
Erase failed Block - 0:0:0x082E
Erase failed Block - 0:0:0x082F
Erase failed Block - 0:0:0x0831
Erase failed Block - 0:0:0x0832
Erase failed Block - 0:0:0x0833
Erase failed Block - 0:0:0x0836
Erase failed Block - 0:0:0x0837
Erase failed Block - 0:0:0x0838
Erase failed Block - 0:0:0x0839
Erase failed Block - 0:0:0x083A
Erase failed Block - 0:0:0x083B
Erase failed Block - 0:0:0x083C
Erase failed Block - 0:0:0x083E
Erase failed Block - 0:0:0x083F
Erase failed Block - 0:0:0x0840
Erase failed Block - 0:0:0x0841
Erase failed Block - 0:0:0x0843
Erase failed Block - 0:0:0x0844
Erase failed Block - 0:0:0x0845
Erase failed Block - 0:0:0x0847
Erase failed Block - 0:0:0x0849
Erase failed Block - 0:0:0x084B
Erase failed Block - 0:0:0x084C
Erase failed Block - 0:0:0x084D
Erase failed Block - 0:0:0x084F
Erase failed Block - 0:0:0x0850
Erase failed Block - 0:0:0x0853
Erase failed Block - 0:0:0x0854
Erase failed Block - 0:0:0x0855
Erase failed Block - 0:0:0x0857
Erase failed Block - 0:0:0x0859
Erase failed Block - 0:0:0x085B
Erase failed Block - 0:0:0x085C
Erase failed Block - 0:0:0x085D
Erase failed Block - 0:0:0x085F
Erase failed Block - 0:0:0x0862
Erase failed Block - 0:0:0x0863
Erase failed Block - 0:0:0x0864
Erase failed Block - 0:0:0x0865
Erase failed Block - 0:0:0x0867
Erase failed Block - 0:0:0x0868
Erase failed Block - 0:0:0x0869
Erase failed Block - 0:0:0x086B
Erase failed Block - 0:0:0x086D
Erase failed Block - 0:0:0x086F
Erase failed Block - 0:0:0x0871
Erase failed Block - 0:0:0x0872
Erase failed Block - 0:0:0x0873
Erase failed Block - 0:0:0x0874
Erase failed Block - 0:0:0x0876
Erase failed Block - 0:0:0x0877
Erase failed Block - 0:0:0x0879
Erase failed Block - 0:0:0x087A
Erase failed Block - 0:0:0x087B
Erase failed Block - 0:0:0x087C
Erase failed Block - 0:0:0x087E
Erase failed Block - 0:0:0x087F
Erase failed Block - 0:0:0x0880
Erase failed Block - 0:0:0x0881
Erase failed Block - 0:0:0x0882
Erase failed Block - 0:0:0x0883
Erase failed Block - 0:0:0x0884
Erase failed Block - 0:0:0x0885
Erase failed Block - 0:0:0x0886
Erase failed Block - 0:0:0x0887
Erase failed Block - 0:0:0x0888
Erase failed Block - 0:0:0x0889
Erase failed Block - 0:0:0x088A
Erase failed Block - 0:0:0x088B
Erase failed Block - 0:0:0x088C
Erase failed Block - 0:0:0x088D
Erase failed Block - 0:0:0x088E
Erase failed Block - 0:0:0x088F
Erase failed Block - 0:0:0x0890
Erase failed Block - 0:0:0x0891
Erase failed Block - 0:0:0x0892
Erase failed Block - 0:0:0x0895
Erase failed Block - 0:0:0x0896
Erase failed Block - 0:0:0x0897
Erase failed Block - 0:0:0x0898
Erase failed Block - 0:0:0x0899
Erase failed Block - 0:0:0x089A
Erase failed Block - 0:0:0x089B
Erase failed Block - 0:0:0x089C
Erase failed Block - 0:0:0x089D
Erase failed Block - 0:0:0x089E
Erase failed Block - 0:0:0x089F
Erase failed Block - 0:0:0x0A02
Erase failed Block - 0:0:0x0A03
Erase failed Block - 0:0:0x0A06
Erase failed Block - 0:0:0x0A07
Erase failed Block - 0:0:0x0A0A
Erase failed Block - 0:0:0x0A0B
Erase failed Block - 0:0:0x0A0D
Erase failed Block - 0:0:0x0A0F
