今天刚到手一个金士顿8GB的U盘,想产量一下,老是做不好,下面是ChipGenius的检测信息
设备描述: [H:]USB Mass Storage Device(Kingston DataTraveler G3)
设备类型: 大容量存储设备
协议版本: USB 2.00
当前速度: 高速(HighSpeed)
电力消耗: 100mA
USB设备ID: VID = 0951 PID = 1643
设备序列号: 00E0B11EAD98FBC0F1D3202E
设备供应商: Kingston
设备名称: DataTraveler G3
设备修订版: 0100
产品制造商: Kingston
产品型号: DataTraveler G3
产品修订版: 1.00
芯片厂商: SSS(鑫创)
芯片型号: SSS6692-B5
错误信息如下:
Device 1:0xB5
MP Version:2.182
INI_File_Name:6692_MG26_256P_8KB.INI
Random delay 0 msec
--- Download MP ISP ---
Auto CE: 0x00 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF
CE-0, Flash ID=AD-DE-94-D2-04-43-AD-DE
Page/Block=256
Searching SORTING BOARD table ...
--> Not Found
Found BACKUP Table (0000023A-0002)
Defect Table (00000800-0008)
Defect Table shows 4096 Good blocks, 0 Bad blocks
SafeErase (0,4096)
---> Max Bad of Plane (0,0)
---> Max BAD/DIE = 0
Total good blocks after SCAN: 4096 / 4096, Bad block=0
==> 2-Plane mode
Max. Bad Block Allowed = 174(0)
Adjust Max LBA = 15646720, 15646656
MaxWindows=2/1910, MaxLBA=15646656, Size=7639 MB
Max BAD of one plane is 0 (43),4096,1,1
RootSector=0xDEF,Sec/Cluster=64, SuperPage=64 ---> Alignment=17
Boot Block=0x0002,0x0004
Lun0(14221852), Lun1(1424804), Public=14221852, Secure=0, CDROM=1424804
Special FE Config = 56-0B-00
Defect Table Block=0x0008
--- Download ISP Code:C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\桌面\1\6692_HY26_MP_V2182\ISP_CODE\6692_B5-IM_20101123_VBB0100_53FB.BIN---
--- ISP Code installed.
Public,Secure,CDROM = 14221852,0,1424804
PHY: E2/E4/E6=72h/36h/04h, D0/C0/CFG10=DFh/0Bh/87h
SN=00E0B11EAD98FBC0F1D3202E
=== Preformat Done ===
Low Level Format DONE
Store INI/ERROR MSG to Block-0x0002:78.
### Error: Device capacity is 0 bytes
哪位达人能帮一下么
