  • 2091阅读
  • 0回复
[鑫创]求助新手量产金士顿DT 101 G2 8G  U盘 失败 [复制链接]
离线ssjsyj
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2012-03-24
Device 1:0xB5
MP Version:2.182
INI_File_Name:6692_HY26_256P_8KB.INI
Random delay 0 msec
--- Download MP ISP ---
Auto CE: 0x00 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF
CE-0, Flash ID=AD-DE-94-D2-04-43-AD-DE
Page/Block=256
Searching SORTING BOARD table ...
--> Not Found
Found BACKUP Table (0000023A-0002)
Defect Table (00000800-0008)
Defect Table shows 4096 Good blocks, 0 Bad blocks
SafeErase (0,4096)
  ---> Max Bad of Plane (0,0)
  ---> Max BAD/DIE = 0
Total good blocks after SCAN: 4096 / 4096, Bad block=0
==> 2-Plane mode
Max. Bad Block Allowed = 174(0)
Adjust Max LBA = 15646720, 15646656
MaxWindows=2/1910, MaxLBA=15646656, Size=7639 MB
Max BAD of one plane is 0 (43),4096,1,1
RootSector=0xF4B,Sec/Cluster=64, SuperPage=64 ---> Alignment=53
Boot Block=0x0002,0x0004
Lun0(15646656), Lun1(0), Public=15646656, Secure=0, CDROM=0
Special FE Config = 54-0B-00
Defect Table Block=0x0008
--- Download ISP Code:C:\USERS\JEE\DESKTOP\3S6692_MP_VER2182\ISP_CODE\6692_B5-IM_20110422_VB88200_B3EF.BIN---
--- ISP Code installed.
Public,Secure,CDROM = 15646656,0,0
PHY: E2/E4/E6=72h/36h/04h,  D0/C0/CFG10=DFh/0Bh/87h
SN=000000000000FC318E830001
=== Preformat Done ===
Low Level Format DONE
Store INI/ERROR MSG to Block-0x0002:78.
Total=15646656,CDROM=0, PublicArea=15646528, SecureArea=0
### Err: SECURE failed(32).
试了很多次都不行....金士顿DT 101 G2 8G  U盘
[attachment=undefined]
[ 此帖被鱼水情在2012-03-25 16:35重新编辑 ]