Erase failed Block - 0:0:0x0A10
Erase failed Block - 0:0:0x0A11
Erase failed Block - 0:0:0x0A12
Erase failed Block - 0:0:0x0A13
Erase failed Block - 0:0:0x0A14
Erase failed Block - 0:0:0x0A16
Erase failed Block - 0:0:0x0A17
Erase failed Block - 0:0:0x0A18
Erase failed Block - 0:0:0x0A1A
Erase failed Block - 0:0:0x0A1B
Erase failed Block - 0:0:0x0A1E
Erase failed Block - 0:0:0x0A1F
Erase failed Block - 0:0:0x0A20
Erase failed Block - 0:0:0x0A21
Erase failed Block - 0:0:0x0A22
Erase failed Block - 0:0:0x0A23
Erase failed Block - 0:0:0x0A26
Erase failed Block - 0:0:0x0A27
Erase failed Block - 0:0:0x0A29
Erase failed Block - 0:0:0x0A2A
Erase failed Block - 0:0:0x0A2E
Erase failed Block - 0:0:0x0A2F
Erase failed Block - 0:0:0x0A31
Erase failed Block - 0:0:0x0A32
Erase failed Block - 0:0:0x0A33
Erase failed Block - 0:0:0x0A36
Erase failed Block - 0:0:0x0A37
Erase failed Block - 0:0:0x0A38
Erase failed Block - 0:0:0x0A39
Erase failed Block - 0:0:0x0A3A
Erase failed Block - 0:0:0x0A3B
Erase failed Block - 0:0:0x0A3C
Erase failed Block - 0:0:0x0A3E
Erase failed Block - 0:0:0x0A3F
Erase failed Block - 0:0:0x0A40
Erase failed Block - 0:0:0x0A41
Erase failed Block - 0:0:0x0A43
Erase failed Block - 0:0:0x0A44
Erase failed Block - 0:0:0x0A45
Erase failed Block - 0:0:0x0A47
Erase failed Block - 0:0:0x0A49
Erase failed Block - 0:0:0x0A4B
Erase failed Block - 0:0:0x0A4C
Erase failed Block - 0:0:0x0A4D
Erase failed Block - 0:0:0x0A4F
Erase failed Block - 0:0:0x0A50
Erase failed Block - 0:0:0x0A53
Erase failed Block - 0:0:0x0A54
Erase failed Block - 0:0:0x0A55
Erase failed Block - 0:0:0x0A57
Erase failed Block - 0:0:0x0A59
Erase failed Block - 0:0:0x0A5B
Erase failed Block - 0:0:0x0A5C
Erase failed Block - 0:0:0x0A5D
Erase failed Block - 0:0:0x0A5F
Erase failed Block - 0:0:0x0A62
Erase failed Block - 0:0:0x0A63
Erase failed Block - 0:0:0x0A64
Erase failed Block - 0:0:0x0A65
Erase failed Block - 0:0:0x0A67
Erase failed Block - 0:0:0x0A68
Erase failed Block - 0:0:0x0A69
Erase failed Block - 0:0:0x0A6B
Erase failed Block - 0:0:0x0A6D
Erase failed Block - 0:0:0x0A6F
Erase failed Block - 0:0:0x0A71
Erase failed Block - 0:0:0x0A72
Erase failed Block - 0:0:0x0A73
Erase failed Block - 0:0:0x0A74
Erase failed Block - 0:0:0x0A76
Erase failed Block - 0:0:0x0A77
Erase failed Block - 0:0:0x0A79
Erase failed Block - 0:0:0x0A7A
Erase failed Block - 0:0:0x0A7B
Erase failed Block - 0:0:0x0A7C
Erase failed Block - 0:0:0x0A7E
Erase failed Block - 0:0:0x0A7F
Erase failed Block - 0:0:0x0A80
Erase failed Block - 0:0:0x0A81
Erase failed Block - 0:0:0x0A82
Erase failed Block - 0:0:0x0A83
Erase failed Block - 0:0:0x0A84
Erase failed Block - 0:0:0x0A85
Erase failed Block - 0:0:0x0A86
Erase failed Block - 0:0:0x0A87
Erase failed Block - 0:0:0x0A88
Erase failed Block - 0:0:0x0A89
Erase failed Block - 0:0:0x0A8A
Erase failed Block - 0:0:0x0A8B
Erase failed Block - 0:0:0x0A8C
Erase failed Block - 0:0:0x0A8D
Erase failed Block - 0:0:0x0A8E
Erase failed Block - 0:0:0x0A8F
Erase failed Block - 0:0:0x0A90
Erase failed Block - 0:0:0x0A91
