  • 2636阅读
  • 3回复
[鑫创]幸苦一晚终于快成功了,最后一个错误报告帮忙看下。 [复制链接]
离线micrisoft
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2012-08-08
Device 1:0xB1
    MP Version:2.159
    INI_File_Name:6690_D2.INI
    Random delay 0 msec
    --- Download MP ISP ---
    CE-0, Flash ID=98-D5-98-B2-76-54-0A-04
    CE-1, Flash ID=98-D5-98-B2-76-54-0A-04
    Found BACKUP Table (00000159-0001)
    Found BACKUP Table (00000259-0002)
        Original Bad Block - 0:0x00B4
        Original Bad Block - 0:0x0122
        Original Bad Block - 0:0x0168
        Original Bad Block - 0:0x0169
        Original Bad Block - 0:0x017B
        Original Bad Block - 0:0x01F4
        Original Bad Block - 0:0x022C
        Original Bad Block - 0:0x0244
        Original Bad Block - 0:0x0245
        Original Bad Block - 0:0x02DB
        Original Bad Block - 0:0x02F6
        Original Bad Block - 0:0x02F7
        Original Bad Block - 0:0x035E
        Original Bad Block - 0:0x0363
        Original Bad Block - 0:0x0365
        Original Bad Block - 0:0x039D
        Original Bad Block - 0:0x03C9
        Original Bad Block - 0:0x03E8
        Original Bad Block - 0:0x03E9
        Original Bad Block - 0:0x043D
        Original Bad Block - 0:0x0458
        Original Bad Block - 0:0x0459
        Original Bad Block - 0:0x0468
        Original Bad Block - 0:0x04AA
        Original Bad Block - 0:0x04F7
        Original Bad Block - 0:0x051D
        Original Bad Block - 0:0x055D
        Original Bad Block - 1:0x0141
        Original Bad Block - 1:0x0282
        Original Bad Block - 1:0x0283
        Original Bad Block - 1:0x02BD
        Original Bad Block - 1:0x0302
        Original Bad Block - 1:0x0304
        Original Bad Block - 1:0x0513
    Defect Table shows 2774 Good blocks, 34 Bad blocks
    SafeErase (0,1404)
        Erase failed Block - 0:0:0x00B4
        Erase failed Block - 0:0:0x0122
        Erase failed Block - 0:0:0x0168
        Erase failed Block - 0:0:0x0169
        Erase failed Block - 0:0:0x017B
        Erase failed Block - 0:0:0x01F4
        Erase failed Block - 0:0:0x022C
        Erase failed Block - 0:0:0x0244
        Erase failed Block - 0:0:0x0245
        Erase failed Block - 0:0:0x02DB
        Erase failed Block - 0:0:0x02F6
        Erase failed Block - 0:0:0x02F7
        Erase failed Block - 0:0:0x035E
        Erase failed Block - 0:0:0x0363
        Erase failed Block - 0:0:0x0365
        Erase failed Block - 0:0:0x039D
        Erase failed Block - 0:0:0x03C9
        Erase failed Block - 0:0:0x03E8
        Erase failed Block - 0:0:0x03E9
        Erase failed Block - 0:0:0x043D
        Erase failed Block - 0:0:0x0458
        Erase failed Block - 0:0:0x0459
        Erase failed Block - 0:0:0x0468
        Erase failed Block - 0:0:0x04AA
        Erase failed Block - 0:0:0x04F7
        Erase failed Block - 0:0:0x051D
        Erase failed Block - 0:0:0x055D
        ---> Max Bad of Plane (12,15)
    SafeErase (1,1404)
        Erase failed Block - 1:0:0x0141
        Erase failed Block - 1:0:0x0282
        Erase failed Block - 1:0:0x0283
        Erase failed Block - 1:0:0x02BD
        Erase failed Block - 1:0:0x0302
        Erase failed Block - 1:0:0x0304
        Erase failed Block - 1:0:0x0513
        ---> Max Bad of Plane (3,4)
        ---> Max BAD/DIE = 15
    Total good blocks after SCAN: 2774 / 2808, Bad block=34
    ==> 2-Plane mode
    Max. Bad Block Allowed = 164(34)
    Adjust Max LBA = 7827456, 7827392
    MaxWindows=2/1274, MaxLBA=7827392, Size=3821 MB
    Max BAD of one plane is 15 (41),2808,1,2
    RootSector=0xF4D,Sec/Cluster=32, SuperPage=32 ---> Alignment=19
    Boot Block=0x0001,0x0002
    Lun0(7827392), Lun1(0), Public=7827392, Secure=0, CDROM=0
    Special FE Config = 54-0B-00
    --- Download ISP Code:F:\MYDISK\6690_TSBD2_MP_V2159\ISP_CODE\6690_B1-56-D3_20090309_V502_F05B.BIN---
    --- ISP Code installed.
    Public,Secure,CDROM = 7827392,0,0
    SN=000000000000F28082CF2035
    === Preformat Done ===
    Low Level Format DONE
    Store INI/ERROR MSG to Block-0x0001:119.
    LBATest 10M activate
    ### Error: CopyTest Fail(Compare LBA=0x00000000, 0000=38,FF)
### CopyTest 10M fail ###
拷贝测试文件错误?该怎么弄下?金士顿 盘 2年前以为量产不了就放着吃会最近要用发现速度不行特来查资料。
芯片什么研究一晚终于搞对了,下载了3s的6690_TSBD2_MP_v2159这个工具
ps:2年前研究一段时间量产过2-3个u盘的速度,但现在忘光光了得重新研究
离线shuishou
只看该作者 1楼 发表于: 2012-08-08
本帖最近打赏记录:共1条打赏M币+5
离线micrisoft
只看该作者 2楼 发表于: 2012-08-08
本帖最近打赏记录:共1条打赏M币+1
离线gamester
只看该作者 3楼 发表于: 2012-08-08
