3S6692主控,HY32nm MLC Flash,通过短路Flash29、30脚才能看到盘符,量产时报错,是INI错误还是“”CDROM=0”错误,请论坛高手指点。Device 1:0xB5
MP Version:2.182
INI_File_Name:6692_HY32_256P_8KB.INI
Random delay 0 msec
--- Download MP ISP ---
Auto CE: 0x00 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF
CE-0, Flash ID=AD-D7-94-9A-74-42-AD-D7
Page/Block=256
Searching SORTING BOARD table ...
--> Not Found
Scan (0,2048)
Original Defect Block - 0:0:0x0002
Original Defect Block - 0:0:0x0003
Original Defect Block - 0:0:0x0004
Original Defect Block - 0:0:0x0005
Original Defect Block - 0:0:0x0008
Original Defect Block - 0:0:0x0009
Original Defect Block - 0:0:0x000A
Original Defect Block - 0:0:0x000B
Original Defect Block - 0:0:0x0392
Original Defect Block - 0:0:0x0393
---> Max Bad of Plane (6,6)
---> Max BAD/DIE = 6
Total good blocks after SCAN: 2038 / 2048, Bad block=10
==> 2-Plane mode
Max. Bad Block Allowed = 82(10)
Adjust Max LBA = 7823360, 7823296
MaxWindows=1/1910, MaxLBA=7823296, Size=3819 MB
Max BAD of one plane is 6 (41),2048,1,1
RootSector=0x7D5,Sec/Cluster=64, SuperPage=64 ---> Alignment=43
Boot Block=0x0006,0x000C
Lun0(7823296), Lun1(0), Public=7823296, Secure=0, CDROM=0
Special FE Config = 54-0B-00
Defect Table Block=0x0010
--- Download ISP Code:C:\6692\ISP_CODE\6692_B5-IM_20110114_VB80000_51F5.BIN---
--- ISP Code installed.
Public,Secure,CDROM = 7823296,0,0
PHY: E2/E4/E6=72h/36h/04h, D0/C0/CFG10=DFh/0Bh/87h
SN=000E7FA8FACFFBB0AA16202C
=== Preformat Done ===
Low Level Format DONE
Store INI/ERROR MSG to Block-0x0006:78.
### Error: Device capacity is 0 bytes