Erase failed Block - 0:0:0x0A92
Erase failed Block - 0:0:0x0A95
Erase failed Block - 0:0:0x0A96
Erase failed Block - 0:0:0x0A97
Erase failed Block - 0:0:0x0A98
Erase failed Block - 0:0:0x0A99
Erase failed Block - 0:0:0x0A9A
Erase failed Block - 0:0:0x0A9B
Erase failed Block - 0:0:0x0A9C
Erase failed Block - 0:0:0x0A9D
Erase failed Block - 0:0:0x0A9E
Erase failed Block - 0:0:0x0A9F
Erase failed Block - 0:0:0x0C02
Erase failed Block - 0:0:0x0C03
Erase failed Block - 0:0:0x0C06
Erase failed Block - 0:0:0x0C07
Erase failed Block - 0:0:0x0C0A
Erase failed Block - 0:0:0x0C0B
Erase failed Block - 0:0:0x0C0D
Erase failed Block - 0:0:0x0C0F
Erase failed Block - 0:0:0x0C10
Erase failed Block - 0:0:0x0C11
Erase failed Block - 0:0:0x0C12
Erase failed Block - 0:0:0x0C13
Erase failed Block - 0:0:0x0C14
Erase failed Block - 0:0:0x0C16
Erase failed Block - 0:0:0x0C17
Erase failed Block - 0:0:0x0C18
Erase failed Block - 0:0:0x0C1A
Erase failed Block - 0:0:0x0C1B
Erase failed Block - 0:0:0x0C1E
Erase failed Block - 0:0:0x0C1F
Erase failed Block - 0:0:0x0C20
Erase failed Block - 0:0:0x0C21
Erase failed Block - 0:0:0x0C22
Erase failed Block - 0:0:0x0C23
Erase failed Block - 0:0:0x0C26
Erase failed Block - 0:0:0x0C27
Erase failed Block - 0:0:0x0C29
Erase failed Block - 0:0:0x0C2A
Erase failed Block - 0:0:0x0C2E
Erase failed Block - 0:0:0x0C2F
Erase failed Block - 0:0:0x0C31
Erase failed Block - 0:0:0x0C32
Erase failed Block - 0:0:0x0C33
Erase failed Block - 0:0:0x0C36
Erase failed Block - 0:0:0x0C37
Erase failed Block - 0:0:0x0C38
Erase failed Block - 0:0:0x0C39
Erase failed Block - 0:0:0x0C3A
Erase failed Block - 0:0:0x0C3B
Erase failed Block - 0:0:0x0C3C
Erase failed Block - 0:0:0x0C3E
Erase failed Block - 0:0:0x0C3F
Erase failed Block - 0:0:0x0C40
Erase failed Block - 0:0:0x0C41
Erase failed Block - 0:0:0x0C43
Erase failed Block - 0:0:0x0C44
Erase failed Block - 0:0:0x0C45
Erase failed Block - 0:0:0x0C47
Erase failed Block - 0:0:0x0C49
Erase failed Block - 0:0:0x0C4B
Erase failed Block - 0:0:0x0C4C
Erase failed Block - 0:0:0x0C4D
Erase failed Block - 0:0:0x0C4F
Erase failed Block - 0:0:0x0C50
Erase failed Block - 0:0:0x0C53
Erase failed Block - 0:0:0x0C54
Erase failed Block - 0:0:0x0C55
Erase failed Block - 0:0:0x0C57
Erase failed Block - 0:0:0x0C59
Erase failed Block - 0:0:0x0C5B
Erase failed Block - 0:0:0x0C5C
Erase failed Block - 0:0:0x0C5D
Erase failed Block - 0:0:0x0C5F
Erase failed Block - 0:0:0x0C62
Erase failed Block - 0:0:0x0C63
Erase failed Block - 0:0:0x0C64
Erase failed Block - 0:0:0x0C65
Erase failed Block - 0:0:0x0C67
Erase failed Block - 0:0:0x0C68
Erase failed Block - 0:0:0x0C69
Erase failed Block - 0:0:0x0C6B
Erase failed Block - 0:0:0x0C6D
Erase failed Block - 0:0:0x0C6F
Erase failed Block - 0:0:0x0C71
Erase failed Block - 0:0:0x0C72
Erase failed Block - 0:0:0x0C73
Erase failed Block - 0:0:0x0C74
Erase failed Block - 0:0:0x0C76
Erase failed Block - 0:0:0x0C77
Erase failed Block - 0:0:0x0C79
Erase failed Block - 0:0:0x0C7A
Erase failed Block - 0:0:0x0C7B
