  • 4560阅读
  • 1回复
[鑫创]SSS6690-B1量产失败。。。 [复制链接]
离线fishggv
只看楼主 倒序阅读 我要置顶 楼主  发表于: 2012-09-29
— 本帖被 鱼水情 从 量产工具发布 移动到本区(2012-10-05) —
失败
报告
Starting Time: 15:11:19
Device 1:0xB1
    MP Version:2.159
    INI_File_Name:6690_D2.INI
    Random delay 0 msec
    --- Download MP ISP ---
    CE-0, Flash ID=98-D7-95-32-7A-54-0B-00
    CE-1, Flash ID=98-D7-95-32-7A-54-0B-00
    CE-2, Flash ID=98-D7-95-32-7A-54-0B-00
    CE-3, Flash ID=98-D7-95-32-7A-54-0B-00
    Found BACKUP Table (000000BB-0001)
    Found BACKUP Table (0000013B-0002)
        Original Bad Block - 0:0x02F5
        Original Bad Block - 0:0x0354
        Original Bad Block - 0:0x038F
        Original Bad Block - 0:0x03FF
        Original Bad Block - 0:0x07FA
        Original Bad Block - 0:0x1098
        Original Bad Block - 0:0x12E8
        Original Bad Block - 0:0x12FC
        Original Bad Block - 0:0x13B3
        Original Bad Block - 0:0x13DE
        Original Bad Block - 0:0x13E0
        Original Bad Block - 0:0x13E8
        Original Bad Block - 0:0x13EC
        Original Bad Block - 0:0x1516
        Original Bad Block - 0:0x1735
        Original Bad Block - 1:0x0321
        Original Bad Block - 1:0x04CC
        Original Bad Block - 1:0x0501
        Original Bad Block - 1:0x0503
        Original Bad Block - 1:0x10C9
        Original Bad Block - 1:0x1394
        Original Bad Block - 1:0x15E3
        Original Bad Block - 1:0x17C2
        Original Bad Block - 2:0x0232
        Original Bad Block - 2:0x048B
        Original Bad Block - 2:0x04C1
        Original Bad Block - 2:0x0654
        Original Bad Block - 2:0x10ED
        Original Bad Block - 2:0x113E
        Original Bad Block - 2:0x13AA
        Original Bad Block - 2:0x1806
        Original Bad Block - 2:0x180A
        Original Bad Block - 3:0x017A
        Original Bad Block - 3:0x0359
        Original Bad Block - 3:0x035B
        Original Bad Block - 3:0x035D
        Original Bad Block - 3:0x040C
        Original Bad Block - 3:0x040E
        Original Bad Block - 3:0x0657
        Original Bad Block - 3:0x0659
        Original Bad Block - 3:0x0739
        Original Bad Block - 3:0x073B
        Original Bad Block - 3:0x105B
        Original Bad Block - 3:0x1174
        Original Bad Block - 3:0x1574
        Original Bad Block - 3:0x1610
        Original Bad Block - 3:0x1612
        Original Bad Block - 3:0x1625
        Original Bad Block - 3:0x1656
    Defect Table shows 16623 Good blocks, 49 Bad blocks
    SafeErase (0,4168)
        Erase failed Block - 0:0:0x02F5
        Erase failed Block - 0:0:0x0354
        Erase failed Block - 0:0:0x038F
        Erase failed Block - 0:0:0x03FF
        Erase failed Block - 0:0:0x07FA
        ---> Max Bad of Plane (2,3)
        Erase failed Block - 0:1:0x1098
        Erase failed Block - 0:1:0x12E8
        Erase failed Block - 0:1:0x12FC
        Erase failed Block - 0:1:0x13B3
        Erase failed Block - 0:1:0x13DE
        Erase failed Block - 0:1:0x13E0
        Erase failed Block - 0:1:0x13E8
        Erase failed Block - 0:1:0x13EC
        Erase failed Block - 0:1:0x1516
        Erase failed Block - 0:1:0x1735
        ---> Max Bad of Plane (8,2)
    SafeErase (1,4168)
        Erase failed Block - 1:0:0x0321
