  • 2259阅读
  • 3回复
[鑫创]6691 成功量产2次后,再量产失败,现短路量产U盘模式依然失败 [复制链接]
离线我最牛
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2012-07-07
出现以下错误 error 28
[OEM]PN=6691 + Toshiba 43nm D2 Normal FlashNote=ISP:6691_B3-A_20100331_VA10F00_9083.BINVID=0PID=0VENDOR_NAME="3SYSTEM"PRODUCT_NAME="USB Flash Disk"STRING_DESC_ENABLE=1SN_CustomerCode=0x0F            [FEATURE_SETTING]FLASH_OP="ALL123"ID35=1             [ISP]Code=6691_B3-A_20100331_VA10F00_9083.BIN
Device 1:0xB3
    MP Version:2.162
    INI_File_Name:
    Random delay 0 msec
    --- Download MP ISP ---
    CE-0, Flash ID=98-D7-94-32-76-54-0C-00
    Found BACKUP Table (000001BB-0003)
    Defect Table (00000400-0008)
        Original Bad Block - 0:0x0000
        Original Bad Block - 0:0x0001
        Original Bad Block - 0:0x0002
        Original Bad Block - 0:0x0004
        Original Bad Block - 0:0x0005
        Original Bad Block - 0:0x025C
        Original Bad Block - 0:0x0277
        Original Bad Block - 0:0x02AA
        Original Bad Block - 0:0x02FE
        Original Bad Block - 0:0x0507
        Original Bad Block - 0:0x0575
        Original Bad Block - 0:0x0582
        Original Bad Block - 0:0x05EF
        Original Bad Block - 0:0x0824
        Original Bad Block - 0:0x0B18
        Original Bad Block - 0:0x0B1C
        Original Bad Block - 0:0x0B20
        Original Bad Block - 0:0x0C30
        Original Bad Block - 0:0x0C39
        Original Bad Block - 0:0x0C3B
        Original Bad Block - 0:0x0CAE
        Original Bad Block - 0:0x1030
        Original Bad Block - 0:0x1031
        Original Bad Block - 0:0x1032
        Original Bad Block - 0:0x1033
    Defect Table shows 4123 Good blocks, 25 Bad blocks
    SafeErase (0,4148)
        Erase failed Block - 0:0:0x0000
        Erase failed Block - 0:0:0x0001
        Erase failed Block - 0:0:0x0002
        Erase failed Block - 0:0:0x0004
        Erase failed Block - 0:0:0x0005
        Erase failed Block - 0:0:0x025C
        Erase failed Block - 0:0:0x0277
        Erase failed Block - 0:0:0x02AA
        Erase failed Block - 0:0:0x02FE
        Erase failed Block - 0:0:0x0507
        Erase failed Block - 0:0:0x0575
        Erase failed Block - 0:0:0x0582
        Erase failed Block - 0:0:0x05EF
        Erase failed Block - 0:0:0x0824
        Erase failed Block - 0:0:0x0B18
        Erase failed Block - 0:0:0x0B1C
        Erase failed Block - 0:0:0x0B20
        Erase failed Block - 0:0:0x0C30
        Erase failed Block - 0:0:0x0C39
        Erase failed Block - 0:0:0x0C3B
        Erase failed Block - 0:0:0x0CAE
        Erase failed Block - 0:0:0x1030
        Erase failed Block - 0:0:0x1031
        Erase failed Block - 0:0:0x1032
        Erase failed Block - 0:0:0x1033
        ---> Max Bad of Plane (8,5)
        ---> Max BAD/DIE = 8
    Total good blocks after SCAN: 4123 / 4148, Bad block=25
    ==> 2-Plane mode
    Max. Bad Block Allowed = 231(25)
    Adjust Max LBA = 7823360, 7823296
    MaxWindows=2/1910, MaxLBA=7823296, Size=3819 MB
    Max BAD of one plane is 8 (57),4148,1,1
    RootSector=0xF4B,Sec/Cluster=32, SuperPage=32 ---> Alignment=21
    Boot Block=0x0003,0x0006
    Lun0(7823296), Lun1(0), Public=7823296, Secure=0, CDROM=0
    Special FE Config = 54-0B-00
    Defect Table Block=0x0008
    --- Download ISP Code:F:\SSSMP_VER2162\ISP_CODE\6691_B3-A_20100331_VA10F00_9083.BIN---
    --- ISP Code installed.
    Public,Secure,CDROM = 7823296,0,0
    SN=9CB70D51B1F9F270779214E9
    === Preformat Done ===
    Low Level Format DONE
    Store INI/ERROR MSG to Block-0x0003:79.
    Total=0,CDROM=0, PublicArea=-128, SecureArea=0
    ### Err: SECURE failed(31).
试了多次,都是这个错误。Err: SECURE failed(31). 网上也没有找到相关解释,求大虾指教。。
离线鲨鱼之家
只看该作者 1楼 发表于: 2012-07-07
离线我最牛
只看该作者 2楼 发表于: 2012-07-07
离线u盘狂人
只看该作者 3楼 发表于: 2012-07-07