Erase failed Block - 0:0:0x0C7C
Erase failed Block - 0:0:0x0C7E
Erase failed Block - 0:0:0x0C7F
Erase failed Block - 0:0:0x0C80
Erase failed Block - 0:0:0x0C81
Erase failed Block - 0:0:0x0C82
Erase failed Block - 0:0:0x0C83
Erase failed Block - 0:0:0x0C84
Erase failed Block - 0:0:0x0C85
Erase failed Block - 0:0:0x0C86
Erase failed Block - 0:0:0x0C87
Erase failed Block - 0:0:0x0C88
Erase failed Block - 0:0:0x0C89
Erase failed Block - 0:0:0x0C8A
Erase failed Block - 0:0:0x0C8B
Erase failed Block - 0:0:0x0C8C
Erase failed Block - 0:0:0x0C8D
Erase failed Block - 0:0:0x0C8E
Erase failed Block - 0:0:0x0C8F
Erase failed Block - 0:0:0x0C90
Erase failed Block - 0:0:0x0C91
Erase failed Block - 0:0:0x0C92
Erase failed Block - 0:0:0x0C95
Erase failed Block - 0:0:0x0C96
Erase failed Block - 0:0:0x0C97
Erase failed Block - 0:0:0x0C98
Erase failed Block - 0:0:0x0C99
Erase failed Block - 0:0:0x0C9A
Erase failed Block - 0:0:0x0C9B
Erase failed Block - 0:0:0x0C9C
Erase failed Block - 0:0:0x0C9D
Erase failed Block - 0:0:0x0C9E
Erase failed Block - 0:0:0x0C9F
Erase failed Block - 0:0:0x0E02
Erase failed Block - 0:0:0x0E03
Erase failed Block - 0:0:0x0E06
Erase failed Block - 0:0:0x0E07
Erase failed Block - 0:0:0x0E0A
Erase failed Block - 0:0:0x0E0B
Erase failed Block - 0:0:0x0E0D
Erase failed Block - 0:0:0x0E0F
Erase failed Block - 0:0:0x0E10
Erase failed Block - 0:0:0x0E11
Erase failed Block - 0:0:0x0E12
Erase failed Block - 0:0:0x0E13
Erase failed Block - 0:0:0x0E14
Erase failed Block - 0:0:0x0E16
Erase failed Block - 0:0:0x0E17
Erase failed Block - 0:0:0x0E18
Erase failed Block - 0:0:0x0E1A
Erase failed Block - 0:0:0x0E1B
Erase failed Block - 0:0:0x0E1E
Erase failed Block - 0:0:0x0E1F
Erase failed Block - 0:0:0x0E20
Erase failed Block - 0:0:0x0E21
Erase failed Block - 0:0:0x0E22
Erase failed Block - 0:0:0x0E23
Erase failed Block - 0:0:0x0E26
Erase failed Block - 0:0:0x0E27
Erase failed Block - 0:0:0x0E29
Erase failed Block - 0:0:0x0E2A
Erase failed Block - 0:0:0x0E2E
Erase failed Block - 0:0:0x0E2F
Erase failed Block - 0:0:0x0E31
Erase failed Block - 0:0:0x0E32
Erase failed Block - 0:0:0x0E33
Erase failed Block - 0:0:0x0E36
Erase failed Block - 0:0:0x0E37
Erase failed Block - 0:0:0x0E38
Erase failed Block - 0:0:0x0E39
Erase failed Block - 0:0:0x0E3A
Erase failed Block - 0:0:0x0E3B
Erase failed Block - 0:0:0x0E3C
Erase failed Block - 0:0:0x0E3E
Erase failed Block - 0:0:0x0E3F
Erase failed Block - 0:0:0x0E40
Erase failed Block - 0:0:0x0E41
Erase failed Block - 0:0:0x0E43
Erase failed Block - 0:0:0x0E44
Erase failed Block - 0:0:0x0E45
Erase failed Block - 0:0:0x0E47
Erase failed Block - 0:0:0x0E49
Erase failed Block - 0:0:0x0E4B
Erase failed Block - 0:0:0x0E4C
Erase failed Block - 0:0:0x0E4D
Erase failed Block - 0:0:0x0E4F
Erase failed Block - 0:0:0x0E50
Erase failed Block - 0:0:0x0E53
Erase failed Block - 0:0:0x0E54
Erase failed Block - 0:0:0x0E55
Erase failed Block - 0:0:0x0E57
Erase failed Block - 0:0:0x0E59
Erase failed Block - 0:0:0x0E5B
Erase failed Block - 0:0:0x0E5C
Erase failed Block - 0:0:0x0E5D
