SK6216
Description:
SK6216是一個效能加強版的隨身碟控制器,它能符合USB2.0的規格並能以極低功率來滿足USB bus-power的需求。
SK6216 的ECC糾正能力高達70bit,可支援最新2x/ 3x奈米之 MLC。
Features:
˙Support 2x/3x nm MLC and TLC NAND:
- 70-bit/1KB BCH error control coding (ECC) for MLC.
- Sufficient embedded buffer for 8K page NAND in dual channel configuration.
˙Advance Wear Leveling can improve P/E cycle of NAND.
˙Outstanding R/W performance:
- HDBench: Read:TBD MB/s and Write: TBD MB/s with MLC in dual channel.
Read: TBD MB/s and Write: TBD MB/s with TLC in dual channel.
- ReadyBoost :>5 MB/sec throughput for random 4KB reads and,
>3 MB/sec throughput for random 512KB writes
˙USB Interface:
- Complied with high-speed USB 2.0 interface, backward compatible with USB 1.1.
- Complied with USB Mass Storage Class specification v1.0.
- Complied with USB bus-powered devices specification.
- Support HID interface for password entry in non-administrator mode.
- Integrated USB 2.0 Transceiver Macrocell Interface (UTMI) and Serial Interface Engine (SIE).
˙Varieties of Supported NAND:
- Samsung 27nm MLC & TLC, 32 nm MLC & TLC.
- IM 25 nm MLC & TLC.
- Hynix 26nm MLC, 32 nm MLC & TLC.
- Toshiba 24 MLC, 32 nm MLC & TLC.
- Kinds of page size: 2KB, 4KB and 8KB.
- Kinds of page per block: 128 pages, 192 pages, 256 pages and 384 pages.
˙Async. NAND Interface with 3.3V VCCq:
- SK6216AAPMC: dual channel and 4 CE/channel.
- SK6216AAPMC8: single channel and 8 CE/channel.
˙DDR NAND interface:
- 1.8V or 3.3V VCCq DDR NAND, either ONFI 2.x NAND or Toggle-mode NAND.
- SK6216AAPMC: single channel and 4 CE/channel with 3.3V VCCq.
- SK6216AAPMC8: single channel and 8 CE/channel with 1.8V/3.3V VCCq.
˙Built-in Watch-Dog Timer (WDT)
˙Enable Multi-Partition features:
- One Read-only Partition, two Read-Write Partitions and one Hidden Partition.
- Read-only Partition is designated for AutoRun feature.
- UFD can have up to two LUNs because to two Read-Write Partitions.
- Each Read-Write Partition can be divided into Public Zone and Private Zone further.
- Private Zone can be protected by password.
- Capacity of each Partition and Zone can sizeable while factory initialization or by application program through vendor specific command.[/td][/tr][/table]
