  • 3754阅读
  • 10回复
[鑫创]6691 成功量产2次后,再量产失败,现在短路量产再失败 [复制链接]
离线我最牛
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2012-07-06
前几天量产CDRom成功,想换个PE 重新量产,结果失败。U盘插入电脑也无法识别。昨天在论坛上学习了下短路法,果然可以找到盘,欣喜若狂之后,果断量产,结果一直没有成功了。
量产start前,已取消短路。
使用该配置文件
[OEM]PN=6691 + Toshiba 43nm D2 Normal Flash (CDROM)
Note=ISP:6691_B3-A_20100331_VA10F00_9083.BIN
VID=0x0C76
PID=0x0005
VENDOR_NAME="Kingston"
PRODUCT_NAME="USB Mass Storage"
STRING_DESC_ENABLE=1
SN_CustomerCode=0x0F
[FEATURE_SETTING]
FLASH_OP="ALL123"
ID35=1
[CDROM]CDROM_ISO=e:\winpeboot.iso                             ——————-- iso只有126M
[ISP]Code=6691_B3-A_20100331_VA10F00_9083.BIN
结果如下:
Device 1:0xB3
    MP Version:2.162
    INI_File_Name:
    Random delay 0 msec
    --- Download MP ISP ---
    CE-0, Flash ID=98-D7-94-32-76-54-0C-00
    Found BACKUP Table (000001BB-0003)
    Defect Table (00000400-0008)
        Original Bad Block - 0:0x0000
        Original Bad Block - 0:0x0001
        Original Bad Block - 0:0x0002
        Original Bad Block - 0:0x0004
        Original Bad Block - 0:0x0005
        Original Bad Block - 0:0x025C
        Original Bad Block - 0:0x0277
        Original Bad Block - 0:0x02AA
        Original Bad Block - 0:0x02FE
        Original Bad Block - 0:0x0507
        Original Bad Block - 0:0x0575
        Original Bad Block - 0:0x0582
        Original Bad Block - 0:0x05EF
        Original Bad Block - 0:0x0824
        Original Bad Block - 0:0x0B18
        Original Bad Block - 0:0x0B1C
        Original Bad Block - 0:0x0B20
        Original Bad Block - 0:0x0C30
        Original Bad Block - 0:0x0C39
        Original Bad Block - 0:0x0C3B
        Original Bad Block - 0:0x0CAE
        Original Bad Block - 0:0x1030
        Original Bad Block - 0:0x1031
        Original Bad Block - 0:0x1032
        Original Bad Block - 0:0x1033
    Defect Table shows 4123 Good blocks, 25 Bad blocks
    SafeErase (0,4148)
        Erase failed Block - 0:0:0x0000
        Erase failed Block - 0:0:0x0001
        Erase failed Block - 0:0:0x0002
        Erase failed Block - 0:0:0x0004
        Erase failed Block - 0:0:0x0005
        Erase failed Block - 0:0:0x025C
        Erase failed Block - 0:0:0x0277
        Erase failed Block - 0:0:0x02AA
        Erase failed Block - 0:0:0x02FE
        Erase failed Block - 0:0:0x0507
        Erase failed Block - 0:0:0x0575
        Erase failed Block - 0:0:0x0582
        Erase failed Block - 0:0:0x05EF
        Erase failed Block - 0:0:0x0824
        Erase failed Block - 0:0:0x0B18
        Erase failed Block - 0:0:0x0B1C
        Erase failed Block - 0:0:0x0B20
        Erase failed Block - 0:0:0x0C30
        Erase failed Block - 0:0:0x0C39
        Erase failed Block - 0:0:0x0C3B
        Erase failed Block - 0:0:0x0CAE
        Erase failed Block - 0:0:0x1030
        Erase failed Block - 0:0:0x1031
        Erase failed Block - 0:0:0x1032
        Erase failed Block - 0:0:0x1033
        ---> Max Bad of Plane (8,5)
        ---> Max BAD/DIE = 8
    Total good blocks after SCAN: 4123 / 4148, Bad block=25
    ==> 2-Plane mode
    Max. Bad Block Allowed = 231(25)
    Adjust Max LBA = 7823360, 7823296
    MaxWindows=2/1910, MaxLBA=7823296, Size=3819 MB
    Max BAD of one plane is 8 (57),4148,1,1
    RootSector=0xF49,Sec/Cluster=32, SuperPage=32 ---> Alignment=23
    Boot Block=0x0003,0x0006
    Lun0(7820428), Lun1(2868), Public=7820428, Secure=0, CDROM=2868
    Special FE Config = 56-0B-00
    Defect Table Block=0x0008
    --- Download ISP Code:F:\6691量产MP_VER2162_ALL\ISP_CODE\6691_B3-A_20100331_VA10F00_9083.BIN---
    --- ISP Code installed.
    Public,Secure,CDROM = 7820428,0,2868
    SN=9CB70D51B1F9F2706D1F14E0
    === Preformat Done ===
    Low Level Format DONE
    Store INI/ERROR MSG to Block-0x0003:79.
    ### Err: CDROM file too large(00000000<00000b34).
离线xhlxl
只看该作者 1楼 发表于: 2012-07-06
本帖最近打赏记录:共1条打赏M币+5
离线shuishou
只看该作者 2楼 发表于: 2012-07-06
回 楼主(我最牛) 的帖子
本帖最近打赏记录:共2条打赏M币+13
只看该作者 3楼 发表于: 2012-07-06
本帖最近打赏记录:共2条打赏M币+10
离线u盘狂人
只看该作者 4楼 发表于: 2012-07-06
本帖最近打赏记录:共2条打赏M币+11
离线我最牛
只看该作者 5楼 发表于: 2012-07-06
离线我最牛
只看该作者 6楼 发表于: 2012-07-06
离线myguitar
只看该作者 7楼 发表于: 2012-07-06
离线u盘狂人
只看该作者 8楼 发表于: 2012-07-06
离线我最牛
只看该作者 9楼 发表于: 2012-07-07
回 8楼(u盘狂人) 的帖子