Erase failed Block - 0:0:0x0E5F
Erase failed Block - 0:0:0x0E62
Erase failed Block - 0:0:0x0E63
Erase failed Block - 0:0:0x0E64
Erase failed Block - 0:0:0x0E65
Erase failed Block - 0:0:0x0E67
Erase failed Block - 0:0:0x0E68
Erase failed Block - 0:0:0x0E69
Erase failed Block - 0:0:0x0E6B
Erase failed Block - 0:0:0x0E6D
Erase failed Block - 0:0:0x0E6F
Erase failed Block - 0:0:0x0E71
Erase failed Block - 0:0:0x0E72
Erase failed Block - 0:0:0x0E73
Erase failed Block - 0:0:0x0E74
Erase failed Block - 0:0:0x0E76
Erase failed Block - 0:0:0x0E77
Erase failed Block - 0:0:0x0E79
Erase failed Block - 0:0:0x0E7A
Erase failed Block - 0:0:0x0E7B
Erase failed Block - 0:0:0x0E7C
Erase failed Block - 0:0:0x0E7E
Erase failed Block - 0:0:0x0E7F
Erase failed Block - 0:0:0x0E80
Erase failed Block - 0:0:0x0E81
Erase failed Block - 0:0:0x0E82
Erase failed Block - 0:0:0x0E83
Erase failed Block - 0:0:0x0E84
Erase failed Block - 0:0:0x0E85
Erase failed Block - 0:0:0x0E86
Erase failed Block - 0:0:0x0E87
Erase failed Block - 0:0:0x0E88
Erase failed Block - 0:0:0x0E89
Erase failed Block - 0:0:0x0E8A
Erase failed Block - 0:0:0x0E8B
Erase failed Block - 0:0:0x0E8C
Erase failed Block - 0:0:0x0E8D
Erase failed Block - 0:0:0x0E8E
Erase failed Block - 0:0:0x0E8F
Erase failed Block - 0:0:0x0E90
Erase failed Block - 0:0:0x0E91
Erase failed Block - 0:0:0x0E92
Erase failed Block - 0:0:0x0E95
Erase failed Block - 0:0:0x0E96
Erase failed Block - 0:0:0x0E97
Erase failed Block - 0:0:0x0E98
Erase failed Block - 0:0:0x0E99
Erase failed Block - 0:0:0x0E9A
Erase failed Block - 0:0:0x0E9B
Erase failed Block - 0:0:0x0E9C
Erase failed Block - 0:0:0x0E9D
Erase failed Block - 0:0:0x0E9E
Erase failed Block - 0:0:0x0E9F
---> Max Bad of Plane (204,257)
---> Max BAD/DIE = 257
Total good blocks after SCAN: 3175 / 4096, Bad block=921
==> 2-Plane mode
Adjust Max LBA = 12587008, 12074944
MaxWindows=2/1474, MaxLBA=12074944, Size=5895 MB
Max BAD of one plane is 257 (261),4096,1,1
RootSector=0x14BB,Sec/Cluster=32, SuperPage=64 ---> Alignment=37
Boot Block=0x0004,0x0008
Lun0(10677348), Lun1(1397596), Public=10677348, Secure=0, CDROM=1397596
Special FE Config = 56-0B-00
Defect Table Block=0x0024
--- Download ISP Code:C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\桌面\MP_VER2162_ALL\ISP_CODE\6691_B3-IM_20100422_VA8010B_C595.BIN---
--- ISP Code installed.
Public,Secure,CDROM = 10677348,0,1397596
SN=C83A35D6F3E8F1604F0014DB
=== Preformat Done ===
Low Level Format DONE
Store INI/ERROR MSG to Block-0x0004:78.
### Err: CDROM file too large(00000000<0015535c).
错误号:error 28 自动跳盘。 无盘 搞了一夜。没搞定
本帖最近打赏记录:共1条打赏M币+3
关键词: SSS6692Kingston
离线木鱼
只看该作者 1楼 发表于: 2011-06-04
本帖最近打赏记录:共1条打赏M币+5
离线sky文
只看该作者 2楼 发表于: 2011-06-04
本帖最近打赏记录:共2条打赏M币+8
离线u盘狂人
只看该作者 3楼 发表于: 2011-06-04
本帖最近打赏记录:共2条打赏M币+11
离线a56516029
只看该作者 4楼 发表于: 2011-06-04
只看该作者 5楼 发表于: 2011-06-04
离线sky文
只看该作者 6楼 发表于: 2011-06-04
回 4楼(a56516029) 的帖子
本帖最近打赏记录:共1条打赏M币+5
离线a56516029
只看该作者 7楼 发表于: 2011-06-04
离线shuishou
只看该作者 8楼 发表于: 2011-06-04
本帖最近打赏记录:共2条打赏M币+8
离线shuishou
只看该作者 9楼 发表于: 2011-06-04
本帖最近打赏记录:共1条打赏M币+5
