Device 1:0xB5
MP Version:2.182
INI_File_Name:6692_HY26_256P_8KB.INI
Random delay 0 msec
--- Download MP ISP ---
Auto CE: 0x00 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF
CE-0, Flash ID=AD-D7-94-9A-74-42-AD-D7
Page/Block=256
Searching SORTING BOARD table ...
--> Not Found
Scan (0,2048)
Original Defect Block - 0:0:0x0002
Original Defect Block - 0:0:0x0003
Original Defect Block - 0:0:0x0004
Original Defect Block - 0:0:0x0005
Original Defect Block - 0:0:0x0006
Original Defect Block - 0:0:0x0007
Original Defect Block - 0:0:0x0008
Original Defect Block - 0:0:0x0009
Original Defect Block - 0:0:0x000A
Original Defect Block - 0:0:0x000B
Original Defect Block - 0:0:0x000C
Original Defect Block - 0:0:0x000D
Original Defect Block - 0:0:0x000E
Original Defect Block - 0:0:0x000F
Original Defect Block - 0:0:0x0010
Original Defect Block - 0:0:0x0011
Original Defect Block - 0:0:0x0012
Original Defect Block - 0:0:0x0013
Original Defect Block - 0:0:0x0014
Original Defect Block - 0:0:0x0015
Original Defect Block - 0:0:0x0016
Original Defect Block - 0:0:0x0017
Original Defect Block - 0:0:0x0018
Original Defect Block - 0:0:0x0019
Original Defect Block - 0:0:0x001A
Original Defect Block - 0:0:0x001B
Original Defect Block - 0:0:0x001C
Original Defect Block - 0:0:0x001D
Original Defect Block - 0:0:0x001E
Original Defect Block - 0:0:0x001F
Original Defect Block - 0:0:0x0020
Original Defect Block - 0:0:0x0021
Original Defect Block - 0:0:0x0022
Original Defect Block - 0:0:0x0023
Original Defect Block - 0:0:0x0024
Original Defect Block - 0:0:0x0025
Original Defect Block - 0:0:0x0026
Original Defect Block - 0:0:0x0027
Original Defect Block - 0:0:0x0028
Original Defect Block - 0:0:0x0029
Original Defect Block - 0:0:0x002A
Original Defect Block - 0:0:0x002B
Original Defect Block - 0:0:0x002C
Original Defect Block - 0:0:0x002D
Original Defect Block - 0:0:0x002E
Original Defect Block - 0:0:0x002F
Original Defect Block - 0:0:0x0030
Original Defect Block - 0:0:0x0031
Original Defect Block - 0:0:0x0032
Original Defect Block - 0:0:0x0033
Original Defect Block - 0:0:0x0034
Original Defect Block - 0:0:0x0035
Original Defect Block - 0:0:0x0036
Original Defect Block - 0:0:0x0037
Original Defect Block - 0:0:0x0038
Original Defect Block - 0:0:0x0039
Original Defect Block - 0:0:0x003A
Original Defect Block - 0:0:0x003B
Original Defect Block - 0:0:0x003C
Original Defect Block - 0:0:0x003D
Original Defect Block - 0:0:0x003E
Original Defect Block - 0:0:0x003F
Original Defect Block - 0:0:0x0040
Original Defect Block - 0:0:0x0041
Original Defect Block - 0:0:0x0042
Original Defect Block - 0:0:0x0043
Original Defect Block - 0:0:0x0044
Original Defect Block - 0:0:0x0045
Original Defect Block - 0:0:0x0046
Original Defect Block - 0:0:0x0047
Original Defect Block - 0:0:0x0048
Original Defect Block - 0:0:0x0049
Original Defect Block - 0:0:0x004A
Original Defect Block - 0:0:0x004B
Original Defect Block - 0:0:0x004C
Original Defect Block - 0:0:0x004D
Original Defect Block - 0:0:0x004E
Original Defect Block - 0:0:0x004F
Original Defect Block - 0:0:0x0050
Original Defect Block - 0:0:0x0051
---> Max Bad of Plane (41,41)
---> Max BAD/DIE = 41
Total good blocks after SCAN: 1968 / 2048, Bad block=80
==> 2-Plane mode
Max. Bad Block Allowed = 82(80)
Adjust Max LBA = 7823360, 7823296
MaxWindows=1/1910, MaxLBA=7823296, Size=3819 MB
Max BAD of one plane is 41 (41),2048,1,1
RootSector=0x7D5,Sec/Cluster=64, SuperPage=64 ---> Alignment=43
Boot Block=0x0052,0x0054
Lun0(7823296), Lun1(0), Public=7823296, Secure=0, CDROM=0
Special FE Config = 54-0B-00
Defect Table Block=0x0058
--- Download ISP Code:H:\WXC\D\QUPAN\3S6692_MP_VER2182\ISP_CODE\6692_B5-IM_20110422_VB88200_B3EF.BIN---
--- ISP Code installed.
Public,Secure,CDROM = 7823296,0,0
PHY: E2/E4/E6=72h/36h/04h, D0/C0/CFG10=DFh/0Bh/87h
SN=4437E68A2FC0FC60133F202C
=== Preformat Done ===
Low Level Format DONE
Store INI/ERROR MSG to Block-0x0052:78.
### Error: Device capacity is 0 bytes
flash芯片
