  • 3165阅读
  • 14回复
[鑫创]3s6690量产失败,求助!!!!!!! [复制链接]
离线biyu2008
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2011-11-03
用的是:
[鑫创]SSS6690 V2.159最新量产固件发布, 东芝TLC可量产USB-CDROM(亲测有效,绝对独家首发)
PS:之前用这个已经量产成功的,但是USB-CD 不能启动,所以想换个ISO重新量产,结果就失败!
错误详细:
Starting Time: 13:47:20
Device 1:0xB1
MP Version:2.159
INI_File_Name:6690_D3.INI
Random delay 0 msec
--- Download MP ISP ---
CE-0, Flash ID=98-D7-99-B2-7A-54-0B-04
CE-1, Flash ID=98-D7-99-B2-7A-54-0B-04
Found BACKUP Table (00000159-0001)
Found BACKUP Table (00000259-0002)
  Original Bad Block - 0:0x00C4
  Original Bad Block - 0:0x03CB
  Original Bad Block - 0:0x03CD
  Original Bad Block - 0:0x041E
  Original Bad Block - 0:0x0B14
  Original Bad Block - 0:0x0C6A
  Original Bad Block - 0:0x0D24
  Original Bad Block - 1:0x0055
  Original Bad Block - 1:0x017C
  Original Bad Block - 1:0x023A
  Original Bad Block - 1:0x031D
  Original Bad Block - 1:0x034E
  Original Bad Block - 1:0x03D1
  Original Bad Block - 1:0x045B
  Original Bad Block - 1:0x0499
  Original Bad Block - 1:0x04C6
  Original Bad Block - 1:0x080E
  Original Bad Block - 1:0x08B0
  Original Bad Block - 1:0x0916
  Original Bad Block - 1:0x091D
  Original Bad Block - 1:0x0937
  Original Bad Block - 1:0x095B
  Original Bad Block - 1:0x0975
  Original Bad Block - 1:0x097F
  Original Bad Block - 1:0x09AB
  Original Bad Block - 1:0x09E2
  Original Bad Block - 1:0x09ED
  Original Bad Block - 1:0x0C9C
Defect Table shows 5588 Good blocks, 28 Bad blocks
SafeErase (0,2808)
  Erase failed Block - 0:0:0x00C4
  Erase failed Block - 0:0:0x03CB
  Erase failed Block - 0:0:0x03CD
  Erase failed Block - 0:0:0x041E
  ---> Max Bad of Plane (2,2)
  Erase failed Block - 0:1:0x0B14
  Erase failed Block - 0:1:0x0C6A
  Erase failed Block - 0:1:0x0D24
  ---> Max Bad of Plane (3,0)
SafeErase (1,2808)
  Erase failed Block - 1:0:0x0055
  Erase failed Block - 1:0:0x017C
  Erase failed Block - 1:0:0x023A
  Erase failed Block - 1:0:0x031D
  Erase failed Block - 1:0:0x034E
  Erase failed Block - 1:0:0x03D1
  Erase failed Block - 1:0:0x045B
  Erase failed Block - 1:0:0x0499
  Erase failed Block - 1:0:0x04C6
  ---> Max Bad of Plane (4,5)
  Erase failed Block - 1:1:0x080E
  Erase failed Block - 1:1:0x08B0
  Erase failed Block - 1:1:0x0916
  Erase failed Block - 1:1:0x091D
  Erase failed Block - 1:1:0x0937
  Erase failed Block - 1:1:0x095B
  Erase failed Block - 1:1:0x0975
  Erase failed Block - 1:1:0x097F
  Erase failed Block - 1:1:0x09AB
  Erase failed Block - 1:1:0x09E2
  Erase failed Block - 1:1:0x09ED
  Erase failed Block - 1:1:0x0C9C
  ---> Max Bad of Plane (5,7)
  ---> Max BAD/DIE = 7
Total good blocks after SCAN: 5588 / 5616, Bad block=28
==> 2-Plane mode
Adjust Max LBA = 16588800, 16441280
MaxWindows=4/1338, MaxLBA=16441280, Size=8027 MB
Max BAD of one plane is 7 (9),5616,2,2
RootSector=0x1DDD,Sec/Cluster=32, SuperPage=32 ---> Alignment=3
Boot Block=0x0001,0x0002asa
Lun0(15465832), Lun1(975448), Public=15465832, Secure=0, CDROM=975448
Special FE Config = 56-0B-00
--- Download ISP Code:E:\6690_TSBD3_MP_V2159\ISP_CODE\6690_B1-D3_20110910_V221B_BEFA.BIN---
--- ISP Code installed.
Public,Secure,CDROM = 15465832,0,975448
SN=6C626DC7DAEFF1B03AD8202E
=== Preformat Done ===
Low Level Format DONE
Store INI/ERROR MSG to Block-0x0001:119.
LBATest 10M activate
### Error: CopyTest Fail(Compare LBA=0x000017C0, 7A00=2D,00)
### CopyTest 10M fail ###
Ending Time: 13:47:39
[ 此帖被biyu2008在2011-11-03 19:32重新编辑 ]
离线biyu2008
只看该作者 1楼 发表于: 2011-11-03
离线shuishou
只看该作者 2楼 发表于: 2011-11-03
本帖最近打赏记录:共1条打赏M币+5
离线木鱼
只看该作者 3楼 发表于: 2011-11-03
本帖最近打赏记录:共1条打赏M币+5
离线acdc1978
只看该作者 4楼 发表于: 2011-11-03
回 楼主(biyu2008) 的帖子
离线biyu2008
只看该作者 5楼 发表于: 2011-11-03
回 2楼(shuishou) 的帖子
离线biyu2008
只看该作者 6楼 发表于: 2011-11-03
回 4楼(acdc1978) 的帖子
离线biyu2008
只看该作者 7楼 发表于: 2011-11-03
离线melvins
只看该作者 8楼 发表于: 2011-11-03
本帖最近打赏记录:共1条打赏M币+5
离线biyu2008
只看该作者 9楼 发表于: 2011-11-03
