  • 6363阅读
  • 14回复
[鑫创]Kingston DT101 8G 用最3S6692_MP_Ver2182量产失败! [复制链接]
离线jyhyq0524
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2011-11-02
用3S6692_MP_Ver2182 量产Kingston DT101 8G :
U盘量产前信息:
---------------- Device 1------------------
  MP Tool Version : V2.187
  INI File Name : 9904415-328.A00LF.INI
  Format Date : 2011-10-07 07:38:00
  Flash Part No : Micron D2 MLC
  CE-0, Flash ID=2C-88-04-4B-A9-00-00
  VID : 0x0951
  PID : 0x1642
  Vendor Name = Kingston
  Product Name = DT 101 G2
  Serial Number = 001CC0EC34A2FBA077092A8B
  Volume Label = NO NAME
  F/W Version : 0xB5
  ISP Version : VB7.0100
  Flash R/W Timing : 25ns
  Channel : Byte Mode
  Homogeneous Mode : On
  HID Function : Disable
  Planes(F/W) : 2
  Pages/Block : 256 pages
  Max Current : 100 mA
  Total Blocks : 4096
  Bad Blocks : 8
  Capacity : 15613512 Sectors, 7994118144 Bytes
                   7806756 KBytes, 7623.79 MBytes, 7.45 GBytes
开始量产:
打开的时候提示:
但是可以打开,
INI文件如下:
但是量产失败:
Result报告如下:
Starting Time: 18:55:03
Device 1:0xB5
MP Version:2.182
INI_File_Name:6692_MG26_256P_8KB.INI
Random delay 0 msec
--- Download MP ISP ---
Auto CE: 0x00 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF
CE-0, Flash ID=2C-88-04-4B-A9-00-00-00
Page/Block=256
Searching SORTING BOARD table ...
--> Not Found
Found BACKUP Table (0000023A-0002)
Defect Table (00000800-0008)
  Original Bad Block - 0:0x005A
  Original Bad Block - 0:0x005B
  Original Bad Block - 0:0x0A2C
  Original Bad Block - 0:0x0A2D
  Original Bad Block - 0:0x0C3F
  Original Bad Block - 0:0x0C4B
  Original Bad Block - 0:0x0C80
  Original Bad Block - 0:0x0C81
Defect Table shows 4088 Good blocks, 8 Bad blocks
SafeErase (0,4096)
  Erase failed Block - 0:0:0x005A
  Erase failed Block - 0:0:0x005B
  Erase failed Block - 0:0:0x0A2C
  Erase failed Block - 0:0:0x0A2D
  Erase failed Block - 0:0:0x0C3F
  Erase failed Block - 0:0:0x0C4B
  Erase failed Block - 0:0:0x0C80
  Erase failed Block - 0:0:0x0C81
  ---> Max Bad of Plane (2,3)
  ---> Max BAD/DIE = 3
Total good blocks after SCAN: 4088 / 4096, Bad block=8
==> 2-Plane mode
Max. Bad Block Allowed = 174(8)
Adjust Max LBA = 15646720, 15646656
MaxWindows=2/1910, MaxLBA=15646656, Size=7639 MB
Max BAD of one plane is 3 (43),4096,1,1
RootSector=0xC93,Sec/Cluster=64, SuperPage=64 ---> Alignment=45
Boot Block=0x0002,0x0004
Lun0(12797296), Lun1(2849360), Public=12797296, Secure=0, CDROM=2849360
Special FE Config = 56-0B-00
Defect Table Block=0x0008
--- Download ISP Code:C:\WLS\6692 V2182\ISP_CODE\6692_B5-IM_20101123_VBB0100_53FB.BIN---
--- ISP Code installed.
Public,Secure,CDROM = 12797296,0,2849360
PHY: E2/E4/E6=72h/36h/04h,  D0/C0/CFG10=DFh/0Bh/87h
SN=001A73265ABDFBB02CFC2038
=== Preformat Done ===
Low Level Format DONE
Store INI/ERROR MSG to Block-0x0002:78.
LBATest 10M activate
CDROM image:C:\数码之家五合一装机维护工具盘.iso
Total=15646656,CDROM=2849360, PublicArea=12797168, SecureArea=0
Create SECURE(CDROM=1,Public=6248 MB,Secure=0 MB)
   Write LBA(0x00C345F0,128) Fail !
### Err: SECURE failed(2088773120).
Ending Time: 18:55:28
就上面几个问题,寻求帮忙!反复量产多次,结果都是Error 28!
离线shuishou
只看该作者 1楼 发表于: 2011-11-02
本帖最近打赏记录:共2条打赏M币+10
离线木鱼
只看该作者 2楼 发表于: 2011-11-02
本帖最近打赏记录:共1条打赏M币+5
离线jyhyq0524
只看该作者 3楼 发表于: 2011-11-02
回 1楼(shuishou) 的帖子
离线ccwdy
只看该作者 4楼 发表于: 2011-11-02
本帖最近打赏记录:共1条打赏M币+5
离线shuishou
只看该作者 5楼 发表于: 2011-11-02
回 3楼(jyhyq0524) 的帖子
本帖最近打赏记录:共1条打赏M币+5
离线jyhyq0524
只看该作者 6楼 发表于: 2011-11-03
回 4楼(ccwdy) 的帖子
离线acdc1978
只看该作者 7楼 发表于: 2011-11-03
回 楼主(jyhyq0524) 的帖子
本帖最近打赏记录:共1条打赏M币+5
离线hfsp
只看该作者 8楼 发表于: 2011-11-06
本帖最近打赏记录:共1条打赏M币+5
离线shuishou
只看该作者 9楼 发表于: 2011-11-06
回 8楼(hfsp) 的帖子
本帖最近打赏记录:共2条打赏M币+14
