  • 5293阅读
  • 6回复
[鑫创]求救啊 sss6691 error28 [复制链接]
离线zzzzypzyp
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2012-03-26
金士顿 101 II量产 报错28
Device 1:0xB3
    MP Version:2.159
    INI_File_Name:6691_TSB_43nm_D2_CDROM.INI
    Random delay 0 msec
    --- Download MP ISP ---
    CE-0, Flash ID=98-D7-94-32-76-54-0C-00
    Found BACKUP Table (000000BB-0001)
    Defect Table (00000200-0004)
        Original Bad Block - 0:0x0000
        Original Bad Block - 0:0x03B7
        Original Bad Block - 0:0x03DB
        Original Bad Block - 0:0x041D
        Original Bad Block - 0:0x0445
        Original Bad Block - 0:0x04B1
        Original Bad Block - 0:0x04C5
        Original Bad Block - 0:0x0529
        Original Bad Block - 0:0x0534
        Original Bad Block - 0:0x0549
        Original Bad Block - 0:0x0591
        Original Bad Block - 0:0x05F5
        Original Bad Block - 0:0x0605
        Original Bad Block - 0:0x0641
        Original Bad Block - 0:0x0655
        Original Bad Block - 0:0x065D
        Original Bad Block - 0:0x0689
        Original Bad Block - 0:0x0699
        Original Bad Block - 0:0x06B5
        Original Bad Block - 0:0x06C5
        Original Bad Block - 0:0x06D5
        Original Bad Block - 0:0x0719
        Original Bad Block - 0:0x0721
        Original Bad Block - 0:0x072D
        Original Bad Block - 0:0x0735
        Original Bad Block - 0:0x074D
        Original Bad Block - 0:0x076D
        Original Bad Block - 0:0x0793
        Original Bad Block - 0:0x07A1
        Original Bad Block - 0:0x07A5
        Original Bad Block - 0:0x07B9
        Original Bad Block - 0:0x07BD
        Original Bad Block - 0:0x07E1
        Original Bad Block - 0:0x07F5
        Original Bad Block - 0:0x0811
        Original Bad Block - 0:0x0AFC
        Original Bad Block - 0:0x0C30
        Original Bad Block - 0:0x0CDA
        Original Bad Block - 0:0x0E46
        Original Bad Block - 0:0x1005
        Original Bad Block - 0:0x1012
        Original Bad Block - 0:0x1030
        Original Bad Block - 0:0x1031
        Original Bad Block - 0:0x1032
        Original Bad Block - 0:0x1033
    Defect Table shows 4103 Good blocks, 45 Bad blocks
    SafeErase (0,4148)
        Erase failed Block - 0:0:0x0000
        Erase failed Block - 0:0:0x03B7
        Erase failed Block - 0:0:0x03DB
        Erase failed Block - 0:0:0x041D
        Erase failed Block - 0:0:0x0445
        Erase failed Block - 0:0:0x04B1
        Erase failed Block - 0:0:0x04C5
        Erase failed Block - 0:0:0x0529
        Erase failed Block - 0:0:0x0534
        Erase failed Block - 0:0:0x0549
        Erase failed Block - 0:0:0x0591
        Erase failed Block - 0:0:0x05F5
        Erase failed Block - 0:0:0x0605
        Erase failed Block - 0:0:0x0641
        Erase failed Block - 0:0:0x0655
        Erase failed Block - 0:0:0x065D
        Erase failed Block - 0:0:0x0689
        Erase failed Block - 0:0:0x0699
        Erase failed Block - 0:0:0x06B5
        Erase failed Block - 0:0:0x06C5
        Erase failed Block - 0:0:0x06D5
        Erase failed Block - 0:0:0x0719
        Erase failed Block - 0:0:0x0721
        Erase failed Block - 0:0:0x072D
        Erase failed Block - 0:0:0x0735
        Erase failed Block - 0:0:0x074D
        Erase failed Block - 0:0:0x076D
        Erase failed Block - 0:0:0x0793
        Erase failed Block - 0:0:0x07A1
        Erase failed Block - 0:0:0x07A5
        Erase failed Block - 0:0:0x07B9
        Erase failed Block - 0:0:0x07BD
        Erase failed Block - 0:0:0x07E1
        Erase failed Block - 0:0:0x07F5
        Erase failed Block - 0:0:0x0811
        Erase failed Block - 0:0:0x0AFC
        Erase failed Block - 0:0:0x0C30
        Erase failed Block - 0:0:0x0CDA
        Erase failed Block - 0:0:0x0E46
        Erase failed Block - 0:0:0x1005
        Erase failed Block - 0:0:0x1012
        Erase failed Block - 0:0:0x1030
        Erase failed Block - 0:0:0x1031
        Erase failed Block - 0:0:0x1032
        Erase failed Block - 0:0:0x1033
        ---> Max Bad of Plane (5,18)
        ---> Max BAD/DIE = 18
    Total good blocks after SCAN: 4103 / 4148, Bad block=45
    ==> 2-Plane mode
    Max. Bad Block Allowed = 231(45)
    Adjust Max LBA = 7823360, 7823296
    MaxWindows=2/1910, MaxLBA=7823296, Size=3819 MB
    Max BAD of one plane is 18 (57),4148,1,1
    RootSector=0xF4B,Sec/Cluster=32, SuperPage=32 ---> Alignment=21
    Boot Block=0x0001,0x0002
    Lun0(7823296), Lun1(0), Public=7823296, Secure=0, CDROM=0
    Special FE Config = 54-0B-00
    Defect Table Block=0x0004
    --- Download ISP Code:C:\USERS\ADMINISTRATOR.SUPERVISOR\DESKTOP\SSS_6691_U3S_MP_V2159\ISP_CODE\6691_B3-A_20100331_VA10F00_9083.BIN---
    --- ISP Code installed.
    Public,Secure,CDROM = 7823296,0,0
    SN=D6AF782F482FF231901614A0
    === Preformat Done ===
    Low Level Format DONE
    Store INI/ERROR MSG to Block-0x0001:79.
    LBATest 10M activate
    Total=7823296,CDROM=0, PublicArea=7823168, SecureArea=0
    ### Err: SECURE failed(32).
求救啊 各位大虾
本帖最近打赏记录:共1条打赏M币+3
离线shuishou
只看该作者 1楼 发表于: 2012-03-26
回 楼主(zzzzypzyp) 的帖子
本帖最近打赏记录:共2条打赏M币+10
离线xiaogang0207
只看该作者 2楼 发表于: 2012-03-26
离线zhucege
只看该作者 3楼 发表于: 2012-03-26
离线gamester
只看该作者 4楼 发表于: 2012-03-26
本帖最近打赏记录:共2条打赏M币+10
离线yujia1shao
只看该作者 5楼 发表于: 2012-03-26
本帖最近打赏记录:共1条打赏M币+5
离线aquilion
只看该作者 6楼 发表于: 2012-09-12
本帖最近打赏记录:共1条打赏M币+10