        Erase failed Block - 1:0:0x04CC
        Erase failed Block - 1:0:0x0501
        Erase failed Block - 1:0:0x0503
        ---> Max Bad of Plane (1,3)
        Erase failed Block - 1:1:0x10C9
        Erase failed Block - 1:1:0x1394
        Erase failed Block - 1:1:0x15E3
        Erase failed Block - 1:1:0x17C2
        ---> Max Bad of Plane (2,2)
    SafeErase (2,4168)
        Erase failed Block - 2:0:0x0232
        Erase failed Block - 2:0:0x048B
        Erase failed Block - 2:0:0x04C1
        Erase failed Block - 2:0:0x0654
        Erase failed Block - 2:1:0x10ED
        Erase failed Block - 2:1:0x113E
        Erase failed Block - 2:1:0x13AA
        Erase failed Block - 2:1:0x1806
        Erase failed Block - 2:1:0x180A
        ---> Max Bad of Plane (4,1)
    SafeErase (3,4168)
        Erase failed Block - 3:0:0x017A
        Erase failed Block - 3:0:0x0359
        Erase failed Block - 3:0:0x035B
        Erase failed Block - 3:0:0x035D
        Erase failed Block - 3:0:0x040C
        Erase failed Block - 3:0:0x040E
        Erase failed Block - 3:0:0x0657
        Erase failed Block - 3:0:0x0659
        Erase failed Block - 3:0:0x0739
        Erase failed Block - 3:0:0x073B
        ---> Max Bad of Plane (3,7)
        Erase failed Block - 3:1:0x105B
        Erase failed Block - 3:1:0x1174
        Erase failed Block - 3:1:0x1574
        Erase failed Block - 3:1:0x1610
        Erase failed Block - 3:1:0x1612
        Erase failed Block - 3:1:0x1625
        Erase failed Block - 3:1:0x1656
        ---> Max Bad of Plane (5,2)
        ---> Max BAD/DIE = 8
    Total good blocks after SCAN: 16623 / 16672, Bad block=49
    ==> 2-Plane mode
    Max. Bad Block Allowed = 1020(49)
    Adjust Max LBA = 31293440, 31293376
    MaxWindows=8/1910, MaxLBA=31293376, Size=15279 MB
    Max BAD of one plane is 8 (63),16672,2,4
    RootSector=0x3C0B,Sec/Cluster=32, SuperPage=32 ---> Alignment=21
    Boot Block=0x0001,0x0002
    Lun0(31293376), Lun1(0), Public=31293376, Secure=0, CDROM=0
    Special FE Config = 54-0B-00
    --- Download ISP Code:C:\6690\ISP_CODE\6690_B1-A_20110908_V150B_78E3.BIN---
    --- ISP Code installed.
    Public,Secure,CDROM = 31293376,0,0
    SN=00E04C800A4BF291D7D0202E
    === Preformat Done ===
    Low Level Format DONE
    Store INI/ERROR MSG to Block-0x0001:79.
    Total=31293376,CDROM=0, PublicArea=31293248, SecureArea=0
    ### Err: SECURE failed(32).
Ending Time: 15:12:10
ChipGenius v4
 设备描述: [H:]USB Mass Storage Device(MyDigit USB Flash Disk)
 设备类型:  大容量存储设备
 协议版本: USB 2.00
 当前速度: 高速(HighSpeed)
 电力消耗: 100mA
USB设备ID: VID = 0C76 PID = 0005
设备序列号: 00E04C800A4BF291DE4F202D
设备供应商: MyDigit
 设备名称: USB Flash Disk
设备修订版: 0100
产品制造商: MyDigit
 产品型号: USB Flash Disk
产品修订版: 1.00
 芯片厂商: SSS(鑫创)
 芯片型号: SSS6690-B1
闪存识别码:  98D79532 - Toshiba(东芝) - 4CE/单通道 [MLC-8K] -> 总容量 = 16GB
ini文件
[OEM]
PN=6690 + Toshiba 43nm D2 Flash
Note=6690_B1-A_20110908_V150B_78E3.BIN
VID=0x0C76
PID=0x0005
VENDOR_NAME="Kinston"
PRODUCT_NAME="USB Flash Disk"
STRING_DESC_ENABLE=1
SN_CustomerCode=0x0F
[FEATURE_SETTING]
FLASH_OP="ALL123"
ID35=1
[CDROM]
CDROM_ISO=F:\CoolMiniPE_V32.iso
[ISP]
Code=6690_B1-A_20110908_V150B_78E3.BIN
那里出问题了。
离线u盘狂人
只看该作者 1楼 发表于: 2012-09-29
