  • 3399阅读
  • 7回复
[鑫创]6692第二次量产一直不成功,高手帮看看错误出在哪,谢谢,在线等 [复制链接]
离线nanxingmao
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2011-11-09
一直出现错误8,
代码如下:
     Device 1:0xB5
MP Version:2.182
INI_File_Name:6692_MG26_256P_8KB.INI
Random delay 0 msec
--- Download MP ISP ---
Auto CE: 0x00 0x01 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF
CE-0, Flash ID=2C-88-04-4B-A9-00-00-00
CE-1, Flash ID=2C-88-04-4B-A9-00-00-00
Page/Block=256
Searching SORTING BOARD table ...
--> Not Found
Found BACKUP Table (0000023A-0002)
Found BACKUP Table (0000033A-0003)
  Original Bad Block - 0:0x0002
  Original Bad Block - 0:0x0003
  Original Bad Block - 0:0x0006
  Original Bad Block - 0:0x0007
  Original Bad Block - 0:0x000A
  Original Bad Block - 0:0x000B
  Original Bad Block - 0:0x000D
  Original Bad Block - 0:0x000F
  Original Bad Block - 0:0x0010
  Original Bad Block - 0:0x0011
  Original Bad Block - 0:0x0012
  Original Bad Block - 0:0x0013
  Original Bad Block - 0:0x0014
  Original Bad Block - 0:0x0016
  Original Bad Block - 0:0x0017
  Original Bad Block - 0:0x0018
  Original Bad Block - 0:0x001A
  Original Bad Block - 0:0x001B
  Original Bad Block - 0:0x001E
  Original Bad Block - 0:0x001F
  Original Bad Block - 0:0x0020
  Original Bad Block - 0:0x0021
  Original Bad Block - 0:0x0022
  Original Bad Block - 0:0x0023
  Original Bad Block - 0:0x0026
  Original Bad Block - 0:0x0027
  Original Bad Block - 0:0x0029
  Original Bad Block - 0:0x002A
  Original Bad Block - 0:0x002E
  Original Bad Block - 0:0x002F
  Original Bad Block - 0:0x003C
  Original Bad Block - 0:0x003E
  Original Bad Block - 0:0x003F
  Original Bad Block - 0:0x0040
  Original Bad Block - 0:0x0041
  Original Bad Block - 0:0x0043
  Original Bad Block - 0:0x0044
  Original Bad Block - 0:0x0045
  Original Bad Block - 0:0x0047
  Original Bad Block - 0:0x0049
。。。。。。中间省略N多
  Erase failed Block - 0:0:0x0E92
  Erase failed Block - 0:0:0x0E94
  Erase failed Block - 0:0:0x0E95
  Erase failed Block - 0:0:0x0E96
  Erase failed Block - 0:0:0x0E97
  Erase failed Block - 0:0:0x0E98
  Erase failed Block - 0:0:0x0E99
  Erase failed Block - 0:0:0x0E9A
  Erase failed Block - 0:0:0x0E9B
  Erase failed Block - 0:0:0x0E9C
  Erase failed Block - 0:0:0x0E9D
  Erase failed Block - 0:0:0x0E9E
  Erase failed Block - 0:0:0x0E9F
  ---> Max Bad of Plane (209,256)
SafeErase (1,4096)
  Erase failed Block - 1:0:0x005A
  Erase failed Block - 1:0:0x005B
  Erase failed Block - 1:0:0x0BDE
  ---> Max Bad of Plane (1,1)
  ---> Max BAD/DIE = 256
求解啊,正郁闷呢?
离线shuishou
只看该作者 1楼 发表于: 2011-11-09
回 楼主(nanxingmao) 的帖子
本帖最近打赏记录:共1条打赏M币+5
离线gamester
只看该作者 2楼 发表于: 2011-11-09
本帖最近打赏记录:共2条打赏M币+7
离线hfsp
只看该作者 3楼 发表于: 2011-11-09
Re:回 楼主(nanxingmao) 的帖子
离线扬帆远航
只看该作者 4楼 发表于: 2011-11-09
离线tingji
只看该作者 5楼 发表于: 2011-11-21
离线dxfdfl
只看该作者 6楼 发表于: 2011-11-21
离线jodz
只看该作者 7楼 发表于: 2012-08-07
