前几天在X东买的金士顿DT101 G2 4GB旋转式U盘(4G是蓝色的) 先上几张U盘及量产工具的图: 硬件标示: 钢口DT101G2/4GB 04416-344.A00LF 5V OS 5422250 TAIWAN 闪存FT32G08UCH1-03 S1119-2117737 主控SSS 6692 H2-U6C J5P01-960B 1126 ----------------------------------------------------------------------------------------------------- 弄了两天,参考了很多帖子,经历了不识别F,然后短接量产等等,得到了如下组合: 量产程序: U3S_MP_V2178.exeISP: 6692_B5-IM_20110407_VB88100_989B.BIN INI配置文件: - [OEM]
- PN=6692+ TSB 32D2 TSOP CM 32Gb x 1
- Note=ISP:6692_B5-IM_20110407_VB88100_989B.BIN
- ;MPTool=U3S_MP_V2173.exe
- VID=0x0951
- PID=0x1643
- VENDOR_NAME="Kingston"
- PRODUCT_NAME="DT 101 G2"
- ;BOUNDARY_CHECK=39200
- ;BOUNDARY_CHECK_LOW=39000
- ;DOS_Volume=
- ;FW_VERSION=0xB3
- STRING_DESC_ENABLE=1
- SN_CustomerCode=0x0F
- [FEATURE_SETTING]
- ;Eraseallfirst=2
- ;ID35=1
- ;ID17=1
- ;ID41=1
- ;ID45=1
- ;ID53=2
- ;sortFlash=2
- FLASH_OP="ALL123"
- ;ID0="01"
- ;ID17=1
- ;ID19=-7620
- ID35=1
- ;ID52=100
- [CDROM]
- CDROM_ISO=D:\PE2011.iso
- ;[AUTO DISK SIZE]
- ;DiskSize-1=7550
- ;DiskSize-2=7050
- ;DiskSize-3=4096
- ;DiskSize-4=2048
- [ISP]
- Code=6692_B5-IM_20110407_VB88100_989B.BIN
原cardinfo: - ---------------- Device 1------------------
- MP Tool Version : V2.177_T2
- INI File Name : 9904416-344.A00LF.INI
- Format Date : 2011-07-28 03:50:17
- Flash Part No : Hynix 32nm D2 MLC
- CE-0, Flash ID=AD-D7-94-9A-74-42-AD
- VID : 0x0951
- PID : 0x1642
- Vendor Name = Kingston
- Product Name = DT 101 G2
- Serial Number = 001CC07CE9A2FB71C92A20E3
- Volume Label = KINGSTON
- F/W Version : 0xB5
- ISP Version : VB8.0000
- Flash R/W Timing : 25ns
- Channel : Byte Mode
- Homogeneous Mode : On
- HID Function : Disable
- Planes(F/W) : 2
- Pages/Block : 256 pages
- Max Current : 100 mA
- Total Blocks : 2048
- Bad Blocks : 0
- Capacity : 7814728 Sectors, 4001140736 Bytes
- 3907364 KBytes, 3815.79 MBytes, 3.73 GBytes
量产时设置Disk Capacity Limitation--Device Size为3192MB之后量产... 现cardinfo: - ---------------- Device 1------------------
- MP Tool Version : V2.178
- INI File Name : 6692test.INI
- Format Date : 2011-09-14 12:35:57
- VID : 0x0951
- PID : 0x1643
- Serial Number = 001E8C032082FB90EB242035
- Volume Label =
- ISP Version : VB8.8100
- Planes(F/W) : 2
- Bad Blocks : 0
- Capacity : 7233536 Sectors, 3703570432 Bytes
- 3616768 KBytes, 3532.00 MBytes, 3.45 GBytes
量产CDROM后的report: - Device 1:0xB5
- MP Version:2.178
- INI_File_Name:6692test.INI
- Random delay 0 msec
- --- Download MP ISP ---
- Auto CE: 0x00 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF
- CE-0, Flash ID=AD-D7-94-9A-74-42-AD-D7
- Searching SORTING BOARD table ...
- --> Not Found
- Found BACKUP Table (0000023A-0002)
- Defect Table (00000800-0008)
- Defect Table shows 2048 Good blocks, 0 Bad blocks
- SafeErase (0,2048)
- ---> Max Bad of Plane (1,1)
- ---> Max BAD/DIE = 1
- Total good blocks after SCAN: 2048 / 2048, Bad block=0
- ==> 2-Plane mode
- Max. Bad Block Allowed = 82(0)
- Adjust Max LBA = 7823360, 7823296
- MaxWindows=1/1910, MaxLBA=7823296, Size=3819 MB
- Max BAD of one plane is 1 (41),2048,1,1
- RootSector=0x747,Sec/Cluster=64, SuperPage=64 ---> Alignment=57
- Boot Block=0x0002,0x0004
- Lun0(7237460), Lun1(585836), Public=7237460, Secure=0, CDROM=585836
- Special FE Config = 56-0B-00
- Defect Table Block=0x0008
- --- Download ISP Code:D:\MP_VER2178\ISP_CODE\6692_B5-IM_20110407_VB88100_989B.BIN---
- --- ISP Code installed.
- Public,Secure,CDROM = 7237460,0,585836
- PHY: E2/E4/E6=72h/36h/04h, D0/C0/CFG10=DFh/0Bh/87h
- SN=001E8C032082FB90EB242035
- === Preformat Done ===
- Low Level Format DONE
- Store INI/ERROR MSG to Block-0x0002:78.
- LBATest 10M activate
- CDROM image:D:\PE2011.iso
- Total=7823296,CDROM=585836, PublicArea=7237332, SecureArea=0
- Create SECURE(CDROM=1,Public=3533 MB,Secure=0 MB)
- Write LBA(0x00702054,128) Fail !
- ### Err: SECURE failed(1235288).
我感觉是ini文件配置有误,求帮助! [ 此帖被soaarp在2011-09-14 15:28重新编辑 ]
